首頁 » Page 32
Nine Reasons Why Cartoon Animator is the Best 2D Animation Software
So, you want to be a cartoon animator? Maybe you have a story to tell or need to put together a pilot for pitching your show. Maybe you want to learn what this 2D animation thing is all about and why so many people are excited about it. With the web, there is unlimited potential to get your work out there in front of as many eyeballs as possible and maybe trigger a few opportunities.
The trouble is that the work has to get done, whether it is a one-person operation or a team, the work still has to be planned, animated, and produced. You do the planning and Cartoon Animator 5 will help with the animation and production.
While there are more than nine reasons to use Cartoon Animator, let’s take a look at nine of the most standout reasons to embrace this software for your projects whether you are a seasoned pro or too new to animation to even know what to look for.
1. Facial Animation & Lip Sync
Facial animation and Lip Sync have long been strong suits for Reallusion since the days of CrazyTalk. The Face Key Editor and the Face Puppet give us control over the facial expressions of our characters. Both tools have a small learning curve and can be productive on first use. The more experience you gain the better your animations become over time.
A few features of the Facial Key Editor include Morph, Template, and Free Form Deformation
For Lip Sync you can load the file with the character selected and Cartoon Animator will do the rest. If you aren’t satisfied with the results you can go into the timeline and edit the visemes to get the outcome you are looking for.
Auto Lip Sync and Editing
You can also Record Voice, TTS (text to speech), MP4, and Cartoon script which dates back to the days of CrazyTalk.
Cartoon Animator’s facial animation and lip sync tools are easy to use giving you one less thing to worry about while making your masterpiece.
2. 3D Motion Support
The ability to use 3D-based motions cannot be overstated as many 2D animators are also 3D animators with a large library of 3D motions. While it might seem confusing to some, Cartoon Animator can make use of those 3D motions with its import 3D motion popup.
Some tweaks can be made in the popup, but it works well just by loading the motion and then continuing. The popup provides a section for camera projection from -180 to 180. There is also a Motion subsection with a Ground Offset slider and checkboxes for Hand Contact, Foot Contact, Root Motion, and Flip Body. Below that is a checkbox for Camera Tracking.
Furthermore, in ActorCore you can find a collection of Cartoon & Anime motion assets designed for 2D-styled characters. Easily import them to Cartoon Animator and project the movements to your character for advanced performances.
3. Motion Capture Animation
Motion Live 2D is a go-between interface for recording and importing motion capture from a variety of solutions. Cartoon Animator can get you started with motion capture devices like webcams, iPhones, Leap Motion, Perception Neuron, and Rokoko. While not all of these solutions are within everyone’s budget, it does include more affordable ways to get started using a Webcam or iPhone for facial capture and Rokoko smartgloves for hand motion capture. From there on to full motion capture suits, Motion Live 2D is an easy-to-use interface to provide mocap solutions for your 2D animation projects.
For more information on mocap solutions please visit the following pages: FACIAL MOCAP (Webcam), FACIAL MOCAP (iPhone), HAND MOCAP BODY MOCAP
4. 360 Head
The 360-degree head simplifies the work of presenting your character from multiple angles. You can do a quick setup or go into a more detailed setup depending on your needs. The Quick Head Turn Setup uses a head-shaped mask for a boundary that keeps the face within that mask. This gives us the option of turning the head within the mask to create different angles without a lot of confusing work if you have never done this before.
If you want to get into more detail there is another mode, Toggle Head Turn Layout, that will provide much more control with more points available for more turns of the head. All this without additional sprites to keep things simple if you are learning while still having the tools of FFD, Transform, and Sprites for more advanced work.
The 360 Head and Head Creator eliminates the difficult and confusing learning curve when trying to emulate 3D movement in a 2D environment.
You can also purchase 360 Head characters from the Content Store and Marketplace. There is the 360 Head Maker with drag and drop head assembly tools and the Face and Hair Tools.
The 360 Head and associated tools make it easier than ever to animate 2D heads in a 360-degree manner.
5. Motion Pilot
Motion Pilot is one of those tools, that when released, had a huge impact on users. It also had a big impact on new animators who could now animate more easily with the movement of a mouse. From personal experience, I can attest that this is one of my go-to tools for fast 2D animation due to my experience being in 3D. Now legacy 3D animators like me can join in on the 2D fun with little to no learning curve.
To quote from Reallusion’s website:
Motion Pilot is tailored for a new wave of 2D animators seeking opt blend simplicity and efficiency. With its intuitive, real-time interface, it empowers you to effortlessly animate characters and props using puppet animation techniques.
When I say using a mouse that also includes tablets with pens or a stylus, the point is that the animation is created by following the input device across the screen or drawing surface. Draw in some easily added spring bones, set their parameters and you have just added more motion to the animation. All in one pass after the spring bones are added.
Motion Pilot is just one of many 2D animation tools packed into Cartoon Animator. Like other tools, Motion Pilot saves time which saves expense and frustration leading to a more pleasant and creative animation experience.
Motion Pilot Features
Transform
Transformation is at the heart of puppeting, providing you with the ability to effortlessly manipulate the movement of objects. You can axially guide objects, rotate them, adjust their size, or automatically reorient them using flips and turns.
WATCH TUTORIAL
Wave
Generate naturalistic wave motions by adjusting its frequency and amplitude, then sprinkle in a bit of noise for pizazz. To time the wave patterns with precision, align its cycles with the cursor speed.
WATCH TUTORIAL
Motion
Puppetry can facilitate character animation and prop motion. Through straightforward mouse control, frame sequences can be played back with smooth blending of animated effects like free-form deformation and elastic motion.
WATCH TUTORIAL
Flock
Simulating natural flocking behavior and controlling the animation tempo has never been simpler. You can establish a leader and its followers, define the animation sequences, and choose between uniform or random delay times to create organic swarms.
WATCH TUTORIAL
6. Motion Path
Motion Path, not to be confused with Motion Pilot, is another easy-to-learn tool that allows you to “animate anything along a path”. This makes quick work out of tasks like airplanes, helicopters, and spaceships flying across the screen or animating a passage across the sea with a map and a ship icon to show the progress as it moves along the path.
You draw out a path, pick an object like a prop or a character, and assign it to the path. There is a Path Properties dialog box that pops up allowing you access to attributes like Path Progression, offset, rotate, and scale. There is also a Follow Path check box with a drop-down menu offering a positive or negative axis to follow.
The Path Progression slider is where Cartoon Animator sets keyframed positions along the path. If you want the object to be 35 percent down the path at frame 200 you go to frame 200 and set the Path Progress to 35 percent.
Yes… it’s that easy.
