Tags
Product
AI Studio
Plug-ins & Tools
AccuRIG
ActorMIXER
AI Render
AI Smart Search
Crowd Sim
Face Tools
GoZ Plus
IAA
LIVE FACE
MetaHuman Live Link
Motion Director
Omniverse Live Sync
Pose Tools
RTX Render
SkinGen
Smart Content Manager
Timecode
UE Control Rig
Video Mocap
Pipeline & Production
3DCoat
3ds Max
Affinity Designer
After Effects
Blender
Cinema 4D
Daz
Houdini
Illustrator
Iray
KitBash3D
Marmoset
Marvelous Designer
Maya
MetaHuman
MetaTailor
Photoshop
PSD Pipeline
QuickMagic
Redshift
Rokoko
Substance Painter
Unity
Unreal Engine
V-Ray
Vector Pipeline
Vicon
ZBrush
Application
3D Scan
AEC
Animation
AR/VR/MR/XR
Cartoon
Comics
Commercial Ads
Films & Movies
Games
Live Performance
Music Videos
Previz
Social Media
Television & Network
Virtual Production
Vtuber
Theme
AI & Deep Learning
Character Animation
Character Creation
Concept Art
Digital Double
Digital Human
Environment & Crowd
Facial Animation
Lip-sync Animation
Metaverse
Motion Capture
Scene Creation
Stylized
Video Compositing
Developer
Certified Trainer
Content
Columnist
AI Studio Storytellers
Garry Pye
WarLord
Digital Double from Photos: PhiBix’s Photorealistic Workflow with CC5 and Headshot 3.1
TL;DR: This tutorial breaks down how Paris-based artist PhiBix builds a photorealistic digital double from photos using Character Creator 5 and Headshot 3.1. You will follow his full pipeline: standardizing reference images, aligning the mesh with Vector and morph tools, projecting texture from four camera angles with Stencil & Clone, repairing coverage gaps in Photoshop and AI Studio, and detailing skin, eyes, and expression until the likeness survives a full 360-degree rotation.
Step 1: Standardize the Reference Photos and Generate a Body Base
Before any geometry work, PhiBix removes hair, beard, and eyebrows from the source photograph. Headshot 3.1 then produces a 4K frontal reference: it moves the face to a frontal view, neutralizes the expression, replaces uneven light with diffuse light, and generates a matching profile reference from the cleaned result.
The generated profile is inspected as a usable secondary reference for the later profile alignment.
The first generated body comes back too muscular for the subject’s age, so PhiBix rejects it. In the Body tab he specifies an elderly, slender man, and the regenerated body matches the intended physique.
Pro Tip: Treat the first body as a proposal, not a final result. Normalize lighting, pose, and facial hair first, then confirm the body supports the subject’s age and silhouette before moving on.
Step 2: Align the Frontal Structure with the Vector Tool
PhiBix uses vector-based Bezier curves to align facial landmarks point by point, guided by the small reference tutorial in the upper-left corner of the interface. The goal is structural alignment, not tracing visible makeup, hair, or shadow. He places the eye curve just below the eyebrow and adds a double eyelid because it is a distinctive structural feature of this face.
Once the curves and the side contour look right, a fast preview converts the vector corrections into a 3D result. This preview is a checkpoint: it shows whether the new landmarks improve the volume before the change is committed.
Note: Align the anatomical feature the guide points to. The eyelid curve follows the eyelid structure, not the eyebrow above it.
Step 3: Complete the Profile Alignment and Refine the Head
On the profile, PhiBix matches nose, lips, chin, forehead, ear, and skull depth to the side photograph. After applying the profile curves, he switches to Character Creator 5 morph controls and works exclusively on the head.
The reason is practical: every visible feature must sit under the corresponding region of the photograph before texture projection begins. He repeatedly toggles the reference opacity to compare the 3D head against the photo, aligning the mouth, nose, nostrils, eyes, chin, ears, forehead, brow ridges, eye shape, and skull silhouette. A correction that works in the front view but breaks the profile is not accepted. Once the alignment is close, he applies the projection, removes skin shine to get a matte working surface, and continues with local morph corrections.
Pro Tip: Keep the body unchanged while you solve the facial projection problem, and make the working skin matte so highlights do not hide proportion errors.
Step 4: Lock the Base Mesh and Generate the Multi-Angle Source Set
PhiBix narrows the left eye, adjusts the brow ridges, and changes the eyelid height, then applies the result. This is the last major geometry pass before texture work begins, and the likeness is already readable.
