首頁 » Page 30
Control Diverse Characters for Live Performances with CTA5.3
Cartoon Animator has just received a free update packed with brand-new features and tools that are going to have you animating like never before. I’m Garry Pye, and I will be taking you on a tour of what’s new in Cartoon Animator 5.3, including the incredible Puppet Stage, where you can control your actors’ body and face movements in real-time with a new trigger system and Motion Live mocap. Now you can activate motions, performances, and effects for your actors with a single button press for real-time animation. This is the perfect tool for live performances and streaming, so you become the actor in your movie.
Cartoon Animator 5.3 now has multiple cameras which you can cycle through in real time, putting you in the director’s chair with total control. And this update introduces image sequencing for character parts like eyes and mouths, meaning you can create the smoothest lip-synching ever, and even create animated face and body parts with amazing results.
Realtime animation Control with Triggers
Besides working with your custom characters, Puppet Stage lets you build your own scenes using characters and backgrounds from the Content Store and Marketplace. With Motion Live, you can capture your own full-body performances and apply it to your actors.
One of the revolutionary features is the use of Triggers, which activate animations including motions, perform actions and more. With Motion Live recording, you can activate these triggers in real time, and your character responds instantly. By pressing the hotkey for each trigger, your actor comes to life. You can even apply Triggers while still capturing your performance with Motion Live and a webcam, so you can perform as your character and even lip-sync them to your voice, all while activating any animation you want.
Customizing Triggers for Unique Performances
Triggers can be fully customized to fit your project needs. You can use preset decks or modify your deck by rearranging, deleting, or adding triggers as required. Each trigger’s parameters can be adjusted to affect different parts of your actor’s face. For example, by disabling the Face Targets, you can still capture facial expressions with a webcam. This allows your character to respond to preset Triggers while also capturing face expressions and lip-syncing simultaneously.
Hotkeys can be set for Triggers, and each Trigger can be configured to play once, loop, or be controlled by mouse movement.
Puppet Stage is ideal for those who want a character to host their videos or live streams. With Puppet Stage, you can embody your character, perform real-time voiceovers, lip sync, and control body movements—all with a single button press using hotkeys. Additionally, you can easily greenscreen your actors over any video.
Compatibility with Various Characters
The best way to introduce yourself to the new Puppet Stage is to load the Klaang character from the Cartoon Puppet Pack, which gives you everything you need to get started including 3 entire new sets of character performances called Chill, Cute and Dramatic. Each of these packs has a number of different Triggers for the face and body which you can activate to change the emotions, expressions and reactions of your characters. And you can apply these packs to any character. Additionally, you can also experience the Anime style live performances from Anime Puppet Pack, which includes the dressing room for changing wardrobes and Pet Bot for 360 head rotation.
>> Get puppet sample projects and actors from here
Here, you can practice working real-time animation with triggers, cameras and Live Motion to get the results you want. Experiment with the different triggers to see what each of them does. You can use these packs as a guide for learning how to build your own custom Puppet Stage packs for any character.
The best thing about the new Puppet Stage for Cartoon Animator is its compatibility with your actors. This is going to work with many of the actors you already own, and then there are hundreds of quality actors available from independent developers in the Content Store and 2D Marketplace. You can take any actor, find the right scene to place them in, set up your deck of triggers, record your character’s performance in real-time and even add in some fun special effects.
>> Sample characters from azbuss, Tivo Studios, and Garry Pye
>> Explore the huge character library from Reallusion Marketplace or Content Store, all CTA characters are compatible with Puppet Stage
Live Perform with Effects and Props
Cartoon Animator 5.3 also has a collection of the most amazing animated effects that you can control using triggers, which have been created by veteran animator Declan Walsh. Declan has contributed a wonderful collection of hand-drawn animated effects that will help your characters express themselves in fun ways. With your actor and props loaded to Stage Mode and with Puppet Stage activated, you can use hotkeys to activate the effects while recording your actors’ performance.
>> Find more VFX from developer DexArt in Reallusion Marketplace
Smoother Animations with Sprite Sequences
Another new feature for the Cartoon Animator 5.3 update is Sprite Sequences which can be applied to actors. In the same way you can create sprite sequences for creating animated props, you can now use Sprite Sequences for body parts like eyes and mouths, so instead of only swapping between single frames, each new sprite selection will play an animated sequence.
With Sprite Sequences, a single mouth movement can be made up of many individual sprites which animate the mouth’s movement, helping to transition between mouth shapes more smoothly and make lip synching more accurate.
You can also use this process to add Sprite Sequences to any face part, including eyes, so you can create some fun emotions and reactions from your actor and you can create all your own animated sequences for every part and even change the speed of the Sprite Sequence in Composer Mode.
Dynamic Camera Tracking
Your cameras now offer a brilliant new feature: they can track and follow actors or objects within a scene, adding a dynamic element to your shots. Camera tracking is simple—just select a camera and lock its focus on your actor or prop. As the actor moves, the camera stays locked onto them, eliminating the need for manual keyframing of camera movements. This innovative tracking capability will transform your storytelling.
Empowering Everyone to Animate
All these new features just add to the incredible lineup of tools we already have in Cartoon Animator. Tools like Spring Bones, Free Form Deformation, SVG Colour Adjustment and Motion Pilot all work together to speed up the animation process and are designed to make real-time animation experience faster, easier and as much fun as possible.
Now anyone can animate. Even if you have no animation experience or any ability to draw, you can be producing quality animations in no time. And you can even do it live! The Cartoon Animator 5.3 update gives you more control over your characters’ performance than ever before, with smoother animation results and advanced camera controls that will have you filming like a pro.
Know more about Garry Pye
Find more Cartoon Animator Assets from Garry Pye
Learn More
Official product page:
2D Animation Software for Cartoon Maker | Cartoon Animator
FREE for 30 days & get 1,700+ ready-made assets:
2D Animation Software Download | Cartoon Animator
Related Posts
The Making of “Skateboard”: Capturing the Dynamic Animation of Skateboarding
This article is featured on befores and afters
The world’s first motion pack that synchronizes human and accessory movements with a single click
Monkey Chow Animation Studios and Motion Capture Orlando, in partnership with Reallusion, presents the groundbreaking “Skateboard – Flatground Skate Tricks” motion pack. Captured at Motion Capture Orlando’s advanced motion-capture studio, this pack showcases professional skateboarding moves. It is the first-ever motion series to be fully integrated with Reallusion’s innovative Smart Accessory animation system, which automatically syncs the skateboard with its animations, eliminating the need for manual matching. Now, adding realistic flatground tricks to character animations is easier than ever!
