For many beginning animators, the thought of using Unreal Engine is more than a bit scary, and it used to be for very good reason… it was difficult in its first incarnation. The problem for beginners was not so much using Unreal as most things were done with iClone via LiveLink, but setting up that link was a problem if you had little technical knowledge or skill with the engine and learning iClone at the same time.
Not so anymore with Reallusion’s latest free Unreal Auto Setup (All-in-One) installer. This new method installs everything needed, including LiveLink, to get our iClone to Unreal connection up and running.
New to Unreal Engine?
As a beginner learning how to link the two together to get a project running properly will open the door to you learning more about Unreal if that is one of your goals. This way, you can learn iClone and, in the process, get a grip on Unreal Engine basics to get closer to your goal of learning both apps.
With the New AutoSetup (All-in-One) installer, it has never been easier.
All-in-one Package Installation
We used to install what we needed from different locations, as Auto Setup was accessed via iClone, while LiveLink was installed via the Reallusion Hub application. This was simplified to a single downloadable package, which you can get access to from the Reallusion Hub. This consolidates everything you need to get LiveLink and the proper high-quality shaders via AutoSetup using one installation file.
The link in the Hub will take you to the All-in-One plugin page and a link to download a simple installer. Reallusion has already provided a great tutorial on the process, and the tutorial will follow below.
Relax… It’s easy, and the video below will start on that topic.
Manual Copying of the Content and Plugin Folders
This is confusing to a lot of first-time users, so you are in good company if you don’t understand the process. The installer package we just covered only installs the necessary files for AutoSetup and LiveLink. We still have to copy these files to Unreal Projects because they are project-dependent.
Your Unreal Project files will already have a content folder, so anything copied will be added to that folder. This manual copying, demonstrated in the tutorial below, will also create a Plugin folder with the LiveLink Plugin. This consolidates copy and paste functions we had to perform in the past, before the All-in-One installer was released. The video below starts at this topic.
FBX Export/Import
Exporting the file is the manual way to export and import your iClone characters, lights, or props. This is the original method before LiveLink was released and provides manual control over the export-import process. It has its pros and cons, like all things, and Reallusion gives us a choice of this or Transfer by LiveLink.
A plus of using the manual method is that you get an option to automatically create an Unreal Control Rig upon import to Unreal, so we don’t have to do this later in the process. This is not a big deal, as you can select the character, right-click, and run AutoSetup, and it will create the Control Rig. Please note that this Control is not necessary at the basic level of animation and can be considered an intermediate to advanced rig, so if it confuses you, just leave it alone until you have more time to learn why you may need it as your skills advance and improve.
This is demonstrated in the Reallusion tutorial that starts at that section:
Hooking up LiveLink
Now that the LiveLink plugin is installed, we need to activate it within iClone using the LiveLink panel, and we need to add it as a source to Unreal Engine and activate it. This is another very simple process.
The short video below shows how to bring up the LiveLink panel if it’s not visible and then the simple process of selecting LiveLink as a source, as demonstrated in the video.
This has not changed, and once the link is established, it should operate as it has in the past. If you have never used LiveLink, you use the transfer tab in iClone to transfer select objects, and you use the Link tab to turn LiveLink control on or off on objects.
NOTE: Using LiveLink to transfer is easier for beginners, as there is no need to match the names of the transferred object or character in both applications. This method is basically selecting the object or character to be transferred in the LiveLink panel and clicking the transfer button. Multiple items can be selected and transferred at one time.
UE Control Rig
The iClone Unreal Engine Control Rig is a dedicated animation system developed by Reallusion to bring advanced character animation capabilities from iClone and Character Creator into Unreal Engine. This Control Rig enables users to animate both body and facial features with high precision, leveraging Unreal Engine’s native rigging and animation tools. It supports a wide range of character types, including realistic humans, stylized toons, and even non-human bipeds.
The system is designed to be compatible with Unreal’s MetaHuman framework, allowing for seamless integration and enhanced animation control. With the Control Rig, users can take advantage of features like full-body IK/FK switching, squash and stretch, twistable bones, and detailed facial morph sliders, all accessible directly within Unreal Engine’s animation environment. This makes it possible to refine and polish animations without needing to return to the original authoring tools.
Another key feature of the iClone Unreal Engine Control Rig is its focus on workflow efficiency and reusability. Animators can save and reuse facial and body poses, apply them to different characters, and make use of animation layer editing for both facial and body movements.
The Auto Setup tool further simplifies the process by automating shader assignments and skeleton mapping, ensuring that characters are ready for animation and motion retargeting as soon as they are imported into Unreal Engine.
Landmarks
Matching up the iClone and Unreal Engine 3D workspaces can be somewhat confusing, particularly if you are learning iClone and Unreal at the same time. I am going to show you the simple landmark method of “lining up” point A in iClone to point A in Unreal Engine.
This bears repeating. Landmarks are necessary to match your locations in both the iClone and Unreal 3D workspaces. This allows you to move and work in iClone and have it match the location in Unreal Engine. You don’t want to set a drink on a table in iClone only to find that drink floating in the air at a different location in Unreal.
For a beginner to get oriented, I recommend loading your character or prop into iClone normally. Go to Unreal Engine, select the landmark object, right-click, and choose transfer to iClone. This will transfer a simplified, untextured version of the selected object (prop) from Unreal to iClone. You can use as many landmarks as you need.
In iClone, select the character you loaded earlier, then link it to the landmark prop you just transferred. Since that prop is not on screen, you will have to use the Scene Manager to link the object. Open the selection box in the link section of iClone, select the Position radio button, and select OK.
This will position the character onto the transferred Unreal prop, after which you can then unlink the character and, with it still selected, hit the home button to take your view to the location. You now have locations matched in both apps. This is demonstrated in the video below.
Add any additional props you need to orient yourself in both workspaces, but you don’t have to load all of them if there are more than a few. You will soon work out your own method for this.
Check out the video below to see how to use Landmarks in iClone LiveLink:
iClone Origin
This is a useful tool for a lot of things, like placement of Actor Groups and matching locations from iClone to Unreal, but it generates a lot of confusion from beginners. This is why I focused on the landmark method first, and it’s also what I am accustomed to using.
It’s been my experience that beginners, having a lot to take in with LiveLink and Unreal in general, get caught up in the iClone Origin being more complicated than it is. Just add the origin to the Unreal project first. It’s basically a tool to line up the two 3D spaces by allowing us to move all our transferred iClone assets that are then parented under the iClone Origin point. This allows us to move everything we transferred from iClone to the proper location in Unreal using just the iClone Origin as the movement point instead of each asset.
To recap: iClone Origin works by defining a reference point for the characters, props, or groups you transfer from iClone with LiveLink into Unreal Engine. That reference point gives both iClone and Unreal a predictable place to measure from, which makes it easier to match positions between the two applications.
Watch the video below that briefly demonstrates how it works:
Summary
Reallusion’s Unreal Auto Setup (All-in-One) takes care of the technical aspects of getting Auto Setup and LiveLink installed with minimum intervention from the user. It takes a more complicated process and boils it down to a simple installation file instead of installing from the Hub and other places.
While Unreal Engine is not exactly beginner-level, it never hurts to start experimenting with it to gain the advantage of its fantastic rendering as soon as possible. You can learn iClone for animation and Unreal for production if that is what you are looking for. This method maintains extremely high, cinematic visual quality while keeping the animation process simple via iClone.
While the task of taking on Unreal Engine and iClone used to be a bit daunting, Reallusion simplified the process with this new all-in-one installer. Like most Reallusion applications, you can use as much or as little of all these tools as you need, but the sooner you can learn to install and hook up Auto Setup and LiveLink, the sooner you are on your way to improving your skillset even more.
The combination of iClone and Unreal Engine opens the door to new opportunities to tell your stories while getting the production value of a Pixar or DreamWorks studio on a budget. Besides… It’s free and so is Unreal Engine! What are you waiting for?
Digital Artist MD “Mike” McCallum, aka WarLord, is a longtime iClone user. Having authored free tutorials for iClone in its early years and selected to write the iClone Beginners Guide from Packt Publishing in 2011, he was fortunate enough to meet and exchange tricks and tips with users from all over the world and loves to share this information with other users. He has authored hundreds of articles on iClone and digital art in general while reviewing some of the most popular software and hardware in the world. He has been published in many of the leading 3D online and print magazines while staying true to his biggest passion, 3D animation. For more information, click here.
Humanoid characters are the single hardest production bottleneck for solo and small-team indie developers. Modeling an organic body is difficult enough — rigging it, animating it, and getting it into a game engine with shaders intact is where most projects stall or settle for stiff, lifeless results. For indie devs building 3D games in Unity, the question isn’t whether character animation matters — it’s whether a small team can pull it off without burning months on pipeline problems.
Thomas Brush, creator of the first-person horror shooter Twisted Tower, found his answer inCharacter Creator andiClone. After shipping two commercial 2D titles — Pinstripe and Neversong — Brush and his team made the leap to 3D development in Unity and needed a character animation pipeline that could support their ambitions without requiring a sprawling art department.
What he landed on was a workflow that takes characters from creation through full-scene animation and directly into Unity as real-time, interactive sequences — no pre-rendered cutscenes required.
Meet the Artist and the Project
Thomas Brush is the art director and project lead at Atmos Games, based near Atlanta, Georgia. He has spent over a decade making commercial indie games, starting with 2D titles Pinstripe and Neversong — both built in Unity and released across multiple platforms. His current project, Twisted Tower, is his first 3D game: a first-person horror shooter set in an abandoned 1950s resort filled with corrupted fairy-tale mascots, published by 3D Realms.
The jump from 2D to 3D introduced an entirely new layer of production complexity. Brush describes himself as someone whose core gifting is atmosphere and storytelling — the visual and emotional texture of a world. On Twisted Tower, he works closely with 3D artist Bryn, who handles character sculpting, while Brush directs the art and stays hands-on with animation. But 3D character animation — humanoid characters with faces, bodies, and clothing that need to move convincingly — demanded specialized tools regardless of how the work was divided.
The Character Creator to iClone to Unity Pipeline: Why Indie Devs Should Care
For indie developers building 3D games with humanoid characters, the central challenge is connecting character creation, animation, and engine integration without losing fidelity — or weeks — at each handoff. Here is the pipeline Brush used for Twisted Tower.
Stage 1 — Character Creator for Character Building
Start with a base model in Character Creator, then customize facial structure, gender, hair, skin color, and clothing to match the game’s art direction. Characters come out fully rigged automatically — no manual rigging required.
Stage 2 — iClone 8 for Animation and Scene Assembly
Bring the rigged character — including body, hand, and facial rigs — into iClone 8 to animate sequences. The team animated characters, cameras, and lights, and assembled full scenes with environment assets for apartments and exteriors.
Stage 3 — Unity via Auto Setup and Data Link
Export animated scenes from iClone 8 into Unity usingUnity Auto Setup and Data Link. The entire scene — meshes, animations, cameras, lights — arrives in Unity as a real-time, interactive sequence rather than a pre-rendered cutscene.
Brush’s core insight: this pipeline doesn’t just save time on individual tasks — it eliminates the gap between cinematic content creation and real-time gameplay. “We don’t have to have a pre-rendered cutscene,” he explains. “We can actually have a full sequence that we can interact with inside of Unity.”
