首頁 » Page 65
3D Render Engines for iClone: Choosing The Best (Part 1)
Comparison of Omniverse, Unreal Engine 5, and Maya V-Ray for 3D Real-time Animation
Introduction
José Tijerín is a digital illustrator and 3D sculptor who has created a video game “Dear Althea” to be launched on the Steam.  His “We’re Besties” content pack is currently selling in the Reallusion Content Store.
In this tutorial, José shares his way of working with Character Creator  and iClone to get fantastic results in Omniverse, Unreal Engine 5, and Maya V-Ray render engines. Then he compares the results and gives his personal opinions on each one of them.  This tutorial will help users to discover new possibilities for showcasing their 3D sculpt and animation work.
Prepare A Character
The first step would be to create a character in Character Creator, however, I’m going to skip this step because I have already written an article with a tutorial video on how to create a cartoon-style character.
Now we are going to add movements to this very same character. In order to bring it to life, we can take advantage of ActorCore’s fantastic motion library.
Once we have selected the desired character animation, we’ll just have to apply it to the character and adapt it to the scene we want represented in iClone. In my case, I had to select an animation of a cook stirring contents in a pan and another motion for taste-testing with a spoon. In order to make the 3D animations fit the scene, I had to connect the spoon to the hand, fix the other hand to the pan handle, and adjust all of the movements to fit the character I was working with. Finally, I animated the character’s gestures and eyes to bring her to life, which is without a doubt, the funnest part of the whole process.
NVIDIA Omniversef
Let’s start with the NVIDIA Omniverse platform, an application that is easy to download and completely free to use: Just register an account on their website and download the program. I’m adamant that everyone should try this software at least once due to its simplicity, usefulness, fun, and ease of use.
Once we have it installed, go back to the open project in iClone and look for the USD export button at the top of the program. In the subsequent pop-up window you can configure various aspects of the export, but in our case the default setting will work as they are. Next, click on the Export button to take the whole project along. We can click the Send to Server button to send it directly to Omniverse, but in my case, I’ll just work off of a scenario already prepared in the program.
Export an iClone project to NVIDIA Omniverse (image credit: José Tijerín)
Now, we will export our files to a folder and open the NVIDIA Omniverse Launcher – if not already opened. The Omniverse Create application can be found and launched from the Library menu.
For my project, I just need to load a scene in which the character will be introduced. To do this, go to the File menu and click on the Add Reference option. Don’t worry if the character enters with whitish skin – thanks to iClone’s intelligent export system to Omniverse – all of the skin texture parameters will be adapted to the program.
To apply the textures to a model in Omniverse, we first have to click on the model by clicking either on the 3D model or on its name in the list to the right and apply new material. Afterward, you’ll notice that the lower right window will be filled with the material properties applied to the model. These material properties will be editable after clicking on the material symbol.
Apply textures in Omniverse Create (image credit: José Tijerín)
Applying the textures to the material is very simple, we only have to look for the folder with the textures in the Content window and drag the textures to different sections that make up the material and configure it in an intuitive way.
For other occasions, as in the case of cartoon-style hair, we’ll need a special material. To apply a different material to an object, we have to right-click on it. In the floating menu that appears, click on the Create menu and, inside it, look for the Materials menu. For this example, I’ll choose one of the predefined Presets of the OmniHair material.
Character hair creation (image credit: José Tijerín)
In case of problems with the 3D animation, such as objects in Attach mode not moving correctly, you should go back to iClone and bake the animation. To do this, go to the timeline. In the CC3 Base Plus section, go to the Collect Clip track and select the entire animation track. Once selected, right-click and perform Add MotionPlus tro Library from the pop-up menu. Then find the custom animation in the content menu and apply it to the character. And in the situation where the facial expressions don’t work, you will have to update the programs and re-export the character.
The Three Different Render Modes in Omniverse
Next topic is on the Omniverse render modes, which is really impressive stuff. If we go to the top of the viewport we can see the lightbulb symbol. Click on it to see three types of rendering that Omniverse has to offer:
  • RTX Real-Time is one we have been seeing so far, which corresponds more or less to the traditional lighting of video games.
  • RTX Path-Traced is the strong point of the program.
  • Iray Photoreal is the most accurate of the group, but it is slow and computationally heavy.
One of the main differences between the rendering modes is the rendering time. For my project, the scene is complex in terms of lighting and textures, so to avoid noise in the video, the render times are quite long compared to the incredible speed that Omniverse usually offers.
Omniverse render mode: RTX Real-Time (image credit: José Tijerín)
The RTX Path Traced result is excellent with rendering speed so fast and of such high quality that you can work on the project while rendering without a problem. This gives you the possibility to tweak the scene without having to wait for the render to update; something that can speed up the production by a lot.
Omniverse render mode: RTX Path Traced (image credit: José Tijerín)
Finally, Iray Photoreal is NVIDIA’s bid to become one of the major rendering engines dedicated for the big screen. Compared to other industry-standard render engines, it can be plagued with some small shader problems in certain situations. However, judging by the color transmission present in the left-over food, it tends to give better results than other modes and can be quite impressive for some scenes.
Omniverse render mode: Iray Photoreal (image credit: José Tijerín)
As you may have noticed, unlike the other modes, the rendering of translucent material does not work by default. So to make it work, we have to go to the Iray menu to the Render Settings section to find the Caustic Sampler option. When we activate it, we get a result that is quite impressive, even for a very simple scene.
Comparison of render modes of Omniverse (image credit: José Tijerín)
Render with RTX Path-Traced
However, given the complexity of the operations to be performed to achieve this result, the time required for this mode to completely remove noise and achieve high definition is very time-consuming compared to the other modes. So I recommend choosing the intermediate mode to work in for good, responsive results.Now that we have chosen a render mode, let’s see how to go about rendering a scene. If we go to the Render Settings menu, we can find the Path Tracing rendering menu. Inside we can find two important sections: Path-Tracing and Denoising. To explain these parameters we are going to render a complicated material like the pre-defined material for honey.
In the first section, we find the Total Samples per Pixel parameter. The higher the number, the greater the number of samples and the higher the quality, but at the cost of longer render times.
The second section is the Denoiser, a system that many 3D programs have been using for some years now. This system detects the noisy areas in the render and softens them. However, you have to bear in mind that the more samples you have to work with, the better the results will be.
