Reallusion Magazine
From AI to Animation: 3 Ways to Bring Hunyuan3D Characters to Life in CC4
José Antonio Tijerín
José Tijerín, a digital illustrator and 3D sculptor, is the creator of the video game “Dear Althea” on Steam and the content pack “We’re Besties” available in the Reallusion Content Store.
The world of digital sculpting is in a constant state of flux, and artificial intelligence is no longer a futuristic promise, but a revolutionary tool that is redefining the foundations of 3D creation. Far from replacing human creativity, generative AI accelerates workflows, allowing us to reach levels of complexity that previously required an exorbitant investment of time and resources. The real power lies not in a single tool, but in the synergy of a production pipeline that merges the speed of AI with the precision of professional tools.
At the epicenter of this new wave is Hunyuan3D, the 3D generation AI developed by Tencent. Its v2.5 version stands out for offering one of the highest geometric resolutions and texture qualities on the market, even generating Roughness and Metallic maps, essential for standard rendering. However, the AI-generated model is not the end of the road, but a formidable starting point.
In this article, we will explore three professional workflows that demonstrate how to transform an AI-generated 3D model into a fully functional, animation-ready character, using the Character Creator 4 ecosystem as a backbone.
The Starting Point: Hunyuan3D
Before diving into the workflows, it is crucial to understand the strategic distinction between the web version of Hunyuan3D v2.5 and its local installable counterpart. This is not a simple choice between quality and speed, but two complementary tools.
The v2.5 online version is the precision tool. Its ability to generate high-density meshes and PBR textures makes it the ideal choice for creating a model of maximum fidelity. On the other hand, the local version, especially its “Mini” model that requires only 3 GB of VRAM, is the engine of agility and creative exploration. Running it in seconds on our own PC, without relying on credits or internet connection, transforms it into a rapid prototyping machine, ideal for iterating accessory designs or frictionless armor components.
A crafty artist will use v2.5 to establish the main vision of their character at the highest quality, and will turn to the local version to populate that design with details, props and variations.
Workflow 1: Auto-rig AI-generated model with Advanced AccuRIG in Character Creator
This is the most direct and efficient method to bring to life an AI-generated model that already has a good humanoid form. It is ideal for when time is short and the goal is to have a character animated in minutes.
Step-by-Step Guide
Generation and Export: Create your character design in Hunyuan3D v2.5 with enough detail and volume to capture your intended concept. Once generation is completed, export the model as OBJ or FBX.
Import into Character Creator 4: Bring the exported model into CC4 and Advanced AccuRIG will analyze the mesh and automatically identifies the key anatomical points. In seconds, it generates a functional skeleton. The tool allows you to manually adjust bones, customize the structure for non-human proportions, and define finger articulation precisely.
Animate: After rigging with AccuRIG, you can easily animate your AI model with the motion in CC4.
Workflow 2: Sculpt CC Base from AI Reference Using GoZ and ZBrush
This workflow represents the industry standard and is designed to overcome the main limitation of AI models: their topology. AI-generated mesh is often dense, irregular, and not animation-friendly. Instead of directly animating it, we treat the AI model as a high-quality design reference.
By leveraging Character Creator’s well-balanced topology, we can reshape the base mesh in ZBrush and conveniently send it back via GoZ plus.
Key Steps
Sketch-to-3D Generation: Begin with a 2D sketch or concept art, and use Hunyuan3D to convert it into a high-detail 3D mesh. This allows for creative exploration while retaining the original silhouette and proportions.
Project AI Details: Import the Hunyuan3D model into ZBrush and use it as a reference. Using ZBrush’s projection tools, transfer proportions and sculptural details onto the CC4 mesh. The organization in polygroups of CC4 models is crucial here, allowing us to isolate and work with precision in areas such as the face or hands.
Send it back to CC4 with GoZ: Once the sculpting on the CC base is complete, send the character back to CC using GoZ. In CC, use the Adjust Bone Auto Position feature to realign the skeleton.
Head Morph and Final Sculpt: To handle the head shape, first deform the CC base head to roughly match the AI-generated head. Use CC’s Morph tools to further refine the head shape. Once the shape is close, send the character back to ZBrush using GoZ and finalize the head sculpt.
Enhance AI Textures: Hunyuan3D’s textures are a solid starting point but often lack resolution. To enhance them, capture orthographic views in Substance Painter and import them into a generative AI editor like Krita AI Diffusion or Photoshop.
By painting over the captures and applying low creativity strength (40–55%), you can add realistic detail while retaining control. The enhanced images are then projected back onto the model in Substance Painter to produce high-quality final textures.
Add Armor: Use the same technique—piece by piece—to generate armor components in Hunyuan3D. Import and fit each piece onto the character in ZBrush or CC4. This modular approach allows you to build a complete, poseable character fully equipped for animation.
The result is a clean, animation-ready mesh with the design fidelity of your AI concept.
Workflow 3: Convert AI-Generated Head to CC Character Using Headshot 2
When focusing on facial fidelity and expression, Headshot 2 is the ultimate shortcut. This AI-powered plugin of Character Creator allows you to generate realistic, animation-ready heads from a photo or 3D reference model.
Step-by-Step Guide
Generate 3D Reference Head: Use Hunyuan3D or other tools to produce a clean frontal view of the head.
Import to Headshot 2 in CC4: Load the model in Headshot 2 Pro. Align key points (eyes, nose, mouth, chin) during the guided setup.
Generate Head Mesh: Headshot 2 creates a clean, rigged head with functional blendshapes. Minor refinements can be made in ZBrush via GoZ.
You’ll end up with a head that has perfect topology, base textures, and full support for facial animation—without modeling or retopology.
A New Paradigm
The intelligent integration of AI into our production pipelines does not turn us into mere machine operators; it frees us to focus on what really matters: art, design, and storytelling. These three workflows demonstrate that AI and professional tools do not compete, but enhance each other. The barrier to entry into the 3D world has been drastically lowered, and for established artists, the creative possibilities have expanded to infinity. The revolution is here, and now is the time to master it.
FAQ
Can I animate a Hunyuan 3D model directly?
There are three professional workflows covered in this article:
How to rig an AI-generated model?
You can use the built-in rigging functions from tools like Hunyuan3D or Meshy, but we recommend using AccuRIG in Character Creator for more accurate, customizable, and animation-friendly results
Does Headshot 2 work with stylized faces?
Yes, Reallusion Headshot 2 supports both realistic and stylized characters through its adjustable Pro Mode.
What if my AI model is not human-shaped?
AccuRIG allows manual adjustment for non-humanoid skeletons, giving flexibility for stylized or creature designs.
Related Posts
Exit mobile version
