首頁 » Page 24
Rig Anything with Your Imagination!
As a kid I was always fascinated with dancing candlesticks, waltzing silverware and other objects brought to life with animation. This was back in the old cell shading days when studios like Disney would animate just about anything to add motion to their cartoons. It was always a little magical to see those objects move with anthropomorphic ease like they were actually alive.
It is a memory that has stuck with me over the years.  There have been many times in the past that I wished there was an easy way to rig non-human or character-based objects using the library of human based, bipedal iClone motions for those newly rigged items.
Character Creator 4 steps up with its ability to easily rig just about anything using bone masking to keep the motions from creating too much distortion.  In the case of animating a candle and holder we can utilize our bipedal motion library with masking to produce great results with little skill on our part.
What Can We Rig?
A recent article I wrote brought this question to the forefront about how I animated certain objects like wooden toy soldiers and Christmas trees to dance. You can also throw in Christmas cookies like gingerbread people and watch them dance to seasonal Christmas tunes.
I also wrote an earlier article back in July about rigging any model with AccuRIG but it did not go into detail about skinning non-bipedal objects. That article mainly delt with bipedal objects and then there is the article I wrote on skinning versus rigging for things like statues that may not have fully defined arms and legs.
The truth is we can do so much more than those articles covered. In fact, we are limited only by our imagination as rigged non-bipedal objects have a lot to add to a scene in the right circumstances.
In the Christmas article, I briefly explained how objects were rigged along with a picture showing masked bones which brought more questions about the process so let’s dig into it a bit deeper with the candle example. Keep in mind that just because it doesn’t have arms and legs doesn’t mean you can rig it with a human skeleton for human (iClone) motions.
Our imagination helped us get here so let’s not shut off the creative tap. A big part of animation is realizing what CAN be animated with your current skillset and tools.
Rigging a Simple Candle
Below I give an example of simple rigging with the option to use or not use the arms and legs via masking. This simple, fast process can turn a static object into an animatable object that works particularly well in cartoons and children’s stories. And don’t forget genres like science fiction where we can easily add a little motion to some props.
Classic Example of Arms and Legs on a Prop
We can use the Disney Lumiere model (Beauty and the Beast) and rig it just as we as did the candle above except with arms this time around. As shown in the image below you can see Disney’s Broom character is an obvious choice for AccuRIG too.
Disney Lumiere and Broom Characters “Lumiere” (https://skfb.ly/pstSM) by ThisIsntAPerson is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
Gingerbread Cookies Dance
I realize it’s not Christmas anymore, but these props serve as practical examples. They are another obvious choice for AccuRIG as some have a bipedal body or in the case of the Christmas Sweater cookie enough of the torso to rig it for the motion library. The first batch is no different than rigging any character. Make note of the Black Masked Bones that lock down that part of the mesh to keep it from moving or distorting. This is optional but can make for smoother movements.
Below are bipedal cookies:
Next up are the not-so-obvious characters like the Sweater, Lollipop and Tree. As you can see these characters rely more heavily on masking to either freeze a limb or a section of bones to limit deformation and make for a smoother animation.
In the above examples, I have masked out some bones on each mesh. The sweater has no functioning pelvis or head while the lollipop only uses the torso section of the skeleton. The tree cookie has a mixture of masked out arms, masked out pelvis but active legs and torso.
The bones that require masking will depend on the model in question and sometimes it can be confusing to new users. The skeleton bones are directionally chained from the Waist down and the Waist up.
Masking can seem to be tricky on your first attempt, but it doesn’t take long to see how it works. Repetition will help bring familiarization with the masking process. It won’t take long for you to grasp how to mask out unwanted bone movement.
Another Classic Example
The Sugar Bowl and Creamer characters from Beauty and the Beast are great examples. I made the objects in 3DS Max then went into Character Creator 4 to skin them as characters. From there over to iClone for composite with the original frame from Beauty and the Beast. I used the AI eraser in Photoshop to remove the original sugar bowl and creamer. I then used an NPR special effect and the Toon Shader.
Pink Alien
This Meshy AI community asset is a great example of an unconventional rig. You may have already guessed that AccuRIG bent over backwards… literally… to rig this four-legged alien using the arms as the back legs which meant I had to correct the hands by pivoting them the opposite direction. It’s not a perfect solution by any means but I hope it will jog those creative juices to show you what can be done with a little imagination.
Example of using the skeleton bent over backwards with the arms working as the back legs. This was achieved by placing the initial markers in the proper locations. The back legs can function as arms if needed.
The walking motion. Not a perfect solution but works for a quick shot that doesn’t linger. It also demonstrates the power of AccuRIG to adapt to unconventional situations.
Correct Pivot Solves a Lot of Problems
One obstacle to rigging non-bipedal objects is a badly off-center pivot or root. This can cause the mesh to jump out of place during the final parts of the rigging process.  Center your character in the screen as best as you can before rigging and set the pivot to the bottom of the mesh. Edit the pivot if necessary to get it properly placed into the center, bottom of the model.
Extend your Existing Motion Library
The big plus is how this rigging opens up our existing motion library to all these newly rigged “characters”. It’s amazing how just a small amount of animation can go a long way. If the torso is all you are animating, then you can use almost any motion that moves the torso. Within minutes you can have a prop rigged and animated with iClone motions.
Mesh Density
This is also a consideration when using a mesh for something other than its intended purpose. There may not be enough mesh density to move without the mesh collapsing. This is more evident in things like elbows and knees on any character. If you find that instead of bending, your mesh is collapsing then you probably won’t be able to use that mesh unless you have another program like ZBrush, Blender or 3DS Max to add more density with subdivision than iClone is capable of.
TIP: If you put together a group of separate parts to form a character such as rocks or pencils, pens and erasers, you don’t have to group them or attach them together. Just export as one object from your software of choice or build it in the CC4 workspace then rig it. No need for attaching or linking beforehand as the rigging process will take care of that.
Summary
As I wrote earlier, we are only constrained by our imagination as to what we can rig and throw into a scene as a main character or filler characters. Cartoons can be fertile ground for his type of wham-bam animation that takes little time and effort but affords a lot of eye candy and movement. This will probably spur more questions but this series of articles on using AccuRIG to extend our motion library to props will hopefully spur your imagination to see what kind of unique characters you can rig and add to your scenes for more engagement.