Watch Tutorial
7. Spring Dynamics
To use Spring Dynamics you will need to create bones that can be converted to spring bones. The process of creating the bones is shown below and is a very simple task to complete. Don’t let the necessity of creating bones stop you from using spring effects. This is a skill that new users can pick up quickly as creating bones is a fundamental part of making your own, custom characters.
Another big dog on the block when it comes to quickly animating anything from a simple image to a more complex object with lots of moving parts, Spring Dynamics is a hero in its own right. Like Motion Pilot, this tool adds another layer of movement that does not require manual keyframing and is done on the fly as the program runs along the timeline.
Whereas Motion Pilot is for a specific movement, Spring Dynamics adds that extra flair of moving parts that inherit movement from the character or prop they are assigned to.
8. FFD – Free Form Deformation
Free Form Deformation is a tool that many 3D and 2D animators are familiar with. It is a bunch of dots (handles) across a grid that allows you to move those dots deforming the image. If we move up or down the timeline between deformations, you get an animation that morphs from one deformation to the other.
Yet another easy-to-learn and use tool that has many uses and makes quick work out of an animation task from swaying flowers to more complex movements like the roaring TRex shown in the demo video below.
9. Pipeline (PSD, Vector, AE)
Cartoon Animator’s 2D animation pipeline utilizes SVG and PSD file types and works with both Vector and Bitmap formats that will export to industry standard tools. The Image and Vector sections of the Preferences panel are where we hook up our editors such as Photoshop for image and Illustrator for Vector.
This allows for a seamless passthrough (round-trip editing) to the preferred external applications in both directions eliminating the need for export and import.
Currently supported for Images are Affinity Designer, Affinity Photo, Clip Studio Paint, and Krita along with Photoshop. On the Vector side supported applications include Affinity Designer, CorelDRAW, Inkscape and Illustrator.
Create new characters and props or edit existing items with tools used by professionals around the world.
Speaking about professionals, to get a cinematic finished look in Cartoon Animator projects, After Effects plays a crucial role in providing high flexibility in final compositing and VFX editing. AE Script contributes a seamless workflow to reconstruct exported CTA projects as AE layers, while keeping the keyframes and Z-depth of all objects, along with the sound and camera movements.
And… here is a little bonus if you haven’t checked it out already. Take a look at motion link. This is a live link between Cartoon Animator and iClone to create and edit 3D motions! Not only can you convert 3D motions to 2D as mentioned above, but with motion link you open up endless possibilities for expanding your motion library.
SUMMARY
These are just nine reasons to use Cartoon Animator 5 for your next 2D project. While these are great reasons to use the software, they are far from the only reasons. Cartoon Animator 5 is packed with 2D tools to help you accomplish tasks that used to be reserved for seasoned professionals and fine artists. As with all Reallusion applications and tools, Cartoon Animator is easy to learn, easy to use, and contains a big toolbox of 2D tools.
MD McCallum - WarLord
MD McCallum – WarLord
Digital Artist MD “Mike” McCallum, aka WarLord, is a longtime iClone user. Having authored free tutorials for iClone in its early years and selected to write the iClone Beginners Guide from Packt Publishing in 2011, he was fortunate enough to meet and exchange tricks and tips with users from all over the world and loves to share this information with other users. He has authored hundreds of articles on iClone and digital art in general while reviewing some of the most popular software and hardware in the world. He has been published in many of the leading 3D online and print magazines while staying true to his biggest passion, 3D animation. For more information click here.
3D Printable Action Figures with Character Creator & ZBrush
Esteban Cifuentes - 3D Sculptor/ Toy Entrepreneur
Esteban Cifuentes – 3D Sculptor/ Toy Entrepreneur / Action Figure Creator
My name is Esteban Cifuentes, better known as Donman Art and I am a 3D sculptor with more than three years of experience specializing in action figures. Thanks to my skills in social media and marketing, I have managed to stand out globally and participate in renowned events such as San Diego Comic Con and Wonder Con. Two years ago, I established a partnership with a toy factory to create FIST, the first figures of action of Colombia. With this project, we not only seek to promote an innovative product, but also put Colombia on the map as a producer of toys and collectibles.
Currently, a significant portion of my income comes from selling 3D printing files focused on action figures. Through platforms such as Patreon, CGtrader and Cults, I have managed to generate income that far exceeds the industry average.
In addition to this, I give talks at universities and participate in international events sharing my experience and teaching how to monetize the art of 3D sculpture. My goal is to continue contributing to the growth and recognition of the design industry in Colombia and globally.
I start my workflow by gathering references from 80s and 90s movies, video games, and classic toys. After listing the character’s traits, I sculpt in ZBrush and pose with Character Creator 4, leveraging skills learned in a Master Course at Libel Academy. Using Character Creator, I saved months of work by effortlessly rigging and posing high-poly characters, transforming my ZBrush sculpts into posable, and playable 3D print toys.
“What used to take me almost a week, now I can do in a few hours. Character Creator is very effective for ‘action figures’, as it works very well for viewing certain poses. It has helped me a lot with hand poses and making some decisions regarding joints.”
Workflow: When I started this it was initially as a hobby, so I didn’t have the best computer or the best tools, so I got used to sculpting with a mouse. And so I generated my own workflow.
Esteban Cifuentes action figures and workstation
My workflow always starts by looking for references of what I want to create, movies from the 80’s and 90’s, video games, classic toys and a lot of the history of my country. There I make a list of characteristics of the character I want to create, from physical aspects to qualities and defects.
From there I look again for some visual references, and with this I start the sculpture in ZBrush, once I have the piece in a standard pose and accessories. My great help has been Character Creator 4 (CC4), to make fluid poses that tell a story.
With the help of Character Creator, I can transform ZBrush sculpts into posable ones in just a few clicks. Its ideal for character artists and 3D print designers. I can effortlessly rig and pose high poly, multi-subtool characters with precision, even at millions of polygons.
Sculpting action figures in ZBrush to later pose them with Character Creator
What used to take me almost a week, now I can do in a few hours. Then when I am clear about the pose I want, I move on to detail and add more accessories. Finally I do the printing test.
Although some believe that the Character Creator program isn’t very effective for “action figures,” it actually works very well for viewing certain poses. It has helped me a lot with hand poses and making some decisions regarding joints.
Posing ZBrush created action figures with Character Creator
Check out Esteban’s interview on Libel Academy where he shares on how he discovered Character Creator through a Master Course at Libel Academy.com, which would eventually help him produce the very first action figures made in Colombia 🇨🇴 .
“My name is Esteban Cifuentes, the creator of the first action figures made entirely in Colombia. If you ask yourself how was the process?
Well, it all started after ending the pandemic as my passion was always about action figures and toys. So I started creating some for myself and my own collection. So how did I go from my personal use, to my own business?
Publishing on social media, I started making 3D prints that led to international contacts reaching out to me. This led to North American companies contracting me to design them action figures and a couple of other things.