You can watch this exciting collaboration unfold in the video below!
Master the Streets with “Skateboard” Motion Pack
This motion pack features 26 flatground skateboarding motion capture animations, in the new Motion+ (Motion Plus) format. Ranging from basic moves like Push, Tic Tac, and Ollie, to advanced tricks such as Spin, Flip, and Shove-It. These animations enable the creation of complete and realistic skateboarding scenarios on the street.
Once the skateboarding motion is applied to an iClone character, items with matching tags will automatically attach themselves. The animated accessory design also allows users to easily combine Motion+ animation clips. For example, users can apply, combine, rotate, blend, and trim both human and accessory motions as a single animation, without needing to micro-edit two separate objects.
Behind the Scenes
Monkey Chow Animation Studios is known for having developed a series of Hollywood-style action motion packs that are wildly popular. These include titles like Run for Your Life, Bank Heist, and Riot on ActorCore, the premier online 3D content store featuring Reallusion certified content.
Their latest and most innovative release of “Skateboard” stands out as a groundbreaking project inspired by VFX and mocap artist Nelson Escobar, who recognized the potential of capturing skateboard tricks using modern mo-cap technology. All animations feature American skater and influencer Brian Ortiz, brought to life through high-end optical systems.
A Cutting-Edge Approach to Advanced Motion Capture
Despite the limited cameras needed to cover a skate park, many tricks could be executed on any flat surface, known as Flat Deck Tricks. Armed with his camera, Nelson documented Brian’s splendid array of flat deck tricks. Together, they compiled an impressive list of tricks, which Brian then performed in the studio.
Tracking static props like a gun is easy.  Getting the skateboard ready was another issue.  It’s not like we can link the board to his foot and start shooting.  The board is like another character that has its own motions that are often separated from Brian’s motions. But for this to work, we had to record both the top of the board and its relationship to the movement of the axils or trucks.
Jeff Scheetz, Monkey Chow Productions and Motion Capture Orlando
To address this, the experienced technical professionals of Motion Capture Orlando utilized Vicon Shogun to reverse-engineer a skeleton, or rig, for the computer model of the skateboard.
iClone Smart Accessory System
Synchronizing human motion with accessory animation brings a new level of visual fidelity and data handling. The innovative design workflow for animated accessories unlocks a new frontier of assets with the construction of the Smart Accessory system in iClone. Adapting this workflow, Motion Capture Orlando was able to convert human and object mocap data into a synchronous Motion+ sequence, and simplify further clip connection or animation editing.
Motion+ Syncing with Dynamic Accessories
Having 3D characters hold objects like cell phones or spears is straightforward, but more complex actions—like rolling a suitcase or flipping a skateboard—require coordinated motions and extensive editing to appear realistic. The introduction of iClone Motion+ format has vastly simplified this process.
 Using Motion+ comes with distinct advantages:
  • Full integration of facial performances and metadata for attached accessories, enabling advanced animations such as cycling or skateboarding.
  • Automatic attachment of accessories, randomization of models and materials, and precise alignment of motion and accessories with flexible editing options.
  • Regardless of body type, Smart Accessories can adapt to various body shapes and sizes, properly aligning to their intended positions while retaining structural integrity, whether stiff or form-fitting.
  • Motion+ combines prop and character motion into a single editable file, making it easier to manage complex tasks like pulling a suitcase, pushing a cart, or operating a wheelchair.
Get the Best in Skateboard Animations
Unlock access to 26 dynamic skateboard motions, perfect for standalone use or for blending with other motions using iClone’s robust editing tools. These royalty-free animations are available in FBX and BVH format, ensuring smooth integration with real-time game engines like Unity and Unreal Engine, along with popular 3D software such as 3ds Max, Maya, Blender, and more. Explore “Skateboard – Flatground Skate Tricks” in the Reallusion Content Store and ActorCore.
Related posts
The original article is also featured on befores and afters.
Forbidden Planet Children of the Krell Producer Phil Browne (BiggsTrek)
About Phil Browne (BiggsTrek)
Phil Browne (BiggsTrek) is an old and well-known name in the iClone community. When I say old, I mean all the way back to when we had to tame squirrels to run in cages just to power our computers. Ok, maybe not that old but I have a hard time remembering the early days of iClone without him being around. It wasn’t just being around either, it was inspirational to see his work back in the days when iClone was more toy than the tool it is today.
His work has always pushed the envelope for iClone. He has consistently demonstrated what is possible with iClone and CC4. His smooth style and lack of concern for over-the-top visuals versus a strong story (narrative) are hallmarks of his work. I’m not knocking his visuals either. This man can take community assets from the iClone users Marketplace to build an aesthetically pleasing scene, well laid out and pleasingly lit to a point that you don’t have to squint to see everything.
He can adapt to different genres with his own clean, eye-pleasing personal style that puts his stamp on a production as if he had signed it.
To top it off, he is a non-professional (I hate using amateur as that doesn’t do this animator justice) storyteller, citizen director, hobbyist… whatever term you wish to use, and he is not alone in the iClone userbase. This type of user is essential to the growth and stability of iClone and other Reallusion products. Their support and feedback have shaped these products into what they are today.
One other thing to know about BiggsTrek is that he has a history of following through and finishing projects that include an interesting story and great visuals to move that story along. He proves you don’t need a huge budget or team to produce great animated stories.
It is with great pleasure that I present to you the following questions and answers from the talented iClone community member and digital artist known to many as BiggsTrek aka Phil Browne and I hope that you will take time out from your busy schedule to jump on over and watch the inaugural episode.
The Interview
Q: You are a longtime iClone user. Do you remember when you first discovered iClone and what drew you to it and to stick with it over the years?
I used to use “The Movies” by Lionhead. When TMO (The Movies Online) was about to shut down I started looking for alternate software to do my animated movies. There were a few options at the time, like Moviestorm, but the best and most advanced seemed to be iClone, so I gave it a try. I wasn’t disappointed! I’ve been using it ever since and even though I probably use less than half its full potential, it has served me well.
The Robot and Control Room from Forbidden Planet – Children of the Krell. Click to Play on YouTube.