Now that we have the basics set up, let’s render the animation by going to the Rendering menu and in the drop-down menu open the Movie Capture menu. In this window, we can configure parameters such as frame rate and resolution. Just select the option to Use Current (RTX Path Traced) and set the number of samples per pixel. When we are done we just have to assign a destination folder for the output images and hit the Capture Sequence button.
The final result is quite good and we have obtained it in a very short amount of time compared to traditional renders.
Unreal Engine 5
Downloading and installing Unreal 5 is completely free, although we must have enough space on our hard disk and some previous knowledge of 3D programs to learn the engine.
Once Unreal is downloaded and installed, we are going to import the animations from iClone. To do this it is advisable to put both programs (iClone and Unreal) side-by-side on the same screen to optimize workflow. Once we have opened both programs, we must go to the Unreal Settings menu and click on the Plugins menu. In the pop-up window, type “Live” in the Search section to check if Live Link and iClone Live Link plugins are activated.
You’ll notice that the new Live Link menu resides next to the Details menu. If we click on the Source button in this menu, we can access the drop-down menu and select the iClone Live Link option and then click Ok to accept the port number.
 iClone Live Link with Unreal 5 (image credit: José Tijerín)
iClone Unreal Live Link
After everything is ready on the Unreal side, we’ll go back to iClone for a moment to make the connection. To do this, we need to deploy the Unreal Live Link menu by going to the Plugins menu. After clicking on it, one should see the Unreal Live Link menu with the options for Transfer and Link. Make sure the Transfer option is selected and go to the bottom of the window and click on Transfer File.
After waiting a few minutes, we’ll have the imported character with all of its materials already configured. Next, we’ll need to link the animation to the transferred character by going back to the Unreal Live Link window in iClone and clicking on the Link button. Again, we have to go to the bottom of the window and click on the Active Link option. If you come across some problems with the linking process, you can click on the character and go to the Details window to diagnose the errors. Under the Animation section, make sure to set Animation Mode to Animation Plane.
Recording Unreal Animation
Now it’s time to record character animation in Unreal. To do so, go to the Sequence Recorder window where we will introduce the models we want to record into the Actors list. Once this is done, simply press the Record button and, when the countdown is over, press the Play button in iClone. When the animation has finished, we have to press the StopAll button in Unreal.
When we do this, a pop-up window will appear at the bottom right of the screen so that we can open the sequence directly. Now that the iClone portion of the process is complete, we can close the application to focus on the Unreal scene. As you can see, in addition to the models we have imported, the models linked to the animation sequence now appear in the scene. We can remove them from the scene so that they don’t get in the way while we work.
If there are textures that you have forgotten to put into iClone, you can still apply them to the materials in Unreal. If we press Ctrl+Spacebar we can access the project content menu. Just import the textures into a folder and create a material. Double-click on the material to access the Material Graph, a graph view where you can drag the textures and connect them to the appropriate channels.
Record animation in Unreal (image credit: José Tijerín)
Once we have connected the textures, we just have to scale the material and drag it to the Materials section in the corresponding element of the model. Now that we have all the materials ready and the scene prepared, we are going to render the video. In the Sequencer window, we have to click on the film plate button to access the Render Movie Settings menu, where we can configure parameters such as the output format or the size of the frames. When we have finished configuring the parameters we just have to give it a destination folder and click on the Capture Movie button.
The result is really amazing for a video game rendering engine thanks to the revolutionary Lumen technology.
Unreal 5 render result with Lumen (image credit: José Tijerín)
If we remove Lumen, the same scene would look as below because the light would not bounce off of the walls in the room. Not having a system that bounces light into the shadows makes the light contrast too abrupt, even if the image was later retouched in post-processing.
Unreal 5 render result without Lumen (image credit: José Tijerín)
Continue reading in Part 2…
3D Render Engines for iClone: Choosing The Best (Part 2)
V-Ray for Maya
This tutorial is going to be carried out with V-Ray for Maya. Keep in mind that although the program works in a similar way in some applications, in others it does not. The common factor is the high price of the one-year license. If you have never used Maya or a similar advanced 3D program before, be warned that the barrier to entry can be prohibitive, with a high price tag.
We are going to import the iClone animation into Maya to use V-Ray. This time, just select the scene elements, go to the File menu and select the Export menu to save the file in FBX format.
A floating window will appear in which we will have to select the Maya 3D preset from the different presets. Then make sure to export all the frames and click on the Export button.
Export an iClone project to V-Ray (image credit: José Tijerín)
To import the FBX file into the scene, we can drag it directly into the program or we can go to the File menu and look for the Import button to find the file on the computer. As long as we don’t separate the FBX file from the folder with the rest of the textures, the model will be imported together with the materials and textures. Unfortunately, we will have to recreate all the materials so that they are all V-Ray materials and appear correctly in the render. However, in order not to repeat what I already explained in the tutorial I talked about at the beginning, I’m going to skip all the creation of the character’s materials.
I’ll just remind you of the basics of rendering the scene. If we click on the Render Settings button, a floating window will appear. In it we will have to configure the animation parameters, the size of the frames, the type of samples to be used by V-Ray (which is in the Bucket option) and finally we will have to add the Denoiser element to eliminate the pixel noise that may arise.
V-Ray render settings (image credit: José Tijerín)
Detailed Comparison of Three Render Engines
The Denoiser in V-Ray does a spectacular job, you can easily turn it on and off in the Frame Buffer window by going to the Layers menu. The rendering with V-Ray is without a doubt the one that offers the most polished result. The lighting has an incredible quality and softness and V-Ray’s handling of complex materials is also completely realistic, like the way in which light passes through honey in the glass jars. It should be noted that, unlike the previous programs which are free, Maya and V-Ray are priced.
We get a decent result in Omniverse, but it does not distribute the light as well as in the previous case. However, if we use Omniverse’s photo-realistic render, the result is quite good. Unreal gives a rather poor result which we can manage to improve with some tricks and effects.
Comparison of 3 render engines (image credit: José Tijerín)
Continuing with the comparisons, it is clear that a big drag on V-Ray and other rendering engines is the time taken to render each frame with pixel noise removed. Thanks to V-Ray’s default Denoiser, this only takes 18 minutes.  It has to be said that this not only affects the final result but also the workflow. When working on 3D scenes, it is really useful to see the results in real-time. This can help us to spot errors, save time checking how the render is coming along, or even allow us to be more creative.