And all this led to brands wanting to produce in different regions other than China. And that is how Colombia came to the point of producing its own action figures.
But that is just one part; as I needed to learn all the areas of hair sculpting, and hand sculpting, That is where Libel Academy came in and it introduced me a tool that saved my life. Which was Character Creator where I could make poses.
For something that would take me almost a month of work, now with Character Creator I could do it in just hours. And with that I could be more effective, which allowed me to charge more, to have a better life and develop my own projects.”
Follow Esteban Cifuentes:
Donman Art Instagram:
https://www.instagram.com/donmanart/
FIST Instagram Colombia:
https://www.instagram.com/fist.colombia/
Related Posts
Reallusion Launches Free Character Creator Auto Setup for Autodesk 3ds Max
Reallusion, a pioneer in enhancing the character workflows of 3D software users, is thrilled to announce the release of the free Character Creator Auto Setup for Autodesk 3ds Max. This groundbreaking tool automates the setup of shaders and rigs for CC Characters, offering lookdev essentials like lighting and PBR swapping to significantly streamlining the character creation process. Finally, realistic Arnold or V-Ray renders of CC or ActorCore characters is now possible without manual material graph setups.
Seamless character and animation import into 3ds max
3ds Max has been a cornerstone in the industry for 30 years, widely adopted by professionals for 3D modeling, animation production, archviz, concept art, and game development. Its powerful scripting capabilities make it essential for studios maintaining long-standing production workflows.
Character Creator, iClone, and ActorCore offer high-quality characters, animations, and assets for film studios and game developers. Traditionally, importing these characters into 3ds Max required complex setups, including creating and assigning material graphs for each part of the character. The Reallusion Auto Setup tool reduces workloads by automating the Digital Human shader and PBR material assignments for characters, outfits, props, and scenes in 3ds Max.
Lifelike Digital Human Shader
Auto Setup automatically converts the CC Digital Human Shader into Arnold and V-Ray material graphs for realistic ray-traced rendering. Easily tweak texture details for skin, eyes, hair, teeth, and tongue using the Auto Setup options panel.
  • Skin: Adjustable subsurface scattering, roughness, specularity, and micro-normal properties for achieving lifelike results.
  • Hair & Beard: Enables natural color variations between hair strands and gradual chroma changes from root to tip.
  • Eyes: Fully adjustable iris, sclera, limbus, and pupil components. Anatomical accuracy is represented with realistic roughness, depth, and refraction effects.
  • Teeth: The Teeth Shader can adjust SSS, color, and brightness to reflect different natural constitutions, ages, or health conditions.
  • Wrinkle: Enhances the appearance of CC3+ characters with high-resolution, multi-texture blending.
PBR Materials for Crowd, Prop, and Scene
For ActorCore crowd actors and models like cloth, accessories, props, or scene elements with PBR materials applied in CC and iClone, Auto Setup can automatically build the material graph, and provides matching PBR values, such as roughness and metallic that helps to ensure visual consistency.
  • Crowd: Utilizing a specialized color adjustment panel, effortlessly expand material variations of ActorCore crowd characters, featuring distinct color regions for skin, hair, and attire.
  • Prop & Scene: Seamlessly transfer and convert PBR materials from CC and iClone to 3ds Max, replicating the original aesthetics while preserving custom material adjustments.
  • Crowd Simulation: Generate realistic masses with detailed facial expressions, accessories, and diverse animation styles using iClone. Seamlessly batch transfer these assets to 3ds Max in the same placement for final rendering.
Effortless animation with control rigs
The Auto Setup tool allows designers to easily add facial and body control rigs for custom animation of imported CC characters.
Face Rig
  • Comprehensive facial control rigs for both CC3+ and ActorCore characters.
  • More than 140 extended facial morphs for CC3+ characters.
  • More than 60 standard facial morphs for 3D extras and crowd sim.
Body Rig
  • Works with official Reallusion characters, including CC3+, ActorCore, and AccuRIG.
  • All characters support 3ds Max Biped and CAT rigging.
  • Easy body part selection via proxy objects, including dummy IK controllers for IK toggling.
Lightning-fast turnarounds with integrated look dev
The Auto Setup Look Dev mode supports different lighting presets, HDR templates and Macbeth Color Checker.
Light Presets
Includes five setups for close-up views and five for full shots, each adjustable to achieve the desired visual outcome, whether for high-quality main characters or low-poly crowd and extras.
HDR & Macbeth Chart
Allowing for HDR background rotation to adjust lighting direction, and integration of custom EXR images. Also features a Macbeth Color Checker with Grey & Chrome balls for accurate color calibration and lighting analysis.
V-Ray & Arnold Multi-pass Rendering
Auto Setup empowers the creation of realistic Arnold and V-Ray renders for high-definition characters from Character Creator, iClone, and ActorCore, and breaks down the rendering process into separate passes.
Crowd
Break down the rendering process into separate passes for diffuse color, specular highlights, shadows, and reflections. This allows fine-tuning specific visual elements and easy tweaking of the final image without re-rendering the entire scene.
Character
Enabling flexible and different post-processing effects applications. Facilitating clearer organization of rendering tasks, enhancing overall rendering efficiency and quality in complex graphics applications.
Free download and upcoming beta version for Maya
The Auto Setup for 3ds Max is available for free download upon registration on the Reallusion website. Recognizing Maya’s pivotal role in film and game production, Reallusion is also developing a beta version of the Auto Setup tailored for Maya. Interested users can gain early access by signing up through an online form. For more information, including download instructions, visit the website.
Related Resources
Game Changer: iClone LIVE LINK and Control Rig for Unreal
This article is featured on AWN
Nildo Essá – FX Animation Studios | CEO, Founder, Writer
Hello, my name is Nildo Essá and I am the Owner of FX Animations Studios. The studio was founded back in 2004 and up until around the year 2017 we were focused mainly on working with TV Commercials being mostly sub-contracted by local advert agencies. Lately we also cater to NGOs and such to make animated PSAs (Public Service Announcement Videos) dealing with several day-to-day issues.Alongside client work, whenever we could, we would invest our time on our own IP, Os Pestinhas aka The Troublemakers
Over the years we have produced a few award-winning shorts and several PSAs using these characters and with great success. Seeing how well they were received locally, we thought it would be a good idea to take the next step… doing a feature film.
As we complete 20 Years of existence in 2024, we find ourselves in the middle of production of our very first Animated feature film “KIBWE” and when it’s complete, it will be the first Animated film out of Mozambique.
We are now using Blender, Unreal Engine, and Reallusion’s iClone and Character Creator 4 (CC4) tools. As a small team, we can leverage iClone’s LIVE LINK and the CC Control Rig plugin for Unreal Engine to enhance speed, efficiency, and enable real-time animation editing, character control, and synchronized camera movements.