Q: What do you feel the advantages are of using iClone and/or Character Creator (like ease of use or short learning curve and so forth)?
For me, iClone was fairly easy to use, and more importantly, allowed me to do pretty much anything I wanted regarding animation and storytelling. I’ve tested a few other animation packages over the years, but I always come back to iClone. Character Creator can feel a little daunting to use at times (so many sliders!), but I love the quality of the results, and you can’t argue with that.
Q: Like many of us you use community assets, and you were around early on when there were practically no assets. Do you feel that the community Marketplace has matured into a more diverse market of assets that can serve many needs removing one of the earlier hindrances to iClone production?
I love the Marketplace! These days, it’s the first place I go when looking for a particular asset or even just browsing for inspiration. The quality of props, costumes, etc. has definitely improved over the years. I used to use the 3D Warehouse (was Google, now Trimble) and while that had a diverse range of props, the quality wasn’t that great. The Marketplace has definitely helped fill that gap as it has grown and made available many fine artists and their work.
Q: Some iClone pipeline users turn to 3rd party software like Unreal Engine or Omniverse for more advanced rendering but you have always made the iClone native render work for your productions. Is there a specific reason you like the native renderer and/or do you have any tips to pass along when using iClone as the production renderer?
Making movies isn’t a quick process for me (I tend to tinker a lot), so I try to keep things simple where I can to help offset that. Adding an extra step (3rd party rendering) doesn’t really appeal to me, plus I don’t have a PC that can actually support Unreal at this time. As it is, I’m actually pretty happy with what iClone itself can produce. And I sure hope they keep improving it in the years ahead.
Q: What draws you to animation? Storytelling, animating… both?
I guess it comes down to storytelling, mostly. I like being creative, and animating allows me to do that in a more entertaining way than with just words or images on their own.
Q: As a filmmaker/animator is your work driven more by the visual, narrative, or a bit of both?
Narrative. I certainly like the visuals, but I have to have something more going on than just “pretty pictures”. I remember a time where most people seemed to just make music videos (not that’s there’s anything wrong with that!) but when I made one, I made sure it had a story as well. (For those that are curious, it is “Some Of Us” a song by Ally Miller, created in “The Movies”.)
Haunter of the Dark Made in iClone 4, 2011. Click to Play on YouTube.
Q: When did you start to realize that you had artistic/creative traits?
This goes back to my childhood. Even as a young adult, I used to draw just for fun, and write silly little stories. And now that I’m older it hasn’t changed much, all these years later. Just the means to do it!
Q: Your past work shows an interest in Lovecraft and science fiction with Haunter of the Dark coming to mind and now Forbidden Planet. Are there other genres that you have a fondness for?
My first love is Science Fiction, but a close second is Fantasy. I made a movie a few years ago called “Under The Shards Of Athena” that is mostly Fantasy with a little Sci-Fi. I like mixing genres together. For instance, I’m also working on a Noir movie that has elements of horror, fantasy, and comedy. And who knows what I’ll do after that!
Q: Your iClone production of HP Lovecraft’s Haunter of the Dark hit YouTube in October of 2011 with, as of recently, over 110,000 views and I thought it was one of the best iClone projects to come to fruition, particularly at that time, considering that iClone had not matured into the animation software it is today. Do you remember what version of iClone Haunter was produced with?
Yes, I do indeed. iClone 4. I actually did some tests in iClone 3.5 (that was my first version of iClone – I still have the box on my shelf!), but when iClone 4 was announced, I delayed production until I could get the upgrade. I believe they had several improvements to character creation that I wanted to exploit, and some other new features that I can’t remember offhand. I also remember thinking that I wanted to show people what iClone was capable of; that it was more than just a music video creator. It was challenging, but worth the time and effort.
Q: Can you speculate on what it would be like to produce Haunter with iClone 8 versus the version you used back in 2011?
First and foremost, the characters would look SO much better if created in Character Creator. (The faces and bodies of the old characters could certainly do with a makeover.) And maybe the assets would be better, now that the Marketplace has so much more to offer. I’m pretty sure 90% of the props in the old movie came from the 3D Warehouse and were pretty basic.
From Under the Shards of Athena. Click to Play on YouTube.
Q: Do you have any advice you would give to anyone wanting to get into animation? How to get started?
I’ll pass on something that a friend told me, many years ago: Just do it. (No, it wasn’t Nike!) Even if what you create doesn’t go well, you can always go back and fix it, or try again. But if you never start, then you have nothing.
Q: Why the Forbidden Planet series? What inspired you to produce this?
I’ve always loved the original 1956 movie, and Robby the Robot in particular. When I first started animating, I wanted to make a movie based on it, speculating what may have happened after (the original movie never got a sequel or remake, which is surprising for Hollywood.) But it wasn’t until I got iClone that I saw that it was possible for me to do so. While it took a few years, even making a few test clips with Robby now and then, I’m glad I finally got the story started.
Q: You used AI voices from Eleven Labs if I remember right. I suspect a lot of readers and users will be interested in this aspect as we don’t always have a budget or resources to hire voice actors. How was the learning curve on getting the AI voices to “act” as you wanted them to?
It was remarkably easy, though you do have to play around a bit, and try various voices to find the right fit. The website is simple to use and the results are remarkably good. This film (Forbidden Planet – Children Of The Krell) became a test of the concept to use only artificial voices. I think it worked!
Q: In my case, I learned little things like typing in “eye clone” instead of “iClone” for a proper readback. How long did it take before you were comfortable with using the AI voice interface and getting acceptable results with the AI voice acting?
While some of the voices I used worked well, others did not always pronounce things the way I wanted. In some cases, you can do as you said, basically spell things phonetically (“Bellerophon” was a challenge) but in other cases, I had to use different methods. While most of the voices I created using Text-to-Speech, eleven labs also supports Speech-to-Speech. This is basically a voice changer, but way more advanced. It keeps the performance pretty much intact, but changes the voice dramatically. For instance, I actually voiced the two female roles using this method to get the performances I wanted. While they aren’t perfect, it still worked pretty well (not many people have actually noticed the voices were artificial!)
Q: Was using AI voices the experience you thought it would be? Something you’d readily do again?
It worked better than expected. When I first started playing around with these artificial voices, I figured I’d just use them for a couple of the characters but ended up doing them all this way.