Comparison of render engines (image credit: José Tijerín)
As for fluid simulations, apart from Unreal which can only use particle effects, both Maya and Omniverse give perfect results, however, the winning edge goes to Omniverse. Unlike the tediousness of working with Maya’s fluid simulations, and the dearth of options in Unreal, Omniverse allows you to edit the simulations in an accurate, intuitive, and hassle-free manner.
We can also compare the performance of the Denoiser in the different renders. In this case we also have to leave Unreal aside, because Lumen uses a completely different system. In this detail of a larger 4K render we can clearly see how both V-Ray and Omniverse denoiser does an excellent job.
Without de-noise, V-Ray renders still hold up with a more polished result and less noticeable noise, yet in Omniverse, the noise becomes less uniform and is noticeable in the overall image. Omniverse gives the best result when Denoiser is enabled across all renderers. It has to be said that the 10 minutes it takes for V-Ray to render the scene is a big hit to its advantage in this department compared to Omniverse’s near instantaneous solution.
Personal Opinions
I will end by giving my personal opinions as a professional who uses these programmes.
These comparisons may be more or less accurate and I have no doubt that, at the rate these engines are evolving, this tutorial will probably be outdated in a short time. However, I hope that it has clarified your doubts and shown you new possibilities to enhance your work.
V-Ray for Maya: Powerful for Large Productions
V-Ray is a very powerful render engine that is used for all kinds of big productions, but that stands out above all for offering a hyper-realistic solution in both lighting and materials, which can be configured to achieve really complex results. It does a fantastic job with integrating computer generated imagery with live-footage. V-Ray is well-prepared to deal with really challenging scenes such as forests and cities, giving a superb and hyper-realistic result. This engine comes at a significant cost, but it can be installed on a large number of 3D programs, including Unreal Engine itself.
image credit: Marvel
Omniverse: Fast and Easy for Collaborative Workflow
Omniverse is a tool that is becoming essential for productions with tight deadlines. In my case, jobs that used to take days to render, I can now deliver with Omniverse on the same day. The fact that it is free and very easy to learn to use also makes it the best engine to start learning 3D and get good results from day one. Although it is new, the programme is constantly being updated, adding new functions and possibilities for free, which indicates that it is a programme with a lot of potential and a great future. These updates have made it the program that works best with Character Creator and iClone.
Having a direct link between both programs allows us to work better, without worrying about the compatibility between formats and materials, so we save a lot of time. So it is highly recommended to bring our characters and animations to Omniverse if we want to get amazing results in a short time.
The biggest problem with Omniverse is that it is not as flexible as other programs. This is because it was designed to work closely with other programs. It is better to create and assemble the scenario in another program and then export it to Omniverse. Fortunately this is easy given NVIDIA’s facilities for importing work, for example, directly from Maya.
This makes it even more advisable to work in Omniverse together with Character Creator and iCone, so that both complement each other and benefit from each other’s advantages. Many of the difficulties I encounter when rendering in the program could be solved if the program included, in addition to progressive rendering, a Bucket system like V-Ray; Something I hope they will incorporate in the future. The rendering problems that can be found in the program can be avoided, although it is advisable to always render at a higher resolution than the one we need to get a higher quality image.
image credit: NVIDIA Omniverse
Unreal Engine 5: Made for Video Games
Unreal Engine 5 Lumen and Nanite systems have revolutionized the world of real-time graphics. There are now film productions using this software in real-time because of its versatility and turn-around. The way it works with iClone in real-time is arguably what makes Reallusion the best choice for animating any production using Unreal. And this also applies to the world of video games, for which Character Creator and iClone have been designed from the ground up.
Working with iClone and Unreal Engine at the same time saves a lot of time and trouble, allowing us to be more creative. It’s great that even textures and materials can be passed to Unreal seamlessly, giving an amazing result. Metahumans can also be animated in iClone with the same degree of realism thanks to its incredible graphics allowing the scenes to translate well to other render engines. Having taken into account various important factors of production, I believe Reallusion presently has the best solution for giving life to digital characters.
If you are thinking of making a hyper-realistic video game, even as a beginner, this is the program for you. Not only because it is free and easy to use thanks to its node-based system, but also because of the ease of use with other programs and the great number of tutorials and features that it has to offer.
If that wasn’t enough, we can finish by saying that in recent times several of the main video game developers are developing their most impressive titles in this programme. Learning to use it can facilitate access to these studios or, at very least, come close to the quality of these blockbusters.
image credit: Unreal Engine
I hope you like and enjoyed this tutorial. Remember to watch the video so you don’t miss any detail in the process that was covered here. Don’t forget to visit Reallusion for more online video tutorials and go to Steam to add “Dear Althea” to your wishlist.
Back to Part 1
befores & afters: How you can access Hollywood-style digital make-up effects
This article is featured on befores & afters.
Special thanks to befores & afters journalist Ian Failes for reporting on how Hollywood SFX make-up artists utilize Character Creator and SkinGen to successfully expand their business beyond their industry into animations, games, AR/VR, and much more.
Ada Productions gives filmmakers and content producers access to high-quality SFX makeup, which are digital alternatives to traditional prosthetic makeup. With the benefit of being reusable, SFX makeup comes in easily adjustable designs that can fulfill a variety of needs.
The main aim is for people to have access to really high-quality cinematic effects. […] We want others to have the ability to create something very quickly, very easily.
Simone Boria, CEO of Ada Productions
Both founders have extensive industry experience for the past 30 years. Simon Boria, the CEO, and founder of Ada Productions has worked as an art director, fashion and theatre designer, and broadcast journalist, and has taught film and media art analysis at the University of Art and Design Linz.
Stuart Sewell, another pillar of Ada Productions, has an impressive record as a prosthetic makeup and animatronics artist for Hollywood films since the 1990s. His SFX makeup have contributed to famous titles such as Frankenstein, Saving Private Ryan, The Hours, The Sea Inside, Lost in Space, and many more. What motivated Simone to found Ada Productions was the inevitable wave of digitization within the entertainment industry.
There was a worry that practical prosthetics would be removed from film altogether, but actually I think it’s like a complementary thing. I’ve seen quite a few makeups that have been enhanced by digital.
Stuart Sewell, Chief Product Designer of Ada Productions
This creation relied on the DMFX design tools by Ada Productions.
With an open mind toward CGI production, they have had many trials with different 3D tools. In the end, they settled on Reallusion’s pipeline solutions due to unrivaled convenience and interoperability. The Reallusion ecosystem of solutions allows for seamless connection with other 3D software, enabling them to transfer their interdisciplinary knowledge, immense experience and artistry into the digital realm.