“The ideal scenario is iClone to Unreal Engine, and with the iClone to Unreal LIVE LINK, and Control Rig plugins, making that bridge less painful. The Reallusion team has been very helpful and receptive to ideas to improve their tools, and I’m glad to consider them our partners in this crazy adventure that is to make a full feature film with a team of just 2 people.”
Os Pestinhas‘ aka The Troublemakers
Kibwe is a story about Lili’s life and her journey to save her grandmother who was poisoned, while discovering stories from her past, unravelling mysteries of her tribe and family of traditional healers. They are a group of 3 children headed by a 10-Year-old girl named Lili who is very spirited and inquisitive and always wants to know the why of things. She was raised by her grandmother and never got to know her parents due to a curse placed on her family when she was born. The other kids in the group are Minhoca aka Stretch and ZeGordo. Stretch is 12 Years old. He is an environmentalist/inventor that is always trying to come up with interesting ideas to use waste in his inventions. ZeGordo is the Glutton. Despite being chubby, under pressure he can be quite agile. Lili and he grew up together and they are like brothers. ZeGordo is super protective of her.
Kibwe, Lili’s story, unfolded amidst the lush greenery of their village, where the scent of medicinal herbs lingered in the air. As they delved deeper into the mysteries that entwined their lives, Lili’s curiosity drove the trio forward, seeking answers to age-old questions. Stretch’s inventive mind brought a new perspective, turning discarded bits into treasures, while ZeGordo’s loyal presence provided a sense of security in their perilous journey. Together, they embarked on a quest that would test their courage, faith, and the strength of their bond.
Ensuring Animation with the Right Tools
This will be our hardest project yet as we aim really high in terms of quality. Our team is very small… it’s just me and my wife. And because of that we are always looking out for tools that will help us tell our stories without “breaking the bank”. Up until 2020 our main tool was Autodesk 3ds Max. In that year we switched to Blender and seeing how Reallusion was developing their animation tools and plugins that connect with Blender in a seamless manner, it seemed to make perfect sense to add those to our pipeline as well.
Today all our characters are Character Creator 4 (CC4) based and every animation we do we start in iClone 3D software. Then we refine them in Blender , to have the Unreal Engine being the end render goal of the pipeline. This workflow works very well, and it is stable. But being a team of 2 (Me and my wife), it’s still time consuming especially when it comes to export/import times involved between all 3 applications.
The Unreal Live Link plugin allows seamless transfer of data between iClone and Unreal Engine, enabling real-time animation editing, character control, and synchronized camera movements.
A group of children playing outside
Description automatically generated with low confidence
Optimizing Transfers with iClone Unreal LIVE LINK
The new iClone Unreal LIVE LINK version provides the functionality we’ve been looking for. Previously, we could only export characters through Live Link and save animations using the Sequence Recorder tool in Unreal Engine. Exporting animations through the standard FBX workflow was not ideal for us.
The improved iClone to Unreal LIVE LINK transfer now supports parallel processing for iClone FBX export and Unreal FBX import, ensuring uninterrupted editing in iClone while transfers are ongoing. You can monitor the transfer progress through the progress bar in Unreal Engine to estimate the completion time.
I appreciate how all characters, props, and cameras transfer seamlessly at once. The cameras animated in iClone and the switcher setup, transition smoothly to Unreal sequencer with correct camera cuts, reflecting the work done in iClone.
A computer screen shot of a video editing program
With our previous pipeline we had to export the animations from Blender one by one, and then the cameras as well.
At a certain point we even tried exporting eight characters with all their animations as subdivided meshes and the plugin with the free Auto Setup tool for Unreal, did it in such an effective manner and all was neatly organized in their proper folders inside Unreal Engine.
CC CONTROL RIG FOR UNREAL ENGINE
The best part was yet to come however, and this was the CC Control Rig for Unreal Engine plugin. With this tool developers now have the freedom to seamlessly control CC characters using the familiar MetaHuman control rig, enabling precise manipulation and customization of both body and facial animations.
When the Reallusion team said that they were working on an Unreal Control Rig version for CC4 Characters, we immediately jumped on board to beta test it. We are still in the Previz stage of the film but have already crafted about 80 minutes of animations in Blender
After some tests with the Control Rig plugin and the iClone LIVE FACE facial mocap tool, we are moving ahead with the production using mainly iClone and Unreal Engine.
“Combining the powerful capabilities of iClone and Unreal Engine, our production workflow is now streamlined and efficient. The seamless integration of the Unreal Control Rig plugin for CC4 Characters and the iClone LIVE FACE facial mocap tool has truly elevated our project to new heights. With these cutting-edge tools at our disposal, we are confident in delivering a stunning visual experience that will captivate audiences. “
The Control Rig plugin is designed in such a way that you can just pick your transferred character in Unreal and click a button. After a few seconds it will be ready to be animated within the engine with rigs for both body AND face. This is especially helpful in our case because then it means that we can just bake any animations to the Control Rig and tweak/refine them in real-time, considering the final sets and cameras angles. This is a dream come true for any animator!
There’s even a Picker to help in selecting the controllers of your Control rig and you can have multiple characters in the scene and the picker will list all of them properly named.
A screen shot of a computer
Conclusions
Lastly, I would like to thank Reallusion for the continued support to this ambitious project. Their availability to help solve issues and the tools they are making really empower anyone to start telling their stories in a very cost-effective way.
I am glad that Reallusion has been such a supportive partner throughout this journey. Their dedication to assisting with problem-solving and providing accessible tools truly enables individuals to unleash their creativity and bring their narratives to life without breaking the bank.
A person walking in the woods
Follow FX Animation Studios:
Website:
www.fxlda.com
YouTube:
https://www.youtube.com/user/FXlimitada/videos
Learn More
Related Posts
The original article was written by Nildo Essá and is also featured on AWN.
Mastering the Art of 3D Construction for Buildings and Interiors
Discover the Power of iClone BuildingGen: The Best-Kept Secret in 3D Architectural Design
José Antonio Tijerín
José Tijerín is a digital illustrator, 3D sculptor, and the creator of the video game “Dear Althea”, available on Steam. You can also find his content pack, “We’re Besties”, for purchase in the Reallusion Content Store. In this article, José will highlight the merits of using iClone BuildingGen plugin to construct 3D buildings and interiors and make a case for why you should use it in your next project.
Why BuildingGen is the Ultimate Tool for Creating Environments
In the world of art and development, creating immersive and lifelike surroundings is crucial. For those of us who love crafting detailed virtual cities, Reallusion’s BuildingGen is a game-changer. As an iClone plugin, it makes building virtual cities not just possible but effortless. I’ll share how BuildingGen has opened up new possibilities for me, from generating unique structures to integrating them seamlessly with other programs like Unreal Engine.
