首頁 » Page 34
AccuRIG and ActorCore Accelerates Creation of Sci-fi Game Character for 3D Modeler
This article is featured on BlenderNation
Nathan Olsen
Nathan Olsen is a character artist from Canada specializing in weapons, creatures and cool-looking characters. He has focused mainly on developing art for video games since 2019 and is keen on learning all methods required for this type of 3D art.
Best Tools for 3D Character Creation
As with any job that one may undertake, it is always great to have the best tools available for the project at hand. In this project the desired tools happen to be AccuRIG, ActorCore 3D store, ZBrush, Blender and Marmoset Toolbag 4.
Let’s start by looking at the process that is involved with the creation of a fully-rigged and animated character and why this method works best for me.
ZBrush, Essential for Sculpting 3D Models
To begin you will need ZBrush for the creation of the high poly sculpt and the low poly, UVed mesh. The Matcap Baker plugin is great for getting ID maps out in the end stages.
Let us take a more in depth look at ZBrush and the Matcap Baker plugin, as it is the starting point for the workflow. After you have sculpted your character, unless you re-meshed it as you worked (this is what I suggest) then now is the time for a re-mesh and projection of the high-poly details back onto the re-meshed character. The reason we do this is to give a better topology for the UVs and animation deforms in AccuRIG.
Pro-tip 1
Try to avoid adding lots of parts around joints that will deform and model in a T- or A-Pose.
Pro-tip 2
Re-mesh all subtools before you combine or merge them into more manageable sub-tools. Try to keep in mind the texture size limits of your project when combining your sub-tools.  You can always combine uv’s in a program like Blender and re-import to give your model new/updated uv maps if you have a very high poly model that requires many sub-tools to keep the sub-tool-poly-count down and export as a single FBX.
Pro-tip 3
When sculpting your details, sculpting with MatCap color painting turned on is essential for your material ID maps for later texture generation. For every part of your model, you should use a different MatCap. At the end, make all matcaps a flat material with none being the same color. Use UVMaster plugin that ships with ZBrush with poly-groups turned on in the plugin.
AccuRIG, Auto-rigger with Fast & Accurate Results
Next, you will need AccuRIG free software available from the ActorCore website. This program allows seamless transfer of the rigged model from a posed static one.
Open up AccuRIG auto-rigger, import your model that you exported from ZBrush and let the magic begin! AccuRIG auto-rigger is an amazing tool for getting your bipeds rigged fast, efficiently and most importantly, accurately. If your AccuRIG generated perfect guide placement on the first go, you’re all set.  If not, move them (use the guides) around to the joint placement you would like. AccuRIG also does hands — and does it well — with the ability to rig up to five fingers, including the thumb.
ActorCore, 3000+ Professional Mocap Animations
ActorCore 3D store makes it incredibly easy to pick something that will fit any flavor you could want. With a huge online library of 3D assets to choose from, you can find a subtle idle or an animation that empowers your character to do back flips. The possibilities are really endless, so have some fun!
Navigation in ActorCore has been streamlined for users, with a search bar that has a huge list of words it recognizes and a generalized nav bar with an expanding list on the left side that holds all the animations on the site. Along the way, if you find an animation that interests you, you can always favorite it by clicking the heart icon on the preview image to revisit later. After exploring the site, pick your animation and give it a double-click. It will appear on your character in the 3D preview window.  Click the purchase button and go through the next screens to make the animation downloadable and have permanent access to it.
Blender, Free Character Animation Editing
Blender is a great, free program you need for the combination of animation and model.  It has been around for many years and undergone substantial changes from when I was young.  With Blender, you can import many different files like FBX, with the rigs attached. Also skeleton files with keyframe data.  It also allows us to import animation to our rigged character and export them as a single object.
Essentially, we will be attaching the animation to the fully-rigged and weighted model downloaded from ActorCore.  Simply import your rigged actor and desired motion to Blender, then, with a few steps you can have the motions perfectly retargeted to the actor without any issues.
Pro-tip 4
Do not worry about deleting the original keyframes — the ones you are about to paste will occupy the same space and will overwrite the old ones.
Marmoset, Building Sophisticated Looks
Lastly, we need Marmoset Toolbag 4 for the final renders of any poses and the fully animated sequences.
It is time to see your work in action! With Marmoset Toolbag 4 open and ready, apply any and all textures created in whatever program you decided to use (I like Marmoset Toolbag 4).
Tweak your render, camera, lights and sky so you can get the perfect animation capture possible. The animation tab and your timeline are important to match up with the loop you are trying to create. So, here we are just making sure that the full sequence is captured and there are no partial repeats of it during rendering. Adjusting the animation speed directly on your model by first selecting the root in its hierarchy can help a lot with fine-tuning the speed of how the animation plays out during render times.