This is also a great exercise for newbies to pros to experiment with AccuRIG in Character Creator 4 to gain a better understanding of what can be done and just maybe add a little “wow” factor to your next animation.
FYI from From ChatGPT:
Some inanimate objects that Disney animators commonly animate include:
  1. Furniture – Chairs, tables, wardrobes (e.g., Beauty and the Beast).
  2. Kitchenware – Teapots, cups, cutlery (e.g., Beauty and the Beast).
  3. Clocks and Candles – Cogsworth (clock) and Lumière (candelabra) from Beauty and the Beast.
  4. Toys – Woody, Buzz Lightyear, and others from Toy Story.
  5. Vehicles – Lightning McQueen and Mater from Cars.
  6. Tools – Brooms and mops (e.g., Fantasia).
  7. Household Items – Umbrellas (The Little Mermaid), carpets (Aladdin), and lamps (Aladdin).
  8. Musical Instruments – Pianos, violins, and other instruments (e.g., Make Mine Music).
  9. Food Items – Dancing mushrooms (Fantasia) and tacos (Foodfight!).
  10. Books and Papers – Animated spellbooks or maps (e.g., The Sword in the Stone).
Related Posts
MD McCallum - WarLord
MD McCallum – WarLord
Digital Artist MD “Mike” McCallum, aka WarLord, is a longtime iClone user. Having authored free tutorials for iClone in its early years and selected to write the iClone Beginners Guide from Packt Publishing in 2011, he was fortunate enough to meet and exchange tricks and tips with users from all over the world and loves to share this information with other users. He has authored hundreds of articles on iClone and digital art in general while reviewing some of the most popular software and hardware in the world. He has been published in many of the leading 3D online and print magazines while staying true to his biggest passion, 3D animation. For more information click here.
Winner Select: Creating Standout 3D Character with Methodical Artistry
Kurt Boutilier takes second place in the “Best Design Styled” category of the Reallusion 2024 3D Character Contest. He shares insights and techniques on how he brought his award-winning piece, “Avice,” to life by synergizing the strengths of Character Creator, ZBrush, and Substance Painter.
Kurt Boutilier
With over 20 years of experience as a freelance 3D artist, Kurt has worked on a wide range of projects, from video games and toys to 3D-printed miniatures. For the past eight years, his focus has shifted primarily to 3D printing, a medium he considers his “first love”. In addition to his professional work, Kurt regularly participates in art contests, viewing them as valuable opportunities for growth and collaboration within the creative community.
Check Kurt’s artstation
Concept
Avice was inspired by Kurt’s admiration for the strong female characters in The Dragon Prince. Eager to push his boundaries, he embraced the stylized aesthetic, stepping outside his usual approach. “The contest gave me an opportunity to work in a style I don’t often do”, he explains. Her design came together swiftly after the initial thumbnail sketches, with Avice’s bold yet feminine appearance reflecting Kurt’s dedication to infuse a blend of strength and grace into her character.
Creation Process
Kurt began by using Character Creator 4  (CC4) to block out Avice’s base mesh, drastically reducing the time needed compared to sculpting entirely from scratch in ZBrush. He then exported the base mesh to ZBrush, where he focused on refining Avice’s appearance and sculpting her intricate outfit.
With the modeling complete, Kurt used Autodesk Maya to lay out UVs for Avice’s outfit and other elements. He textured the character in Adobe Substance Painter, blending stylized and semi-realistic textures to enrich her design. Finally, Avice was posed and rendered in Maya using Arnold.
Why Character Creator 4
For Kurt, CC4 was invaluable in the early stages of creating Avice. “CC4 allows me to block out the base mesh of a character quickly without having to spend hours building up forms and a silhouette from scratch in ZBrush”, he explains. Beyond initial creation, CC4 also enabled him to pose Avice efficiently, maintaining her strong yet feminine essence.
The integration between CC4 and ZBrush was another highlight for Kurt. “The way I can go from CC4 to ZBrush effortlessly from a base mesh to a finished sculpt is a huge time saver”, he says. Additionally, AccuRIG proved instrumental in refining poses, providing a quick and intuitive solution compared to the time-intensive adjustments in ZBrush.
Overcoming Challenges
The most challenging aspect of the contest for Kurt was posing Avice in a way that balanced her strength and femininity. However, he found that the contest pushed him to grow as an artist, both in terms of trying new styles and improving his skills. “Contests like this help artists of all levels improve and challenge themselves”, he reflects.
Looking Forward
Kurt’s passion for 3D printing continues to fuel his creative ambitions. His next objective is to create a collection of printable miniatures, a long-held idea he’s eager to bring to life. He also plans to explore concept work further, focusing on character design and illustration.
For Kurt, contests like the 2024 Reallusion 3D Character Contest are more than competitions—they’re platforms to connect with fellow artists, experiment with new styles, and push creative boundaries.
Related Posts
Click through to learn more about the winners’ portfolios and judge comments
Winner Select: Virtual Live Capture & Animation for Anthropomorphic “Monkey Band” | Character Creator, iClone, Unreal
Anthony Evans / Digital Puppets UK
Hi, my name is Antony Evans, and I am the co-founder of Digital Puppets, an animation studio based in the United Kingdom. I have worked as a character designer for many years, specializing in real-time animation, and collaborating with studios such as Disney, Warner Bros, and the BBC. In addition to creating real-time performing avatar puppetry, I focus on developing and designing custom characters for clients in a wide range of styles.
My team and I can replicate any existing licensed character or company/product mascot. Our studio not only creates motion capture characters for online entertainers, educators, and marketing/advertising agencies, but we also produce fully animated shows for our clients using the characters we design.
Recently, we completed a 50-episode series for the UK nationwide radio station ‘RADIO X’, where we animated the hosts and transformed their weekly podcast into engaging content for their online audience. We also work with globally recognized broadcasters such as the BBC and Cartoon Network, among others, though many projects remain undisclosed due to NDAs.