Magic behind BuildingGen
BuildingGen is a fantastic tool that lets you create buildings using modular components. You can start with pre-existing content packs, like Reallusion’s French architectural styles, or get creative and design your own elements.
What I love about BuildingGen is its versatility. It’s not just for urban structures – you can create all sorts of architectural and decorative elements. Imagine designing a palatial garden with various plants and ornaments, or even constructing a train carriage with modular components, like those available on Sketchfab.
Using modular parts downloaded from the internet, even if they’re not traditional buildings, is straightforward. It takes just a few minutes to import models into iClone and prepare them for BuildingGen. Once you have everything set up, configuring the structure’s parameters is intuitive, making it easy to achieve exactly what you envision.
In a matter of minutes, you can create an interior train carriage of any length and arrangement that suits your project’s needs. This flexibility grants artists the freedom to experiment and diversify their projects, incorporating unique and personalized elements that enhance the visual storytelling of any environment.
Creating a BuildingGen Pack
The process begins within iClone, where it is essential to have all the models required for the final building. Reallusion offers a variety of reference models that can serve as a foundation in your favorite 3D creation program. Once the basic elements are established, it is crucial to ensure that the pivot points of each element are correctly positioned to avoid subsequent adjustments. With the models prepared, the next step involves setting up the BuildingGen Packager in iClone. This package will encompass all the elements necessary to construct the building.
In addition to these modular elements, the tool simplifies the task of adding complementary elements like doors and windows. For example, walls with windows should be assigned the “Window” category type and their model dragged into the “Child elements” area. These elements can be added alongside the modular parts within the BuildingGen Packager. Doing so allows for uploading multiple versions of these elements to randomize the outcome when automatically placed during building generation.
BuildingGen’s ability to generate variations and combinations swiftly is a significant advantage. You can effortlessly create ruins, seaports, or gardens. For instance, with a simple wall model and a shrub, you can compose an attractive outdoor space in a matter of minutes.
I created this kind of mushroom house in 3D Maya using as reference the modular parts that Reallusion offers. You can download these models from iClone to be able to use them in your 3D program in a very simple way.
Integration with Unreal Engine and Advanced Techniques
One of the most effective ways to render these BuildingGen-generated models is by exporting them to Unreal Engine 5, particularly when utilizing Nanite technology. This technique enables models to have a near-infinite polygon density without distorting the model’s shape or affecting the program’s performance. Employing Nanite significantly enhances the volume’s finish, light incidence, and shadow detail, delivering unprecedented realism.
If you refer to the tutorial video associated with this article, you’ll see an example of creating a modular Spanish village with houses featuring rough walls made of unsculpted rocks, subsequently whitewashed for a realistic texture. To replicate this, download the modular elements of “Spanish modular village houses” on Sketchfab. Activate the Nanite properties within the material settings, adjusting options like “Used with Nanite” and “Enable Tessellation.” This transformation converts detailed textures, including ambient occlusion maps, into actual volumes within the 3D model. The result is a surface rich in detail, with defined edges that enhance the visual immersion of the village or city you’re creating.
Finally, I must mention a small trick to improve the final outcome of our buildings, especially in villages like the one in this example, where the streets are very narrow, curved, and with significant unevenness. Once the building is placed on the stage, we can enter Unreal’s “Modeling” editing mode. We can select the “Deform” tool on our building to easily and intuitively curve it into the desired shape.
Conclusion
Reallusion’s iClone BuildingGen emerges as an indispensable tool for any 3D designer seeking efficiency and creativity in constructing virtual environments. Its ability to manage modular components, coupled with its integration with Unreal Engine and advanced technologies like Nanite, makes it a powerful option for projects of any scale.
Related Posts
The original article was written by José Tijerín and is also featured on Creative Bloq.
Mastering 8 Key Animation Skills, A Minute at A Time
Lessons from Minute Guides
Cartoon Animator 5 is a powerful 2D animation software for creating engaging and dynamic animations. Whether you’re a seasoned animator or a beginner just starting out, mastering the essential tools offered by this software can significantly enhance your workflow and creativity.
  • Eight key functions that every animator should become proficient in to fully leverage the capabilities of Cartoon Animator 5.
  1. Motion Pilot – Animating without the timeline
  2. Face Puppet – Smooth facial expression
  3. 2D Motion Key Editor – Flexible animation
  4. Sprite Editor – Fine-tuning character designs
  5. Face Key Editor – Precise facial expressions
  6. Path properties – Leveraging animation paths
  7. Spring Editor – Organic animation
  8. In-application vector color adjustments
  • How to make your animations five times faster, smoother, and more lifelike, while easily animating complex facial expressions.
  • How to streamline character movements, switch sprites seamlessly, and control animation paths with precision. You’ll also learn how to create realistic follow-through effects effortlessly and adjust colors quickly and effectively.
Be well-equipped to create captivating animations that stand out. Let’s dive into each tool and uncover the specific benefits they bring to your animation projects, transforming your creative process and final results.
Motion Pilot lets you animate by pressing record and moving your mouse.
In this episode, you will learn how to generate unique and complex animations using a couple of clicks and swipes with Motion Pilot. This video covers how to initiate Motion Pilot, preview animation with different parameters, how Lazy Mouse can smooth your animation, add depth with Z controls, and change the moving directions.
The face puppet tool lets you animate facial expressions easily by moving your mouse, bringing life to your character.
In this episode, you will learn one of the quickest and most powerful ways to animate your character’s facial expressions in real-time using only mouse movements. Additionally, the video will show you how to choose from various animation profiles and templates, such as sad, angry, or happy, and how to disable specific facial elements, like the eyes, for more natural head movement. This tutorial will equip you with essential Face Puppet skills, enhancing your animation capabilities and enabling you to create detailed and vivid character expressions effortlessly.
The Motion Key Editor lets you freely pose 2D characters using bones in Cartoon Animator.
In this episode, you will learn how to structure intricate bone rigs, use pins to constrain certain bones, and optimize subdivision topology for smoother deformations. Additionally, you will learn how to change the direction of a character, lock leg positions to maintain a natural stance, and adjust overall character movements flexibly. Ultimately, the video will cover how to correct knee bending issues to ensure smooth and natural motions.
Sprites allow you to change from one drawing to another.
(Character made by Garry Pye for Space Coppers, directed by Ward Anderson)
In this episode, you’ll learn how to efficiently set up character components using PSD transfer in CTA Pipeline Edition. We’ll guide you through the process of selecting and replacing various body parts, including changing expressions, switching hand gestures, and animating by altering these elements. You’ll also learn how to use the face tab to modify facial features, such as choosing different eye expressions. Additionally, the video will demonstrate how to select body parts in the editor by simply clicking on them in the workspace.