Character Creator: Solving the Hardest Problem in Indie 3D Development
For indie developers, humanoid characters represent a unique production trap. Unlike hard-surface props or environments, organic characters require correct anatomy, deformable skin, a functional skeleton, weighted vertices, and — if the face needs to express anything — a facial rig with blendshapes. Each of these is a specialized discipline. In a large studio, different artists handle each stage. On a small team, one or two people have to handle all of them.
Brush frames the problem simply: “Humanoid organic models, they’re tough.” Character Creator addresses this by providing a base human model that can be extensively customized — facial structure, body proportions, hair, skin, clothing — while handling the rigging automatically behind the scenes.
Customization Without Starting from Zero
The key value Brush highlights is the ability to start from a production-ready base rather than a blank viewport. “If you want to take a base model that you can get from Character Creator, tweak the facial structure, change the gender, or the hair or the skin color and the clothing, you can do that and bring it directly into your game.” For a small team whose core strengths lie in art direction and storytelling rather than technical character rigging, this means creative energy goes toward the decisions that define a game’s identity — how characters look and feel — rather than the infrastructure that makes them functional.
Automatic Rigging: The Silent Time Saver
Brush emphasizes that Character Creator characters arrive “fully automatically rigged.” This includes body, hand, and facial rigs — the full skeleton a character needs for both gameplay animation and cinematic performance. For small teams without a dedicated rigger, automatic rigging removes what is often the single most technically demanding step in the character pipeline.
iClone 8: Where Characters Come to Life
Full-Scene Animation, Not Just Character Motion
What sets iClone 8 apart in Brush’s workflow is that it functions as a full scene-assembly and animation environment — not just a character animation tool. For Twisted Tower, the team didn’t limit themselves to animating individual character actions. They built entire cinematic sequences : characters performing, cameras tracking, lights shifting, and environment assets placed for apartments and exterior scenes.
“I animated my characters, I animated the cameras and the lights, and brought in various assets for the apartment or the exteriors,” Brush says. This is a fundamentally different approach from assembling animation clips in a game engine’s timeline editor. By building the full cinematic vision in iClone 8 first, Brush could direct performances and camera work with creative intent before dealing with engine constraints.
From Rendered Cutscenes to Real-Time Sequences
The traditional indie approach to in-game cinematics is to pre-render them — export a video file and play it back during gameplay. It works, but it creates a visual disconnect between cutscenes and real-time gameplay, and the files are large and inflexible.
Brush’s workflow flips this. Instead of rendering and exporting video, he takes the full iClone 8 scene — characters, animations, cameras, lights — and imports it into Unity as a real-time scene. “Not only can we export and render out these sequences, we can also take these scenes and actually just save them and import them into Unity,” he explains. The result is cinematic content that lives inside the game engine, rendered in real time, and — crucially — content the player can interact with.
Unity Auto Setup and Data Link: The Bridge That Doesn’t Break
One-Click Scene Transfer
The practical value of Brush’s pipeline depends on the handoff between iClone 8 and Unity being reliable. This is whereUnity Auto Setup and Data Link come in. Auto Setup handles shader assignment, characterization, and material configuration automatically when Character Creator and iClone assets arrive in Unity. Data Link goes a step further: it creates a live connection between iClone 8 and Unity, allowing entire scenes to be streamed across.
Brush describes the experience with visible enthusiasm: “I could take an entire scene like this and simply just link it up to Unity. I mean, that’s pretty cool.” For a developer managing art, code, gameplay, and cinematics simultaneously, reducing the export-import cycle to a single link eliminates one of the most friction-heavy steps in 3D production.
Real-Time Meshes and Animations Directly in Unity
The end result is that characters, their animations, camera paths, and lighting setups arrive in Unity as native, real-time assets — not baked video files. This means the developer retains full control: animations can be triggered by gameplay events, cameras can respond to player input, and characters can transition between cinematic performance and interactive gameplay without a jarring cut to pre-rendered footage.
What This Pipeline Means for Solo and Small-Team Game Development
The indie game market on Steam is enormous and growing — and the bar for visual quality in 3D games rises every year. Players comparing indie 3D titles against AAA productions may forgive simpler environments, but stiff, poorly animated characters break immersion instantly. Character animation quality is increasingly a gating factor for whether a 3D indie game gets wishlisted or passed over.
What Brush’s pipeline demonstrates is that a small team can produce character-driven cinematic content that would traditionally require a character artist, a rigger, an animator, and a technical artist to get into the engine. Character Creator collapses character creation and rigging into one tool. iClone 8 handles animation and scene direction. Auto Setup and Data Link handle the engine handoff. The creative bottleneck shifts from “can we get a rigged, animated character into Unity?” to “what story do we want to tell with this character?” — which is exactly where an indie developer’s energy should go.
“It’s been a godsend for Twisted Tower,” Brush says.
Look Ahead
Thomas Brush has been developing Twisted Tower for over three years, and the game’s demo launched on Steam in early 2025 to strong community interest. The game is published by 3D Realms and targets a full release on Steam and consoles. Brush and his team continue to use the Character Creator and iClone pipeline as the foundation for their character and cinematic production — a workflow they adopted specifically because of the 2D-to-3D transition and one they now consider essential to the project.
Key Takeaways for Indie Game Developers
Don’t rig humanoid characters manually if you don’t have to. Character Creator’s automatic rigging — body, hands, and face — removes the most technically demanding step for small teams without a dedicated rigger.
Customize characters at the art-direction level, not the infrastructure level. Start from a production-ready base and spend your time on the creative decisions — face shape, clothing, skin — that define your game’s identity.
Animate full scenes, not just individual clips. iClone 8 lets you direct characters, cameras, and lights together as a cinematic sequence, which produces more cohesive results than assembling clips in an engine timeline.
Eliminate pre-rendered cutscenes. Importing iClone scenes into Unity as real-time assets preserves visual consistency between cinematics and gameplay — and gives you interactive control.
Use Auto Setup and Data Link to protect your iteration speed. The handoff between animation tool and game engine is where indie pipelines often break down. A one-click transfer keeps the pipeline alive during revisions.
Invest your energy in your strongest creative skill. Brush’s core insight applies beyond tools: find what you’re most gifted at — storytelling, music, code — and let purpose-built tools handle the rest.
Thomas Brush
Thomas Brush is the art director and founder of Atmos Games, based near Atlanta, Georgia. Over more than a decade of commercial game development, he has shipped three titles — Pinstripe, Neversong, and the upcoming Twisted Tower — progressing from 2D development to leading a small team on an ambitious 3D first-person shooter published by 3D Realms. On Twisted Tower, he works alongside 3D artist Bryn, who handles character sculpting, while Brush directs the art and stays hands-on with the animation pipeline.
Brush is also known for his game development education content, running the Full Time Game Dev course and a YouTube channel with over 345,000 subscribers. His creative philosophy centers on atmosphere and storytelling: “My gifting is creating atmospheres and stories and worlds.”
FAQs
Why use Character Creator for humanoid characters instead of modeling them from scratch?
Humanoid characters are uniquely demanding because they require correct anatomy, deformable skin, a functional skeleton with weighted vertices, and — if the face needs to express anything — a facial rig with blendshapes. Each of these is a specialized discipline that large studios distribute across multiple artists. As Thomas Brush puts it: “Humanoid organic models, they’re tough.” Character Creator solves this by providing a production-ready base model with extensive customization — facial structure, body proportions, hair, skin, clothing — while handling rigging automatically behind the scenes. For small teams, this means creative energy goes toward art direction decisions rather than technical infrastructure that has nothing to do with the game’s identity.
Why are Character Creator and iClone a good fit for indie game developers specifically?
The core problem for indie teams isn’t a lack of talent — it’s that the traditional character pipeline spreads across too many specialized tools and disciplines for a small team to manage efficiently. Character Creator collapses character creation and rigging into one tool, eliminating the need for a dedicated rigger. iClone goes beyond clip-based animation — it functions as a full scene-assembly environment where characters, cameras, lights, and props can be directed together as cinematic sequences. Together, they shift the bottleneck from “can we get a rigged, animated character into the engine?” to “what story do we want to tell?” — which is where a small team’s energy should go. The suite is also available through Reallusion 3D Suite 365 at $50/month, keeping the cost manageable for indie budgets.
How do I bring Character Creator and iClone content into Unity?
Reallusion provides Unity Auto Setup, a free plugin that automates shader assignment, characterization, and material configuration when Character Creator and iClone assets arrive in Unity. For a deeper integration, Data Link creates a live connection between iClone 8 and Unity — allowing entire scenes, including characters, animations, cameras, and lights, to be streamed across with a single click. The result is real-time meshes and animations directly in Unity, not pre-rendered video files, so cinematic content stays interactive and visually consistent with gameplay.
Does this workflow work with Unreal Engine or Godot, or only Unity?
Character Creator and iClone support pipelines for Unity, Unreal Engine, and Blender. Reallusion provides dedicated Auto Setup tools for each engine, includingUnreal Auto Setup andBlender Auto Setup.
Welcome to AI Storytellers, a new series from Reallusion that explores the creative possibilities of AI Studio through the eyes of storytellers. In each episode, we’ll go behind the scenes with creators, filmmakers, artists, and innovators to discover how they’re using AI Studio to develop characters, build worlds, and bring their stories to life. We begin with Space Rocks, an original sci-fi adventure created by John Martin, showcasing a production workflow that combines Character Creator, iClone, AI Studio, and generative AI to create consistent AI Actors and cinematic storytelling. Future episodes will spotlight additional storytellers and projects, further exploring the creativity, techniques, and innovations shaping the future of AI-powered storytelling.
One Creator. One Vision. An Entire Universe.
Every science fiction story begins with a spark of imagination.
For filmmaker and storyteller John Martin, that spark became Space Rocks, a cinematic exploration of deep space, alien life, and visual storytelling created through AI-powered filmmaking techniques. Featured in the AI Studio Storytellers series, Space Rocks showcases how a single creator can develop characters, worlds, and cinematic sequences using AI as a creative partner while maintaining complete artistic direction.
The project follows an alien civilization navigating life among drifting asteroids, blending science fiction aesthetics with cinematic world-building. What makes Space Rocks unique is not only the story itself, but the process behind its creation—a workflow built around character development, visual continuity, shot design, and AI-generated filmmaking.
Building a World from Imagination
Unlike traditional productions that begin with physical sets, crews, or large production teams, Space Rocks was developed through a process of iterative visual exploration.
John Martin began by defining the visual language of the universe: weathered asteroid surfaces, glowing celestial phenomena, alien technology, and creatures adapted to survive in the harsh environment of space. Through AI Studio, concepts rapidly evolved into cinematic visuals, allowing ideas to move from imagination to screen in a fraction of the time required by traditional workflows.
Each image became a stepping stone toward a larger cinematic vision, refining the look and feel of the world while maintaining consistency across the project. Instead of generating disconnected artwork, every shot was designed to contribute to a larger narrative universe.
Creating an AI Actor
At the center of Space Rocks is a distinctive alien protagonist brought to life through a hybrid 3D and AI workflow.
The process began in Character Creator, where Martin cast the alien as a fully realized digital character. Rather than relying solely on prompts to generate different versions of a creature, the character was first established as a controllable 3D asset with defined anatomy, facial features, proportions, and visual identity.