Antony Evans’s ArtStation
Concept & Character Creation
Last year, we submitted a clip of “Monkey Band” to the Reallusion 2024 Character Contest and won “Best Mocap Use” in the “Special Awards” category. This contest allowed us to explore new workflows and integrate our existing practices with innovative technologies and techniques. It’s also the inspiration behind this article, where I’ll be sharing the full creation process.
The decision to create the Monkey Band stemmed from our desire to explore fur creation within Character Creator. Additionally, monkey characters provided a unique opportunity to utilize the humanoid base mesh, granting access to the clothing and hair systems. This allowed us to design distinctive outfits and looks for each band member, thereby, enhancing their individuality.
The concept was inspired by our long-standing interest in virtual bands that can perform in real time. To achieve this, we ensured the characters were equipped with detailed facial morphs to maximize performance during live facial capture. The band was specifically designed to enable real-time virtual avatar control for the lead character, allowing us to stream pre-recorded performances seamlessly. You can see an example of this in action here
The characters were developed using a combination of Character Creator 4 (CC4) tools and ZBrush via the GoZ workflow. ZBrush was instrumental in adding intricate details to the base model and in sculpting facial morphs. Its capabilities in creating organic shapes allowed for rapid exploration of different looks, which greatly contributed to giving each band member a unique personality.
While designing the monkey characters, we utilized preset hair cards to create their fur. Specifically, the “Fur Collar” and “Fur Cuffs” presets from the “Stylings” pack in CC4 proved invaluable. By leveraging the Edit Mesh tool, we customized and duplicated these hair cards to achieve a full-body fur effect. For a more in-depth look at the process, you can refer to our video on customizing hair.
iClone Motion LIVE for Facial Animation
When utilizing Live Face for facial capture, it’s important to exaggerate expressions. Overacting ensures that subtle details are captured, as it’s easier to tone down exaggerated expressions during post-processing than to add missing nuances. Additionally, the quality of blend shapes is critical. Take time to review them in the Facial Profile Editor, ensuring they work well, particularly for stylized characters like the monkeys. Modifications to the base mesh for a stylized appearance can sometimes distort blend shapes, so proper setup is essential to achieve high-quality facial capture.
Facial mocap is highly efficient and allows for a quick turnaround. For this animation, I mimed the song while recording the performance using an iPhone and LIVE FACE. Afterward, I reviewed the recording and made adjustments to refine expressions and mouth shapes. Simultaneously, I recorded the audio track and used AccuLips to generate a viseme track.
By blending the viseme track with the expression track, I achieved more natural results. The viseme track ensures accurate mouth shapes for speech, while the expression track adds emotional nuance. This workflow significantly reduced the time required compared to manual facial animation.
iClone for Body Animation
For this project, we utilized the Xsens Link motion capture suit, which delivered highly accurate results with minimal cleanup. Each character’s movements were recorded in single takes, one after the other. The motion data was processed in Xsens MVN software and exported as FBX files. Importing the mocap data into iClone was seamless—simply drag and drop the FBX file onto the character and select the Xsens profile.
The primary cleanup involved aligning the characters’ hands with their musical instruments. For example, refining the hand placement for the keyboard took the most time. Using an actual keyboard during the mocap session would have been beneficial, as physical props provide clear points of contact and improve accuracy in hand positioning.
Here are some Dos and Don’ts when animating body motion in iClone:
DO:
-Exaggerate your movements to ensure the capture conveys dynamic motion.
-Use real-world props to add weight and realism, especially for interactions like playing instruments.
-Allow sufficient space for natural movement during capture.
DON’T:
-Avoid miming contact with imaginary objects; it’s challenging to replicate consistent positioning without real props.
-Don’t neglect refining hand and finger alignment during cleanup, especially for detailed tasks like playing instruments.
Final Render in Unreal
The workflow between iClone and Unreal is highly efficient, especially with the Auto Setup plugin. This tool makes it simple to transfer animations to Unreal while retaining the original look of the characters without the need to recreate materials. For this project, all animations were created in iClone and transferred to a pre-built stage scene in Unreal using Live Link. Once transferred, the remaining steps involved setting up cameras and adjusting the lighting directly in Unreal.
The Unreal Sequencer is intuitive and functions similarly to other timeline tools. One standout feature of iClone’s Live Link is its ability to automatically configure the Sequencer when transferring animations. In this case, transferring animations for four characters was straightforward, as Live Link set up the Sequencer automatically, saving a significant amount of time and effort.
Unreal was selected for its ability to handle large environments seamlessly. While iClone’s renders were great, Unreal’s render offered access to an extensive stage asset complete with pre-configured particle effects and dynamic lighting. This allowed us to effortlessly integrate our animations into the scene, achieving professional-quality results with minimal setup.
Additionally, Unreal’s real-time capabilities made it ideal for a live show setup. By connecting the Xsens suit, we could perform live interactions, such as the lead singer engaging with the audience in real time. This setup also allowed us to trigger pre-animated sequences, like songs, with a single button press, before seamlessly transitioning back to the live performance. Unreal’s real-time triggers enabled one person to orchestrate an entire virtual band performance.
Closing Thoughts
Working on the “Monkey Band” project alongside my brother Scott has been an incredibly rewarding experience. At Digital Puppets UK, we’ve always strived to push the limits of real-time animation and virtual avatars. Using tools like iClone, Character Creator, and Unreal Engine, we’ve been able to create detailed characters and fluid animations with a remarkable level of efficiency. By blending motion capture with real-time performances, we can deliver highly engaging content, transforming simple ideas into polished, professional-quality animations that truly resonate with audiences.
Looking back at projects like animating RADIO X’s podcast and working with major broadcasters like the BBC and Cartoon Network, it’s clear how far we’ve come. Each step of our workflow—from character design to live performance capture—has been meticulously refined to ensure we’re always delivering the best. The “Monkey Band” project, in particular, showcases how we can seamlessly integrate these powerful tools to bring a virtual band to life. It’s exciting to see how these innovations are shaping the future of virtual production, and we’re proud to be part of that journey.
As we reach the conclusion of this article, I can’t think of a better way to wrap things up than by offering you some more Monkey Band for your entertainment:
Related Posts
Elvis gives a textbook-level acting performance in facial animation with iClone LIVE Face Mocap.