The Face Key Editor allows precise facial animation. For automatic positioning, use the face puppet tool, but for precision, the Face Key Editor is best.
In this episode, you’ll learn ways to masterfully control the frame-by-frame expression animations of your characters. We’ll show you how to select and move individual eye components or coordinate multiple facial parts for synchronized movements. Using the Transform options, you’ll easily reposition facial elements or use the deform function to alter the shape of any element, allowing you to make your character smile or frown effortlessly.
6. Path Properties – Leveraging animation paths
Paths allow you to move characters on precise trajectories.
In this episode, you’ll learn how to infuse your animations with enhanced dynamism by defining object movement paths. Discover how to attach objects to a path, edit the path shape using bezier curves, give smooth or linear transitions, set start and end points, adjust movement speed, and ensure objects follow the path trajectory. Watch your character animated along the path, achieving smooth and precise movements.
Use spring effects to automate follow-through — one of the core animation principles — to make physics easy to animate in Cartoon Animator.
In this episode, you will learn how to adjust spring bones in characters and props, and enhance secondary animation with organic physics behaviors. Discover how to apply spring effects to selected bones and assign them to groups, or using presets for quick assignments. You’ll also see how to preview the effects in real-time, make necessary adjustments, and fine-tune settings like speed or gravity to perfect your animation.
With vector characters, you can easily change colors in Cartoon Animator without leaving the software.
In this episode, you will learn how to efficiently group vector elements and adjust colors in specific parts or across the entire character. Composer mode allows you to set up color groups, grouping by individual parts or entire color schemes. For instance, you can transform a blue skirt to red by utilizing the “Group by Color” feature, and change all the segment colors at once.
In Short:
Mastering these essential tools in Cartoon Animator 5 will significantly enhance your animation skills.  With smoother, more lifelike animations and increased efficiency, you’ll be able to create captivating projects that stand out.
Additional interface tips
After learning the key features above, you can continue with the step-by-step UI interface guide below to gain a clearer understanding of the operation steps.
1. Motion Pilot
1. Select your character and click the Motion Pilot icon to open it.
2. Practice your moves by pressing preview (space) to see it in action.
3. For smoother movement, click on “Settings” and increase “Lazy Mouse” to 15.
4. Adjust settings with the Z control to move in front of and behind objects like this seaweed.
5. You can also disable “Face Cursor” to make it move in one direction.
2. Face Puppet
1. Press Ctrl+U or find it in the toolbar.
2. Press “Record” and move your mouse to animate, using clicks to make your character blink.
3. Choose from different animation profiles and templates like sad, angry, or happy.
4. Click on face elements to disable them; for example, disabling eyes makes the head move without eye movement.
1. Press K or find its icon in the toolbar.
2. Click on “Flip Hip” to change the character’s direction.
3. The lock feature can keep the feet planted on the ground while the hips are moved about.
4. Disable it to move the entire character. And, if the knees bend incorrectly…
5. Select the shank and click “Reverse Joint” or press 5.
6. This applies to arms as well. Disable constraints to move bones freely and adjust bone settings by clicking “Bone Display” to hide bones, change their color, size, or opacity.
4. Sprite Editor
1. With your character selected, press S or find its icon in the toolbar to open the editor.
2. Select a body part, like the right hand, to switch between different sprites.
3. You can swap sprites for the body or click the face tab to change facial features.
4. For example, selecting the left eye, lets you choose different eye expressions.
5. Face Key Editor
1. Press Ctrl+K or find its icon in the toolbar.
2. Use the head rotation gizmo to turn the head, or drag the circle indicator to rotate it.
3. Select both eyes and click and drag to move them.
4. Select multiple face parts to move them together.
5. Click on templates to quickly change emotions like angry or sad. Select the expression style and face template.
6. Under the “Transform” tab, move face elements easily or use deform to change the shape of any element, making the character smile or frown quickly.
6. Path Properties
1. Click the “Create Path” icon in the toolbar, then click in the scene to add points.
2. Click and drag to add Bezier handles for a smooth curve.
3. Press ESC when done. Reposition points and adjust the path as needed.
4. After selecting another object, reselect the path and click “Path Properties” to start editing.
5. To animate a character along the path, select the character (1), click the Path Properties eyedropper tool (2), and then click the path (3).
6. To adjust the progression to move the character: Set progression to zero, advance the timeline, and set it to 100 to animate — now your character is moving along the path.
7. Spring Editor
1. To add springs, select the character, enter Composer mode.
2. Click on “Springs” in the toolbar, and choose the target bone for adding spring effects.
3. Select a bone and click “Assign to Group”.
4. Click “Preview” and move the character to see the springs in action. Continue adding springs to the group, previewing as you go.
5. Adjust settings or presets as needed; for example, reduce speed to 30.
6. When done, stop the preview, close the editor, and return to the stage.
1. First, select the character (1) and enter Composer mode (2).
2. Set up group colors by clicking the icon and choose to group by part or color sets.
3. For example, to change a dress from blue to red, click “Auto Color Group”.
4. Select “Group by Color”, click “Process”, and “Okay”.
5. Close the window; and in the toolbar, click on “Adjustments”.
6. Click on the blue skirt to make it blink. This indicates that the blue colors are selected.
7. Proceed to change the color.
8. Select red, and click “OK”.
9. Repeat the steps for all the blue elements, in order to turn them red. Recolor the entire dress  to complete this lesson.
Learn More
2D Animation Software for Cartoon Maker | Cartoon Animator
FREE for 30 days & get 1,700+ ready-made assets:
2D Animation Software Download | Cartoon Animator
Rigging Any 3D Model with Character Creator’s AccuRIG
When I got into 3D freelancing decades ago, rigging a character was a sought-after skill. Many of us could create props, even animated props, but that didn’t always translate into being a successful character developer who could handle the setup and rigging of the character’s internal skeleton. It wasn’t the creation of the mesh or the texturing, it was the skinning as we called it back then which today translates into rigging.
What is Rigging?
As I just stated, rigging was different in the early days. It meant, at least in my experience, attaching a control box to built-in animation controls or “rigs” as they were known. Control knobs and levers were made from non-rendering splines to create a control panel. These control rigs were set up on hands, digits, extremities, and anything that might need to be animated within the character. As computational power increased so did the complexities of rigging.
After this came the process of skinning. This is where things could get interesting and more than a bit tedious. My software of choice back then was 3DS Max which worked with envelopes that encompassed every bone including finger and toe bones, which could get tedious. We had to set the control envelope tolerances to minimal to avoid collapse, folding over, or poke through on multi-layers like clothing. Those were just a few considerations.
You had to think ahead if you wanted a clean topology with tight control envelopes that wouldn’t distort the mesh in any fashion. Mesh collapse, usually on arms and legs at extreme poses, was a major headache in the low poly days. By extreme poses I mean folding the arms or crossing the legs when there were barely enough polys to pull it off.