I’ll definitely use it for the rest of the Forbidden Planet series. However, there’s nothing quite like a human that you can explain things to and get a better performance. At least not yet…
Q: What are your future plans for the Forbidden Planet series?
Well, I’m working on Chapter Two right now. Initially, I was going to go back to my Noir film, but as the “Children Of The Krell” has been so well received, I felt I should get stuck into Chapter Two before doing anything else. I have a couple new characters I want to introduce in the next chapters and I’m trying to keep them as diverse as possible, e.g.: the new Chief Engineer and the Captain of the Perseus. I believe the whole story will have between three to five Chapters, depending on how long I make each part. I have the story written down in note form, but I like to change things occasionally, so it’s not set in stone. But the script for Chapter
Two is complete and right now I’m gathering assets and creating the new characters in CC4.
Wish me luck!
MD McCallum - WarLord
MD McCallum – WarLord
Digital Artist MD “Mike” McCallum, aka WarLord, is a longtime iClone user. Having authored free tutorials for iClone in its early years and selected to write the iClone Beginners Guide from Packt Publishing in 2011, he was fortunate enough to meet and exchange tricks and tips with users from all over the world and loves to share this information with other users. He has authored hundreds of articles on iClone and digital art in general while reviewing some of the most popular software and hardware in the world. He has been published in many of the leading 3D online and print magazines while staying true to his biggest passion, 3D animation. For more information click here.
Smart Accessory: Easy Motion Editing and Automatic Accessory Attachment with iClone 8.5
iClone Smart Accessory is a revolutionary system for editing motions and integrating accessories in a streamlined process. Animators can now generate and simulate virtual crowds adorned with unique accessories and props that automatically sync to mocap animations. Handheld objects can also trigger realtime interactions for added dynamism.
MotionPlus – Pairing with Dynamic Accessories
The iClone MotionPlus format seamlessly integrates facial performance and accessory metadata for complex animations like cycling and skateboarding, where precision in motion and accessory alignment is essential. MotionPlus automates accessory attachment, randomizes models and materials, and ensures perfect synchronization between character movement and accessory interaction
  • Auto Load: Once a MotionPlus file is applied to an iClone character, accessories with matching tags will automatically snap to their appropriate positions.
  • Selected or Random: Specific accessory items can be picked when right-dragging a motion file to the actor, or the default accessory can be picked by left-dragging instead. These accessories can be further modified with custom models and materials.
  • Drag-n-Drop Replacement: Applied accessory models can be swapped and still retain their original positions and orientation.
  • Animated Accessories: MotionPlus files can store and sync human motion with accessory animations. This level of synchronization comes in handy for coordinated human-object performances such as biking and skateboarding. Animated accessories also dynamically adapt to the proportion and size of the character.
  • Animation Auto-Alignment: Human and accessory animation can be aligned for motion editing, making it easy to combine, rotate, or trim MotionPlus clips as one congruent animation.
Creating Smart Accessories
The Smart Accessory system offers robust features for creating and customizing accessories. With Motion-Accessory Pairing, animators can assign multiple accessories to specific motions, restoring default accessories or assigning new ones as needed. This flexibility allows for highly personalized animations, where characters can interact with various accessories in a lifelike manner.
Primary tools allow users to customize their own smart accessories:
  • Multiple Placement Points: One accessory item can store several placement points, for instance, a sword can be held with either one hand or both hands, and sheathed at any designated location on the body. Users can select where this accessory is attached while right-dragging it onto a character.
  • Motion-specific Placement: In the Motion-Accessory Pairing pane, the accessory attachment points can be defined for specific MotionPlus files. A motion-accessory relation, like holding a sword with both hands, can be directly stored in the MotionPlus file.
  • Accessory Visibility: MotionPlus supports visibility keys, allowing for quick repositioning of accessories during animation. For instance, the accessory can snap to the hands or relocate to other points on the body.
  • Downloadable Assets (coming soon): A large library of Smart Accessories that is available in ActorCore. These accessories are perfectly paired with motion files with platform-specific download options.
Creating Animated Accessories
The ability to synchronize human motion with accessory animations adds a new layer of realism to animated projects. The Smart Accessory system simplifies this process, allowing for seamless data handling and enhanced visual fidelity.
The several ways to create animated accessories:
  • Handkey Editing: Accessory animations can be produced via keyframes, curve editor, from imported FBX data. VFX made with particles, PopcornFX, material animation, and lighting effects are also supported.
  • Motion Capture: Human and prop mocap data can now be combined into a single, fluid MotionPlus sequence, benefiting teams and studios of all sizes by enabling seamless clip connection and unified animation editing.
  • Physics Simulation – iClone physics simulation is instrumental in creating lifelike accessory dynamics. Calculated rigidbody and soft-cloth animations can be baked into the base animation of a moving accessory and synced to a loaded motion file.
Flexible Motion Controls
One of the most powerful features of the Smart Accessory system is its support for a wide range of motion controls, which are essential for crowd simulation and interactive animations made by Motion Director.
  • ActorGroup – Automated accessory placement allows you to define the types of accessories that different Actor Groups can wear or carry. The distribution of these props can be deliberate, random, or a mix of both.
  • MD Motion Mixer – Mixer motions allow for dynamic blending of upper- and lower-body movement. Now, animation triggers can spawn corresponding accessories for 3D actors to interact with.
  • MD Push-and-Drag – 3D actors can move items around, such as pushing a cart or pulling a wheeled luggage.
  • MD Prop Interaction – Unique MotionPlus animations can be associated with specific MD props, and triggered using customized radial menus.
  • Crowd Gen – By adding MotionPlus files with predefined accessory pairings to ActorGen Motion Pool, large crowds can be effortlessly animated with corresponding accessories, significantly reducing the time and effort for manual prop assignment.
ActorCore Library of 3D Assets
Discover a vast collection of high-quality 3D content in ActorCore. From mocap animations and hand-keyed motion to fully rigged characters, accessories, and props—everything you need to enhance your scenes is in store. Why wait? Take your 3D simulations to the next level with Reallusion’s extensive content library today.
More about iClone 8.5: Prop Interaction
Engaging Environments with Interactive MD Props and Intuitive Controls in iClone 8.5
MD Props is a significant leap forward in virtual actor-environment interactivity. As a new feature designed to complement iClone Crowd SIM, it lets artists breathe life into 3D environments, making simulations more immersive and dynamic than ever before.