Once the character was finalized, iClone was used to prepare the character for AI-driven production. By establishing the performer in 3D first, Martin created a foundation that could be used across an entire production while maintaining continuity of appearance from scene to scene.
Using AI Studio, the character was transformed into an AI Actor—a creator-directed digital performer capable of appearing consistently across multiple shots, environments, and story moments. This workflow bridges traditional character creation with AI-powered image generation, giving storytellers a reliable method for preserving character identity throughout a project.
For Space Rocks, this approach solved one of the most significant challenges facing AI filmmaking: consistency.
Instead of producing a different interpretation of the character with every generation, the AI Actor maintained recognizable features, proportions, and personality throughout production.
The result is an alien character that feels less like a collection of generated images and more like a true cinematic performer inhabiting a believable science-fiction universe.
Thinking Like a Director
One of the defining characteristics of Space Rocks is its cinematic approach.
Every image was treated as a shot rather than a standalone picture. Composition, camera placement, lens choice, lighting, and visual storytelling guided the creative decisions throughout production.
This filmmaking mindset transformed AI from a simple image-generation tool into a visual production partner. Instead of asking AI to create random artwork, each prompt was designed to support a specific moment in the story.
The result is a project that feels directed rather than generated.
By approaching each sequence with the mindset of a filmmaker, Martin was able to create visual continuity, pacing, and emotional progression throughout the project. Every shot served a purpose within the larger narrative.
From Concept to Screen
The creation of Space Rocks demonstrates how AI Studio can support storytellers throughout the creative process.
Ideas become concepts. Concepts become characters. Characters become AI Actors. AI Actors become scenes. And scenes become stories.
First shot breakdown
Nano Banana for Image Gen in AI Studio was used here as the results with this model were the best for the dimly lit sci-fi spaceship look.
The AI Actor is the essential element to cast characters that will maintain continuity shot by shot.
The Prompt is where all the details about scene design, lighting, cameras, AI Actors, and action are designed for the initial image generation. The prompt is best approached as a way to inform the shot, direct the action, and achieve the first frame of your shot that will drive your video generation. Along with your text prompt, Reallusion AI Studio has a helpful menu of Camera and Style presets that will empower the look of every shot.
The prompt for the first shot is all about framing the Lizard Alien’s left eye with camera prompting and the Extreme Closeup camera from AI Studio.
To ensure that the image was photoreal, the Style for Photo Realism was applied to emphasize the complete scene tone.
The final prompt informs the shot to focus on the extreme close-up camera of the Lizard Alien’s left eye with depth of field, and the scene to maintain photo realism with the style. Lighting is directed to be a warm yellow glow and ambient. The AI Actor is the subject, and the shot is all about the prompt. Sometimes a lengthy prompt with massive details will suit best, and other times simplicity is as powerful.
By combining Character Creator, iClone, and AI Studio, a single creator can develop cinematic productions that maintain continuity, visual consistency, and creative control while benefiting from the speed and flexibility of AI-powered content generation.
Rather than replacing traditional storytelling principles, AI Studio extends them—giving creators new ways to visualize ideas, refine narratives, and build worlds.
The New Independent Filmmaker
Projects like Space Rocks represent a shift in how stories can be created.
For independent filmmakers, AI is not simply about generating content faster. It is about expanding creative possibilities. It allows creators to visualize worlds that may have previously existed only in their imagination and to explore ideas without the limitations of traditional production resources.
Through AI Studio Storytellers, Space Rocks demonstrates that compelling science fiction no longer requires a major studio, a visual effects department, or a massive production pipeline.
By combining Character Creator, iClone, and AI Studio, John Martin transformed a 3D character into a consistent AI Actor capable of performing across an entire production. The result demonstrates how creators can maintain the continuity, direction, and visual consistency expected of traditional filmmaking while embracing the speed and flexibility of AI-powered storytelling.
Sometimes it starts with a single creator, a story to tell, and the willingness to explore what is possible.
The future of storytelling belongs to creators who can imagine new worlds and bring them to life.
Space Rocks is the first episode of AI Studio Storytellers, celebrating the new frontier of filmmaking with Reallusion AI Studio. Stay tuned for more!
John Martin
John Martin is a producer, digital storyteller, and Vice President of Marketing at Reallusion, where he has spent more than two decades helping shape the future of real-time animation, digital humans, and AI-powered content creation. With a background spanning filmmaking, performance capture, animation, and emerging technologies, John has been instrumental in the development and testing of AI Studio, helping refine workflows that connect traditional CG production with generative AI. His passion is empowering storytellers with innovative tools that transform imagination into cinematic experiences.
TL;DR: This is a behind-the-scenes look at how Hip Hop artist and 3D animator Ali Tomineek used a complete Character Creator to iClone animation workflow to build a fully populated hip-hop music video scene in seven days. The pipeline moves from CC5 character sculpting through iClone 8 facial and body mocap, into scene building with Reallusion Content Store assets, and finishes with ActorCore-driven crowd simulation, all sent into Blender via Blender Auto Setup for final polish.
The full Reallusion 3D Suite, including Character Creator 5, iClone 8, and ActorCore, handles every stage from concept to final render. The 7-day format forced one rule: every step had to be fast, repeatable, and production-ready.
Day 1: Brainstorming and Following the Passion
Rather than rush to open a 3D application on the first day, Ali spent it thinking. The concept came before anything else: an animated hip-hop music video featuring a rapper character, with lyrics he would write and perform himself. The vibe, the mood, the lyrical content all had to be locked in before the tools mattered.
Ali Tomineek reviewing his J. Cole character concept sketch for the Reallusion 7-day animation challenge
For a self-taught artist with over a decade of music-making behind him, that creative direction wasn’t an abstract exercise. It was the foundation that everything else would serve.
“One of the most important parts of creating is following the fun. Whenever I create things solely for the purpose of fulfilling that passion, that’s when I create what I consider to be my best work. I try not to overthink anything. I trust my instincts, keep it simple, and follow the passion.”
Ali Tomineek, Hip Hop artist and 3D animator
Every tool choice across the next six days was made in service of the moment Ali had already committed to on day one.
Day 2: Crafting the Character in Character Creator 5
With the concept settled, the second day moved into Character Creator 5. For hero character creation, Ali approached CC5 as a sculpting environment rather than a quick generator. The Proportion Editor and the extensive morph slider library gave him the surgical control he needed for likeness work.
Character Creator 5 hero character creation: matching J. Cole’s facial likeness using CC5 morph sliders and the ActorMIXER panel
CC5 ships with a deep library of named morph sliders. Searching for a feature like nose width, eye shape, or jaw angle surfaces the relevant control, and a single drag dials in the exact value. That searchability is what shifted CC5’s role in Ali’s pipeline from background-character tool to hero-character tool for the first time.
CC5 hero character render: finished J. Cole digital double in Character Creator 5 with SubD HD skin shading
“This was the first time I used CC5 to create one of my main characters. I normally use it for extras or background characters that aren’t the prominent focus of the scene, but with CC5 Deluxe, the amount of tools, features, and control that I have at my disposal made using the software a no-brainer.”
Equally important was the round-trip with Blender. Ali is, by his own description, a Blender addict, and every project he ships passes through Blender at some point. The Blender Auto Setup plugin reduces what used to be a multi-step export-convert-import process to a single click: select the character in CC5, send to Blender, done. The existing pipeline stays intact, and the Reallusion ecosystem just layers on top.
Blender Auto Setup round-trip: CC5 character sent to Blender via DataLink for one-click pipeline integration
Day 3: Lip Sync with AccuFACE in iClone 8
Day three tackled what is, for Ali, the most expressive part of any performance: facial animation. He doesn’t treat lip sync as a technical step. Getting the character’s emotions to bleed through the animation is where the work either earns its keep or doesn’t, and historically that meant hours of manual keyframing per minute of dialogue.
“Before using AccuFACE, animating one minute of talking or lyrics could easily cost me four to five hours of meticulous manual work, tweaking each facial muscle, and that’s with an asset library of pre-made mouth shapes that I could reference to speed up the lip syncing process.”
AccuFACE in iClone 8 collapses that timeline. Ali recorded himself performing the lyrics on camera, fed the footage into iClone, and AccuFACE mapped his facial performance onto the character. What used to be the entire job is now the first pass.
AccuFACE facial mocap in iClone 8: capturing facial expressions for the J. Cole hero character
The second pass is where Ali still does his real work, going over the AccuFACE baseline and tuning subtle movements, timing, and the moments where lip sync needs to land precisely. The plugin handles the structural performance, and the artist handles the nuance. It’s not animation replacement; it’s animation acceleration. Skip the repetitive 80% and concentrate effort on the 20% that actually elevates the result.
Ali Tomineek refines the expressions with HD Face Control in iClone
Day 4: Full-Body Motion Capture with Video Mocap
By day four, Ali was halfway through the challenge and increasingly conscious of where his hours were going. His usual body capture path runs through a Rokoko suit, gear he loves, but suiting up, calibrating, and managing extra hardware between tools costs setup time he didn’t have.
Ali Tomineek used to do body mocap with Rokoko suits.
Video Mocap inside iClone 8 removed the suit from the equation entirely. He set up a phone, performed the movement, and the plugin extracted motion data ready to apply to the character.
“If I can cut down the number of tools I’m switching between, I speed up the process, and for a 3D artist, time is everything.”
The same two-pass logic from AccuFACE applies here. Video Mocap delivers the base animation, and Ali refines key poses over the top. What changes between traditional mocap and video-based capture isn’t the underlying craft. It’s the friction. No suit, no calibration, no app-hopping. For solo artists working against the clock, friction is the enemy.
Video Mocap in iClone 8: Ali’s recorded performance driving the rapper character’s body animation through markerless motion capture
Day 5: Setting the Scene with Reallusion Content Store Assets
With the character performing, day five turned to environment work. The video called for a New York-style street scene with brick buildings, sidewalks, trees, and the boom-bap urban aesthetic. Rather than model the world from scratch, Ali pulled assets from the Reallusion Content Store and assembled a walkable street block for the rapper character to inhabit.
Reallusion Content Store browsing: Ali sourcing 3D environment assets to build the urban street scene for the music video
The restraint here is worth noting. He didn’t build a grand, meticulously detailed environment. He built just enough world to make the performance land.
“I didn’t need to make a whole grand, meticulous, and elaborate idea to animate. I just needed to set the scene and create a moment. That’s what I believe true art is. Moments.”
It’s a principle that scales beyond this project. Over-engineering an environment is one of the most common time sinks for solo animators, and it rarely improves the finished piece. The scene serves the moment, not the other way around.
Day 6: Populating the World with ActorCore Crowd Simulation
A single character walking down an empty city street doesn’t read as a city. It reads as a ghost town. To make the urban environment believable, the scene needed crowds. Manually placing and animating 50 to 100 background characters in a single day isn’t viable, but iClone 8’s built-in crowd simulation, powered by ActorCore assets, made it routine.
