首頁 » Page 73
Concept Art MasterClass #7: Comping Renders, Paint, and Finish
Gnomon Instructor and Senior Concept Artist Kyle Brown shares a groundbreaking workflow
Kyle Brown, a veteran of the CG world, Kyle has worked within the field since 2015 and has had his hand in a number of projects throughout the film and television industry. He also currently is an instructor at the Gnomon School of Visual Effects where he is able to share his expertise with others.
This Master Class comes in 7 parts, each carries its own tutorial video to guide you through the entire process of how Kyle incorporates Character Creator, Photoshop, ZBrush and other tools to create the concept art. You can find links to the other 6 tutorials below.
Part #7: Comping Renders, Paint, and Finish
With the renders complete, I bring them into Photoshop to put on the final touches. The amount of painting varies from piece to piece but as so much of these pieces were figured out early in the process, it doesn’t take much to get them looking the way I want them to.
The first thing I do is play around with some color LUTs to get a unified color grading, very similar to the post effects available in CC3.
On the two other versions that weren’t based on my initial sketches I want to push some of the stock elements a little bit further to match the Cyberpunk look. As mentioned earlier in the tutorial, I not only wanted the costume to be different between the versions but also the artificial skin as well. I opted to tweak some of the cut lines and QR code on the cheek a bit, opting on the third to remove it completely for more of a natural aesthetic.
With the more ‘mechanical’ bits on the second version, I wanted to paint in some extra cut lines and material reads, including some additional texture and sheen. As well, this version showcases the alternate glow texture created earlier in the tutorial.
I used some really cool streetwear for the third variation that looked great right out of the box but felt it needed some more break ups in the pattern and something futuristic in the read to push it over so I opted for some plastic or some sort of transparent material.
And here we are! The three final design iterations for our futuristic Cyberpunk android!
And that about does it! There are plenty of resources out there to cover the digital sculpting and digital painting processes, but I was happy to put together a tutorial that tied all of these elements together and showcased an alternate way of utilizing Character Creator 3 for concept design! As I experimented with this new workflow, I found feature after feature that I am excited to implement going forward. I only scratched the surface of all of the new features available in Character Creator 3, whether it’s the brand new SkinGen or the awesome Headshot plugin that allows you to easily capture likeness, something I feel will be extremely valuable on upcoming projects!
Thank you so much for taking the time to check out this tutorial! It was fantastic getting to explore a new workflow, one that feels like a missing component my workflow was missing and one I am excited to push forward. Once again, thank you to the Reallusion team for inviting me to participate and helping so much along the way! Can’t wait to get into the next piece!
Follow the other 6 tutorials in this series:
Part #1: Getting Started and Sketches
Part #2: Costume & Asset Creation in ZBrush
Part #3: Refining and Adding Details in ZBrush
Part #4: Generating Textures and Importing into Character Creator 3
Part #5: Lighting and Posing a Character in Character Creator 3
Part #6: Costume Variation and Texture Modification
Concept Art MasterClass #6: Costume Variation and Texture Modification
When you spend all the upfront time getting your avatar set up, posed, lit and positioned in frame the way you want, you’ve done all of the heavy lifting. With Character Creator 3’s incredible library of assets that can be applied to nearly any character, you can mix and match these incredible assets to get all new looks for your design. With concept it is all about exploring a variation and possibility so being able to change bits and bobs to get new looks is crucial which makes CC3 such an exciting and efficient new tool to be added to the toolbox.
With custom clothing and accessories, it might require some tweaks to make sure pieces don’t interpenetrate and overlap incorrectly. Luckily, we can tackle these issues right inside of the CC3 Modify tab. Hitting conform will give you options to adjust the clothing as a whole where the Vertex modifiers will allow you to use different tools, including options like sculpting to select and move specific vertices, a really handy tool to keep the whole process simple and efficient.
This is a preview of the conform options which will place your model back in T pose allowing you to see the fit as a whole. Like most 3D packages of your choosing, you can use soft selections to make gradual adjustments to areas without distorting the mesh too much.
My first version had the visor up as it did in the initial sketches, but on each iteration I like to change up as much as possible so I easily move the visor down to see it in action.
You can generate a whole library of clothing and accessories that fit within a genre so you can pick and choose elements to get brand new looks with a few clicks and quick adjustments.
I decided that I want some options on the character herself. I elected to remove the cut lines that I had created earlier and opted to create something else that will still evoke the cyber punk feeling while hopefully feeling fresh and interesting.