Give Life to Props
MD Prop Tools give iClone characters the ability to interact with 3D environments. By replacing the proxy components with custom 3D models, MD props manifest into visceral objects that 3D actors engage with.
All manners of interactive behavior can be generated from just FIVE TEMPLATES representing the core of MD TOOLS.
  1. ACTIONABLE: The most frequently-used interaction type that initiatives a behavior from the interacting actor while responding with an animation of its own.
  2. STATE-SWITCH: Transforms an actor’s animation state from one to another. Each state includes its own idle loop and triggerable animations, such as standing, sitting on a chair, leaning against the wall, or indoor cycling.
  3. BI-DIRECTIONAL: Focuses on scenarios requiring two-point mobility. A common application is for characters to move between two designated locations, such as entering or exiting automatic sliding doors, or traversing a crosswalk.
  4. PORTABLE:  Supports the movement of items from one placement point to another. This includes picking up an object, carrying it around while using it, and placing it back down in the same or different location.
  5. DOLLY: Allows 3D actors to maneuver a cart and drag a wheeled object like a luggage. Once activated, a designated character will approach the dolly prop, grasp its handels, and steer it along a custom path.
Intuitive Radial Menu
MD Prop takes user experience to the next level with its intuitive Radial Menu system. These menus are designed to be easily accessible, launched by a simple mouse-over or click. The radial menus offer a range of interactive options, all of which can be customized with multi-level command groups and assignable hotkeys for quick and efficient access.
This feature also introduces Self Interaction, where a 3D actor can be directed to perform personal actions like using a phone, looking around, or even smoking a cigarette. These actions are not only gender-specific but also adapt to the actor’s profile, ensuring realistic behavior.
Action List & Concurrent Behaviors
Action Lists support the chaining of multiple motions to extend action sequences. When the scene simulation is paused, individual Action Lists can be assigned to every character in the scene. Upon playback, all the appointed characters will move simultaneously according to their own set of instructions.
  • Action List allows animators to chain multiple actions together, creating seamless sequences that can be assigned to individual characters.
  • Concurrent Behaviors When the scene simulation is paused, individual Action Lists can be assigned to every character in the scene. Upon playback, all the appointed characters will move simultaneously according to their own set of instructions.
Prop Customization
Customizing an MD template tool is straightforward: simply replace the proxy objects with a 3D model of your choice. Once the prop appearance is finalized, you can assign new animations or adjust the actor’s associative movements with minimal tweaks. This includes repositioning reach target positions to account for hand placements and varying arm lengths, as well as adjusting the look-at point to focus the character on specific features of the prop.
  • Replace Mesh, Assign Custom Animations
  • Refine Entrance Position, Look-at Point, Reach Point
Object Animation
MD Prop offers robust tools for animating itself. Creators can freely move, rotate, and scale any 3D item, with additional options for object morphing and particle effects. Morph Animator in iClone allows for intricate morph animations, while PopcornFX enables particle effects for added realism. Additionally, texture UVs can be adjusted and scrolled to create dynamic visuals, and video textures can be used to mimic interactive slideshows or film sequences.
Reactive Crowd Behavior
Beyond just triggering interactive behavior from individual actors, the MD Prop system enables autonomous crowd behavior. Crowd characters no longer roam aimlessly; they can now gravitate toward points of interest and even explore various props around the scene. Groups or individuals can find a spot to sit, visit the vending machine, or gather around a busker show—unleashing endless possibilities for dynamic crowd interactions.
  • Simulation Modes – Characters moving along paths or spawning in a zone have a probability of engaging with the surrounding MD props.
  • Following Options – Groups can be instructed to wait on members engaged with MD props before proceeding to their next destination.
  • Random or Initial Occupants – Predefine multiple positions to attract passersby to stop and participate in an activity, or characters can be designated to occupy specific positions right from the start.
  • Enter and Exit Probability – Interaction with MD props can be regulated according to character types and probability scores. Engagement frequency for MD props can be specified. Common settings include random, never, or a finite number of interactions.
Smooth Motion Transitions
iClone “Turn to Stop” and “Multiple Entry” functionality simulate natural human behavior in approaching and engaging with a target prop. This includes slowing to a stop, making a turn, and approaching with measured pace, distance, and orientation. MD props take care of the rest with smooth and natural interactive motions that are tailored to the gender and characteristics of the interfacing actor.
Multi-Platform Export & Render
Exporting these creations is seamless, with iClone Auto Setup plugins available for 3ds Max, Maya, Blender, Unreal Engine, and Unity. Live Link support also allows for synchronization with Unreal Engine and NVIDIA Omniverse, providing a two-way workflow that’s essential for modern animation and game development pipelines.
Learn More about iClone 8.5: Smart Accessory
iClone 8.5 Free Update: SIM Builder with Prop Interaction & Smart Accessory
Digital Twin and Crowd Simulation with Smart Environment Interaction
The automation of animated crowds has been widely used in the movie and entertainment industries. As the demand for digital twin, machine learning, and AI training grows, a new industrial revolution is emerging, particularly in areas like autonomous driving, smart surveillance, factory automation, and intelligent consumer devices.
These fields require cameras not only to see but also to understand the world around them, especially in recognizing human behaviors. To achieve this, there is a growing need for applications that can generate realistic scenarios for camera training purposes, taking into account various angles, lighting conditions, and occlusions. This development is bringing the automation of 3D crowds to a new stage, with a higher level of interaction and realism.
As a leader in 3D character animation, Reallusion has combined its expertise in character generation and automated animation, transforming iClone into a simulation platform. With the latest release of iClone 8.5, users can rapidly build live environments, from crowd simulation to world interaction, with the ability to automatically load and manipulate accessories.
iClone 8.5 New Release
iClone 8.5 introduces two key innovations: World Interaction and the Smart Accessory system. Building on core features like Motion Director and Crowd Sim, these enhancements empower the creation of dynamic environments. In these interactive spaces, 3D characters can explore, operate props, and seamlessly load and manipulate accessories through interactive triggers or motion files.
WORLD INTERACTION >> Click to see the features
MD Props present advanced features designed to complement iClone Crowd SIM, marking a significant leap forward in ways that 3D actors interact with their virtual environments. Learn More
SMART ACCESSORY >> Click to see the features
Smart Accessory is a cutting-edge system that dramatically streamlines the process of editing motions and integrating accessories in animation projects. Learn More
MD Prop Expansion Packs: Indoor & Outdoor Interaction
The indoor and outdoor expansion packs provide numerous ways to showcase the versatility of MD Props. Each prop includes both male and female animation sets, offering unique gender-specific performances. Easily swap the MD Prop placeholders with your custom models or adjust the animations to fit different interactive scenarios.