Conventional Rigging/Skinning
Conventional rigging took many hours and was usually the bottleneck in any production pipeline whether it be a large studio or small indie project. Like texturing, rigging/skinning was a vital step and perhaps the most important step in the development of the character mesh. As I said earlier, in 3DS Max we had to size the control envelopes to each bone including knuckles in some cases. This meant a lot of control envelopes in a very small area. When they overlapped you resorted to the dreaded weighting, which was necessary in any decent character.
Rigging skeletal bones in 3DS Max. The Left is a Shaded view, the right is a wireframe working view. The Bones are moved forward in the left images so we can see them with the shaded view. Rigging one bone at a time with different “handles” for tweaking the size. Can be very time-consuming even with experience.
Today we paint weights which were available back in the early days but mainly it was manual weight tables with a lot of back-and-forth fine-tuning via numbers. This gave exact control but was one of the leading factors in the production bottleneck. An experienced skinner could push out the work, but it could take newbies, trainees, and interns a while to get on board. With experience, you knew a better range of weights to start with, which saved some time.
Creating the character mesh was fun, but took some time and texturing it took some time too, None were the time hog that rigging/skinning was. It was also a buzzkill. Nothing could kill the creative urge and slow down or almost stop your pace like being assigned to rig/skin a character. There were times I’d rather create an entire city than skin a character, especially a novel character with many arms and tentacles. Not all character meshes were bipedal. Creatures like aliens and monsters could be a real pain to wire up. It wasn’t unusual to have to add some meat to the character mesh in places so it would not collapse or bind. This wasn’t simple either as that change had to be re-topologized and re-textured.
The Weight table from 3DS Max. Tedious but direct vertex control. Not for beginners or the less adventurous.
Character development was a big part of the budget back then too. It was nothing to pay thousands of dollars over the development life of a character. Each revision had to go back down the line and then back up again, sometimes with multiple approvals along the way. It was nothing to wait several days to two weeks to get a small revision completed on a character.
It is no wonder it was incredibly expensive to produce a minute of animation back then as the character development cost was just a part of a much larger production budget.
AccuRIG and Characterization
Flash forward to today where the term skinning is not used anymore as rigging has replaced it as the terminology for skinning. If you use any of the old-school tools like Max, Maya, and the like then you can still create control rigs but why do so when Character Creator skips that step completely?
The same with skinning. It’s all handled, the clean topology, proper skinning tolerances, and all that goes with making a character ready for animation, by Character Creator with either the Characterization tool or AccuRIG.
Simply put, if you want to preserve an existing skeleton then you use Characterization by matching bone to bone until you have enough bones to activate a working, animatable character. If you want to add a skeleton to a character mesh that does not have one or you want to replace the existing skeleton, then you use AccuRIG.
Check out my article for more detailed information on AccuRIG versus Characterization to learn more about the process of each one.
A wide variety of character Meshes from several industry-leading sources rigged in Character Creator.
Using AccuRIG to Rig a Character Mesh
“Garfield” (https://skfb.ly/oHRtU) by gaddiellartey2010 is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
“Odie (1)” (https://skfb.ly/oGERJ) by mustafatylan68 is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
Anyone can Rig/Skin with Character Creator
Not only was rigging and skinning a sought-after skill, but it was also one that you had to use often or you could grow rusty. Freelancers tend to jump from task to task as called for by their contracts, so it wasn’t unusual to have to spend some unpaid time refreshing your skills when you got a character dev contract.
Character Creator and tools like AccuRIG have eliminated all of that. We get to focus on creating a great mesh with AAA texturing or use the sliders on a base mesh to shape a unique character. We can also send that base mesh over to ZBrush via a very robust GoZ function that makes transfers between the applications seamless. This feature alone gives us a method of sculpting that is used by studios and indies for top-shelf production.
With AccuRIG and Characterization, anyone with competent computer skills can create a “ready for animation” 3D character.
Using Characterization to Retarget an Existing Rig in a Character Mesh
“Cyberpunk character” (https://skfb.ly/6SDpO) by 4d_Bob is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
Masking Bones
A great feature, often overlooked, is the bone masking tool that allows us to mask out unnecessary bones from an unusual character mesh. We can rig meshes like partial characters or sculptured busts with the body, arms or legs masked out, so they don’t interfere or induce unwanted movement when applying motions.
“Wheeled Robot” (https://skfb.ly/ouCQD) by Andrei Milin is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
In the image above I have masked out everything except the arms. When you select a bone and turn masking on it will mask all bones in that hierarchy. Masking a torso or pelvis bone will mask out the legs and feet or possibly all of the upper body depending on the bone chain direction. If you select a torso bone to mask and the arms are masked but you want to use them then select the arms again and turn off the mask for them.
I also used the Extract Mesh tool to extract the wheel/tire, radar, and a few other items and finally extracted the claws so I could spin them even though I didn’t use that in the demo.
Production Budgets Drop Dramatically
It’s still not cheap for a large, triple-A studio to create a minute of animation but budget considerations have changed dramatically for the small, indie producer or studio. It was not uncommon in the early days of 3D production to have $5K to $10K or more annual expenses just for licensing some needed applications.  That was in dollars that had a lot more purchasing power than today, so the tools weren’t cheap by any means. Piracy was a problem because of the expense. It was a barrier to a lot of smaller indie producers and animators.
Today we have pricing and competition that have reduced the annual cost of 3D software. It may still take a good budget to get started with a lot of tools, but maintaining those tools is no longer a $5K to $10K annual burden. There were times we were forced to spend the first few months of the year just paying for our software or maybe I should say waiting for that annual license to pay for itself, then we could make money.
Character Creator and iClone have empowered a lot of new animators by being able to learn and produce animation at a small fraction of the cost per minute. I’m not saying our time is not worth anything, but I am saying our time is key in lowering the budget for out-of-pocket expenses. Some iClone productions have little to no budget while producing quality work for any number of reasons from previsualization to trying to get noticed or a project financed.
Summary
It’s hard not to like the power and ease of use that Character Creator and tools like AccuRIG provide. I have become so spoiled at using Character Creator and its auto rigging tools that I can’t remember the last time I rigged a character in 3DS Max.
I hope I never have to again either.
Selling your Art for 2D Animation – Clay Triche Interview
Selling your Art for 2D Animation with Cartoon Animator
Clay Triche – 2D Animator / Content Developer
Clay Triche
The Cartoon Animator 2D Marketplace is a rich source of potential for artists looking to profit from their 2D art work, as they are able to sell their content to a large audience of animators and have total control over their work.
Clay Triche is a new content developer for Cartoon Animator, and he made quite the impact when he joined the 2D community, not only as a developer but also as a leading animator.