Headshot 3.1 generates five views, but PhiBix uses four: front, one profile, back, and the opposite profile. He deliberately keeps both profiles because faces are not symmetrical. Moles, wrinkles, and skin variation cannot be assumed to match from one side to the other.
Step 5: Project a Digital Double from Photos Using Stencil & Clone
This is where the digital double from photos really takes shape. In Stencil & Clone, PhiBix loads the frontal reference and matches the 3D camera angle, scale, and framing to the photograph rather than trusting the nominal lens value used when the image was generated. For this source, the match lands near a 69 to 70 mm focal length with a viewing angle of roughly 20 degrees.
He removes remaining shine, selects the Constant brush, sets Strength to 1, and begins the unifying pass only after the facial regions are positioned consistently.
Note: Geometry first, projection second. The brush cannot compensate for a nose, ear, mouth, or skull that is in the wrong place. Stop and realign whenever the projection stops landing on the correct anatomy.
Step 6: Project the Profile, Back, and Opposite Profile
On the first profile, PhiBix corrects skull depth, mouth, ear size, chin, forehead depth, and ear angle, with a 2-degree tilt and a scale of 189 percent producing a close match. The Constant brush stays at Strength 1, but he avoids the frontal face to protect the work already done there.
For the rear skull he uses full strength to unify coverage, then reduces strength behind the ears. A smaller brush handles narrow areas such as the nostril wing and the corner of the mouth. The second profile repeats the same logic, because the two sides carry different wrinkles and moles.
Pro Tip: Do not force the ears. When an ear outline is not aligned well enough, postpone its texture and repair it later in the diffuse map.
Step 7: Review the Projection and Map the Cleanup Zones
PhiBix does not treat the combined projection as finished. He moves around the head and inspects it for three categories of problems: incomplete coverage, visible overlaps, and lighting baked into the source photographs. His review loop is consistent: project, inspect the complete head, identify exactly what the projections could not solve, and choose a targeted repair for each remaining area.
The cleanup list here is specific: baked highlights on the chin, nose, cheekbones, forehead, and philtrum; imperfect seams around the ears; an incompletely covered scalp; and a gap directly under the chin.
Step 8: Clean and Consolidate the Diffuse Map in Photoshop
Starting from both the default Headshot projection and the Stencil & Clone projection, PhiBix transforms a generated right-profile photograph to fit the diffuse map, then adjusts it for matte finish, hue, tone, contrast, and brightness, blending precisely with the eraser. He repeats the approach around the eyes and mouth, and addresses the scalp with transformed material and a symmetry pass.
For the underside of the chin he demonstrates a manual route: use a frontal source, match proportions, switch between the source and the diffuse map, apply Warp and Puppet Warp, blend with the eraser, and correct color and brightness. The image is then flattened so the matte finish and the head-to-body transition stay coherent.
Note: Ear mirroring is not a universal rule. PhiBix mirrors the ear here only because this subject has no distinctive asymmetrical ear marks to preserve.
Step 9: Generate an Under-Chin Reference with AI Studio
For an integrated alternative that stays inside Character Creator 5, PhiBix opens AI Studio, chooses Image Gen and Edit, selects the Headshot front and profile images, and asks Nano Banana Pro to create an under-the-chin view from the two references. He sets the aspect ratio to 1:1 and the resolution to 2048 pixels, and generates the view with the chin tilted upward. When the first result casts a shadow below the jaw, he adds an even-tone lighting instruction and regenerates.
He then imports the generated image into Headshot 3.1 as a custom image, uses Edit Pose to put the 3D character into the same pose, aligns scale and proportions, and projects only the under-chin region. That projection also produces normal and roughness information for the repaired area.
Step 10: Extend Map Coverage and Refine Identity Detail
Because the character has a shaved head, scalp and neck detail cannot stay incomplete. PhiBix generates a normal map from the diffuse map in Photoshop and fills the areas that hair would normally hide, so skin relief continues across the scalp and neck.
He then darkens the overall skin tone and refines the eyes: a bluish iris rim, more bloodshot sclera, adjusted pupil and iris proportions, added iris depth, and the slightly bulbous eye shape. Makeup tools add a watery effect along the lower lash line, define the lips, harmonize the eye contours without erasing beauty marks, add subtle cheek veins, and restore localized sheen where moisture naturally appears. The same identity logic extends to the hands, where SkinGen adds age spots and vascular detail so the body matches the aged facial skin.