STAYING AT HOME  >> Click to see the features
The Staying At Home MD Prop pack infuses home settings with cozy, domestic charm, offering 14 interactive props and hundreds of home-inspired animations for male and female characters. Whether it’s lounging on the sofa, watching TV, leafing through a book, flipping light switches, enjoying a meal, or fitting in a home workout, this pack brings the nuances of everyday life to your scenes. Learn More
DOWN THE STREET >> Click to see the features
With 10 masterfully crafted MD Props, street-side interactions can be automated to achieve natural performances every time. Hundreds of trigger animations allow characters to sit, lean against walls or fences, or rest in chairs. Common actions, such as using a vending machine, ordering drinks, smoking, and gathering for street performances, are also seamlessly integrated for realistic behavior.  Learn More
The iClone 8.5 Grand Release is a free update for all iClone 8 owners! New users can download the free trial to experience advanced virtual simulation with intuitive character controls, motion editing, and Smart Accessories.
Resource Links:
Read the Release Notes for the Full Updates of iClone 8.5.
iClone 8.5 Feature Pages:
Prop Interaction
Smart Accessory
MD Props Content Packs:
Staying at Home
Down the Street
How to:
iClone 8.5 Tutorials: MD Prop, Smart Accessory
iClone 8.5 User Manual
Libertas Review: Wilderness Survival Pack for Adventurous Assassins
Erik Larson (Libertas)
Hailing from Chicago, Libertas developed a passion for filmmaking early on. His love for the AAA game Assassin’s Creed led him to create videos about the game, which can be found on his channel, Libertas Video. He also produces a series of Assassin’s Creed-inspired micro-short films, such as “Modern Assassin Training Session”.
Despite his shoestring budget, Libertas enjoys crafting characters and costumes, bringing them to life in his YouTube short films. During the day, he is the Director of 3D of a production house and runs Libertas Video as a solo 3D generalist by night. He enjoys spending his free time creating characters, costumes, and props for his digital actors.
In this article, Erik takes a moment out of his precious time to introduce the “Wilderness Survival Pack”.
Inside the Wilderness Survival 3D Motion Pack
This pack offers 43 animations across four categories: “Explore,” “Hunt,” “Camp and Cook,” and “Idle”. Clearly inspired by survival shows like Naked and Afraid, these animations replicate realistic wilderness scenarios. But can they go beyond their original intent? After a deep dive, the answer is a resounding yes! Here are the several ways we can unlock the full potential of this motion pack.
A Closer Look at Interactive Animations
I appreciate this pack for its interactive animations. Whether it’s paddling a boat, foraging, or chopping wood, the Wilderness Survival Pack showcases detailed hand motions that engage with various props and environments. Given my familiarity with iClone, I can focus on these interaction details, especially how animations adapt to different terrains and objects.
However, some technical challenges may impede our progress. For example, aligning character movements with props often requires constraints and fine-tuning in iClone. To tackle these complexities, I recommend utilizing Reallusion’s Learn Portal, where tutorials offer step-by-step guidance for effective solutions and workarounds.
Crafting Storylines and Adapting 3D Motions
Although the pack is designed for survival scenarios, I adapted it by having my two assassins search for a lost temple. I crafted a narrative that extends beyond the wilderness survival theme by creatively repurposing animations like campfire setups and tracking prey. This demonstrates the pack’s versatility, showing that with a bit of creativity, animators can mold it to fit various storytelling contexts in iClone. Thinking outside the box when evaluating animation packs can lead to discovering new uses—especially where motions are repurposed for different projects.
Enhancing Realism 3D Motion with Facial Animations
Facial expressions are just as crucial in conveying emotions and engaging the audience. To infuse realism into my work, I used iClone’s Face Puppet and Face Key tools to create the basic expressions. I believe these animations could benefit even more from the AccuFACE Mocap. Having tested it before, I achieved impressive results and think it could elevate the emotional depth of the characters.
Overcoming Animation Challenges with Creative Solutions
Despite the overall positive user experience, I still encountered some challenges with specific animations, particularly those involving stream crossing and climbing. I found that these motions, inspired by the survival genre, often appeared too slow or cautious for my needs.
As a solution, I used camera angles and editing techniques to make the movements appear more dynamic and aligned with his characters’ seasoned assassin personas. This approach underscores the importance of creativity in overcoming limitations within pre-made animation packs, allowing animators to tailor the content to their specific storytelling needs.
Final Thoughts: Valuable 3D Motion for Versatile Storytelling
In conclusion, I endorse the Wilderness Survival Pack as a valuable resource for animators, even for projects beyond the survival genre. The pack’s detailed animations, along with its potential for customization and reuse, make it a versatile tool across various storytelling contexts.
When assessing an animation pack, consider not only its immediate applications but also its long-term value across a broader range of creative projects. For those looking to explore the possibilities of this pack, my Libertas Armory models and additional resources are available in the Reallusion Content Store, offering everything animators need to bring their stories to life.
Related Posts
Free Auto Setup for 3DS Max | iClone 8 & Character Creator 4
Most animators are looking for realistic cinematic renders. There is an industry devoted to third-party renderers that will attest to this. Reallusion once again extends the ease of use that comes with iClone to another blockbuster rendering tool that is also packed with many other features and could arguably be considered the granddaddy of 3D apps.
Autodesk’s 3DS Max is one of the most powerful 3D software tools available. It not only provides modeling and sculpting tools, but it also provides powerful animation tools, curve editors, dope sheets and many more professionally oriented tools that have been embraced by major studios and indie studios of all sizes. It has POST features and effects that were not always available from its competitors.
(Click on Image to Enlarge) A magazine mockup using a Sketchfab car model and Character Creator 4 character rendered with Arnold.
“Future Car” (https://skfb.ly/54ihge0) by 3DHaupt is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
3DS Max produces and renders some of the greatest-looking scenes in computer-generated animation with VRay and its built in renderer Arnold. With the right lighting and materials both renderers can produce near photo-realistic results. On the other hand, they can also produce great quality “Pixar” type toon renders.