ActorCore crowd simulation in iClone 8: populating the music video scene with diverse background characters and motion variants
Ali pulled character packs and motion packs from ActorCore, combined them inside iClone, and let the simulation handle placement, variation, and movement logic. The division of labor across his pipeline is the real insight. Hero characters get built from scratch in CC5 with full likeness and custom morphs, while background characters come from ActorCore as production-quality, ready-to-animate assets.
iClone 8 Crowd Generation panel: setting volume spawn region, actor pool, and group settings to populate the urban scene with ActorCore assets
“I take pride in crafting my main characters from scratch, especially when they’re front and center. But when I need to fill a scene with background characters or a lively crowd, ActorCore is my go-to. I can download character packs and motion packs, combine them together, and let iClone do all the heavy lifting.”
The result is a scene with depth: background characters living their own moments, stories unfolding past the main camera frame. That’s what production value actually looks like, and for a solo artist working in a 7-day window, ActorCore is what makes it achievable.
Day 7: Final Polish, Lighting, and Render
By day seven, the hardest creative decisions were behind him. What remained was the work that separates a sketch from a finished piece: lighting setup to establish mood and direct the eye, camera angle selection to frame the performance, and continuity passes to make sure every detail flowed shot to shot.
Polish work is rarely glamorous, but it’s where the deliverable either crosses the line from animation to film or doesn’t.
“By the end of day seven, it wasn’t just an animation. It was a moment.”
Summary
This Character Creator to iClone animation workflow shows how a complete music video scene, from hero character through full performance, populated environment, and final polish, can be built in seven days using the Reallusion 3D Suite end-to-end. CC5 handles hero character creation, iClone 8 covers facial and body mocap through AccuFACE and Video Mocap, the Content Store supplies the environment, ActorCore populates the world, and Blender Auto Setup keeps an existing Blender pipeline intact. The key insight from Ali’s run: combining purpose-built tools at each stage compresses what used to take weeks into a workable production schedule for solo artists.
Key Takeaways
Lock in the concept before opening any software. Tools serve the creative direction, and committing to the moment first prevents pipeline decisions from driving the project sideways.
Use CC5’s named morph sliders for hero character likeness. Searchable, dial-in control over individual facial features makes Character Creator 5 viable for main characters, not just background extras.
Treat AccuFACE and Video Mocap as a two-pass system. Capture the baseline performance first, then refine on top. This skips the repetitive 80% of mocap work and concentrates effort on the 20% that elevates the result.
Combine hand-crafted hero characters with ActorCore crowds. Custom-build the leads, fill the background with production-ready ActorCore assets. This is how solo artists deliver populated scenes without burning weeks on extras.
Use Blender Auto Setup to enhance an existing pipeline, not replace it. One-click round-tripping between CC5 and Blender means a familiar Blender workflow gains the Reallusion ecosystem without giving anything up.
Ali Tomineek
My name is Ali Tomineek. I’m an artist and 3D creator born and raised in Phoenix, Arizona. To be clear, I’m a Hip Hop Artist. Not just a rapper. Everything I do is rooted in Hip Hop culture.
The way I animate, direct, write, and tell stories all come from that same foundation. Hip Hop isn’t just something I listen to; it’s how I see the world.
I’ve been creating music and videos for over 15 years, but my journey into 3D animation began around six or seven years ago. Like many self-taught artists, I learned Blender through YouTube tutorials, online articles, and community forums. In 2021, I started posting my viral celebrity animations featuring my signature animated character, Lil’ Ali. Those videos quickly took off, reaching over 100 million views, and opened doors to collaborations with brands like BET, ESPN, Hulu, and NBC.
Can I use AccuFACE with just a webcam, or do I need an iPhone?
AccuFACE works with a range of inputs, including live webcam, recorded video files, sports cameras, and phone footage. Specialized hardware is not required. For the best results, capture in good lighting with the face fully visible, then run a second refinement pass inside iClone 8 on top of the AccuFACE baseline.
How does Video Mocap compare to wearing a mocap suit?
A suit like Rokoko delivers higher-fidelity capture, especially for fine finger or hip movement. Video Mocap trades some of that fidelity for setup speed: no suit, no calibration, just a phone or camera. For solo artists working on a deadline, the time saved on tool-switching often outweighs the fidelity gap.
Do I need to abandon Blender to use Character Creator and iClone?
No. The Blender Auto Setup plugin makes CC5 to Blender a one-click transfer. An existing Blender pipeline stays intact, with the Reallusion ecosystem layered on top. Character creation, facial mocap, body mocap, and crowd simulation all feed into the Blender scene the artist already knows.
Is the Reallusion 3D Suite subscription worth it for solo creators?
For independent artists, the subscription model lowers the upfront barrier. Character Creator, iClone, and the plugins can be explored month-to-month rather than committing to a large one-time purchase. That flexibility makes it practical to test the full pipeline before scaling commitment.
How long does it actually take to learn this full workflow?
The 7-day challenge format works because the tools are designed for fast onboarding. AccuFACE, Video Mocap, and ActorCore each abstract away the most repetitive parts of their respective domains. A working Blender artist can be productive in CC5 and iClone within a few sessions, and the deeper craft (refinement passes, polish, lighting) is where the long-term skill investment lives.
Reallusion’s 2026 Vision integrates Hybrid AI across its 3D ecosystem for enhanced production.
Upcoming features include RTX Render, Headshot 3 for Character Creator 5, and the AI Studio for precise 3D control.
This evolution addresses critical needs for VFX studios and film pre-viz teams, offering faster, higher-quality output.
Game programmer Neri Neto highlights how these innovations empower artists to achieve unprecedented speed and quality in 3D content creation.
Reallusion is setting a bold trajectory for 3D production, unveiling its 2026 Vision focused on Hybrid AI integration. This initiative directly addresses the industry’s demand for advanced automation without compromising creative control, enabling VFX studios and pre-visualization teams to leverage cutting-edge tools like iClone 8 and Character Creator 5 (CC5) for faster, more realistic digital content. The core aim is to bridge professional CG workflows with intelligent generative capabilities, making complex tasks more accessible and efficient.
What is Reallusion’s 2026 Vision for Hybrid AI?
Reallusion’s 2026 Vision redefines 3D production by fusing traditional CG workflows with powerful Hybrid 3D+ AI. This strategy aims to accelerate character creation, animation, and scene rendering, providing artists with granular 3D control over AI-generated content. Instead of relying solely on text prompts, artists maintain complete artistic oversight within a robust 3D environment, ensuring high-quality, production-ready assets.
How Will RTX Render Enhance iClone 8 Real-Time Visualization?
The upcoming RTX Render integration within iClone 8, Reallusion’s flagship real-time animation suite, promises a significant leap in visual fidelity for scene visualization and animation previews. By leveraging NVIDIA’s ray tracing technology, artists can experience highly accurate reflections, realistic lighting, and intricate material definitions directly within the viewport. This partnership with NVIDIA enables rendering with higher quality previews, dramatically reducing iteration times.
“What’s impressive is the level of iClone control over every material layer, from reflections and lighting to facial detail and rendering accuracy. In partnership with NVIDIA Ray Tracing, the iClone RTX Render previews look incredibly realistic , especially the eyes. It gives artists access to much higher-quality renders and real-time previews, which is fantastic.”
Neri Neto – Game Programmer & Tech Journalist
How Does Headshot 3 Transform Character Creation in Character Creator 5?
Headshot 3, a plugin for Character Creator 5, revolutionizes the digital human pipeline. It allows artists to generate fully rigged 3D characters from a single image or text prompt. This AI-driven tool produces characters optimized for pipelines like Unreal Engine 5, featuring customizable body morphology and enhanced facial precision. The refined input image correction features of Headshot 3 improve the quality of generated full-body characters, ensuring phenomenal quality even from imperfect source material.
Basically, with Headshot 3 for CC5 you can start with either an image, mesh, or a text prompt, and instantly generate a character from it. What’s really amazing is that all of this happens directly inside Character Creator. You end up with a fully compatible character ready for Unreal Engine 5, while still having complete control to customize every detail of the character’s appearance and body.
What is the Role of AccuFACE 2 in Advanced Facial Animation?
AccuFACE 2 facial mocap plugin for iClone 8 delivers unparalleled precision in facial motion capture and lip-sync. This new module simplifies the animation process, making it compatible with both Reallusion characters and Unreal Engine 5 MetaHumans. Artists can capture their own facial expressions using video mocap and transfer them to their 3D characters with highly accurate lip-sync, achieving natural, expressive performances previously requiring extensive manual keyframing. Mastering setting up the AccuFACE 2 pipeline can drastically improve character realism.
How Does CC5 Character Wrap Address AI-Generated Model Topology?
Reallusion’s CC Wrap (Character Creator Wrap) provides an AI-powered solution for restructuring the topology of complex 3D models, including those generated by other AI tools like Meshy. This feature is crucial for converting topologically challenging assets into animation-ready, performance-optimized characters. It automatically remeshes models to ensure clean edge loops and efficient vertex distribution, preventing common issues that can crash game engines or hinder animation. This capability allows artists to integrate diverse AI-generated content into their production pipelines seamlessly, thanks to the customization and rigging power of Character Creator 5.
Pro-Tip: Utilizing CC Wrap to automatically retopologize AI-generated models dramatically streamlines the character pipeline. This method can save artists months of manual retopology and rigging setup, allowing for rapid iteration and integration into projects.
What is AI Studio and How Does it Offer Fine 3D Control?
AI Studio emerges as a pivotal tool in Reallusion’s vision, offering precise 3D control over AI-generated assets. Unlike basic text prompt systems that offer limited control, AI Studio allows artists to start with basic 3D forms and motions, and iterate with AI, maintaining fine control over character design, body, facial features, and precise animations. This ensures creative intent is preserved while leveraging AI for speed and variation. It essentially transforms generic AI outputs into bespoke, production-ready 3D content, allowing artists to define specific parameters and refine results within a familiar 3D environment.
What are Joint Corrective Morphs (JCM) and Their Impact?
Joint Corrective Morphs (JCM) are being implemented in both Character Creator and iClone to enhance the natural deformation of character joints during animation. These specialized morph targets automatically adjust the mesh around bending joints, preventing unnatural pinching or volume loss often seen in standard rigging. JCMs significantly improve the realism and fidelity of character movements, especially in highly expressive animations, ensuring a more organic and visually appealing result.
Reallusion 2026 Vision: Core Features Overview
Feature
Primary Function
Key Benefit
Integration/Compatibility
RTX Render
Real-time ray tracing visualization
High-fidelity previews & cinematic quality
iClone 8
Headshot 3 plugin
AI-driven photo/text-to-3D character generation
Rapid creation of AAA production-ready humans and stylized charaters
Character Creator 5
AccuFACE 2 plugin
Precise facial motion capture & lip-sync
Natural facial animation, expressions and dialogue
iClone 8
CC Wrap
Automated retopology & mesh optimization
Converts complex meshes and AI generated models into properly rigged animatable assets
Character Creator 5
AI Studio
Fine 3D control over generative AI assets
Bridging 3D assets and animations into highly customized generative AI productions
JCM (Joint Corrective Morphs)
Automated mesh deformation correction at joints
Smoother, more natural character articulation
The Future is Hybrid: Empowering Artists with Reallusion’s AI
Reallusion’s 2026 Vision for Hybrid AI is not merely an incremental update; it’s a fundamental shift designed to empower artists and studios with unprecedented speed, quality, and creative control in 3D production. By intelligently integrating AI into core workflows, Reallusion aims to make advanced 3D character creation and real-time animation more accessible and efficient for everyone, from indie developers to enterprise studios.
