Tags
Product
AI Studio
Plug-ins & Tools
AccuRIG
ActorMIXER
AI Render
AI Smart Search
Crowd Sim
Face Tools
GoZ Plus
IAA
LIVE FACE
MetaHuman Live Link
Motion Director
Omniverse Live Sync
Pose Tools
RTX Render
SkinGen
Smart Content Manager
Timecode
UE Control Rig
Video Mocap
Pipeline & Production
3DCoat
3ds Max
Affinity Designer
After Effects
Blender
Cinema 4D
Daz
Houdini
Illustrator
Iray
KitBash3D
Marmoset
Marvelous Designer
Maya
MetaHuman
MetaTailor
Photoshop
PSD Pipeline
QuickMagic
Redshift
Rokoko
Substance Painter
Unity
Unreal Engine
V-Ray
Vector Pipeline
Vicon
ZBrush
Application
3D Scan
AEC
Animation
AR/VR/MR/XR
Cartoon
Comics
Commercial Ads
Films & Movies
Games
Live Performance
Music Videos
Previz
Social Media
Television & Network
Virtual Production
Vtuber
Theme
AI & Deep Learning
Character Animation
Character Creation
Concept Art
Digital Double
Digital Human
Environment & Crowd
Facial Animation
Lip-sync Animation
Metaverse
Motion Capture
Scene Creation
Stylized
Video Compositing
Developer
Certified Trainer
Content
Columnist
AI Studio Storytellers
Garry Pye
WarLord
Creating Simple Audiences with Crowd Sim
The new crowd simulator in iClone is one of the most exciting additions to an application that is already packed with exciting tools and features. Open the tool, drag-and-drop some necessary assets from the Content Manager or an Explore window, generate one-click placement over and over until you like what you see then Deploy Actors and you have a crowd.
As a freelancer, I have worked with several crowd generators and while most of them did a decent job, all of them fell short in one way or another. One was too restrictive in features. Another was like a cyber wrestling match trying to get custom assets imported. You never knew who was going to win that match either.
Other simulators were very complicated and time-consuming or involved prohibitive pricing models affordable only in some cases to high revenue-earning animators. Small shops, a lot of freelancers, and hobbyists were on the outside looking in, wishing they could get their hands on such tools when Reallusion introduced their 8.4 upgrade to iClone with the Crowd Sim tool in the free update.
The Crowd Sim is, like most iClone tools, easy to use with a small learning curve. No nodes, just assets, computer-aided placement, and orientation of those assets with paths, terrains, props, or volumes.
A clear view of the Boxing Match crowd used in the main article graphic. 3D characters upfront with 3D stadium seating and 2D photographic crowd.
Generating multiple, animation-driven characters is a snap with this tool. CC4 can optimize and decimate characters down to as little as 800K for use in the distant background while optimizing mid-range characters at around 7000K.
And yes, you can easily use your custom content. If the content was created outside of the iClone/CC4 environment you can use the auto-rigging features of CC4 to make it compatible with iClone motions and editing.
SEATED AUDIENCE CROWD
For a lot of events like sports, theatre, or movie screenings the audience would be primarily a sitting crowd. Creating a sitting audience is simple but requires a little tweaking depending on the dimensions of the bleachers or seats in use. If, like the one in my example below are not tall enough you can still tweak the position, camera angle or scale of the bleachers if necessary. Not all props like this are created to character scale so you adapt as best you can by tweaking the positioning of the actors after placement or using camera angle to conceal any problems.
STANDING AUDIENCE CROWDS
Standing crowds, particularly at sporting events or concerts can be rowdy crowds at times so I used motions from the Emotes Pack along with characters from the Casual section of the Modern People Sampler in generating the standing crowd. This pack also has multiple material options for more character variations. This produced a lively crowd very quickly. I have found these two packs to be very useful for generating realistic crowds.
You can use custom assets to make a crowd that fits your needs like a futuristic cyberpunk crowd or a period of time like the Victorian age.
SITTING AND STANDING CROWDS
Mixed audiences, standing, and seating, is another crowd type that may require a little tweaking to get the results you want. I started with the sitting crowd made earlier and replaced the sitting motions with standing motions in the popup dialog while using the spacing slider to position the added characters. This can take a little patience until you get something usable and then you can tweak it after the fact if needed.