It seems I have been married to Autodesk products in some form (3D Studio, Max, Maya) since the dawn of time, and it has been a great ride and very fruitful. Learning the software that many triple-A studios adopted afforded income opportunities for its users. 3DS Max is still used for movie and television production to this day which demonstrates its staying power as a modeling and animation application.
(Click on Image to Enlarge) The Sketchfab and Character Creator 4 model in 3DS Max with preset base lighting and the Auto Setup Menu docked to the side.
It only seemed natural to include 3DS Max into the “easy to animate” arena of iClone by producing a free plugin, Auto Setup for 3ds Max, that takes care of one of the most important parts of rendering a character, proper materials, and shaders. It also includes some lighting presets and other features. The importance of proper materials and shaders cannot be overstated as that directly affects how the render will look, particularly realism.
Installation
As usual, Reallusion has made the installation into 3DS Max very simple with a free download that contains a batch file and supporting files that will either install or uninstall the plugin with no other action required. Just a few clicks and you are on your way to using Auto Setup inside 3DS Max.
Go to the webpage to download the version or versions of 3DS Max applicable to your situation.  Unzip the file and click on the installation batch file. It’s that simple.
Auto Setup Import Versus Standard FBX Import
Seeing is believing so let’s take a look at what happens when you import a character FBX directly into 3DS Max versus using the free Auto Setup plugin. In the image below the LEFT-SIDE character was imported into 3DS Max with the Auto Setup plugin. The RIGHT-SIDE character was imported via the standard import menu choice in 3DS Max bypassing the plugin.
As you can see the difference is day and night. I adjusted the skin roughness on the plugin-imported character to take out some shiny areas on the face and hands. This was easy as the plugin provides sliders under different tabs depending on the task you need to accomplish.
Left: Import Via Free Auto Setup. RIGHT: Standard FBX import.
The Auto Setup Menu, Tabs, and Sub-Tabs
The Auto Setup Menu is the heart of the plugin and can be docked or free-floating. As the following menu breakdown shows, it has a LOT of options to help you get that right look and much-improved render.
I will be focusing on the native Arnold renderer as it produces great results without a lot of interaction and comes with the application at no additional cost. Any images rendered using Auto Setup in this article use Arnold which you select in the first tab of the Auto Setup menu.
The plugin interface is self-explanatory as you will see in the following overview. There are a LOT of CHOICES so experimentation is highly recommended and might even help you develop a personal render style for characters. There is also an online manual available.
(Click on the image to enlarge)
This is where you import your CC4 characters into 3DS Max. This is the Import tab, the first tab at the top of the menu.
First, we must choose our renderer which has to be compatible with Auto Setup. This dropdown list is populated by the renderers available to 3DS Max on your system.
In my case, I had only one compatible renderer which was the native Arnold renderer. Even though it is native to the system it is not a second-class renderer by any means.
As mentioned earlier, if you for any reason import a character into 3DS Max via the standard import menu you will not get a nice-looking character as the materials will not match the renderer. This is the big advantage to using the plugin as it sorts all that stuff out for us. Even though Kai’s tutorial said it exported from CC4 I exported from iClone which produces the needed JSON file too.
Now we move the Look Dev tab and the Look Dev sub-tab. This is where the facial body lighting presets are located.
These are one-click presets that can be chosen while the renderer is running depending on the complexity of the scene of course.
There is also a one-click button to remove the lighting solution completely. This includes any props or other items loaded by the preset.
The presets can also be a great starting point as they provide lights that you can duplicate and move around to get that “just right” lighting setup before the final render.
There is also a Macbeth Chart for color matching that can be added and removed with a click.
The HDR sub-tab gives you a choice of four HDR images or you can load your own.
There is also a rotational offset slider and a general strength slider.
If you check Global Exposure, you get access to the Exposure Value slider and the White Balance choices such as Illuminant, Temperature slider, or Custom color.
Illuminant gives you many options like Daylight, Sunlight, Shade, Overcast, Incandescent, fluorescent, and many other choices including Halogen, Xenon, and Sodium among others. As in iClone and Character Creator 4, HDR is an important part of the overall scene lighting scheme and will produce results from dull to vibrant depending on your needs.
Now we are moving over to the Material tab and the Skin sub-tab in particular. All of these sub-tabs are fine-tuning for the overall look of the skin in the render.
Experimentation is encouraged, particularly if you are not familiar with all of the sliders so you can see the visual impact of each one.
Sub Surface Scattering is an important part of gaining realism in the render. Too much and areas of the skin will appear to glow. Too little and the skin will look dull and lifeless depending on the skin color. There is also a Head or Body selector for the second section of this sub-tab. This includes Normal Strength, Roughness, Specular, Micro Normal Tiling, and Micro Normal Strength.
These two panels contain a multitude of advanced sliders that control the Roughness on the left and Sub Surface Scattering (SSS) on the right.
While not exactly glamorous these two sub-tabs show just how much detail you can drill down to for added realism. Both include sliders for further enhancements to the nose, mouth, ears, cheek, forehead, and chin areas.
The wrinkle sub-tab provides pre-defined areas via the dropdown menu:
  • Forehead Lines
  • Frown lines
  • Eyelid Crease
  • Tear Troughs
  • Bunny Lines
  • Crow’s Feet
  • Nasolabial Folds
  • Lip Lines
  • Smile Lines
  • Marionette Lines
  • Pebble Chin
  • Neck Lines
  • Neck Veins
Each selection has a slider for Strength and Rate of Appearance which is the speed in which a wrinkle appears.
According to Kai’s tutorial, the Wrinkle system is independent of the basic texture maps for an additional level of realism. Yet another area for experimentation even if you are familiar with the controls.
These two tabs control the facial expressions from the Face Rig tab (left) or create a custom body rig with the Body Rig tab (right).
Your character must have a facial profile to work with the Facial Rig and you can see this rig is quite extensive. It provided more than enough controls to create custom expressions for your characters inside 3DS Max. The Body Rig tab provides a one-click Biped or CAT rig if you prefer those control rig types.
Summary
I’ll admit to relegating 3DS Max to modeling and simulations since the advent of easier-to-use tools like iClone and Character Creator 4 became available. My 3DS rendering and rigging skills have suffered. With the preset lighting, it didn’t take long for this old Max veteran to start getting great renders. The presets provided a starting point to copy light and reflectors and then reposition them for additional lighting effects to further enhance the renders beyond the presets.