Winner Select: Hybrid 3D Animation feat. Markerless Mocap and Facial Capture | Rokoko, Move.ai, iClone
Elvis Deane
Hi, I’m Elvis Deane, a seasoned digital event and video producer. I take pride in my ability to communicate clearly with clients and my proficiency with a wide range of production tools. My educational background in visual effects coordination, virtual production, and creative arts has provided me with a strong foundation in both traditional and cutting-edge industry techniques. After graduating in 1999 from one of Toronto’s first 3D college programs, I chose not to pursue a full-time career in animation. Instead, it became a hobby of mine alongside my work in video production, making me a long-time 3D enthusiast.
The character I selected for the 2024 Reallusion 3D Character Contest is one I’ve been developing since 2001. Drawing inspiration from my love for Samurai Jack and Star Wars, I created Griff as the protagonist of a series of silent short animated action films. His backstory revolves around a pilot on the run from a powerful, evil military. However, I soon realized that completing the entire project alone was too ambitious. Instead, I pivoted and created a comic that tells part of his story.
Elvis’ ArtStation
Character Design in Character Creator
Every few years, I revisit the character and model new versions based on the software I’m using at the time. In 2020, I tried a demo of Character Creator and created a version of Griff to test the program. Since then, the character has undergone three revisions, and I’ve finally settled on a more cartoony, stylized version for the 2024 Reallusion 3D Character Contest.
I didn’t use any reference material when stylizing Griff; instead, I drew from intuition. Given that he’s a tall and thin character, I wanted to exaggerate those traits in his face. I opted for realistic textures while keeping his features cartoonish to create a strong contrast, allowing me to apply realistic props and set pieces.
Versatility of AI-based mocap
As part of my setup for mocap, I make sure to have a few hours of uninterrupted time when nobody will disturb me. I also mark boundaries at the edges of the camera’s frame to prevent moving off-screen and losing tracking data. This is vital because I use AI-based mocap with Move.ai, and processing happens only after recording. If there’s an issue, I won’t know until about half an hour later, when the data is finally processed and I can preview the motion.
By using an AI-based mocap solution, I’m not required to wear a marker suit. Instead, I typically wear something comfortable and flexible, while clipping on a lavalier microphone to capture high-quality audio. I prefer recording facial motion capture simultaneously with the body performance, as it enhances the realism of the final result.
In the past, I recorded body and facial capture separately, but this caused a loss of subtle details, particularly in eye and head movements. This project marked the first time I used the Rokoko Headrig, designed to hold a phone. Previously, I built my own facial capture rig using an airsoft helmet and GoPro mounts. While it worked, the helmet was heavy and shook during fast movements. In contrast, the Headrig is lightweight and pairs well with an iPhone for Live Face. I also like to mount a light on the helmet when possible, ensuring my face stays lit even if I turn away from the light source.
Facial Animation in iClone
Live Face is really a dream app. It gets a very accurate version of my performance, and the more recent addition of denoising is amazing for taking out any small jitters. Once I have the data inside iClone, I also like to use AccuLips with the audio recording of my performance to get a more accurate lipsync. One of my favorite parts of AccLips is the Talking Style Editor, which lets you break down an audio clip into different sections and apply different styles of talking. For this animation, Griff is pretty loud, so I used the Bellowing setting for most of the monologue.
For the body mocap, I used MoveOne, which is an iPhone app that records a video and then sends it to the cloud to process the movement into an FBX file. Even though it only sees the movement from one angle, it does a very good job at capturing my overall movement.
Having the mocap as a basis to start my animation is very helpful. I like to take that performance and exaggerate certain things as necessary.  Sometimes the eyebrows and eyes need bigger movements at times to emphasize a point in the dialogue.
Character Animation in iClone
The thing I love about iClone is how many tools there are to adjust and tweak a motion capture performance.  I did two full takes of the monologue but preferred the start of the second take and the end of the first take. It was very easy to line them up in iClone and blend them so that it became one seamless performance.  I also really appreciate the curve editor. As good as MoveOne is, it often has a lot of small jitters in the motion capture data which can make the character look shaky. I also like to use different motion layers when I’m working so that I can add new animation to the character without affecting what I tried before.
Final Render and Composition
For the final renders, I chose to use Unreal Engine, starting with LiveLink to transfer my characters from iClone. Sticking to my preferred method, I built a rough set using boxes and cylinders to get a general sense of camera movement. Once I was satisfied with the layout, I recorded a take of the LiveLink from iClone and began refining the set before focusing on lighting.
It usually takes me a day or two to finalize the look and composition, but for my contest entry, I managed it in about a day since I started the animation late and was running out of time. I’ve learned to delete all my lighting and start fresh if something doesn’t feel right—sometimes a blank slate is more effective than trying to fix what’s not working.
Benefits of iClone
Though I almost talked myself out of participating, I’m incredibly thankful I entered the Reallusion contest. It provided a challenge and a deadline that pushed me to complete the animation, forcing me to think deeply about new directions for the character that I hadn’t explored before. Griff had always worn a jacket, but for fun, I decided to dress him in a hockey jersey instead. His character had always been a bit serious, and this contest gave me the opportunity to experiment with a different look. I’m hoping this fresh energy will translate into the film I’m currently working on.
Art contests are a great way to push yourself out of your comfort zone and spark fresh ideas. For years, I avoided creating 3D work because the technical demands of building and rigging multiple characters were so time-consuming, sapping my energy for animation. Since I started using iClone, I’ve taken on many more creative projects. I can use motion capture for a base performance, but iClone also offers excellent tools if I prefer to animate by hand.
iClone is especially beneficial for indie or solo creators. It simplifies the technical aspects of 3D that I’ve always struggled with, allowing me to focus entirely on animation. I no longer have to fight with rigging or clothing, and there are plenty of tools for scaling up a project, adding crowds, or creating complex interactions in scenes. Another advantage is its integration with other software. The new CC Control Rig in Unreal Engine lets you make adjustments after exporting, adding elements like squash and stretch to enhance your animation.