I grabbed the same texture from the cut lines that were directing the glow effect and once again took advantage of the Texture editor that sent it over to Photoshop. I used the texture reference in tandem with the original cutline glow to figure out where I wanted the new glow to be, I really enjoy hand painting these maps, giving me a very fluid workflow that can help create options on the fly.
With mixing and matching, I am able to set up three unique renders that I can now take into photoshop to finish off with some paint and photo texture to get that last little bit of the way to the finish line!
*Note: You can Right click on your color map in the modify tab to pull up the option to Adjust color. This allowed me to desaturate the texture of some clothing I had that didn’t quite work with what I had established. This gives me a great base to work with in Photoshop.
Concept Art MasterClass #5: Lighting and Posing a Character in Character Creator 3
With all of the textures in place and material properties assigned, I start to work with some of the other properties within the content library, including the Stage elements. I enjoy looking through the Smart Gallery as well so see how options are bundled for a more cultivated look.
Not only can you set up the lights but you can also further adjust the image window with a number of post effects including blurs, color adjusts and LUT color grading effects.
This is great for artists who want to streamline the process as much as possible and limit their time in their post processor of choice.
I flipped through a number of studio lighting scenarios that had some really strong dramatic lighting. I wanted a nice blend between studio lighting and something that would feel a little more natural or environmental as though some of the lighting was coming from some neon street signage.
Once you pick a studio lighting preset you will see that it generates lights in your scene tree that you can move and manipulate for further customization.
With lights arranged I went digging through the library of content to see what I could tackle inside of CC3 rather than generating elsewhere or photobashing later. I was thrilled to find the Floor_Asphalt and Floor_Tarmacked available in the Content > Stage Elements > Props > floors.
There is also a really great concrete wall that fit perfectly for the vibe I was trying to achieve in the piece and did a great job of framing the scene.
I experimented with some posing earlier in the process, when checking to make sure all of the costume and prop elements were parented to the right body part and conforming properly. After setting up the lighting with the figure in T-Pose, and locking in a little bit of the environment, I deep dive into getting my character into her final pose.
The final Pose is similar to the initial pose used for the sketch phase, still maintaining the same attitude that the sketch had. I wanted a pose that showed off a bit of character without it being too extreme, blocking parts of the costume. As this is for concepts, it’s important to communicate as much information as possible to the viewer.
I had to tweak a few elements of the costume, including the shoulder pauldron that after moving was interpentrating the upper torso and arm.
Everything is looking the way I want, the pose and position are where I want them, the camera angle is where I want so I start adjusting some of the camera effects.
These adjustments can be made in the Visual tab, where you can make adjustments to your Light, Shadow, Ambient Occlusion and much more. You have the option to edit your post effects that were added from your content library as well.
Here is the piece rounding the final adjustment to get our primary scene set up. I make some adjustments to the Bloom to get a little bit more ‘oomph’ out of the visors and play up that cyberpunk aesthetic.
CC3 can render out a static image from the real time window, It’s is important to know that there is also the option to render with the Iray renderer that can be installed with CC3. To take advantage of the real time benefits of the SkinGen set of tools and their appearance, it would be best to render with the real time render in CC3. This will be one set image when I render out, with no additional passes which means I want to handle as much in one pass as possible and handle the rest in paint within photoshop.
I want to get some depth of field in the shot, so I select the Camera in my scene tree and jump over to the Modify menu where you find some additional options you can tweak.
If you want to see the effect of the depth of field, you can check or uncheck the Activate box in the Modify menu to turn it on and off. I will do this as I apply different costume pieces to the other iterations in the coming steps.
*Tip: To save the Camera by navigating to the Content tab, selecting the Stage Elements > Camera and selecting Custom. Hit the + at the bottom of the menu to add your custom camera in case you accidentally move out of that view while modifying your character.
Pitch & Produce | INVASION 2040: Director harnesses Character Creator iClone and Unreal Engine for Web Series
César Turturro – Director / FX Producer
Creavision is a small studio located in the city of Bahia Blanca, Argentina. We mainly focus on the realization of 2D and 3D animation projects, although we also do filmic works, such as advertisements, corporate videos and documentaries.
Invasion 2040 is a project that started in 2017. Post-production started immediately, as I wrote the script. At the beginning, almost 70% of the project was carried out on my own, without involving other artists or studios. This was due to the fact that it was a search and learning process, and we did not have financial support.