With something like iClone and Character Creator, what I like about them is that they’re iterative and elastic. They allow you to change things on the fly.
Download Character Creator: https://bit.ly/37k0wp8
Learn more about SkinGen Premium Plug-in: https://bit.ly/3KDjMwx
Learn more about Ada Productions: https://dmfx.tools/
SkinGen assets by Ada Productions: https://bit.ly/3vdmUbJ
Read the full article on befores & afters: https://beforesandafters.com/2022/03/31/how-you-can-get-access-to-these-hollywood-style-digital-make-up-effects/
Character Creator 4 – Create Animated Personalities
Work in Progress : Part Three
In the latest WIP III video, we’d like to show how artists can create accentuated characters with their unique set of expression styles. With the newly introduced Expression Profile Editor, designers can use native modelling morphs and bone tools to reshape expressions. Artists can take advantage of the FBX workflow between Blender, Maya, and 3ds Max to create custom expression morphs, to make batch facial updates back to Character Creator.
Furthermore, Delta Mush helps you smooth the messy parts of the mesh, either to fix the cloth distortion or to clean facial morphs. Character Creator 4 enables everyone to produce high-quality models which are ready for animation for well-crafted personalities.
Expression Editor: Native Morph Slider Editing
With well-constructed interface, users can easily adjust different angles of characters’ facial features. Not only does the succinct thumbnail design make editing more intuitive – what you see is what you get – but the Modify panel also enables users to tweak each morph slider in detail. Without the aid of any third-party tool, artists are encouraged to use Edit Mesh to design their own customized morph sliders in Character Creator 4.
Red dots in each thumbnail are parts controlled by the morph slider. Artists can edit the mesh of each slider to customize the characters’ stylized expressions.
Blink animations are probably the most challenging area for making characters unique and come alive. In Character Creator 4, blink animations rely on five distinct morph sliders: Eye Blink, Eyelid, Eyelash, Eyeballs, and Eye Look.
By adjusting the source morph target shape of these sections, each expression morph slider can be revised, and with the use of the Mesh Edit tool, one can quickly overcome these obstacles. Lastly, having finished the eye animations for one side of the face, artists can use the Mirror tool to instantly apply the same slider settings to the other eye.
The Mirror function can be seen at 3:11.
Besides modeling morph targets, Character Creator 4’s Bone Adjustment feature can be used to modify specific facial expressions and mouth motions that is often inextricably linked to jaw movements. Freely design nuanced emotions by customizing the mesh of each morph slider. Customizations to the mesh editing, bone adjustments, and morph target models can be saved to custom sliders.
The Quick Update feature refreshes the iClone Muscle Edit data along with facial mocap to give unique styles of animation to your characters that is hard to emulate.
Bone adjustment – Jaw
The Highlight feature can promptly update the viewport to preview changes made to the morph sliders, which is very useful for fixing morph shapes while checking specific expressions and performances. In addition, morph sliders that are activated during playback are clearly listed under the Currently Used section of the interface.
Besides the existing Expression Editor, Character Creator 4 provides Mesh and Expression Set for exporting individual facial morph sliders in sequential frames, which are editable in third-party 3D software, with which you are familiar with. Consequently, artist taking advantage of the seamless GoZ pipeline process between Character Creator and Zbrush can update their custom expression shapes on the fly, with a simple click of a button.
Single slider update – GoZ
Ⅰ. Once you’ve made your adjustments using expression sliders, you can bake your work as a component of the character’s expression profile.
Ⅱ. Press the GoZ button to export it from Character Creator (CC) to ZBrush for advanced editing.
Ⅲ. Export those edited profiles back to CC using Re-Align function to update the newly designed expressions on your characters.
Expression Editor: External Blendshape Editing (FBX/OBJ)
Beyond fixing CC3+ characters, you can take a custom rigged character from Blender or other 3D applications and add an entire personality within hours. Directly import FBX blendshape files from Blender, Maya, 3ds Max, Unity, Unreal, Motion Builder and Cinema4D, just to name a few.
Most importantly, the Batch Update feature of Character Creator 4 enables you to import/export the enormous expression files all at once. Less tedious than ever, the new painless workflow gives precise results in a very short period of time.
Batch update – FBX Pipelines : Blender
Batch update – FBX Pipelines : Maya
Batch update – FBX Pipelines : 3ds Max
Mesh Smoothing Tool: Delta Mush
Besides the Expression Editor, Character Creator 4’s Delta Mush helps artists to mesh smooth the characters’ facial expressions and body topology, including outfits, shoes, and even the patterns on their clothes! Whole or partial mesh can be cleaned to achieve proper topology. This is especially useful for characters with faulty or irregular mesh as a result of intensive model processing.
• Fix cloth distortion
• Clean facial morphs
You can check the 3D Character Creation & Animation webpage for more information about the free upgrade offer, feature comparison, and FAQs. If you’re interested in the Character Creator 4 motto of “Enlivening any Character” and “Animating any Rig”, you can refer to the article ‘Working in Progress: Part One‘. It’s also recommended to watch the Sneak Peek review narrated by Russell Midfield, who precisely explains each feature. For more technical details, please have a look at our latest New Features Introduction.
If you have further questions, please contact our Support Team, or join the discussion at Reallusion Forum.
Winning Tips & Tricks: The Making of Petar Puljiz’s “Dear Rosie” Showcase
The “Winning Tips & Tricks” series covers practical workflows and techniques shared by winners from the “2021 iClone Lip Sync Animation Contest”. To let users see the full spectrum of the iClone facial pipeline, we are introducing projects that are rendered with different 3D engines including; Unreal, Unity, iClone, Blender, and Cinema4D.  Let’s now take a look at Petar Puljiz’s: “Dear Rosie”, combining workflow in Character Creator, iClone, Marvelous Designer, Blender, and Unreal Engine.
Petar Puljiz
Hello! I’m Petar(Peter) Puljiz, originally from Split, Croatia. I describe myself as a visual producer and artist, but I work in many roles. Currently, my main role is Visual Artist in Lowly from Trap Nation where I produce and publish experimental visual content for music. My current focus is based on virtual humans, and their implementation and representation on digital/virtual platforms. One of my virtual humans is mister visual, which I will write more about soon.
Why did I create this showcase?