Neri Neto (Neriverse)
Neri Neto, a seasoned technology journalist and skilled game programmer behind Neriverso, has a profound passion for leveraging cutting-edge tools in indie game development. Known for crafting engaging mechanics and contributing to captivating titles like his upcoming game, Faceless Residence, Neri actively explores and shares insights into advanced 3D software. He critically assesses new technologies, particularly those that streamline and enhance the artistic process, providing a developer’s perspective on practical application and workflow integration.
Neri’s workflow using Reallusion tools centers on maximizing efficiency and quality. He emphasizes how tools like iClone 8 and Character Creator 5 allow him to produce realistic characters and animations at speeds previously unattainable. For Faceless Residence, he leverages iClone’s animation capabilities and Character Creator’s robust character pipelines. He specifically notes the potential of upcoming Hybrid AI features, such as Headshot 3 and AI Studio, to dramatically accelerate asset creation while retaining full creative control, directly translating to enhanced production values for indie developers.
“In my opinion, Reallusion is one of the companies truly connecting 3D creation control with Generative AI in a way that aligns with the future of content production. The Character Creator 5 and iClone 8 AI Studio ecosystem enhances everything 3D artists already know and do. By learning these tools now, artists will be able to create more content, at higher quality, and with far greater speed in the future.”
How do I export a rigged character from Character Creator 5 to Unreal Engine?
Character Creator 5 provides robust integration with Unreal Engine via its Unreal Engine Auto Setup plugin. This pipeline tool simplifies the export process, ensuring characters are correctly scaled, rigged, and textured for optimal performance within the engine. It automatically sets up material instances, skeletal meshes, and animation blueprints, allowing for seamless transfer and immediate use in game development or virtual production environments.
What is the difference between Reallusion’s AI Studio and standard text prompt AI art generators?
Reallusion’s AI Studio offers fine 3D control, a crucial distinction from standard 2D AI art generators. While text prompt generators produce AI hallucinated images and videos from text prompts, AI Studio allows artists to generate and modify 3D assets within a defined spatial context. This means creators can manipulate parameters like character morphology, proportions, asset placement, and exact motions in 3D space, ensuring artistic vision is precisely translated and integrated into a production pipeline.
Can AccuFACE 2 be used with custom 3D characters or only Reallusion avatars?
AccuFACE 2 is designed for broad compatibility, extending beyond just Reallusion’s native avatars. It can be utilized effectively with custom 3D characters, provided they are properly rigged with facial blendshapes or a compatible skeletal setup and imported into iClone 8. Furthermore, AccuFACE 2 offers direct compatibility with Unreal Engine 5 MetaHumans, enabling precise facial animation and lip-sync for these highly detailed digital characters, significantly enhancing their realism and expressiveness.
Why does efficient topology matter for game development and animation?
Efficient topology is critical in game development and animation for several reasons. Well-optimized topology ensures smooth deformations during animation, preventing visual artifacts and unnatural joint bending. It also directly impacts performance, as low-polygon, clean meshes are easier for game engines and rendering software to compute, leading to higher frame rates and faster render times. Tools like CC Wrap help maintain this efficiency, especially when integrating varied 3D assets.
Reallusion has launched AI Studio, a new platform built on a powerful premise: your hard-earned 3D skills are not a liability in the AI era; they are your ultimate advantage. Instead of forcing artists to start over with unpredictable text prompts, AI Studio uses 3D as a precision control layer for cameras, motion, and layout, while letting AI handle the visual richness, expressions, and physics.
AI Studio is now available with Early Access for iClone 8, Character Creator 5, and Character Creator 4 Full Members, who receive one free month of the Starter Plan, including 1,100 AI points, full feature access, and the complete 3D Previz content and AI Actor library.
AI Studio translates your exact 3D scene (spatial layouts, camera settings, and character animation) directly into AI inputs. You build the scene and frame the shot in 3D, then pass it directly to the AI to generate the final image or video without the guesswork.
Multi-Model Integration
Artists can swap between leading AI models within a single environment to match the specific needs of any shot:
A centerpiece of this launch is the native integration of Seedance 2.0, widely recognized as the most advanced video generation model on the market for interpreting precise 3D spatial data. Seedance 2.0 understands the mechanics of the 3D world like no other video model, making it the perfect counterpart to iClone.
Absolute Cinematic Fidelity: Complex camera paths, including crane shots, dolly moves, and multi-axis orbits, carry through faithfully. For the first time, even instantaneous camera switching and multi-camera cuts translate perfectly from the 3D viewport to the AI output.
Preserved Character Motion: The model accurately honors complex character movements and keyframed choreography, ensuring all spatial relationships and timing established in your 3D software remain completely intact.
Fluid Camera Enhancement: Seedance 2.0 rigorously respects your creative intent. Instead of altering your framing, it optimizes the execution by smoothing out camera translations and rotations for more realistic and natural results while keeping your original direction intact.
Advanced Multi-Shot Prompting: Seedance 2.0 interprets camera terminology flawlessly. Even when using just a single start frame or start-end frame images as a reference, you can simply type in different shots and how you want them, and the model will execute a phenomenal, physically accurate result.
Build Your Scene First: 5,000+ 3D Previz Contents
What makes 3D-guided generation immediately practical is the depth of the library behind it. Reallusion has handpicked over 5,000 contents from its massive library and optimized them specifically for AI creation.
The library covers poses, posed people, interior furnishings, buildings, animals, trees, plants, and vehicles.Artists can fully populate and compose a scene to have a vision before they actually start generating.
The full 5,000+ 3D content library is available to AI Cloud subscribers at no additional cost, while free-tier users have access to a curated selection of 200 sample assets to get started.
Resolving Character Consistency with AI Actor Creator
AI Studio solves the classic “AI drift” problem with AI Actor Creator. You can generate consistent AI Actors (iModels) from your own 3D characters or from a few reference photos. For artists who build their own characters, they have both the 3D asset and the AI version. Unlike flat AI generation that locks characters into a single platform, this dual-layer approach ensures true creative ownership and total flexibility to export your character to game engines, 3D printing, or broadcast animation.
Consistent Character Sheets: The AI Actor Creator generates sheets of up to 14 images across multiple angles and expressions, locking in a visual identity that remains stable across different environments or styles.
Multi-Actor Scenes: You can assign multiple named AI Actors within a single scene, and each will maintain its individual identity even as visual styles shift from cinematic to sketch or toy-like treatments.
200 Production-Ready AI Actors: For projects that need to start immediately, AI Studio includes a library of 200 ready-to-use AI Actors (iModels) spanning realistic digital humans, stylized characters, aliens, and creatures. The complete 200+ actor roster is fully unlocked for AI Cloud subscribers, while free tier users can access 12 starter actors to begin exploring.
Advanced Voice and Filmmaking Dialogue Tools
AI Studio extends beyond visuals by offering a full suite of performance tools that let you direct digital actors like a filmmaker. The workflow automatically detects languages and supports multiple input types, allowing you to generate text-to-voice using default voice options, upload a reference voice for cloning, or directly import your own audio files.
Lip-Sync and Performance: Turn static portraits into speaking characters or synchronize voice lines to existing video footage with frame-accurate precision.
Multi-Character Dialogue Orchestration: Assign independent voices to multiple characters within a single scene, keeping full control over the delivery sequence, speaking pace, and emotional tone per performer to build natural, story-driven conversations.
Prompt-Driven Dialogue: Alternatively, advanced video models like Kling 3.0 and Seedance 2.0 support native audio generation within the prompt itself. This introduces a separate, highly efficient creation path, allowing you to generate contextual dialogue and ambient sound alongside your video content using nothing but text prompts.
All-in-One AI Generation and Enhancement Toolkit
AI Studio consolidates the creative workflow by providing built-in tools that help you start faster with the basics and understand how AI features operate in intuitive ways. This complete environment supports everything from rapid conceptual testing and quick editing to the final visual enhancement of your project.
Start-End Frame Video Generation: Provide the AI with your start and end frames, and let the video model creatively fill in the gaps. This allows the AI to dream up smooth, dynamic transitions and cinematic actions between your key beats while respecting your narrative goalposts.
Production Templates: Easily handle common tasks and discover how tools work through intuitive setups for text-to-image generation, element swapping within existing visuals, animating still images, and replacing actors in video footage.
Editable Prompt Presets: Jumpstart your ideas with ready-made combinations of lighting, camera angles, and styles, allowing you to fine-tune the prompt for total creative control.
Built-in Upscaling: Raw AI generations often come with resolution limits to image and video. The built-in upscaling tool closes that gap during final enhancement, sharpening fine details like eyes, skin textures, reflections, fire, and fabrics to bring your work up to professional broadcast standards.
Early Access Now Open
AI Studio is now open for Early Access. If you are a Full Member of iClone 8, Character Creator 4, or Character Creator 5, you have immediate access to this new workflow ecosystem.
To get started, please upgrade your software to the latest version via the Reallusion Hub. Once updated, you can immediately redeem your complimentary one month of the AI Studio Starter Plan.
TL;DR: This tutorial walks through the complete 10-step Character Creator 5 to Blender workflow used to build Barnabe — the half-bat mascot from The Grimsleys stylized vampire family pack. Starting from CC5’s SubD HD base mesh and Proportion Editor, the character is sculpted in Blender via GoB morph transfers, then returned to CC5 for texturing, rigging, and final assembly — including custom-modeled wings and a signature top hat. The workflow demonstrates how the Character Creator 5 to Blender pipeline, powered by Blender Auto Setup, makes professional stylized character creation both efficient and accessible.
About The Grimsleys Pack
Barnabe is one of six premium stylized vampiric characters in The Grimsleys — Stylized Vampire Mixer, a content pack developed by Vivid Mesh Studio in partnership with Mythcons, built exclusively for Character Creator 5 and iClone. The pack includes the full family: Thaddeus (the imposing patriarch), Belladonna (the elegant matriarch), Lilith (the angsty teen), Morty (the mischievous troublemaker), Bram (the chaotic toddler), and Barnabe (the bat mascot). All six characters come with custom clothing, hair, skins, facial profiles, and 60 ActorMIXER presets — ready for animation in sitcoms, Halloween shorts, stylized games, or any project that calls for gothic-whimsical characters.
Step 1: Laying the Foundation with the Proportion Editor
The process starts inside CC5 by loading a base mesh utilizing the CC5 SubD HD system. Instead of jumping straight into heavy sculpting, the first goal is to rough out the exaggerated proportions of the stylized bat. The Proportion Editor handles this — scaling bones directly to establish a solid base silhouette before any external modeling happens.
Step 2: Sending to Blender (SubD Level 1 or SubD Level 2)
Once the structural foundation is in place, it’s time to push the shapes further. Using the GoB function in Blender Auto Setup, the character is sent to Blender as a Morph at SubD Level 1 or SubD Level 2 resolution.
Step 3: Sculpting the Character
With the character in Blender, the geometry can be pulled into the stylized bat shape.
The Sculpting Process: Using a mouse, keyboard, and Blender’s Grab brush, you can quickly establish the primary forms.
Masking: If you want to restrict your detailing to certain areas without affecting the rest of the mesh, utilize Blender’s Auto-Masking functions in conjunction with Face Sets.