Step 11: Build the Expression, Style the Character, and Run Technical Checks
PhiBix shapes the characteristic expression first, then refines it with Edit Facial: the head tilts slightly sideways and down, the eyes look upward, the eyebrows raise, the forehead furrows, and a subtle half-smile appears. He adds tight curls, earrings, a dark suit, a tie, and a pocket square, and adjusts the default pose to preserve the intended head tilt and gaze.
Finally, he validates. Different light sources are tested so reflections and shadows do not hide texture problems. When the tie knot intersects the shirt collar, he corrects it with Edit Mesh. A full 360-degree turnaround confirms that geometry, seams, map coverage, and identity cues all hold together, not just in the hero angle.
Pro Tip: Clothing is part of the final validation, not an afterthought. Check that hair, accessories, shirt, tie, and jacket do not collide with the mesh before you call the model done.
Summary
PhiBix’s method comes down to a repeatable sequence: standardize the references, match the mesh, match the camera, project only aligned regions, repair coverage gaps, refine identity-specific detail, and validate under rotation, close-up framing, and varied light. Because of long experience with Character Creator, he completed this build in under four hours, and he estimates a newcomer who already knows the tools could reproduce it in roughly one to two days. You can watch the complete walkthrough in the full video tutorial.
Key Takeaways
  • Standardize the reference before touching geometry. Neutralize expression, remove hair and facial hair, and flatten lighting first, or the geometry and texture projection will inherit every flaw in the source photo.
  • Align the mesh to the photo before you project any texture. Toggle reference opacity constantly and confirm both front and profile, because the brush cannot fix a feature that sits in the wrong place.
  • Capture both profiles, not just one. Faces are asymmetrical, so moles, wrinkles, and skin variation on the left will not match the right, and a single profile leaves half the identity guessing.
  • Match the camera, not the nominal lens value. Dialing the 3D camera to roughly 69 to 70 mm and a 20-degree viewing angle for this source gave a far closer projection than trusting the generated metadata.
  • Treat coverage gaps as a repair list, not a failure. Behind the ears, the top of the scalp, and under the chin will almost always need targeted work in Photoshop or AI Studio after the main projection.
About Phibix
PhiBix is a digital-double specialist at RL-FRANCE, a multimedia production company on the Champs-Elysees in Paris that builds photorealistic doubles for trailers, commercials, music videos, and films, usually as a white-label partner for professional clients. He has created more than 250 commissioned hyperrealistic celebrity doubles and also works as a trainer and technical consultant for schools and companies developing character-production skills. He has used Character Creator since its earliest versions. You can follow his work on YouTube and Instagram.
FAQ: Building a Digital Double from Photos
Q: Can I use this digital-double-from-photos workflow on a subject I photograph myself?
A: Yes. The workflow starts from a standardized frontal image, so a well-lit, face-on photo with a neutral expression is the ideal input. Headshot 3.1 handles the frontal and profile reference generation, and the rest of the pipeline is the same whether the source is a commissioned shoot or your own camera.
Q: Why does PhiBix use four camera angles instead of a single front photo?
A: Because faces are not symmetrical. Keeping the front, both profiles, and the back lets the Stencil & Clone projection capture moles, wrinkles, and skin variation that differ from one side to the other, which a single-photo projection would flatten or mirror incorrectly.
Q: What versions do I need to follow this tutorial?
A: The workflow uses Character Creator 5 with the Headshot 3.1 plugin, plus SkinGen for skin detailing and Edit Mesh for the final collision cleanup. Photoshop is used for diffuse and normal-map repair, though AI Studio inside Character Creator 5 offers an integrated alternative for the under-chin region.
Q: Do I have to leave Character Creator for the texture repairs?
A: Not necessarily. PhiBix shows both routes. Photoshop gives the most manual control for diffuse cleanup, but the AI Studio Image Gen and Edit workflow with Nano Banana Pro can generate and project a missing view, such as the under-chin area, without leaving Character Creator 5.
Q: How long does building a digital double this way take?
A: PhiBix completed this build in under four hours thanks to years of practice. He estimates a beginner who already knows the tools could reproduce the same workflow in roughly one to two days.
Related Posts
Download a free 30 day trial of Character Creator 5
Related topics
Leave a Reply
Recommended Posts
Discover more from Reallusion Magazine
Subscribe now to keep reading and get access to the full archive.
Continue reading