Closing thoughts
Participating in this contest not only reignited my passion for my character, Griff, but also opened my eyes to the possibilities of blending creativity with cutting-edge tools. It’s been an invaluable experience, pushing me to step outside my usual workflow and explore new ways of bringing my characters to life. The process of combining motion capture, hand animation, and powerful software like iClone has made a significant difference in how I approach animation. For anyone working solo or on smaller teams, iClone’s user-friendly features are a game-changer, enabling more focus on the creative aspects without getting bogged down by technical challenges. The journey continues, and I’m excited to see where this hybrid approach takes me in future projects.
Related Posts
Beginner Guide to AccuPOSE
When I first got into animation, I remembered early on that some of the hardest animations to keyframe and sell the audience on were everyday motions. Something as simple as picking up or putting down a drink on a counter took hundreds or thousands of keyframes from limbs down to finger joints. It took days, not hours unless you had a lot of experience and back then, no one had a lot of experience as practical and effective 3D animation was something new.
Shaking hands, forget about it. Things like that just weren’t done back then. They were intentionally left out of the storyboard due to being financially and deadline impractical. It took a long time to animate any movement. In some applications, every bone or joint had to be moved until some form of linking or IK was introduced and even then, it was basic and simplistic with a lot of adjustments.
Some of you know that I hate tedious tasks and to be honest, I’ve never met anyone that really embraced it either. It did not take long to realize that this cool thing known as 3D Animation was going to, possibly, become the most tedious work a person could do.
Imagine populating a battlefield with low poly proxies before multi-duplicate or scatter existed. Sure, we could cut, paste, and drag each item to a location but what if there were 500 to 1000 items? Even this was preferable to keyframing a motion like smoking a cigarette in a camera closeup. This could take thousands of keyframes until it was done and at the end… the creative spark was dead, cold, and buried.
AI-Aided Animation
We move on down the timeline of life a few decades and Reallusion brings us AccuPOSE. AI-aided sweetness that does so much of the hard work of everyday motions that I have LOOKED for scenarios to experiment with. Generally, I would have avoided such work, when possible, but AccuPOSE has flipped the script for me by opening up more opportunities to enrich a scene with detailed movements and motions I might never keyframe and curve on my own.
What’s the big deal? Well, I’m an animator not an AI expert but it basically marries AI-assisted posing with automatic keyframing for lack of a better term. All we have to do is lock down certain parts of the character we don’t want to move, then go down the timeline and make our changes by simply moving the character into place. AI makes sure everything else follows in a natural way.
Core Library
A library of AI-Assisted motion is provided with the plugin. From the Reallusion website:
The Core Library is available for free to all iClone members, providing a hands-on experience of how AccuPOSE responds to fundamental human body movements. Explore natural actions like standing, sitting, squatting, kneeling, lying down, crawling, rolling, and even performing a handstand.
All of the examples used in this article use the free Core library.
Installing the Plugin
The plugin is very easy to install via Reallusion Hub. If you don’t see it there then refresh the Hub and you should see it under iClone plugins. Just press the install button to continue and the plug in along with the Core library are installed.
We can invoke AccuPOSE by selecting a character and pressing the “9” key or press the AccuPOSE button on the upper toolbar, or we can also go to the plugins menu and select it from there but the fastest for me is the “9” key. The AccuPOSE menu does not appear to be dockable but is instead a floating window.
Pose to Pose
This technique has been around for a long time, or at least of long as we’ve been able to “tween” the frames between the manual keyframes. This is a feature of most modern animation software and a norm in the industry. Computer aided tweening was instrumental in making computer animation feasible in the first place.
I’ve taught pose to pose techniques in tutorials years ago as it is a great way for beginners to get some animation time under their belts. Back then there was still a lot of cleanup and manual keyframing, but IK reduced some of the load. Now the AI-assisted AccuPOSE plugin makes sure that limbs follow in a natural progression without twisting or contorting unless that is what you want it to do.
With the old method we had to move everything down to fingers and toes in some cases, with curves, but now we just grab a character, start AccuPOSE, load a pose, set the alignment, move down the timeline to the next pose and load it.
For example, using the Core Library, I’ll load Kevin into the workspace, select him and press F9 to load AccuPOSE. I want Kevin to stand with his arms crossed then sit down and naturally put his hands on his lap.
  1. For this I started off by loading the Cross Arms pose in frame one.
  2. From here I clicked the Pose Alignment button and set it up to align to the Right foot of the Previous Keyframe. This keeps the character from sliding around between the roots of the different pose motions. In this case Kevin sat down instead of sliding back or forth to sit down.
    How far apart you place the keyframes determines the speed of the sitting down motion. You can change the speed by editing the motion shortening or lengthening the distance between keyframes.
  3. Move down the timeline and select another sitting or standing pose. From here is just a repetition of the same steps going between poses and keyframes.
Be sure to pay attention to the Align Pose settings as the default Root setting will make the character slide back and forth between root locations. In the example below Align to Right Foot kept the character in place as needed.
With this method all we have to do is choose our poses and how many frames apart they need to be as the AI makes sure the character moves according to our choices.
Demonstrating basic AccuPOSE usage and the importance of Alignment
Control Points
Control Points are a bit more complicated than simple Pose to Pose but you can dive right in anyway.  With Control Points we need to remember every Control Point activated is one less limb the AI is positioning and one more that we will have to position. We will also have to lock certain control points when needed to keep a foot or hand in place as one example.
Controls points allow us to decide what happens, where that limb will go without interference from the AI. When we set up control points, we tell AI to guide everything that is NOT a control point as we will take care of that movement ourselves.
The second tab of the AccuPOSE interface is the Control Panel that gives us access to several shortcuts like selecting only the Hip and Feet or just the Hip. We can transform, rotate or lock as needed.
This is where we can set a pose then lock, unlock, move or rotate limbs into our desired positions on the next keyframe down the timeline. This can be tricky at first but the more you do it the easier it gets. There can be a lot of locking and unlocking for some poses but not every pose. Once you get a little Control Point time under your belt, you’ll quickly learn how to handle most situations.
Kai’s tutorial below goes into detail about how to use control points and locks.
If you are a beginner, you might consider skipping control points in the early stages of learning the plugin. At least until you understand exactly what is going on with the plugin as the wrong combination can start to create unexpected results. Unlike the Pose to Pose method described earlier, the use of Control Points and Locks requires a fundamental understanding of the plugin. On the other hand, you won’t learn what you don’t try so don’t avoid it by any means. Just get a handle on AI assisted Pose to Pose first.