Step 4: Returning to CC5 as a Morph
Once the primary sculpting reaches a sufficient point, the character is sent back to Character Creator using the GoCC function. Because this was a Morph Editing session, the character returns as a Character Morph.
Step 5: Mesh Corrections and Adjustments
Back in CC5, the heavy sculpting has likely distorted some internal geometry. Now is the time to replace any deformed eyes or teeth with fresh ones. After replacing those elements, use the Proportion Editor again to make any final structural adjustments to the rig and base mesh if necessary.
Step 6: High-Resolution Detailing in Blender
With the base clean and corrected, the character goes back to Blender one more time — but this time at the highest SubD resolution. This allows for sculpting finer, high-resolution details without worrying about breaking the core mesh.
Step 7: Crafting the Wings
A bat isn’t a bat without its wings. Staying in Blender, the wings are created from basic mesh planes — subdivided and shaped to match the stylized aesthetic, UV unwrapped, and given basic textures.
Step 8: Saving Assets and Returning to CC5
Using the Blender Auto Setup add-on, the newly created wings are saved as an Asset. Then, the core character is sent back to CC5 using GoCC — again returning as a morph.
Step 9: Texturing
Back in CC5, the character’s textures are adjusted using CC5’s built-in skin presets. For specific stylized variations, textures are taken into Krita for basic painting.
Note: While Krita works well for basic edits, a dedicated 3D texture painting app (such as 3D-Coat, Substance Painter, or Blender) is highly recommended for more complex material work.
Step 10: Final Rigging and Accessories
Finally, with the character back in CC5 and the wing assets imported, skin weights are transferred to the wings so they articulate properly with the rig. To finish the look, pre-created accessories — like Barnabe’s signature top hat and red bow tie — are attached, and the character is complete.
Conclusion
This Character Creator to Blender workflow shows how a professional stylized character can be built by moving back and forth between CC5 and Blender — without starting from scratch. CC5’s SubD HD system and Proportion Editor provide the structural foundation.
Blender handles the creative sculpting and custom asset creation, and GoB/GoCC transfers keep the pipeline non-destructive throughout. Once you get the hang of these morph-based round trips, the process becomes second nature. Barnabe and the rest of The Grimsleys family are available now on the Reallusion Content Store.
Mythcons
Greetings, my name is Peter Alexander. In this demonstration, I’m going to walk you through how you can leverage Character Creator 5‘s new ActorMIXER as a powerful stepping stone to create unique, stylized characters. We’ll use the CC Base Mesh as our foundation, and ActorMixer will provide the next layer from which to build, making professional character creation that much easier. For this demo, I’ll be creating a stylized version of Arnold, using the Blender Autosetup pipeline, which is both cost-effective and efficient for creating characters and assets.
Use the Proportion Editor to block out exaggerated silhouettes before sculpting. Scaling bones inside CC5 first saves significant time in Blender and establishes correct proportions early.
Send characters to Blender as Morphs, not final exports. GoB morph transfers keep the pipeline non-destructive — changes come back to CC5 as editable Character Morphs.
Replace internal geometry (eyes, teeth) after heavy sculpting. Aggressive stylization in Blender often distorts these elements; swapping in fresh ones back in CC5 is faster than trying to fix them.
Build custom assets like wings at the scene origin (0,0,0). Centering geometry before rigging prevents bone offset issues when transferring back to CC5 for skin weight assignment.
Start from a professionally built base rather than from scratch. Packs like The Grimsleys provide production-ready stylized characters with ActorMIXER presets, saving weeks of character development time.
FAQs
Do I need Blender to use The Grimsleys pack?
No. The Grimsleys pack is ready to use directly in Character Creator 5 and iClone. Blender is only needed if you want to follow the behind-the-scenes sculpting workflow described in this tutorial or further customize the characters.
What is the GoB/GoCC transfer in Blender Auto Setup?
GoB sends a character from CC5 to Blender for morph editing, and GoCC sends it back. The key advantage is that changes return to CC5 as non-destructive Character Morphs rather than permanent mesh edits, so you can always dial adjustments up or down.
Can I use this CC5-to-Blender workflow for my own original characters?
Absolutely. The same 10-step pipeline — Proportion Editor, GoB morph transfer, Blender sculpting, GoCC return, and final rigging — works for any stylized character you want to create with Character Creator 5 and Blender.
What version of Character Creator do I need for The Grimsleys?
The pack requires CC v5.06 or above (and iClone v8.70 or above for animation). It also includes 60 ActorMIXER presets for blending and generating character variations.
Does this workflow require ActorMIXER?
The sculpting workflow itself does not require ActorMIXER. However, the Grimsleys pack includes ActorMIXER presets that let you blend the six family members into new stylized variations — which is a powerful creative extension of the base characters.
In modern game development, characters are no longer simple visual assets—they are the emotional core of the player experience. For studios focused on storytelling, building believable characters quickly and efficiently is essential. This is where Character Creator 5, Reallusion’s powerful 3D animation software, becomes a game-changing solution.
Spanish indie developer Indigo Studios has embraced this technology as part of its production pipeline. Known for crafting narrative-driven mystery and adventure games, the studio relies on Character Creator 5 and Unreal Engine to bring complex characters to life for its upcoming detective title, The Family Crypt.
Through their development diary, Indigo Studios demonstrates how modern tools empower independent developers to create their own characters, design realistic performances, and produce cinematic storytelling without the overhead traditionally associated with AAA pipelines.
Indigo Studios: A Story-Focused Indie Developer
Founded by Kim Planella and Judit Hierro, Indigo Studios is an independent game development studio based in Spain. The duo combines experience from film, theater, and audiovisual production with game design to create immersive interactive stories. In the past, they have been candidates for the Reallusion Pitch & Produce program with their game LUCIDUS MORTEM.
Their games are known for several defining characteristics:
Narrative-driven gameplay
Atmospheric environments
Deep character development
Original soundtracks
Cinematic presentation
Rather than focusing solely on mechanics, Indigo Studios prioritizes emotional engagement and mystery-driven storytelling.
Their portfolio includes projects such as:
Seven Doors
Charon’s Staircase
The Last Case of John Morley
Portrait of a Torn
Lucidus Mortem
Each title emphasizes story, puzzle-solving, and character interaction. This creative philosophy makes advanced character tools like Character Creator 5 especially valuable in their pipeline.
Indigo Studios’ newest project, The Family Crypt, is a psychological murder mystery set in 1932.
Players take on the role of Inspector Julian Artemis Banks, a detective investigating a disturbing case involving the mysterious deaths of six members of the Von Haffenhoven family.
Unlike traditional detective games, The Family Crypt introduces gameplay built around reading facial expressions, body language, and emotional cues. Players must interpret characters’ reactions, identify lies, and uncover hidden motives.
To achieve this level of narrative depth, the development team needed realistic character animation, believable facial performances, and efficient character pipelines.
Their solution: Reallusion Character Creator 5 integrated with Unreal Engine 5.6.
Character Creator 5: A Modern Human Creator for Games
Creating realistic digital humans has traditionally required multiple complex tools, extensive sculpting work, and technical rigging knowledge. Character Creator 5 simplifies this process by providing a powerful human creator designed specifically for real-time production pipelines.
For small studios like Indigo Studios, this drastically reduces development time.
Instead of spending weeks constructing base models and rigs, artists can focus on storytelling and design—areas that truly impact the player experience.
Creating Inspector Julian Artemis Banks
In their development diary, Indigo Studios walks through the process of creating the game’s main protagonist: Inspector Julian Artemis Banks.
The character is a complex figure—a detective haunted by past experiences who must unravel a web of secrets surrounding the Von Haffenhoven murders.
Using Character Creator 5, the team began by establishing the fundamental character base.
This allowed them to experiment with:
Facial proportions
Age and personality traits
Skin textures
Hair and wardrobe
Within minutes, the team could iterate through multiple versions of the character until they found a look that matched the narrative vision.
For game developers, this ability to quickly create your own character and iterate on design ideas is invaluable.
Rapid Character Design for Storytelling
One of the biggest advantages of Character Creator 5 is its ability to empower the character designer with intuitive tools.
Traditional pipelines often require separate artists for modeling, rigging, texturing, and animation preparation. With CC5, many of these steps are streamlined into a single environment.
This allows small development teams to:
Experiment with visual styles quickly
Refine character personalities through appearance
Adjust facial structures for emotional expression
Maintain consistent topology for animation
For Indigo Studios, this meant they could concentrate on creating characters that support the narrative tone of The Family Crypt.
Seamless Unreal Engine Integration
A crucial component of Indigo Studios’ workflow is Unreal Engine 5.6, which powers the game’s real-time rendering and gameplay systems.
Character Creator 5 integrates directly with Unreal through Reallusion’s Unreal Live Link.
This integration allows developers to:
Transfer characters instantly to Unreal
Maintain skeleton and rig compatibility
Preserve facial expressions and animation controls
Synchronize updates in real time
For indie developers working with small teams, eliminating manual import pipelines saves enormous amounts of production time.
Instead of wrestling with technical issues, artists can focus on creating engaging characters and environments.
Realistic Facial Performance and Lip Sync Animation
Because The Family Crypt revolves around reading characters’ emotions and expressions, facial performance is critical.
Character Creator 5 provides tools that make high-quality 3D character animation more accessible, including facial rigging systems compatible with modern animation tools.
These capabilities allow Indigo Studios to create scenes where subtle facial movements communicate suspicion, fear, or deception—an essential mechanic in their detective gameplay.
Efficient Workflows for Indie Developers
Indie developers often face significant constraints: small teams, limited budgets, and tight production schedules.
Character Creator 5 addresses these challenges by offering a production-ready character pipeline.
Key advantages include:
Speed: Artists can build realistic characters in hours instead of weeks.
Consistency: Characters maintain a clean topology optimized for animation.
Compatibility: Assets transfer smoothly between software environments.
Scalability: Teams can quickly produce multiple NPC characters.
For story-driven games that require large casts, these efficiencies are crucial.
Indigo Studios combines several tools to create its characters and animations.
Their workflow includes:
Character Creator 5: Primary character creation platform.
Unreal Engine 5.6: Game engine powering rendering and gameplay.
Reallusion Unreal Live Link: Real-time synchronization between CC5 and Unreal.
Additional tools commonly used in similar pipelines include:
Maya for animation refinement
ZBrush for sculpting
Substance Painter for texture detailing
Together, these tools create a flexible ecosystem for modern character production.
Why Character Creator 5 Is Valuable for Narrative Games
Narrative-driven games rely heavily on believable characters.
Players must feel connected to the people they interact with. If characters appear stiff or artificial, the storytelling impact diminishes.
Character Creator 5 helps solve this challenge by enabling developers to:
create emotionally expressive characters
maintain consistent animation rigs
support cinematic storytelling
produce realistic digital humans quickly
For Indigo Studios, this technology allows them to maintain a high visual standard while still operating as an independent studio.
The Future of Character Creation in Indie Games
The tools available to independent developers today are more powerful than ever.
Platforms like Character Creator 5 democratize character production, enabling smaller teams to compete with larger studios.
For narrative-focused developers, this means:
faster prototyping of characters
improved storytelling through animation
higher visual fidelity
more immersive player experiences
As technology evolves, the line between indie and AAA production continues to blur.