During that time I used different types of programs and render engines until August 2020, while working remotely in the middle of the Covid-19 pandemic that we won the support of Reallusion’s Pitch & Produce program. It was then when we also began work with Unreal Engine, and when I involved two more artists from the studio.
“With the help of all these real-time tools — in just a few months we accomplished more than half of all the animation and rendering work, which had personally taken me almost 3 years before.”
In summary, I can say that there is a before and after both in my career and in the way we work. Today Invasion 2040 is being released on several networks and has won various awards at festivals around the world. With all the shots and animations that I imagined 4 years ago, I can say that we have realized not only a movie… but a dream.
Concept Art MasterClass #4: Generating Textures and Importing into Character Creator 3
Character Creator 3 can handle quite a bit, but as it is designed to get a character ready for real time engines, it is important to optimize geometry for those engines. This whole process is for concept, so as mentioned before, I am trying to keep the pipeline as simple as possible, so I will tackle the following in ZBrush.
Utilizing the Zplugin > UV master we can apply quick UVs to our subdivided or decimated meshes. In the attached example I work on the Thigh plates that are subdivided. The mesh is too dense to take over the CC3 so I opt to clone the mesh at its lowest subdivision level and Unwrap it using the UV Master plugin. After that, I can clone that UV from that unwrapped subtool and apply it back to the original mesh with subdivisions.
Now that there are UVs on the mesh, I can capture both the color information as well as the high res detail information. As I was sculpting up the costume, I painted up the wardrobe and graphic elements. This is just polypaint, or vertex color information so it must be converted to a color or albedo map.
On that same subtool, I need to capture the high-resolution detail that can be baked out and exported to be used inside of Character Creator. By switching to subdivision level 1, I navigate over to the Normal Map menu in the tool palette and with the below options selected, click Create NormalMap. This should capture the detail from each subdivision that will make these thigh plates look much cleaner in CC3.
You can also Decimate a mesh utilizing Decimation Master in the Zplugin dropdown menu with the option to preserve the existing UV coordinates of your mesh while reducing the vertex counts.
Now that everything is optimized for Character Creator 3, we can utilize the GoZ function and relink our character that started it all as well as importing each new part of the costume. I select Cloth for elements of the costume that I want to conform to the body of my cyberpunk character and Accessory for the elements that shouldn’t conform or remain rigid on my cyberpunk character.
Once everything is in place within Character Creator 3 and make sure each element is parented to the right part of the underlying avatar.  Below you can see the rig of our character after the relinking from ZBrush.
Before tweaking the 3d textures further I want to make sure that everything is linked correctly as I experiment with some poses. Any distortions will let me know where the skin weights of certain pieces aren’t working or the parenting may be incorrect. The final pose isn’t anything too extreme but I wanted to get a feeling for what she would look like in action. As you can see below, accessories like the backpack are shifting and separating from the rest of the character.
Using the Traditional materials or PBR in the modify menu we can get some nice material reads in tandem with our color maps we imported. From the beginning I envisioned the skirt as a futuristic plastic-esque material so I lowered the transparency and played with the specularity.
On my next project I would like to experiment with 3d textures crafted in Substance Painter which can easily be imported and assigned in CC3.
When I started on this project I wanted to include an element in the design that would take advantage of CC3’s new SkinGen tools, an incredible layering system that allows you to stack different effects one on top of the other to get incredible results. I hinted earlier in the tutorial that I wanted to include this new workflow addition to generate cyberpunk cutlines on our cyborg.
I jump back over to ZBrush and sculpt the cut lines into the face of our cyborg and once completed, I generate a new normal map of those cuts and export them to CC3.
And here is that Normal map imported back into CC3’s SkinGen.
Following is an example of another customization option of SkinGen, the ability to cake warpaint onto your character. Here you can see how you can manipulate the included maps with sliders to get hundreds of custom looks or, if you want even more control you can export a UV reference map and the opacity map directing the effect to your editor of choice, mine being Photoshop where I edit the paint and re-import them to CC3 trying out the proposed idea of war paint on my Cyborg.
Concept Art MasterClass #3: Refining and Adding Details in ZBrush
This Master Class comes in 7 parts, each carries its own tutorial video to guide you through the entire process of how Kyle incorporates Character Creator, Photoshop, ZBrush, and other tools to create the concept art. You can find links to the other 6 tutorials below.
The fun part! Well it’s all fun, but this is where the piece starts to come together in sculpt. I blocked out some interesting greeble pieces for the shoulder pauldrons that I convert to insert meshes and apply them to single sided planes as Nanomesh. I do this so these pieces are instances and not committed geometry yet, and this gives me the option to switch them out on the fly or switch them for another conceptual iteration.