The goal of this project is to explore what’s the most fun and painless way to animate complex characters such as Metahuman with a variety of tools. I used to believe in a lie that I would be able to get character animation straight from motion capture. But then I found I was a bit naive, because it requires a lot of data-cleaning for the captured motion data, and that’s just the way it is. Since I’m getting into a new storytelling format – virtual influencers – I need a lot of tools in a one-stop-shop solution, and a more streamlined process to animate MetaHuman. The iClone Lip Sync Animation Contest was a great motivation to free up time and dive into their tools. So I set up some criteria, took a deep breath, and dove into iClone!
A quick summary of my workflow
  • After refining the Rokoko mo-cap data, I used iClone’s Motion Layer Editor to create several natural body movements emphasizing the character’s talking animation, including hand contact on the table, and grabbing and releasing the cup prop.
  • Like the other contestants, I used AccuLips to drive the main lip-sync animation and observed the Unreal render in real-time via the iClone to Unreal Live Link.
  • Instead of using a facial mo-cap, I chose to blend subtle emotional expressions using iClone’s Face Puppet and made final detailed tweaks via MetaHuman’s facial controller.
I relied on Marvelous Designer to create the character’s unique dress and gave it a dynamic animation within an environment built up in Blender. Now you know the outline, let me just break down the details of each production phase.
How I do it with Reallusion Tools
Preparation: Concepting my character
First, I step into the shoes of my female character, Rosie and describe her personality, situation and anatomy. I try to look at the world from her point of view. It helps me to know how she acts and behaves in certain situations, which will ultimately reflect in the 3D animation.
Step 1: Rokoko – mocap, gloves, and suit: preparation work and motion data capturing
I used a Rokoko Smartsuit and its Smartgloves for motion capturing. The first reminder for you would be: Please get used to the suit! Because the suit is very tight, it will restrict your movement when performing. Don’t be afraid to stretch the costume to extend your body movement — you need to feel comfortable first!
Mocap animation provided me with an awesome block-out for movement; it gave me great timing and canvas to animate. After the mocap session was over, we prepared the data to retarget from Rokoko to iClone via 3DXChange. It’s easier if you have a plugin, but this is a good way to do it too.
Step 2: iClone – clean up, additive layer for the body, Acculips for mouth animation editing, and Facial Puppet for the rest of the face
Here we are, the moment of truth! I start to click around, seeing all the tools, I take a brief look at official documentation to get a much clearer vision. I begin placing a Metahuman dummy and ExPlus face in the scene with additional props that my character will interact with and setting up an additive layer to manipulate the mocap animation data and fix root motion. All the while using IK controls to get bigger moves and polishing it with FK controls later on. I parent the cup of coffee to the hand bone, and when it leaves it on the table I deactivate it. I fell in love with Reach Targets — ain’t gonna lie! For hand placement, I used ReachTargets so the hands stay on the table, and then deactivate it when the arm needs to be raised.
For fingers, Gestures help me to create main keys and then I polish them manually. After the body, I started with the face, and the first item is the mouth, using AccuLips to create the main layer of animation editing. Then I used iPhone LIVE FACE to get a good foundation for the rest of the face.
After the mouth, I did the eyes, eyebrows and nose. For the whole time, I had a second monitor with Unreal Engine and Live-Link turned on to exactly see what I’m getting, not relying solely on the iClone viewport.
Step 3: UE4 – Record 3D animation and ControlRig clean up and additive layer.
Unreal Engine
Once I finished with character animation in iClone, I transferred the animation data to Unreal via Live Link and Take Recorder. Disable the Reduce Keys option because we want to preserve all of that “juicy” animation (raw data). Also, I set up all my keyframes in Linear, because every frame is keyframed and you wouldn’t want auto-smooth or curves as they can create errors.
In Unreal, I import animation on our character, bake data to Control Rig and play with it a little bit. I spent some time here, just to clean up stuff we don’t need and put some more fine-tuning, especially for the face.
Step 4: Import the baked animation sequence from Unreal Engine and convert it to Alembic with a fixed table prop
Once done and satisfied with the animation editing, I bake ControlRig Animation Sequence to get an animation asset from it. With that, I export animation in FBX format. From there we import to Blender to convert it to an Alembic file which will be imported to Marvelous Designer.
Now, bake an animation asset from the control rig animation in Unreal Engine 4, and export it as FBX to Blender. Convert the animation asset to Alembic cache and send it to Marvelous Designer for cloth simulation.
Step 5: Marvelous Designer garment and simulation
The goal here was to test the pipeline and create small interactive cloth details. After importing the Alembic file, apply the motion to simulate the cloth animation.
Step 6: Transferring from Unreal Engine 4 to Unreal Engine 5
Our simulation is done and ready to be imported to Unreal. Once every setting is completed in Unreal, I continue to finish our scene and lighting. And after a couple of hours of adjustment, voila! That’s how I complete it, and now I’m ready to send all the animated files for full render.
Hope you enjoyed reading my tips and tricks!
Development Studio creates game on hit Reality TV Show: BIG BROTHER
Dr. Finn Krewer | Head of Development, 9th Impact
Dr. Finn Krewer – Founder / Head of Dev at 9th Impact
Finn Krewer is a founder and head of development at 9th Impact with responsibility for the development of Big Brother: The Game. Finn has been developing games since he was 14 starting on Xbox 360 and has developed on consoles, desktops, web and mobile for over 15 years.
He has worked as technical lead on franchise projects including Biker Mice, Danger Mouse and now leads the multi-disciplinary team dedicated to Big Brother: The Game. Finn received his bachelor and doctorate of computer engineering from National University of Ireland, Galway for his work on FP7 funded AI project SI-Elegans and his work Neural Network FPGA design and ultra-wideband medical radar applications.
Game development studio 9th Impact uses Character Creator to generator over 1 million character variations for hit reality TV show game: Big Brother.
” Character Creator is a very fast workflow where conforming and skinning is immediate and without designer intervention except in some edge cases. The availability of a large clothing library for Character Creator also allows us to use and customize stock outfits.”
Q: Hello Finn, and welcome to our Reallusion feature stories. Kindly introduce 9th Impact Studios, and the game development that your studios specializes.
9th Impact is a game development studio who partners with TV studios to make the official games of TV shows. We design games that fans of the TV show will love, so we don’t focus on any one particular genre of game. We are a small team but carry out game design, development, art production, testing and publishing in-house, which gives us tight co-ordination across disciplines and the ability to undertake complex and technically challenging projects.
