Recently I wrote an article on the AccuPOSE Core library and how it can be a boon to beginners and a time-saver for experienced users and pros by keeping the body in proper position while moving a limb or limbs for custom animation. The built-in AI-assisted posing maintains a proper posture while we push, pull, or rotate limbs into position.
The Core Library has a wealth of everyday motions that can be very difficult to keyframe by hand and we all know canned motions can, and usually do, require editing as they can’t fit all situations. This is where the AI-assisted accuPOSE library fits in. Motions are great and Pose to Pose is great but AI-assisted Pose to Pose allows us to manually create poses that do not contort or move body parts out of place while moving down the timeline to create our own custom motions.
The Core Library is free, and the optional INFINITY subscription allows that library to grow as more AI-assisted pose packs are added. Infinity already has many different types of AI-assisted poses with plans for many more. In fact, there is a roadmap for the continual expansion of the Infinity pose library.
INFINITY Subscription
The INFINITY subscription expands the Core Library with new AI-assisted motion packs already available or coming soon according to the INFINITY roadmap.
Pricing directly from the website:
Available Now in INFINITY
Let’s take a quick look at what is available now. The categories are Daily Life, Communication, Occupation, Combat, Action and Adventure and Dance.
Dailey Life
Communication
Occupation
Combat
Action & Adventure
Dance
Mobility Male, Mobility Female, Mobile Phone F, Mobile Phone M
Conversation, Emote
Construction, Rock Singer
Agent F, Agent M, Assassin, Wall Crawler, Street Fighting, Pistol, Rifle, Sword & Shield, Boxing, Orc
Parkour, Flee Male, Flee Female, Injury & Rescue M, Injury & Rescue F, Car
Dance 60s – 90s, Ballet
You can also see where some packs complement each other like Wall Crawler & Parkour or Rock Singer and Dance. This initial library has many time-saving packs like mobility and mobile phone that will provide realistic poses for our pose-to-pose work for everyday or even camera-centric scenarios.
You will notice INFINITY has already released its first expansion available to subscribers via an update in Reallusion Hub. This expansion includes: Wall Crawler, Rifle, Boxing, Orc, Ballet, Flee Male, Flee Female, Injury and Rescue Male, Injury and Rescue Female and Car.
How Can This Benefit Beginners?
As I wrote in my article about the free Core library AccuPOSE extends our current motions by giving us the ability to manually move parts of a character (keyframing) while keeping the character in the proper position and not distorting the body. The proper use of translation and rotation locks help with this by keeping certain body parts locked in to place or open for movement.
Manual keyframing can be one of the most difficult skills to master as a slight movement out of place can produce strange or off-putting results for the viewer. AccuPOSE takes care of this problem by using AI-assisted poses to keep everything in line.
It is more difficult to explain this article than it is to actually do. It also brings us one step closer to that animation easy button we are all wanting.
What is Pose-To-Pose?
If you are not sure what Pose to Pose is, you are not alone. It baffles many beginners, but it relies on picking a frame like 40 and loading a pose at that frame then moving a number of frames down the timeline, in this case 100 frames, to frame 140 and altering the pose with the built-in tools and locks or loading another pose. iClone will take care of the animation between those keyframes.
Yes, it’s that simple.
I didn’t say easy as some packs like Web Crawler will still involve some work on the posing until you get some experience but that is a more extreme type of animation. Everyday life events like picking up an object or opening a door benefit tremendously with the AI-assist and those “everyday” motions can be some of the most difficult to learn and execute manually.
Just because we can get from point A to point B in an animation sequence doesn’t mean we ‘ve done it well. If our technique is lacking, then our animations will be lacking too. Keep in mind the fact that our viewers are trained to near perfection by Pixar, DreamWorks and other triple A studios. It becomes imperative we make our animations as good as possible.
Audiences may forget bad stories or writing, but they might not forget bad animation.
CPR Tutorial
Let’s start with a real-world example of a scenario involving a police officer giving CPR to a person on the street. While this might not be a difficult animation for a pro it can be very difficult if you are just getting started. accuPOSE INFINITY provides a pack that includes this scenario making quick work out of what once would have taken hours and maybe even a day to animated properly.