While there is a manual as I stated earlier, I think I only had to look at it briefly a couple of times as Auto Setup for 3DS Max is very easy to use with little to no learning curve like most Reallusion products. The extended facial rigging and ability to switch to Biped or CAT is another plus for Max veterans if that is the rig they are most proficient with.
The plugin is freely available for 3DS Max 2023, 2024 and 2025. Download your copy today!
MAX BEYOND: Transfer iClone Expressions to Unreal Engine
Hasraf ‘HaZ’ Dulull – Filmmaker / Director / Animator
Hasraf ‘HaZ’ Dulull
HaZ started his career in Video games before moving into Visual Effects,  and then later transitioning over to Directing & Producing with his breakout feature film THE BEYOND, the indie sci-fi was released in 2018 and was number 2 in the iTunes Charts before being licensed on Netflix and turning into a profitable movie.
His second feature film – 2036 Origin Unknown, starring Katee Sackhoff (Battlestar Galactica, The Mandalorian) earned a limited Theatrical release before landing on Netflix.  He was then hired by Disney to helm the pilot for action comedy series Fast Layne, where he also served as EP / Creative Consultant on the entire series.
HaZ is the co-founder of production company HaZimation, producing the indie CG animated feature MAX BEYOND. This is a feature made with an array of real-time and virtual production tools, including Character Creator, iClone, ActorCore and Unreal Engine.
“iClone’s intuitive interface and powerful features allow animators to focus on creativity without getting bogged down by technical challenges. By using iClone, we can focus on perfecting the creative aspects of animation, while ensuring that technical elements are seamlessly integrated into Unreal Engine.”
Mastering Animations with Haz Dullul
In the ever-evolving world of digital animation, integrating tools and software to create lifelike characters is a crucial skill. A compelling video tutorial by Haz Dulull showcases how to seamlessly transfer stylized expressions from iClone to Unreal Engine. This detailed guide explains the step-by-step process of importing characters, crafting facial expressions, and refining animations for final rendering. The use of iClone in this workflow demonstrates its powerful capabilities in creating nuanced animations. This article highlights the key steps and insights shared by Haz Dulull, emphasizing the importance of proper setup, organization, and customization.
The Role of iClone in Animation
iClone is a real-time 3D animation software that simplifies the process of character creation, animation, and scene design. It provides animators with a wide array of tools for crafting detailed character animations. Haz Dulull uses iClone to develop stylized expressions, which are then transferred to Unreal Engine for further refinement and rendering.
Importing Characters from iClone to Unreal Engine
Synchronization and Control
The initial step in the animation process involves importing characters from iClone to Unreal Engine. Synchronizing and controlling character expressions manually is crucial for effective animation. Dulull emphasizes the importance of proper setup. He states that “correct synchronization ensures that characters are imported accurately. This allows for precise control over their expressions.”
  • Selecting the Right Avatar: Carefully choose the appropriate avatar from the iClone library. This ensures that the character’s movements and expressions are effectively transferred to Unreal Engine.
  • Manual Expression Control: iClone enables animators to manually control expressions, providing greater customization. This involves keyframing expressions for desired effects within the Unreal Engine sequencer.
Exporting and Importing Settings
Exporting settings play a vital role in transferring animations from iClone to Unreal Engine. Adjusting specific settings, such as unchecking ’embed motion,’ helps streamline the export process. This step is essential for ensuring that animations are correctly imported and functional in Unreal Engine.
  • Understanding FBX Import Options: To maintain compatibility and functionality, users must uncheck the import mesh option. They must also select the correct skeleton during the import process in Unreal Engine.
Organization and Naming Conventions
Importance of Proper Organization
Proper organization and naming conventions are critical when exporting animations for visual effects. This practice ensures that all elements are easily identifiable and linked correctly throughout the project, facilitating smoother collaboration and production.
  • Creating Dedicated Folders: Organizing assets into dedicated folders for each character simplifies management and prevents confusion. This practice is especially important when handling multiple assets in a project.
  • Consistent Naming Conventions: Using consistent naming conventions for files allows for quick identification of specific shots and expressions. This aids in efficient collaboration among team members.
Setting Up Animation Scenes
Loading Levels and Shots
Importing settings and loading scenes are essential components of the animation workflow. Proper organization of levels and shots ensures a smoother process when working on character animations.
  • Loading the Level: Establishing the environment where characters will interact and perform is the first crucial step in animation.
  • Accessing Cinematic Folders: Access the correct cinematic folder related to the level. It contains all the shots necessary for the specific scene being animated.
  • Managing Shot Numbers: Identifying and managing shot numbers accurately prevents confusion. It ensures that the right expressions and animations are applied to characters.
Enhancing Animations for Realism
Adding Details for Expressiveness
Enhancing character animations from iClone to Unreal Engine involves focusing on adjustments like blinking and head movements for realism. This process includes keyframing techniques to add details that improve the final animation quality.
  • Blinking and Eye Movements: Adding detailed animations like blinking enhances character expressiveness. Keyframing different eye positions creates realistic effects that bring characters to life.
  • Head Movements: Animating head movements such as rotation and tilting adds realism to characters. iClone allows animators to keyframe these movements without compromising the original motion capture.
  • Adjusting Eyelines: Realistic character animations require accurate eyeline adjustments. This enables characters to interact authentically with their environment and other characters during scenes.
Rendering the Final Animation
After fine-tuning expressions and movements, the final step is rendering the animation in Unreal Engine. This process brings all the elements together, culminating in a polished and lifelike animation.
Key Takeaways
  • iClone’s Role: iClone plays a pivotal role in creating and transferring stylized expressions to Unreal Engine. This enables animators to craft detailed and expressive animations efficiently.
  • Workflow Efficiency: The integration of iClone and Unreal Engine streamlines the animation process. This allows for greater creativity and precision in character development.
Conclusions
The video by Haz Dulull provides valuable insights into the process of transferring stylized expressions from iClone to Unreal Engine. Dulull emphasizes the importance of proper setup, organization, and customization. He demonstrates how modern animation tools can be effectively integrated to create lifelike and engaging animations. This workflow not only enhances the quality of animations but also empowers animators to push the boundaries of creativity. For those looking to master the art of animation, iClone and Unreal Engine offer a powerful combination. These tools simplify the process while delivering exceptional results.
Related Articles