Producing incredible characters for Cartoon Animator at record pace, Clay already has quite the catalogue of work which spans multiple themes and genres from crazy zombies, to famous faces. We sat down with Clay to discuss his speedy rise through the ranks of Cartoon Animators top developers and see what insights he could offer other artists.
“The reason I chose to use Cartoon Animator is because of how easy and fast it is to produce animation. For all of the other animation platforms that I used over the years, none of them has the flexibility and easy workflow like Cartoon Animator.”
Q: Hi Clay, welcome! Could you begin by telling us about your work using Cartoon Animator?
Hello there! I’m the kind of cartoonist that was raised in the 70’s and 80’s era and I grew up with Bugs Bunny, Scooby Doo, Woody Woodpecker, Popeye, along with all of those great cartoons, so the kind of work I’m doing is to bring back the feel of that era with my own creations.
Right now what I am working on with Cartoon Animator 5 are several projects, and one of them is my Mega Zombie Pack that I started on this past Halloween, but it’s been delayed for the Holidays and now that the Holidays are over I started working on it again, The idea of the pack was actually inspired by The Motion Comic Mini Event that was held back in September in the Cartoon Animator User Group page, so the entire Pack is actually designed for Motion Comics, but can be used in animations as well.
And one of the other projects that I’m working on is my Stone Age 10,000 B.C series for my Channel and as I create characters, props and scene, I add them to the marketplace to share with others so they to can create a Stone Age cartoon.
Q: Initially what drew you to working with Cartoon Animator as your 2D animation software of choice?
The reason I chose to use Cartoon Animator is because of how easy and fast it is  to produce animation. With all of the features that’s packed into Cartoon Animator is  actually everything you need to bring your ideas to life. For all of the other animation  platforms that I used over the years, none of them has the flexibility and easy workflow  like Cartoon Animator, so with that said Cartoon Animator will always be my platform of  choice!
“For all of the other animation  platforms that I used over the years, none of them has the flexibility and easy workflow  like Cartoon Animator, so with that said Cartoon Animator will always be my platform of  choice!”
The advantage I find Cartoon Animator gives me is that I can create animation and have them uploaded to my channel in one day, because I’m a fast creator. Plus I can earn money buy selling the content I make using Cartoon Animator by uploading them to the 2D Marketplace straight from the software, which helps me get recognized by other creators and build up my followers.
Q: Do you have a specific genre or theme that is your favourite to work with?
Hmmm… hard to tell what my favorite genre or theme is, but if I had to choose then I would say Military. I always loved to watch war movies, and TV shows like Hogan’s Heroes, and Gomer Pyle U.S.M.C, two of my all time favorites. So I always liked to do comic strips of my own  Military like I do with my series the Dog’s. I can think up of a bunch of funny stories of any military scenarios!
Q: You have created a number of characters in a very short time. How do you find the creation process for Cartoon Animator?
Cartoon Animator I find to be by far the most easiest and fastest animation platform on the market. I say this because with Cartoon animator I can actually enjoy making contents and animation without the frustrating features compared to other software choices which I have used but struggled with.
Now using Cartoon Animator I love what I do with a passion, and that’s animation, and I would recommend to anyone who wants to create their own cartoons without taking weeks, months, or even years to learn, to use Cartoon Animator!
Q: You say that Cartoon Animator makes 2D animation easy and fun. What tools, or features in particular do you like most?
My favorite feature in Cartoon Animator I would say is Spring Bones and Motion Pilot, because with spring bones you can now add more life and realism to your characters, I never had that in the other software before.
Seeing that I can make the hair on my characters bounce around, I even add them to my characters clothes, like a skirt, or an unbutton shirt to make them wave as the characters move. I find that to be really cool!
And Motion Pilot is another awesome feature I really love, because now I can just use the mouse to control the movement of my characters and props and it records it to the timeline, it really makes animating even a whole lot easier, and I love how you can add Flocks as well using this feature, these are wonderful addition of tools to Cartoon Animator and it makes me want to use Cartoon Animator even more!
Q: As a relatively new developer to the 2D Marketplace, and having already made a name for yourself as a leading developer, what advice do you have for for inspiring Cartoon Animator developers?
My advice to anyone who wants to create and sell contents, is create something unique, find out what users are looking for, and always add a good description to your content page.
Make sure to mention what you use to make it, what features it does and doesn’t have. This will help users decide whether or not they can use your content.
“The advantage I find Cartoon Animator gives me is that I can create animation and have them uploaded to my channel in one day, because I’m a fast creator. Plus I can earn money buy selling the content I make using Cartoon Animator.”
Q: So what are your future plans with Cartoon Animator? Do you have any current projects in the works?
Recently I have  been working on my Mega Zombie Pack for the Marketplace. I have also been working on my Stone Age series and Character packs for the Marketplace.
Some of my most recent releases include Pete the Dragon, a few Stone Age characters and a little Alien called Zee, which made me think outside of the box in order to make him unique. I have a bunch of projects planned, but I don’t want to give them all away because I like to surprise people with my creations. I like to see the wows, lol!
Let’s just say this….. I have plans to help the Marketplace grow!
Follow Clay Triche
Facebook:
https://www.facebook.com/profile.php?id=100090060426058
YouTube:
https://www.youtube.com/channel/UCp-ET1dJ9HD0cBxsBq_9FzQ
Related Posts
INCREDIBLE program for 3D Crowd Simulation
Welcome to Neriverso, where the captivating world of video games meets the expertise of Neri Neto, a seasoned technology journalist and skilled game programmer. Through Neriverso, Neri shares his profound insights and boundless passion for everything he adores, including video game development!
As a dedicated game programmer, Neri has lent his talents to numerous indie projects, crafting engaging mechanics and contributing to the development of captivating titles. Embrace the Neriverse and embark on a journey fueled by Neri Neto’s unwavering enthusiasm and commitment to his craft and community.
In his latest video, Neri talks about the powerful 3D crowd simulation feature in iClone, that enables animators, game developers, archviz creators and more to create realistic crowd scenes including how:
  • Creating crowds in 3D environments can be achieved using iClone Crowd 8 Simulation tool, a versatile software applicable in architecture, gaming, and virtual shows, offering robust crowd simulation capabilities.
  • Using software like iClone 8 can provide ready-to-use character libraries and animations, making it efficient for most projects, with the option to purchase additional characters and animations for more customization.
  • Using animation and real-time graphics, creator can seamlessly integrate characters into a scene, adjust animations, and create paths for character movement.
  • Using advanced character scanning technology to create realistic 3D characters for crowd simulation can enhance performance and visual quality in various projects.
Follow Neriverso:
Instagram:
https://www.instagram.com/neriverso/
TikTok:
https://www.tiktok.com/@neriverso