No Curve Editor Needed
I’m not saying the curve editor couldn’t improve things, but beginners rarely use a curve editor so the smooth tweening means little if any need for editing any curves. This leaves us plenty of time to work on all that other stuff we are learning about as new animators.
Summary
The Core library is extensive with over 40 AI assisted poses that kick your animations up a notch. No more writing around the “hard to animate” motions when the Core library provides so many poses that can translate to many different scenarios.
It’s not just for beginners either as seasoned pros can speed up their workflow while making it more enjoyable by eliminating a lot of the tedious animation work leaving room to be much more creative.
Never before has it been easier to animate everyday motions for just about any animator from beginner to pro. This is just another tool in the amazingly large toolbox of animation tools within iClone.
Manual
Reallusion Courses
AccuPose – Three Tutorials
Melis Caner: Turning myself into game character with Headshot 2
Becoming a Game Character using Headshot and Polycam | Unreal Engine
Author: Melis Caner
Melis Caner
Hi, I’m Melis Caner, a 3D Generalist and filmmaker with a Film degree from Dokuz Eylul University. After graduating with a focus on cinematography, editing, and sound design, I discovered 3D animation during the pandemic that followed. Amazed by its limitless creative possibilities, what began as a hobby quickly became my career and a new form of self-expression. My lifelong love for drawing, dancing, and acting now comes together in 3D animation, blending all my passions into one art form.
Melis Caner | LinkedIn / Melniverse | Instagram
Making Game-Ready Characters from 3D Scans
In this article, I’ll guide you through the workflow of transforming a 3D scan into a fully game-ready character using Polycam and Reallusion Headshot 2. From scanning to exporting, it covers the entire process, along with tips for effective character creation.
3D Scanning with Polycam
Polycam is a powerful app for capturing real-world objects in 3D. Using just a smartphone, it can effortlessly create high-quality, detailed scans. For this project, I started with a head scan.
For a clean scan, even lighting is essential. Cloudy weather offers naturally diffused light, making it ideal. Take plenty of photos from the neck to the top of the head, ensuring all angles are covered. Scanning the back of the head is less critical, as details are scant and errors can be easily remedied.
After exporting GLTF or OBJ from Polycam, bring it into a 3D software to clean up the mesh. Smooth the rough surface and delete the unnecessary parts and merge the mesh by distance.
Processing the Scan with Headshot 2
Reallusion’s Headshot 2 Plugin is a great tool for converting 3D scans into digital characters. The following are the steps I used:
  1. Import the cleaned OBJ file of the 3D scan into Character Creator (CC).
  2. Click on “Start Head Generation” and then “Auto Detection”.
  3. Align the points according to the model. You can also increase the number of the points for more detail.
  4. Proceed to the second step for “Head Gen” and pick the suitable effective area for your model. I personally recommend choosing the face, as it usually works the best for me.
  5. Refine the mesh by sculpting on the model and make sure it is the right shape according to the original head scan.
  6. Use the “Mask” feature in Headshot 2 to refine areas like the eyes and mouth and fix broken areas. Choose the mask that works best for your character.
Accessorizing & Adding Personality before Unreal Engine Export
Once the base head model is ready, select the appropriate skin type and enhance it with clothing and accessories from your CC content library. I typically choose hair and other items that align with the character’s story and style. If the right assets aren’t immediately available, don’t worry—you can easily import custom clothing and accessories into your CC library.
Using the Character in a Unreal Engine
  1. Export the clothed character in FBX format, selecting the “Unreal” preset as the target application.
  2. Choose “Mesh” or “Mesh and Motion” if animations are included. Adjust the texture size if necessary.
  3. Delete hidden faces to reduce the overall polycount.
  4. Use the Auto Setup plugin for Unreal Engine to import the character efficiently into the engine.
The final step involves exporting the character to a game engine for real-time use. Reallusion provides the Auto Setup plugin for Unreal Engine to streamline this process. Integrating the character into the engine was a straightforward process:
Special thanks: The project was made possible with the help from other! Game Demo by Byron Qiao.
Conclusion
Converting a 3D scan into a game-ready character blends artistry with technology in a rewarding way. Tools such as Polycam and Reallusion Headshot 2 make the process accessible to artists of all skill levels. This workflow empowers indie developers, digital storytellers, and creatives to infuse real-world authenticity into their projects.
Check out my video for a quick breakdown of this process
Related Posts
Bringing The Soldier to Life with iClone
A Trailblazing Career in Animation and Production
Dom Fred – Director / Producer / Editor / 3D Animator
Dom Fred – 3D Maya Animator
Dom Fred, a veteran in the television advertising industry, has continually pushed the boundaries of animation and production using cutting-edge tools. His mastery of Autodesk Maya, combined with two decades of experience, has earned him acclaim in commercials, music videos, and documentaries worldwide.
At the helm of DOM ANIMATION STUDIO, Fred specializes in integrating 3D characters with real environments, leveraging special effects (SFX) to create dynamic martial arts and acrobatic action sequences.
In his latest project, The Soldier, Fred demonstrates how iClone enhances his animation process.
A New Era of Production with iClone
In The Soldier, Fred’s primary objective was to establish a robust workflow that blends technical precision with creative storytelling. By adopting tools such as iClone, Unreal Engine, and Character Creator, he navigates seamlessly between software, enabling innovative production techniques.
“In The Soldier, the goal was to set up a solid workflow with technical mastery, both for the preview of each scene and its execution. With new production methods, tools like iClone and Character Creator allow us to design detailed characters and refine scenes with greater efficiency.”
Highlighting Realistic Action
The action sequences in The Soldier are a testament to Fred’s expertise in choreographing martial arts and acrobatics. He treats these scenes as if they were live-action productions, carefully orchestrating every movement and angle.
“Here, we have several action scenes where I wanted to highlight all the techniques and production methods involved in shooting a real live-action scene,” Fred notes. This approach bridges the gap between animation and reality, delivering visually compelling results that resonate with audiences.
Fine-Tuning Shots with iClone
Once the fight sequences are complete, Fred transitions to iClone to finalize the visual narrative. This stage is critical for defining camera shots and angles, ensuring the scenes align with his creative vision.