We load the CPR AccuPOSE and watch the character immediately jump into an appropriate pose for the motion pack. As I show in the short tutorial below, I also use Lie from the Core library for the prone pose of the victim.
Industrial Painting Tutorial
The Construction pack under Occupation in the INFINITY pose library provides us with another easy to learn example of pose to pose with iClone taking care of the movement between poses. This example shows how quickly you can add background motions as scene filler. This also adds more life to the scene.
Think Outside the Box
Just because a motion pack says it is for a certain type of motion doesn’t mean that pack can’t be used for other motions. All we need to do is see what fits our needs like sitting, standing and so forth then drill down through those packs to see what can be used for our current need as a starting point or pose.
Almost any sitting pack will work for simple animations like a pilot in a cockpit as long as we use the locks and tools properly. A sitting conversation pack might well work for a pilot moving a joystick around while staying within the confines of the seating area or a character using a control panel.
Expanding Library of Packs
The INFINITY Library will grow regularly over time as more AI-assisted motion packs are added with new packs already available in early January.
As you can see from the above image Reallusion already has several new packs scheduled for release to expand the INFINITY library.
Existing Projects
AccuPOSE can slip right into an existing project to enhance the work with AI-assisted posing and posture. To quote from the Reallusion website:
Works with Normal Poses
Transform existing poses into AccuPOSES with selected AI model and experience the precision of natural posing through customizable IK constraints.
Clip Layer Editing
By incorporating AI-assisted layer keys, users can effectively enhance motion velocity in selected motion clips.
Keyframing from Library
Easily add poses from the AccuPOSE library to arrange keyframes on the timeline, with the option to fill in custom in-betweens and curves for smooth transitions.
Accelerate Animation Workflow
Handkey Animation
Driven by deep-learned human motions, the pose suggestions enhance the efficiency of quality keyframe posing and support the creation of compelling animation styles.
Connecting Clips
The intelligent posing feature simplifies the process of filling in missing poses between motion clips, creating more natural transitions.
Mocap Correction
The natural AI posing capability can effectively solve the mocap challenges such as shoulder stiffness, motion distortion, and even enhances animations with realistic hand gestures.
Curve & Trajectory
iClone’s Motion Curve and Motion Trail functions empower animators to fine-tune keyframe timing and spatial trajectories, ensuring high-quality animation results.
Summary
The free core library is a great library of poses in itself, but the INFINITY Library subscription is already expanding the AccuPOSE library with more poses and will continue to do so according to its release schedule. The poses are not only AI-assisted but also professionally created to maintain superior quality that can enhance your animation project.
I have always been a pose-to-pose advocate even when it required cleanup but with AI assistance the cleanup will be little too non-existent which is a plus to beginners.
As you have seen in the examples using pose-to-pose with AccuPOSE is only a matter of timing (the number of frames between poses) and positioning of the limbs which is guided by AccuPose. As I wrote earlier the INFINITY subscription is another step closer to that coveted “easy button” for animation.
Reallusion Courses
AccuPose – Tutorials
MD McCallum – WarLord
Digital Artist MD “Mike” McCallum, aka WarLord, is a longtime iClone user. Having authored free tutorials for iClone in its early years and selected to write the iClone Beginners Guide from Packt Publishing in 2011, he was fortunate enough to meet and exchange tricks and tips with users from all over the world and loves to share this information with other users. He has authored hundreds of articles on iClone and digital art in general while reviewing some of the most popular software and hardware in the world. He has been published in many of the leading 3D online and print magazines while staying true to his biggest passion, 3D animation. For more information click here.
3 comments
I have a future, it´s with REALLUSION…
I have been trying to use Accupose I make a pose on Frame 1, go to Frame 10, and make a different pose, but there’s no interpolation. I’ve watched a course on it too, but it’s only in 720p
A story where I’m more interested in the core issue than anything else is a mere variation.