I tried a NavMesh, but it couldn’t produce one that was usable on that type of bleacher mesh. The NavMesh seems more suited towards solid props without the pipe framing as it could only pick up bits and pieces of the seating surfaces. A solid mesh, blocky bleacher works better. Rescaled stairs can work in a pinch.
ACTOR GROUPS FOR AUDIENCES
Actor Groups are more powerful than you may think. They are a fantastic addition in that you can create your own groups as a Base group and use that base group in creating a Preset with a large actor pool that you can fill with other actors for more variations when you drag in the custom group.
CUSTOM BASE ACTOR GROUP
A custom base group will contain the same character makeup each time we load it which is why it is a base. It can be used in creating a preset that randomizes the group of actors each time it is loaded. Below is loading a simple base group I created for a test.
CUSTOM PRESET ACTOR GROUP
Dragging in or loading a custom Preset Actor Group will trigger a popup menu that allows for control over the randomization of the group actors. As shown in the video below you have the option of using the preset as it is when you drag it in or randomizing the actors even though they will be random each time they are loaded.
LOADING A BASE ACTOR GROUP FOR EDITING
An Actor Group is a project file, and you can build the group over time while saving it to test, use, or come back to later just like a project file.  In my test, I created a bleacher-based crowd of random sitting characters.  Then I saved the custom Actor Group as described in Kai’s video later down in this article. This is simply pressing the save button in the Actor Group Settings popup used when creating the group.
Loading an Actor Group for editing is different. You do not drag and drop the original Preset group into the workspace. Instead, you load the Actor Group via the Actor Group Setting dialog. This will repopulate the scene with actors and props. Don’t be confused, this is the same file that you can drag and drop but you need to load it with the Actor Group Settings popup for editing.
TIP: For Editing purposes load the file you saved using the Actor Group Setting popup menu. Loading the original present Actor Group into the workspace will only load the saved group with no popup window or editing. This is demonstrated in the video below.
Kai has a great tutorial on creating the different custom Actor Groups. This covers how to create a base group and presets and random Actor Groups.
With Actor Groups I can fill a scene quickly. Especially the immediate area in front of the camera.  Depending on the type of group the characters will be different each time I load or drag and drop the custom Actor Group into the scene. Being able to add props like benches and accessories like phones or purses makes for fast deployments of multiple Actor Groups that can breathe life into an otherwise empty scene.
Actor Groups are a powerful addition to iClone that can be as simple as drag and drop or when tweaked they can include custom characters and motions. We can even use Motion Director motions when the need arises.
SUMMARY
Audience-type crowds, sitting, standing, or mixed are simple examples of how to get started with the Crowd Sim tool. They also represent just a small selection of the types of crowds we can now create with this new tool. An audience is as varied as any crowd and the more variation we can throw in the better the crowd will look but, unless it’s Lord of the Rings, it’s not all about how many characters we can stuff into a scene.
It’s really about the proper use of characters in a given area, within the view of the camera. Sell the immediate area to the viewer and the midrange to background elements will fall into place as the viewer’s mind will fill in a lot of information, more implied than seen if properly done.
Animation doesn’t need to mimic real life, but it does need filler. Empty scenes have long been a problem in animation from the early days of cell-animated cartoons to current 3D projects. With iClone’s Crowd Sim tool, those empty scenes can be a thing of the past.
MD McCallum - WarLord
MD McCallum – WarLord
Digital Artist MD “Mike” McCallum, aka WarLord, is a longtime iClone user. Having authored free tutorials for iClone in its early years and selected to write the iClone Beginners Guide from Packt Publishing in 2011, he was fortunate enough to meet and exchange tricks and tips with users from all over the world and loves to share this information with other users. He has authored hundreds of articles on iClone and digital art in general while reviewing some of the most popular software and hardware in the world. He has been published in many of the leading 3D online and print magazines while staying true to his biggest passion, 3D animation. For more information click here.
Related topics
Leave a Reply
Recommended Posts
Discover more from Reallusion Magazine
Subscribe now to keep reading and get access to the full archive.
Continue reading