“After completing the fight scenes, I send the animations to iClone to define the camera shots. This step allows me to achieve the real feeling I want to convey on screen,” Fred elaborates.
iClone’s user-friendly interface and real-time preview capabilities enable precise adjustments, saving time and enhancing the production’s overall quality.
Redefining Animation with Innovative Tools
Fred’s adoption of iClone and its companion tools exemplifies the potential of modern animation technologies. By incorporating these tools into his workflow, he achieves a level of realism and efficiency that traditional methods often cannot match.
His work on The Soldier not only showcases the technical and creative possibilities of tools like iClone but also inspires other animators to explore new horizons in storytelling.
Dom Fred’s dedication to advancing animation techniques reflects his passion for blending art with technology. As he continues to innovate, projects like The Soldier serve as benchmarks for what’s possible in the ever-evolving world of 3D animation.
Follow Dom Fred
Website:
https://www.domfredfilm.com/accueil
LinkedIn:
https://www.linkedin.com/in/dom-fred-films-81904194/
YouTube:
https://www.youtube.com/channel/UCaEVZPzkWUsg9Wti9Cao4Vw
Facebook:
https://www.facebook.com/profile.php?id=100063571358642
Vimeo:
https://vimeo.com/spaceagentsmysteriousax/videos
Related Posts
Getting to Know AI Smart Search
Have you ever been looking for a specific content item for an animation project, but you just can’t find it? The right character or background, or maybe a unique prop? And you’ve spent hours scouring the 2D Marketplace but you just can’t find what you’re looking for.
With the new Keyword Search and Deep Search tools, you can now find the right item for your project instantly right here in Cartoon Animator. And who knows, maybe you’ll even be inspired by a few items you didn’t even think of!
Let’s go to the AI SMART Search page to learn more about these two amazing tools.
Difference between Deep Search and Smart Search
The new KEYWORD SEARCH tools allow you to simply type in a product name, keywords, descriptions, authors, or search through related items of what you’re looking for.
The new DEEP SEARCH tools bring intuitive search functions with category-based filtering. You can type using natural description in any language and even drag in thumbnail images for visual recognition to get matching results straight away, without ever having to leave Cartoon Animator.
Making a project using AI Smart Search
The best way to demonstrate how practical and how much fun the new AI SMART SEARCH tools are, is to create an actual scene, and see how it can help us find all the elements we want to use. Lets say I want to set up a scene of a backyard barbecue, complete with background, actors, props and some animated effects. Lets see how we can use any of the SMART SEARCH tools to find everything we need.
Set up a scene
The first thing we’re going to need is the actual background scene of a backyard, where we can host our barbecue. Starting with DEEP SEARCH we can type in the word Backyard and see what results that gives us.
This search will give results of all different backyards created by a variety of developers. One thing to take into consideration is that you will get much better results if you use natural language prompts and include more descriptive adjectives to specify the content you are looking for. For example: instead of just typing Backyard, use more descriptive language like “ Summer House Backyard” or “Fenced Area backyard”.
The DEEP SEARCH has bought up a selection of Packs related to backyards. Under the Pack tab there are many different results for backyards, meaning you don’t have to dig through hundreds of different unrelated packs to find what you need for your project.
DEEP SEARCH provides only the results that are relevant to your search, saving you valuable time. You also have the option to search by Item, which will bring up individual items for your search.  The great thing here is that you are going to get results from all the Cartoon Animator developers, meaning you might stumble across a hidden gem or two.
In the Item Search window, you can see the backyard scene which is available in the Marketplace. To take a closer look you can toggle your view to be Extra Large Thumbnails. Right-click the thumbnail and select View Product Page to be taken to the Marketplace page where you can purchase the pack. You can also filter where you get my content from, including the Content Store, Marketplace and ActorCore.
The product page provides all relevant information about this pack, the price and who the developer is so you can follow their work. Once the pack is purchased, it will install automatically to your Content Manager, ready to use.
This DEEP SEARCH has suggested some other packs as well, created by multiple content developers, which may give inspiration and suggest other items which can be used.
Since this scene is going to be a backyard barbecue, we will need a barbecue. Under the Search Item tab, you could just type in a keyword BBQ for a selection of content items based on that text prompt.
However, should you require a specific style of barbecue, a quick Google search returns a variety of options, and for this example we will choose the red kettle barbecue.
Simply drag and drop a photo directly from your browser and then DEEP SEARCH will track down content that best matches the image. If searching items in the Marketplace or Content Store, you can drag an drop images directly into the Smart Search UI. You can also exclude image searches you don’t need. Now that we have the barbecue, double-click the thumbnail to view the product page.
As well as being able to search by keywords and images, If you particularly like an author, you now can start to try  KEYWORD SEARCH to search by Author. So if you have a favourite content developer you follow, you can type in their name and find their content fast.
The backyard scene and barbecue used in this example were created by the developer Garry Pye, and if we want the look of the rest of our scene elements to match, we can include his name into the search to find other content packs and items created by the same developer and give our scene a consistent look.
Sometimes you can successfully mix and match content from different developers, to keep the same style and look consistent, it can be beneficial to stick to one developer.
But for this example, let’s first look for some content created by other developers. A search for the developer Parramon brings up a variety of content, including a tree that we want to add to our scene. By double clicking on the item it will automatically download to your Content Manager. Some content will offer a trial version, so you can test it out in your project by just dragging it into your project. Use of trial content will result in a watermark being overlaid on your project until you either purchase the content or remove the trial content.
Using the DEEP SEARCH tool we now have our backyard scene set up. And SMART SEARCH makes it so easy to find everything we need to build great projects. For now, let’s remove the trial content in order to retain a consistent look in our art style.
Add a character
It’s time to add a character to our scene. Using the name of the developer in the search field so we keep a consistent look, we can type in ‘Cartoon Man’. In the left hand column you can select the actor tab to only get search results of actors. Should the character be from a particular series you remember, you can type that series name in, to focus your search further.
Once you settle on the right character for your scene, double-click him to be taken to the page in the Marketplace or Content Store to make a purchase and download him to Cartoon Animator. But now he’s going to need something to cook on that barbecue. A search for food packs will provide results and you can use Deep Search Similar to find other related items to fit the scene.