Many of our games are cross-playable on different devices and we develop for mobile, PC, Facebook and Switch. Typically our games are localised into many languages. 9th Impact have created the official games of Biker Mice from Mars, Danger Mouse, Sunny Bunnies and Big Brother and have 2 new TV titles in development.
Q: Your team is currently working on Big Brother: The Game, based on the hit television series. Could you share with us the vision behind creating the game? How do the mechanics emulate what happens in the show, how do contestants participant in this experience?
Big Brother is the most watched TV show in history – 500 series have aired across 69 markets, producing over 28,000 episodes. So we knew that a large proportion of the global population would have watched Houseguests on TV competing in Big Brother.
The vision of the game was to create an official season of Big Brother where the TV audience could become the Big Brother Houseguests, using their mobile phone or PC as their portal into a virtual Big Brother House. The game is played in real-time, so the experience is slower than what you might expect from a mobile game, but becomes very immersive. A player is place in a House with 7 other real players. They get to know their Housemates and communicate via chat, voice messaging and private messaging. The latter is important for making secret alliances and plots!
Each day players compete in a mini-game to become Head of House. The Head of House chooses the nominees for eviction. There is Power of Veto competition that allows the winner to take one of the nominees “off the block” and force the Head of House to select another Housemate. At the end of the day, the Houseguests all vote on which nominee to evict.
The last remaining Houseguest is the winner of the House and continues to the next Tier. There are 7 Tiers in total and the winner of the Tier 7 House wins the grand prize. The prize fund increases with the number of players up to $1,000,000 with a guaranteed minimum of $50,000.
Q: With the Character Creator ecosystem, your team was able to create high quality avatars for the game. How were you characters originally made, and what made you decide to use Character Creator? What advantages does this application bring to game development studios?
Originally we would develop one base character that we would then create clothing for using tools like Marvellous Designer, Blender and Maya. The biggest effort in this path is the iterative conforming and skinning of clothing and accessories onto the base character.
In Reallusion Character Creator this is a very fast workflow where conforming and skinning is immediate and without designer intervention except in some edge cases. The ability to autohide elements of the base character which are hidden by clothing also decreases vert count and decreases clipping, in turn this decreases the need to conform and reskin multiple times.
The availability of a large clothing library for Character Creator also allows us to use and customize stock outfits to the Character Creator base character. Once conformed and skinned the clothing can then be directly used by the game engine.
Q: Season 2 of Big Brother will include over a million character variations. Typically what is your creation process like and how long does it take to create characters for the game?
The individual character variations are broken into slots which are available in the game such as Hair and Outfits. Each variation is prepared in Character Creator on a standard body which does not change. This allows the character to be built from multiple sections such as Hair, Outfit, Feet. Very basically the process includes selection of variation, application to the base character, conforming, skinning, skinning correction and pose testing in Character Creator.
The export pipeline then takes the required mesh and textures out to the engine. Finally, during engine import the Character Creator plugin is used to set up standard options and the UMA plugin is used to set up the options for the imported slot with all metadata and textures. Changing to Reallusion as our core character art toolset for season 2, reduced our production time by half and improved the quality of the output.
Q: When does Big Brother Season 2 begin, and how can the community join in on the fun?
Big Brother: The Game is available right now and players can join the competition by getting the game on App Store, Google Play, PC download and it is coming to Steam soon.
App Store:  http://bit.ly/bbtg-app
Google Play: http://bit.ly/bbtg-gp
PC (Windows): www.bigbrother.game/download
Steam:  https://store.steampowered.com/app/1388050/Big_Brother_The_Game/
Follow 9th Impact:
Website:
https://9thimpact.com/
Facebook:
https://www.facebook.com/9thimpact/
Twitter:
https://twitter.com/9thimpact
Videographer Makes Digital Walls, Virtual Homes Pop With NVIDIA Omniverse
This article was written by NVIDIA, and featured on NVIDIA Blog.
Helsinki-based Pekka Varis showcases browse-and-buy possibilities of digital art gallery, using NVIDIA Studio drivers, Reallusion and Lightmap software.
Pekka Varis’s artistry has come a long way from his early days as a self-styled “punk activist” who spray painted during the “old school days of hip hop in Finland”.
More than 30 years later, he’s embracing the future of graphics as a videographer who uses NVIDIA Omniverse, a physically accurate 3D design collaboration and simulation platform, to create vibrant virtual worlds.
His freelance video production company Catchline translates complex technology services into attention-snagging, easily digestible video messages or commercials.
A recent project was an animated ad for Artio, an app that brings a global digital art gallery to individual smart devices.
In the commercial, a digital family searches for the perfect piece of art to enliven their new home, visualizing options on the walls in real time. Plus, the parents unpack boxes filled with detailed items, a child plays with block toys, the dog shakes its head and wags its tail — all in a physically accurate way, thanks to Omniverse.
“NVIDIA Omniverse has given me more artistic power and a totally new level of freedom. It’s a trusty playground where I can bring in quality content and focus on creating designs, visuals, variations — all that fun stuff.”
Pekka Varis
Vivifying the Videography
The Helsinki-based videographer takes viewers through his creative process in a three-part tutorial that details his recent commercial project, in which Artio helps the digital family make their blank walls pop.
Watch the first installment of the tutorial series on demand and below:
In subsequent episodes, Varis covers his animation process with Reallusion Character Creator:
as well as his steps for lighting and color correction in Omniverse:
His multi-app workflow — bringing characters to life with Reallusion software and perfecting the lighting with Lightmap HDR Light Studio — is made possible by Omniverse Connectors, plugins that connect third-party design apps with Omniverse, and NVIDIA Studio drivers.
He estimates a 90 percent savings in time and cost using Omniverse. “With Omniverse Connectors to Reallusion software like Character Creator and iClone, I can make commercial-quality characters quickly and easily, which I wouldn’t have even dreamed about before,” he said.
“Natasha,” made by Varis using Reallusion Character Creator and Omniverse Create.
His favorite Omniverse apps, he added, are Omniverse Create — a toolkit built on Pixar’s Universal Scene Description format that accelerates advanced scene composition — and Omniverse Machinima, with which he animates and manipulates characters inside of virtual worlds.
“I see myself using Omniverse with every single work commission I get moving forward. And I hope my video tutorials inspire viewers to try using these superb tools to create their own artwork.”