The next part of the costume I focus on is the quilted skirt piece. Another bit of costume that I can tackle right inside of ZBrush now thanks to Dynamics. This will give some nice gravity and initial folds that will look good in tandem with the character poses inside of Character Creator 3. It starts as simple geometry cut out and shrunk to the surface so it feels like it is actually draping off of my character.
Once the skirt is in place and looks the way I want it to, making sure it drapes appropriately and making sure that the size and cuts of the fold mimic the appropriate fabric I’m going for.
Then as everything is in place, I’ve sculpted in some additional folds that didn’t have in the dynamics simulation. I generate a quick UV using the Zplugin> UV Master (Something we will revisit in the texture section) and morph UV in the tool palette, a relatively new addition being the ability to sculpt on the morphed UV.
As mentioned earlier, everything is blocked out and what will be seen from the proposed camera angle is what get’s priority. I did decide to detail out the backpack a little bit more because I’m not sure if more of it will be visible if I change up the character pose.  With the power of CC3, this is now an accessory that I utilize in the future with other characters.
At this point, I am nearing the end of the block out and detailing our cyberpunk character. I’m always trying to strike a balance between simplicity and over-complicated detailing, giving me the freedom to paint into the final renders, giving me more control.
I pull up my initial sketch and reference it constantly throughout the process to make sure that I am matching what was approved.
After checking my design against the sketch, I finished tightening up a few remaining details, including filling out the red graphics on the breastplate and abdominal pads. I utilize the fantastic Spotlight Projection under the Texture tab. It gives me a little bit more control than dragging out an alpha, here I can apply a texture from the camera. I found an interesting ‘techy’ texture that feels almost fabric-like while still maintaining the cyberpunk character qualities.
Concept Art MasterClass #2: Costume & Asset Creation in ZBrush
This Master Class comes in 7 parts, each carries its own tutorial video to guide you through the entire process of how Kyle incorporates Character Creator, Photoshop, ZBrush and other tools to create a character concept. You can find links to the other 6 tutorials below.
We start back in Character Creator 3 with the same base I used on the sketches. This is another benefit as it will provide the same underlying structure for my 3D blockout that I used for the sketches, so there really shouldn’t be an issue making sure elements line up and proportion properly.
CC3 has an incredibly easy GoZ bridge, click and use the corresponding options to quickly send your 3D character over to ZBrush as a workable Ztool.
You can choose to send over your avatar from Character Creator 3 to ZBrush in A-Pose, T Pose, or Current Pose. The current pose is a fantastic addition that will be instrumental in my 3D character designs that aren’t rendered directly in CC3 going forward.
The process described in this workflow revolves around the following workflow. CC3 has so many great pieces of wardrobe, costume, and accessories, both out of the box and available for purchase. This however is a new design and requires new costume elements created from scratch. It starts with the A-posed base mesh and masking out the outline of the new garment. Using the extract option under the subtool pallet, you can start to layer low res subtools one after the other to create a character’s clothing.
Once I have the extraction, I use the fantastic tools inside of the Zmodeler brush inside of ZBrush to make cleaner surface adjustments and modeling changes. This is the most methodical part of the process, more poly-modeling than digital sculpting, but I find it easier to be a little bit more patient at this point upfront to get better-looking results, then to try and polish up rough-looking surfaces later. Zmodeler keeps me in one program, a huge help in a concept design pipeline.
Once the mesh is blocked out, we can slice the mesh and assign polygroups. By using Brush > Auto Masking > Mask by Polygroups, you can move these sections independently and get cool clean shapes on your costume.
At the time of the recording of this tutorial, those of us with ZBrush were given the serendipitous release of ZBrush 2021 and with it, the inclusion of their brand new and amazing Dynamics feature. For quick accurate folds I will take geometry into programs like Marvelous Designer to get quick results, and though it will still be a necessary part of my workflow, the new Dynamics features in ZBrush will be an incredible and “How did I live without this” feature going forward, especially as it relates to generating clothing for Character Creator 3. I used more masking and Dynamics mixed with the inflate function to get a jumpsuit/ leather effect on my character’s pants.
My goal with a costume is to get the biggest forms or elements blocked in first, never jumping into tertiary details before everything is in place, meaning I don’t want to use alphas or other sculpture details to make things like nuts and bolts before I can get a clean read of the costume as a whole. The last thing I block out during this initial phase of the ZBrush portion is to get the cool techy backpack. I plan on rendering her out from a front-on angle and probably won’t see much of the backpack, but it is large enough that it will wrap around the torso and affect the silhouette, so I make sure to get it in there.