A new Prop Search for ‘BBQ Food Meals’ and see what that gives us. Again, being a little more descriptive with the text never hurts!
As the steak cooks on the barbecue, you’ll want to add some animated smoke drifting up from the hotplate. Use KEYWORD SEARCH and the keywords smoke and backyard and you’ll find many different developers packs suggested.
Once you find the right prop, double-click the pack to go to the Marketplace page to see the contents of this pack. You may find a Youtube video to click on and see the animated props in action. Purchase the pack and download it to your Content Manager. Now simply drag and drop the animated smoke prop into Stage Mode and to get your steak cooking away nicely.
There’s one more thing AI SMART SEARCH can help with for this example project. We need to get this guy cooking! And the fastest way to do that is by using a pre-made cooking motion. Don’t forget, if you want to search motions, they are only supported in KEYWORD SEARCH for now. In the KEYWORD SEARCH menu, select the Animation tab and search for ‘Cooking.’ Instantly we get all the results of premade motions for cooking and right there at the start is the perfect animation we can apply to our barbecue chef to finish our animation.
Now you know how to use KEYWORD SEARCH and DEEP SEARCH to find everything you need for your next project. With this new feature, you are going to be able to build any scene you can imagine!
Tips for content developers
If you are a content developer for Cartoon Animator, the new SMART SEARCH function right here in Cartoon Animator offers a great opportunity for users to find your creations. DEEP SEARCH relies on visual recognition, so your thumbnail design is crucial. KEYWORD SEARCH is the only way to find motions, or search by author, and it finds your assets based on names, descriptions and tags, making it essential to have a good product name with clear descriptions containing keywords. Now, potential customers don’t need to know who you are to discover your content! They can text or image search for specific characters, scenes, or props directly in Cartoon Animator, and your content will appear.
To let your assets be easily searched for by SMART SEARCH, please go to the Developer Center, scroll down and  check the Smart Search Guidelines for more details on how to optimize their assets for maximum exposure.
Keyword Search and Deep Search are just two great new tools that are going to speed up your productivity and make your animation experience more fun than ever before.
Related Posts
Love is a Championship (LIAC) is a film project directed by seasoned 3D and VFX artist Geoff Hecht. This project is powered by Reallusion's Character Creator and iClone, bringing together over 30 artists from six countries and features a cast of 10 actors known from Netflix and Paramount Plus.
Pitch & Produce: AccuFace as the Solution for Rapid Film Production
Geoff Hecht / Love Is A Championship
Geoff Hecht is a seasoned 3D and VFX artist based in San Francisco, California. A graduate of the Academy of Art University with a degree in Animation and Visual Effects, Geoff directed a team of 78 on the animated short Metro6, which was featured in nearly 70 international film festivals and nearly ranked among FilmAffinity’s Top 100 Best Animated Shorts of 2020. Building on this success, he is now directing his second animated film, Love is a Championship (LIAC).
LIAC is a short-form animated romantic comedy that creatively parallels sports with dating. The project brings together over 30 artists from six countries and features a cast of 10 actors known from Netflix, Paramount Plus, Amazon Prime, and major films. Under Geoff’s direction, the film humorously likens penalty calls in sports to the awkward missteps of relationships. By mid-2023, LIAC had made significant progress in storyboarding and production development.
Surpassing Traditional Facial Animation
Facial animation has traditionally been a time-intensive hurdle in filmmaking, especially with the challenges of precise lip-syncing. For LIAC, Geoff Hecht turned to Reallusion AccuFACE to streamline the process. This decision proved transformative, as AccuFACE enabled pre-recorded video to drive virtual character performances with a flexible workflow. By separating body and facial animations, the LIAC team achieved significant time and cost savings in production.
AccuFACE: Transforming Facial Animation Workflow
In December 2023, Geoff’s team completed a motion capture shoot for body animation, postponing facial animation to February 2024 due to onsite limitations. AccuFace’s support for remote recordings proved invaluable, enabling actors to participate via Zoom when in-person sessions were not an option. By removing the need for restrictive equipment, AccuFace allowed actors to deliver natural performances, enhancing the quality of the final animation.
Efficient Facial Animation Production with Unyielding Quality
Reallusion’s iClone and AccuFace enabled Geoff to mash up the best takes and minimize the need for reshoots for LIAC. Its compatibility with industry-standard tools like Maxon C4D, Maya, Unreal Engine, and Blender ensured seamless integration across the diverse production pipeline that Geoff was already used to. With Redshift rendering and a paint-over workflow, the film took full advantage of AccuFace’s adaptability and efficiency to overcome various technical hurdles.
Aria Song recording her performances for AccuFACE
Revolutionizing Facial Animation for Modern Filmmaking
For Geoff, AccuFace wasn’t just a technical upgrade; it represented a creative breakthrough. By cutting production costs, speeding up workflows, and preserving high-quality standards, AccuFace became a vital tool. As Love is a Championship nears completion, its use of AccuFace underscores how innovative technology can empower creators and transform the way stories are told in animation.
Editing viseme in iClone AccuLips
Additional Information
“Love is a Championship” is a passion project directed by Geoff Hecht. With a team of 30 people, Geoff understands that a systemic approach is essential to manage both the team and production time with efficiency and precision. Since its announcement in November 2023, Geoff and the team have completed the script, the full animatic storyboard, body motion capture, and several animation scenes.
Lead Animator Michael Grassi and the team are proud users of Reallusion Character Creator and iClone. Having released several tutorials online, they invite you to join them on their animated filmmaking journey
Outreach
By subscribing to their creative channel and Patreon, you can gain exclusive access to behind-the-scenes footage that walks you through the tools and methodologies used to bring Love is a Championship to life. For instance, we have worked closely with Noitom and proudly use their Perception Neuron Body Mocap for entire body movements. We have put these professional voice actors into mocap suits, having them perform real actions from the script and it all paid off. Unlike traditional releases, where the audience must wait until the film’s completion to see the final behind-the-scenes video, Geoff’s team is sharing these insights progressively, leading up to the film’s ultimate release. Geoff refers to this approach as “Before the Scenes”.
Related Posts