Pekka Varis
When not creating videos, Varis makes music as a drummer who loves metal, rock and hip hop — and spends time with his six-year-old daughter, his source of inspiration.
Related Links:
NVIDIA Blog: https://blogs.nvidia.com/blog/2022/04/04/pekka-varis-omniverse-creator/
OrpheusVR | re:Naissance Opera brings live virtual performance with iClone
OrpheusVR is an indie VR game prototype that I have been working on in conjunction with Debi Wong of re:Naissance Opera, Brian Lee Topp, and Youhan Guan. The project was conceived as a way to engage new virtual reality platforms with the ancient art form of opera. Live From The Underworld is a series of interactive live-stream performances featuring mythological avatars brought to life by real-time motion capture technology and live opera singers.
In 2018 a team of digital and opera artists came together to ask “what would opera look like if it were invented today?”. From that initial question OrpheusVR, an interactive, choose-your-own-adventure, virtual-reality opera was born. After completing the prototype in 2021, the OrpheusVR team started working in the digital live stream space, using iClone real-time animation software, iClone’s LIVE FACE mocap animation with Xsens body live motion capture technology and computer avatars from the OrpheusVR world to create live, interactive operatic performances that can be streamed from any device.
Debi Wong – Founding Artistic Director
Debi Wong
Debi Wong is an interdisciplinary performance artist that loves to weave together sound, text, movement, and technology to create contemporary stories. Her performances have been recognized as “unique and magical” (Rondo Classic) and “electric” (Schmopera).
As a soloist, Debi has performed with leading orchestras and ensembles across Europe and North America most notably with her lute and voice duo, White Sparrow at The Stockholm Early Music Festival, The Copenhagen Renaissance Music Festival, The BRQ Vantaa Festival (Helsinki), Garrick’s Temple To Shakespeare (UK) and the Venice Biennale. Debi is currently artistic director of re:Naissance Opera, a Vancouver-based indie opera company.
Debi is the founding artistic director of re:Naissance Opera in Vancouver, BC. With re:Naissance she has created #DidoAndAeneas (2014), an interactive, social-media opera; Acis & Galatea which was recognized by Vancouver Classical Music as one of the city’s best operas in 2017. In 2019, Debi spearheaded OrpheusVR, an interactive Virtual Reality Opera that was featured at the VIFF Immersed exhibit at the 2020 Vancouver International Film Festival and in 2020 she co-created the award-winning podcast The Apocrypha Chronicles (Finalist, New York Festivals Radio Awards).
Debi is a graduate of Yale University (M.Mus) and The Yale Institute of Sacred Music (Diploma in Sacred Music), where she studied vocal performance and was the recipient of the 2010 Margot Fassler Award for outstanding performances in sacred music. She is currently a Doctoral candidate at The University of the Arts Helsinki.
Conrad Sly
Conrad is a 3D Artist with a deep passion for the medium and its many platforms. He specializes in real-time graphics and has been producing architectural visualization for virtual reality projects for 4 years, and has worked on several iterations of the VR Theatre for SIGGRAPH in 2018 and 2019. He has a deep interest in the crossroads of experimentation with emergent technologies such as VR and AR, and traditional theatrical and art contexts.
Conrad and Debi began collaborating in 2018 when Debi took an interest in the digital art and virtual reality games Conrad was creating at the Centre for Digital Media. Their initial conversations led to the 2020 prototype of OrpheusVR, an interactive, VR opera for Oculus Quest, and Live From The Underworld (2021), a new interactive live stream that uses mythological CG avatars, motion capture, and dancers and singers to innovate live opera and online performance.
Conrad Sly – Art Director
“It is pretty complicated, but at the same time we’ve entered into these partnerships with, for example, Reallusion Software, and they’ve really created these user-friendly tools that have really helped us as indie producers.”
Q: Greetings Debi and Conrad, welcome to our Reallusion Feature Stories! Kindly introduce OrpheusVR and what your team is trying to achieve with LIVE from the Underworld.
OrpheusVR is a mythological world we have been creating over the past three years. Inside this world, we’re trying to explore in what ways real-time gaming technologies and live motion capture technologies can bring something new to the table of traditional opera performance.
We’ve developed a prototype of a choose-your-own-adventure VR opera and we are now experimenting with live streaming our operatic avatars to mobile and personal devices. We’ve been having a lot of fun exploring what kind of design aesthetics we can create that you might not see in a traditional theatre and how livestreaming to personal devices allows for interactivity and new kinds of engagements from audiences.
Q: Please share with us how you were able to combine different performances to bring your avatars to life for a live experience. What are the biggest challenges in doing this in real time?
One of the biggest challenges of real-time motion capture has to do with capturing high quality data from live performances. We use the Xsens, which produces excellent results, but still has responsiveness limitations — but because everything is live, we don’t have the luxury of going back and cleaning anything up or doing any detailed work. Coupled with an indie setup for the face using a iPhone with iClone‘s LIVE FACE app, it starts to get pretty complicated in terms of how to manage the intake of data in a performant way for real-time graphics.
This meant we had to “rehearse” our avatars in very specific ways – we had to discover what kinds of movements read well with the suit and which movements do not produce great real-time results. We went through a similar process with facial capture and we also learned that mounting head rigs on opera singers is extremely cumbersome and limiting for their techniques.
We decided to approach these challenges by compartmentalizing our motion capture and live performance art, dedicating certain workstations to specific tasks. We also started treating the avatars like puppets. We used dancer-choreographers to create vocabularies of movement for us and our singers did the same for facial gestures. In the end, we actually puppet our avatars with two performers: a dancer plays the body of character and an opera singer plays the face and voice. This lets us have a really diverse and expressive range of choreography and dynamic vocal acrobatics.
Q: As a producer, how has iClone and its LIVE FACE mocap animation helped your production ? What combination of tools and hardware did you use for the live actor performance?
We’re an indie studio working in real-time so the great thing about iClone is the ease of use for our team and its ability to bring in many different data streams (for our livestreams, we use an Xsens suit with Rokoko Smartgloves to capture the dancer’s body and finger data and the LIVE FACE app running on an iPhone 12 mini to capture facial expressions from our singer.). It produces great results with our custom Character Creator (CC3) avatars and we are able to produce really exciting live results.