Conclusion: Empowering Creators with Character Creator 5
Indigo Studios’ development diary for The Family Crypt highlights how modern tools are transforming the character creation process.
By integrating Character Creator 5, Unreal Engine, and Reallusion’s Live Link technology, the studio can efficiently design realistic characters that support their cinematic storytelling goals.
For 3D animators, game developers, and digital creators, this workflow demonstrates how accessible high-quality character production has become.
Whether you are an indie developer building your first game or a professional studio expanding your pipeline, Character Creator 5 offers a powerful platform to create your own character, animate expressive performances, and produce engaging interactive stories.
If you want to explore the future of 3D character animation, Character Creator 5 is a tool worth adding to your creative arsenal.
Character Creator 5 is a professional 3D character creation and animation tool used to design realistic digital humans for games, animation, and virtual production.
Can Character Creator 5 work with Unreal Engine?
Yes. Character Creator 5 integrates seamlessly with Unreal Engine through Reallusion’s Unreal Live Link, enabling real-time character transfers and animation updates.
Is Character Creator 5 suitable for indie developers?
Absolutely. The software simplifies complex character creation processes, allowing small teams to produce professional-quality characters efficiently.
Does Character Creator support facial animation and lip sync?
Yes. Character Creator provides advanced facial rigs that support expressive performances and lip sync animation for cinematic storytelling.
What industries use Character Creator?
Character Creator is widely used in game development, animation production, film previsualization, virtual production, and interactive storytelling.
TL;DR: This tutorial covers the complete Character Creator 5 to ZBrush accessories, armor, and cloth physics workflow used to equip three alien creature characters for animation and rendering. Starting from sculpted HD bases built with Character Creator 5 and ZBrush, the guide tackles three production challenges: linking a weapon to a character’s hand via Pick Parent, attaching rigid and conforming armor pieces using Transfer Skin Weights, and configuring cloth physics on a cape — including both real-time simulation and an offline Marvelous Designer–to–Alembic pipeline for cinematic shots.
This is the second installment in digital sculptor Óscar Fernández’s alien creature series. The first article covered the HD sculpting workflow from concept to motion-ready character. Here, those same creatures — an insectoid, a crustacean, and an amphibian — get outfitted for production using CC5, Substance Painter, iClone, and Marvelous Designer. All three characters will be available as a content pack on the Reallusion Content Store.
This article focuses specifically on outfitting characters with weapons, armor, and cloth — the production steps that come after the base character is sculpted and rigged. If you are interested in Óscar’s HD GoZ sculpting workflow and how these alien creatures were built from scratch, please check:
Hello everyone! I’m Óscar Fernández, a digital sculptor and educator specialized primarily in figures for 3D printing. Before we start working on the mesh, we need to set the direction for our work. Once again, I’ve turned to the talent of KithKart to define the conceptual design and aesthetics of these three characters. We opted for a visual narrative based on terrestrial biology applied to alien environments.
The Insectoid
This character stands out with a slender and vertical silhouette, featuring elongated limbs that suggest speed. Its design features segmented biological armor that protects vital areas without sacrificing mobility.
The insectoid concept
The Crustacean
A creature with a massive build, a low center of gravity, and broad shoulders. Its body is covered by a heavy exoskeleton, with textures evoking a crab or spider crab shell, including irregularities and micro-details of wear and tear.
The crustacean concept
The Amphibian
This specimen features more rounded volumes and skin with a wet, elastic appearance characteristic of anurans. Unlike the previous ones, its morphology is less rigid, with a prominent torso and powerful yet fluid limbs.
The amphibian concept
Before diving into the process of how they came to life, I’d like to mention that these three aliens, as well as the three previous designs, are available in the Reallusion Content Store. So, if you like the final result, you can work with them directly in your own projects.
Establishing Alien Proportions in CC5
The starting point for all three cases will be identical and fundamental to ensuring the technical compatibility of the model. We’ll start by loading the new “HD CC5 Neutral Base,” a mesh that, as we already know, features a rigging system and topology optimized for the most demanding deformations.
Before any intervention, we’ll place the character in a neutral pose. From here, we will use the native CC5 morphs to define the global proportions. This is the time to establish the height, shoulder width, leg length, etc., and the primary volumes that will serve as the foundation for our sculpture.
Once we have the base structure, the next step is to send the model to ZBrush. We will use the GoZ button to send the character directly to ZBrush. At this point, we will skip any texture maps and keep the default subdivisions. Our goal is to receive a clean and lightweight geometry in ZBrush, ready for the organic sculpting process to take over.
Morph the character with Proportion Editor in Character Creator 5 (CC5), then send to ZBrush for further sculpting via GoZ plus.
Sculpting the Aliens in ZBrush
We’ve already covered the sculpting process in ZBrush in previous videos, so we won’t repeat it, but we will recap the key points to keep in mind for everything to work perfectly:
Don’t modify the model’s topology.
Don’t delete subdivision levels.
Don’t alter the default pose.
Don’t rename the Subtools.
Reducing Finger Count Without Breaking the CC Rig
One of the recurring challenges when working with base meshes is the limitation in the number of fingers. The “HD CC5 Neutral Base” has a standard five-finger structure, but for our alien species, we need to alter this configuration without compromising the integrity of the mesh. This is where we’ll apply an incredibly simple but effective technical trick:
For our frog, we’re going to convert the 5-finger hand into a four-finger hand. The procedure is simple but requires some precision. We mask the middle finger and, using the TrimDynamic tool, we collapse the polygons onto themselves until their volume is reduced to an imperceptible scale. After controlled smoothing, the finger visually disappears, but the topology remains intact for the CC5 engine.
Reducing CC character’s finger count without breaking the rig
And in the case of the crustacean, we take this method even further. We apply the same principle to the middle and ring fingers, achieving a three-fingered hand with a much more aggressive and functional silhouette for its design. This system is vital: it allows us total creative freedom in ZBrush while maintaining the weight mapping and the original bone hierarchy of Character Creator, avoiding export errors or strange deformations in animations.
Beyond these structural alterations, the workflow follows the logical sculpting methodology we already know. We’ll start with the proportions and primary volumes at the lowest subdivision levels. We must try to hold back and only increase the polygon load as the shapes demand higher resolution for fine detail.
When defining the features of our species—whether it’s the more humanoid face of the insect or the broadened shapes of the amphibian—we must make an effort to adapt our sculpture to the model’s original topology. We can isolate the head and load the CC5 reference texture. This allows us to visualize the deformation regions in real-time. Respecting these guides while sculpting ensures that when it’s time to apply expressions, the muscles and facial folds behave with absolute naturalness, no matter how extreme the creature is.
Load CC5 reference texture to visualize the deformation regions in real-time
When reaching the detail phase, we must check the behavior of the fingers we had hidden. When increasing the subdivision level, the default subdivision may try to recover volume in the collapsed areas or generate certain pinching in the mesh. To fix this, we will again collapse any residual polygons and apply controlled smoothing, which will remove any trace of the original base mesh.
ZBrush Polypaint
With the sculpture finalized and the topology respected, we enter the Polypaint phase. Although I feel comfortable with volumes, color is something I’m particularly bad at, but luckily, I can count on KithKart again to give me a hand. Out of all the proposals she offered for each character, these are the ones we finally chose:
For the insectoid, we opted for a palette of earth tones and olive greens, looking for that natural camouflage to break up its slender silhouette.
For the crustacean, the approach is the opposite: we work with highly saturated organic reds and tonal variations on the edges to simulate calcium wear and the impact of the environment on its shell.
Finally, for the amphibian, the technical challenge is the transition. We apply soft gradients as if we were painting with an airbrush to simulate that permeable and moist skin, adding irregular spot patterns to help define the torso volumes.
The color guides of CC5 HD Alien Mixer Pack ver2
Having these color guides before actually starting to paint in ZBrush is a total lifesaver since we know beforehand that the artistic base is solid and will work perfectly once we export everything back to CC5.
Returning to CC5 with GoZ Plus
With the sculpting and Polypaint phases finished, it’s time to return our specimens to the Character Creator 5 ecosystem. For this process, we will use the CC GoZ Plus plugin, which, as we know, completely automates the data transfer and map generation.
In the export settings, we’ll select subdivision levels 0 and 1. This ensures a lightweight base mesh for animation, but with the geometric support necessary for the normal maps. We’ll activate the automatic generation of all maps so that CC5 correctly interprets our Polypaint and the sculpted detail.
After pressing “All” and returning to the CC5 interface, the final step is the Update. But first, we must ensure the “Adjust bone to fit morph” option is active, though we could also adjust the bones automatically later, as we already know. Since we made a fairly extreme alteration of proportions in ZBrush, this function will automatically relocate the internal skeleton to match our new sculpture.
ZBrush to Character Creator 5 GoZ Plus workflow: subdivision export settings, GoZ Options, and baked UV texture maps
Now that our three characters are prepared, let’s move on to the three challenges we’ve set for this project. We’ll start with the simplest one.
Linked Weapon — Attaching Accessories with Pick Parent
With the three characters ready and articulated in CC5, we’re going to tackle the first of our challenges: the integration of linked accessories.
Since KithKart handled the conceptual weight of the entire project, I turned to her again for the weapon design. She proposed several creative directions with a variety of silhouettes ranging from technological to arcane.
Different weapon design in CC5 HD Alien Mixer Pack ver2
Each proposal had something I particularly liked, so I decided to combine the most powerful elements of the different designs.
I kept the base structure and silhouette I liked from KithKart’s sketches, but decided to sculpt it with a twisted, organic wood texture in ZBrush, integrating that central eye as a biological energy focus. On this occasion, I’ve decided to keep the object fairly simple and apply the details directly in Substance Painter.
To send it to Substance, we need UVs, so I sent our accessory to RizomUV via its free plugin, which works great in ZBrush. Now we just have to export a low-poly version (at the lowest subdivision level) and a high-poly version (at the highest level) in FBX to do the baking within Substance itself and start playing with texturing.
I used some Smart Materials as a base and added layers on top with dirt, micro-wear, tonal variations, etc., until reaching the final result. Once the final texture maps are exported, we return to Character Creator 5. Here, we load the original low-poly mesh and link each map to its corresponding channel within the materials section. The result is a visually complex but polygonally lightweight staff.
Staff weapon accessory pipeline: ZBrush sculpt to RizomUV unwrap to Substance Painter texturing for Character Creator 5
The process of linking the staff to the hand is incredibly simple.
First, we position and orient the accessory using the transformation Gizmo, ensuring an ergonomic fit with our character’s hand anatomy. Once placed, we go to the Attach section and activate the Pick Parent function. We just have to click on the hand’s geometry to establish that dependency hierarchy.
From this moment on, the staff is anchored to the hand node. When applying any animation or modifying the character’s pose, the accessory will maintain its relative position and respond coherently to the arm’s kinematic chain.
CC5 Pick Parent attaching a staff weapon to an alien character’s right hand using the Attach panel in Character Creator 5
All right, with the accessory linked and responding to every movement, we’ve completed the workflow for rigid objects. Let’s head to the next challenge.