This wraps up part I of the ZBrush portion, the following Chapter will jump into refining the elements already established as well as really getting into what makes this ZBrush to Character Creator 3 so awesome.
Here is where the sculpt is at.
Artist and Content Developer Ken Long renders 3D backgrounds for use in 2D Cartoon Animator
Ken Long – 3D / 2D Content Developer
Ken Long
Combining the power of 3D / 2D artist and writer Ken Long uses Cartoon Animator to produce images for children’s books , creating wild and fanciful stories that move from his imagination to the screen.
In this interview, Ken talks about his passion for animation and the inspiration he takes from the great story tellers of the past.
“When it comes to Cartoon Animator I like the ability to do work that would have, not so long ago, been beyond anyone without a Walt Disney type set up.”
Concept Art MasterClass #1: Getting Started and Sketches
As the world of 3D art and animations continues to expand into a new renaissance, animators and artists alike are rushing to find the best, most efficient tools to bring their visions to life. To CG artists, the ability to seamlessly move through the workflow of concept to finished product is invaluable. From rigging and posing character models, to the generation of textures and skins, and finally the pipeline to outside 3D tools, these artists require the best possible tools at their fingertips. And for Senior Concept Artist Kyle Brown and his students, having such tools is essential.
Kyle is not a character modeler. Any 3D he has learned has been out of necessity to make the conceptual designs he creates more efficient. For the longest time, the only 3D package he utilized was ZBrush with programs like Keyshot to render.
This is Kyle’s first time using Character Creator and SkinGen Premium Plug-in. After this project, he shared the work he has done using Character Creator, and he is constantly telling friends and peers who work in the industry and use the same tools about Character Creator 3 and how valuable it has been to his work as a whole.
In this demo, Kyle will walk you through the steps of using Character Creator 3 from the earliest steps to render out a simple image to sketch on top of to using that same avatar to send to ZBrush to sculpt and dress, then to finish back in Character Creator 3 where we resolve textures, lighting, and rendering of our cyberpunk character.
This Master Class comes in 7 parts, each carries its own tutorial video to guide you through the entire process of how Kyle incorporates Character Creator, Photoshop, ZBrush, and other tools to create a character and concept art. You can find links to the other 6 tutorials below.
There are plenty of options in the 3D marketplace, but from the first time I opened Character Creator 3 was clear that it was a step beyond. A real time render window gives me an up to the second preview of my character creations. This was extremely valuable to start the whole process as I was able to find and place the female character of my choice into the scene and use some basic, yet impactful stock lighting to bring it all together. Since This was going to be the same character, I would use for the rest of the design process, I knew that whatever I sketched on top to have approved, would be fully achievable on the proportions of my avatar.
The base body render straight out Character Creator 3 that will serve as the base of our cyberpunk character / android sketches.
I utilized the perspective and lighting built into the initial render to quickly sketch out ideas for her costume. This offers an efficient way to create a character and be creative without having to juggle a bunch of balls like blocking out the underlying anatomy for every concept.
The Sketches might not be the prettiest, but variety is the name of the game with early exploration. I want it to be clean enough that it reads and will convey exactly what I plan on doing with the final to the client, meaning I want hard surface pieces to look like hard surfaces pieces, cloth like cloth and skin to look like skin as a few examples.
After the first wave of initial sketches, completed in grey scale so the client can look at the shapes alone, I utilize the client’s feedback and some inspiration to explore some color options. I really enjoy the color palettes of any cyberpunk universe, whether they are dark and gritty, muted with pops of neon, or an over the top ‘extreme’ aesthetic based in future street fashions and extreme sports.
I explore some refined facial details for the new features in SkinGen inside of CC3. Looking through the features, I saw there is an ability to apply decals or cuts to the skin that I figured would be perfect for the traditional cybernetic cutlines on cyborgs and androids.
I opted for a blend of the two, something with a tactical purpose but something that would stand out. Saying it now, it might sound like a contradiction, but visually I want it to look purposeful but still look sleek and unique.
I quickly blocked out some color, not being too precious with fine details, but opting for more of a graphic read, something the client can quickly look at and give immediate reactions and input to. Once we get the greenlight on the options, or make quick modifications of the presented versions, we are ready to jump back into CC3 and ZBrush!