LIVE FACE has also been a really powerful tool for us because it means any of our opera singers can take out their iPhones and capture data for us. We tested a few different options for facial capture because opera singers make pretty distinct facial animations when they sing and we discovered that calibrating facial movements and using LIVE FACE produced the most expressive real-time results for our singers.
iClone’s LIVE FACE app for iPhone facial motion capture
Both iClone and LIVE FACE are an integral part of our livestream production pipeline and they have been second to none.
Facial key editing inside of iClone animation software
 Q: After LIVE from the Underworld, what other projects can the community look forward to from re:Naissance Opera ?
We have a few dreams we are entertaining – we’re curious about streaming live in 360 and how our Reallusion tools can help us accomplish that in Unreal Engine. We are excited to go further with our live performances and audience interactions – we want our audiences to feel like they are participating in gameplay when they join our livestreams.
Live streaming performance from iClone to Unreal Engine via the LIVE LINK plugin
We are continuing to explore and discover in what ways these emerging and increasingly affordable technologies can infuse the world of opera with new life.
Live streaming rendered inside of Unreal Engine
Orpheus VR live virtual performances with iClone and Unreal Engine
Follow OrpheusVR
Website:
https://reopera.ca/
https://orpheusvr.ca/
YouTube:
https://www.youtube.com/channel/UCCJ_d9ADrBdNfZsRtkwFvow
Reallusion Releases ActorCore Library for NVIDIA Omniverse
Integrating 3D Character and Mocap Animation Collection with NVIDIA’s Collaboration Platform and Asset Store to Simplify Crowd Generation for Business Visualization
Reallusion, the developer of Character Creator and iClone real-time animation software, has released new ActorCore Content for NVIDIA Omniverse™. ActorCore offers a large selection of AI-controllable 3D characters and mocap animations, significantly reducing workflow and increasing production efficiency for crowd rendering for use in AEC (architecture, engineering, construction) simulations and visualizations.
Already deployed in digital twin projects including NVIDIA drive simulations and BMW manufacturing visualizations, ActorCore’s 3D content has been quickly adopted by professional animators not only in archviz applications but in media entertainment, games, and films.
“As a leader in 3D character animation, Reallusion continues to provide the most intuitive tools and premium content for creators,” said Charles Chen, Reallusion CEO. “The iClone and Character Creator Connectors have added a complete character animation pipeline to Omniverse. In response to the huge demand for business visualization, particularly digital twin, the latest release of ActorCore Omniverse Content empowers business users with massive interactive assets for real-time crowd simulation on the virtual platform.”
Collaboration with Photorealistic Simulation
NVIDIA Omniverse™ is an easily extensible, open platform built for virtual collaboration and real-time physically accurate simulation. Creators, designers, researchers, and engineers can connect major design tools, assets, and projects to collaborate and iterate in a shared virtual space. Additionally, developers and software providers can also build and sell Extensions, Apps, Connectors, and Microservices on Omniverse’s modular platform to expand its functionality.
NVIDIA Omniverse open platform made for AEC simulations (Image credit: Reallusion and Bentley Systems)
Animated 3D Crowd for Industrial Visualization
A cloud-based 3D character and mocap motion platform; ActorCore allows users to quickly search, view, and download photorealistic 3D people for crowd scene usage. ActorCore also provides thousands of AAA quality, well-themed mocap animations. Combining ActorCore and Omniverse, individuals or design teams can create a large group of 3D crowds to animate, and deploy for AEC simulations and visualizations.
Drag and drop ActorCore 3D characters and animations directly to Omniverse (Image credit: Reallusion and Bentley Systems)
Interactive Lightweight Actors for Real-Time Rendering
In contrast to commonly used 3D models with no natural movements and expressions, ActorCore’s fully-rigged characters can perform lifelike facial and talking animations suitable for different camera ranges. PBR materials are merged for the best crowd rendering performance in real-time, and the actors are fully compatible with thousands of mocap motions available in ActorCore expansive libraries.
Rigged lightweight characters for real-time rendering (Image credit: Reallusion)
A large collection of 3D people designed for business simulations (Image credit: Reallusion)
AAA Production with Seamless Motion Transitions
To meet demands from different industries, ActorCore offers professionally produced motions in well-planned themes. A specially designed motion system ensures smooth transitions between primary and secondary stance modes, offering high flexibility for professional animation production and interactive game character controls. Illustrated videos provide different usage scenarios to choose from, including individual, group, or paired motions for maximum compatibility.
Thousands of mocap animations organized with different themes.(Image credit: Reallusion)
AAA production motion capture animations in ActorCore (Image credit: Reallusion)
Simplified Workflow and Optimized Asset Management
Users can directly export ActorCore’s rigged characters and motions to the USD (Universal Scene Description) format, and easily drag and drop the content to Omniverse apps to continue scene setup. With motion retargeting*, the same motion can be applied to characters with different body scales, optimizing ActorCore’s large content library and reducing effort for asset management.
*Motion retargeting will be supported by Omniverse Machinima version 2022.1.0 and after; it will also be supported by Omniverse Create. Please pay attention to NVIDIA’s official announcement.
Motion retargeting simplifies 3D animation workflow in Omniverse (Image credit: Reallusion)
Explore, Search, Interact – 3D Browser Experience
Exceptional performance on ActorCore gives users the best interactive 3D viewing experience on chosen characters and motions. Users can quickly search and explore thousands of contents through tags, categories, and keywords to find that ideal asset.
Quick search by keywords and interactive 3D preview on ActorCore (Image credit: Reallusion)
New Standard for 3D Crowd Simulation
ActorCore allows a variety of industries to access and deploy a large number of 3D people as task performers or citizens, defining the next generation of 3D character solutions for key industry simulation partners and technologies. For AEC, users can generate digital people to inhabit and interact with designs, buildings, and manufacturing sectors to simulate workforce and training.
Create industrial simulations with ActorCore in Omniverse (image credit: Reallusion, BMW Group, and NVIDIA)
Next-level Character Control with iClone
iClone’s easy facial and body controls allow full character performance with smooth bi-directional motion blending, FK/IK motion layer editing, and reach-target animation for advanced motion editing. Adjustable colors and materials allow for unlimited visual varieties while adding subtle facial performances and lifelike lip-sync animations for custom facial expressions.
Advanced character control of ActorCore content with iClone (Image credit: Reallusion)
Free ActorCore USD Character and Motion Resource
Get a first-hand experience of ActorCore with free 3D character and motion assets. Visit
ActorCore website, or download Omniverse and access free USD sample content in Omniverse asset store.