Armor — Rigid Binding vs. Transfer Skin Weights
For the armor design, the starting point was KithKart’s original concept, beginning with the helmet and upper pieces. However, when moving it to 3D, we encountered a common production challenge: what works aesthetically in 2D doesn’t always translate with the same strength in 3D.
After the first block-out tests, I felt the original design lost its presence in complex camera angles.
That’s why we decided to change the armor design. I looked for a more aggressive and functional segmentation, creating plates that not only protect but also emphasize that slender, alien silhouette. Since the character itself was already finished, the armor’s shapes practically emerged on their own.
For the texturing of the armor, we followed a workflow identical to the staff: we ran the pieces through RizomUV to get the UVs, exported low and high meshes to bake in Substance, and started texturing. I started texturing the helmet and saved the material to apply it to the rest of the armor pieces.
Insectoid armor breakdown: ZBrush sculpt vs textured pieces — helmet, shoulder pads, chest armor, wings, and boots for CC5
Now it’s time to move the pieces to CC5. Although everything can be sent at once, I prefer to send them one by one to check the behavior of each part individually. To prevent GoZ Plus from having to check all subtools, I’m going to move each piece to a new ZBrush document and export it from there using only subdivision level 0, deactivating color, normal, and displacement maps since we’ve already generated them in Substance Painter.
We plug the maps into the corresponding slots, and everything is ready. If the textures don’t look right when plugged in, it’s because we worked in DirectX while texturing, and CC5 uses the OpenGL standard; just expand the UV panel and flip each one vertically, and everything will look perfect.
Once we have all the armor pieces in CC5, we must decide how they will behave mechanically. Here, the workflow splits into two strategies depending on the piece’s function.
For elements that must maintain absolute rigidity, such as shoulder pads, forearms, or knee pads, we’ll opt for the method we saw with the staff: we load them as accessories and link them directly via Pick Parent to the corresponding bone. This ensures the piece moves with the limb without suffering any elastic deformation.
However, for pieces that cover complex flexion areas, like the breastplate or footwear, we need the mesh to follow the character’s volume. For this, we will use the Transfer Skin Weights tool. When applying the default preset for the breastplate, CC5 automatically calculates which part of the torso’s weight should influence the armor. In the case of the shoes, the specific footwear preset ensures that the sole and instep follow the foot’s movement naturally.
CC5 armor rigging: Transfer Skin Weights presets for chest and shoes alongside Pick Parent for rigid forearm and knee pieces
Once the pieces are linked, we can apply animations and poses to our character, and we see that the armor responds perfectly to the deformation of our character’s skeleton.
Cloth Physics — Real-Time and Offline Simulation
The third major technical challenge is the implementation of cloth physics, and for this, we will focus on the crustacean. I wanted to give him the air of a wandering warrior, a pilgrim, or something like that, and nothing communicates that narrative better than a cape worn out by miles and miles.
Concept art by KithKart: crustacean alien in a weathered pilgrim cape — the cloth physics reference for the CC5 workflow
We’ll start by exporting our crustacean base from ZBrush at a low subdivision level to use it as a collision avatar. This time we’ll use Marvelous Designer to create the garment. So, once the character is imported, we start tracing the pattern for the cape. Designing on the actual model allows us to see in real-time how the fabric folds and deforms on the fly, reinforcing that image of a weary traveler. It is this physical behavior, and not just the visual aspect, that ultimately infuses the creature with soul and purpose before returning it to our main engine.
Marvelous Designer cape pattern and 3D drape on the crustacean alien — cloth creation for the CC5 physics workflow
For now, the shapes will be clean, and we’ll add the tears later in Substance.
To create the cape’s tears, the first step in Substance Painter is to change the project shader. By default, the transparency channel is deactivated, so we change the mode to pbr-metal-rough-with-alpha-blending. Once this is done, we manually add the Opacity channel to our Texture Set. Now the software is ready to process invisibility.
We create a Fill Layer where we deactivate all channels except opacity, setting it to zero. On this layer, we apply a Black Mask. By painting with white on the mask, we are “revealing” the fill’s transparency. We will paint manually on the mask to create those tatters and holes along the edges of the cape. The best part is that, thanks to the previous shader change, we see the result of the tears in real-time while painting.
We export the maps and load the garment and textures into CC5 as we’ve seen before.
Substance Painter alpha-blending shader and opacity mask for painting cape tears on the crustacean’s cloth for CC5
At this point, we’re going to look at two different workflows.
The first and simplest is to let CC5 handle the physics in real-time: Originally, the cape is imported as a rigid accessory, so the first step is to perform a Transfer Skin Weights. By doing this, CC5 stops treating it as a static object and officially turns it into a piece of clothing (cloth) linked to the skeleton.
With the garment ready, we ensure that physics are activated in the Project Settings. Now comes the crucial part: the Physics Weight Map. In my case, I preferred to paint directly in ZBrush. The logic of this new map we’re going to create is as follows: white areas are those that will be affected by physics and wind, while black areas will remain anchored to the body, without physical movement, but with the typical deformations of a cloth object.
First, we paint the entire garment white, and then we can go to the lowest subdivision level, mask the edge loops of each piece, increase the mask size, invert it, and paint in black. With this, we can generate the new map from Polypaint and export it. Once the map is applied in the Modify panel, all that’s left is to adjust the friction and elasticity parameters. The result is immediate: our frayed cape now collides with the crustacean’s hell in a totally organic way.
CC5 cloth physics setup: Transfer Skin Weights, PhysX activation, and physics weight map for the crustacean’s cape
Now let’s look at another, slightly more sophisticated possibility with a brutal result. For more cinematic shots where cloth realism is much more important, we leave behind real-time physics and enter an offline simulation workflow. The goal is to capture every fold and movement of the cape with total physical precision.
In iClone, I generated the character’s specific animation, saved it, and then loaded it into CC5 because we have a very interesting option when exporting that we’ll see now. When exporting it as an FBX from CC5, we use the Marmoset preset with a critical configuration: we select Mesh and Motion at 30 FPS.
Here, the professional trick lies in the export range: we set the initial frame as Bind Pose and add a 60-frame physics transition before the actual action begins. These 60 frames are vital; they act as a safety margin that allows the fabric to move from its resting state to smoothly adapt to the shell’s volume and the character’s initial posture, avoiding jerky pulls or failed collisions when the animation starts.
CC5 FBX export settings for offline cloth simulation: Marmoset preset, Mesh and Motion at 30 FPS, BindPose with 60-frame physics transition
Back in Marvelous Designer, we remove the static avatar and replace it with this new animated FBX. Thanks to our frame planning, we see how the cape settles naturally over the crustacean’s anatomy before it takes its first step. We activate the simulation recording and let the Marvelous engine calculate the dynamic behavior frame by frame.
Once the capture is complete, we export the cloth geometry as an Alembic (.abc) file. At this point, we deactivate all textures in the export; we don’t need them because we already have our Substance Painter maps.
Marvelous Designer Alembic export: simulated cape on the crustacean with textures deactivated — geometry-only export for CC5 and iClone
This Alembic file contains exclusively the position of every vertex in every frame. When importing it into Marmoset or back into iClone, it synchronizes perfectly with the character’s animation, achieving cinema-level cloth behavior that reacts with inertia, weight, and perfect collisions.
Conclusion
What I like most about Character Creator 5 is that it has broken technical barriers that previously seemed insurmountable. As you’ve seen, even someone like me, without prior training in the field of animation, can achieve professional-level results thanks to such an intuitive and powerful workflow. If you liked these three new creatures, remember that you can find them available in the Reallusion Content Store, along with a huge amount of premium content with packs and elements provided by leading certified artists.
ÓSCAR FERNÁNDEZ / DIGITAL SCULPTOR
Óscar Fernández is a freelance digital sculptor from Spain, specializing in creating figures for 3D printing. With deep expertise in ZBrush, he is known for crafting highly expressive characters that capture both personality and motion. His work stands out through the meticulous attention to facial expression, muscle definition, and dynamic posing, giving each sculpt a strong sense of tension and storytelling power.
All three alien characters featured in this tutorial — the insectoid, the crustacean, and the amphibian — along with the three creatures from the previous article, are available on the Reallusion Content Store. The pack includes fully rigged characters with HD sculpt detail, custom textures, and the accessories and armor shown in this workflow. They are ready for animation, rendering, and further customization in Character Creator 5 and iClone.
Key Takeaways
Use the finger-collapse technique to alter digit count without breaking the rig. Masking and collapsing unwanted fingers with TrimDynamic preserves CC5’s bone hierarchy and weight mapping, enabling alien hand configurations that animate cleanly.
Choose the right attachment method for each asset type. Pick Parent for rigid pieces (weapons, shoulder pads); Transfer Skin Weights for conforming pieces (breastplates, footwear) — mixing both on a single character produces realistic armor behavior.
Flip UV maps vertically when textures baked in DirectX look wrong in CC5. CC5 uses the OpenGL standard; a simple vertical UV flip in the UV panel corrects the mismatch without re-exporting from Substance Painter.
Add a 60-frame physics transition before the action starts in offline cloth simulation. This buffer lets fabric settle naturally onto the character before animation begins, preventing collision failures and jerky movement.
Start from a professionally built base to accelerate production. The HD Alien Character Pack provides fully rigged, sculpted creatures ready for customization — saving weeks of character development.
FAQs
Can CC5 create characters with fewer than five fingers?
Yes. While the HD CC5 Neutral Base ships with a standard five-finger structure, you can collapse unwanted fingers in ZBrush using the TrimDynamic brush without deleting any topology. Character Creator 5 preserves the original bone hierarchy and weight mapping, so four-fingered, three-fingered, or other non-standard hand configurations animate cleanly — ideal for aliens, fantasy creatures, or stylized characters.
Can CC5 simulate cloth physics?
Yes. CC5 supports real-time cloth simulation using physics weight maps and collision volumes. Paint a weight map to define which areas of a garment move freely (white) and which stay anchored to the body (black), then adjust friction and elasticity parameters. For higher-fidelity cinematic results, CC5 also supports an offline workflow — export your animated character as FBX, simulate the cloth in Marvelous Designer, and bring the result back as an Alembic (.abc) file for frame-perfect playback in iClone or Marmoset Toolbag.
Can CC5 attach weapons or props directly to a character’s hand?
Yes. CC5’s Pick Parent function lets you link any rigid accessory — weapons, staffs, shields, tools — to a specific bone with a single click. Once attached, the accessory follows the arm’s kinematic chain through any animation or pose. Position and orient the object with the transformation gizmo first, then use Pick Parent to click on the target geometry.
Can CC5 automatically rig armor and clothing imported from ZBrush?
Yes. When you send armor or clothing pieces from ZBrush via GoZ Plus, CC5 automatically skins them to the base character. For pieces that need to conform to the body (breastplates, boots), the Transfer Skin Weights tool calculates the correct weight distribution using built-in presets. Rigid pieces like shoulder pads can be linked directly to bones via Pick Parent instead, keeping them deformation-free.
Can CC5 handle extreme proportion changes made in ZBrush?
Yes. After sculpting significantly altered proportions in ZBrush — elongated limbs, oversized heads, non-human body plans — CC5’s “Adjust bone to fit morph” function automatically relocates the internal skeleton to match the new silhouette. This ensures that even radically stylized or alien characters retain full animation capability, including motion capture, facial morphs, and lip sync.