Press F5 (animation) and F11 (keyframe render) on your keyboard after you have done all required modifications to the settings and have the best-looking environment for your character. Wait for your render to record and think about angles for some single-frame renders that will really help highlight your project.
Final Thoughts
The method outlined here is my favored approach for a complete rigged, animated and rendered character simply because it works! It is quick, efficient and yields accurate and pleasing results. Before we had such a powerful tool (AccuRIG) to add to our pipeline, this was all done painstakingly by hand… Now with a few clicks, you’re ready for action!
This workflow and AccuRIG auto-rigger are a must-have, for the budding 3d artist and seasoned vet alike. Not only will it save you time and frustration, it will help you focus your workflow into a sharper point with a great UI and straight-to-the-point flow.  Try it yourself and have some fun!!!
Related Posts
The original article was written by Nathan Olsen and is also featured on BlenderNation.
Turning Hosted Podcast into 2D Character Animation
Lucky Planet’s self-introduction
Hi, I’m Lucky Planet. I’ve been a huge fan of “WiTcast,” one of Thailand’s first science podcasts, since 2012. Their stories always spark my imagination, and I thought it would be amazing to visualize them. So, one day, I reached out to see if they’d be interested in turning their stories into animations. That’s how it all started. The idea was simple: take a 3-hour podcast episode, distill it down to its key message, and create a vibrant 3-minute animation. This project got its initial boost from the Thai government media fund, which supports great content for all ages — exactly what we’re doing here!
From live broadcast to 2D character animation
Designing the 2D character animations took some time. I sketched a lot until I found the perfect designs. To cut down on production time and costs, I gave the characters longer arms and legs, which made their gestures more articulate and expressive. And, since they mostly stood or sat during the show without much action, this approach was ultimately the right decision.
Meet Professor Almond, our main host. He’s an alien dedicated to unraveling the mysteries of our world as a science communicator and advocate. I drew inspiration for his appearance from renowned science figures like Neil deGrasse Tyson and Bill Nye. His facial features are simple, mostly circles and squares, with distinctive rabbit ears to highlight his non-human origin. With broad shoulders, Almond defies the typical scientist stereotype. His signature color is blue, reflecting his cosmic origins and evident in his choice of fashion.
Next is Cookie, Almond’s co-host. She has no background in science, but dreams of becoming a YouTuber. To pursue this ambition, she’s teamed up with the Professor. Cookie’s design contrasts Almond’s — her color is red, and she wears huge pants to make her lower half look bigger compared to Almond’s top-heavy frame. We’re not sure if Cookie is human, since she has a big lucky clover on top of her head — a mystery for another day.
The most important feature for both 2D characters are their big, expressive eyes with large white areas. This allows them to clearly connect with the audience as they guide us through the amazing world of science.
Animating dynamic facial expressions
The audience will watch these two hosts’ faces for three minutes in every episode. In that timeframe, their facial expressions have to be interesting and relatable. Mostly, the characters would be talking directly to the camera or interacting with each other, keeping the 2D character animations dynamic. To achieve this, I used CTA’s “360 Head” feature, which allows for natural-looking and easily controlled head movements.
(3D Head Creator transforms 2D art into 3D styled characters with up to 360 degree of motion)
As expected, the voice actors really nailed it on their podcast. My only sole concern was to animate them as authentically as I could; and having known them for years definitely helps. I crafted approximately 10 mouth shape designs, and then let the software handle the lip-syncing automatically. However, it didn’t quite sync up perfectly with the Thai audio. With CTA version 4, I had to manually adjust about half of it. Interestingly, in version 5, I’ve noticed a significant improvement — it only requires about 30% manual editing now.
(Import a WAV file or capture your voice with an integrated recorder. A vast library of phoneme shapes is ready to be deployed on your images. )
Enhancing character motion with spring bones
“Spring bones” is a fresh addition in CTA version 5. It effortlessly applies dynamic movements onto stiff bones, as seen in elements like the rabbit’s long ears, hair, and the fluttering leaf. Once I animate the head and body, the rest simply falls into place, resulting in 2D character animations that are even more endearing.
The key lies in striking the perfect balance: Too many bones can bog things down, whereas too few can result in choppy movements. Cartoon Animator 5 offers a range of spring types to suit your needs, from highly elastic for exaggerated, cartoony motions to stiffer options for more nuanced or realistic movements.
Given that our 2D character animations steer clear of the exaggerated movements found in Looney Tunes, I prefer stiffer springs. This choice also helps keep the audience’s attention on the characters’ facial expressions. Setting up Almond’s ears posed a challenge, especially with the 360 Head feature in use. At certain angles, the inner and outer ear parts move independently. To manage this, I had to incorporate two separate bone sets for precise control.
Behind the scenes on character setup and storyboarding
With the character setup complete, it was time to dive into animation! I began by sketching out a basic storyboard to outline the timing and pacing. Given that it’s a talk show format, the animation remained fairly straightforward. I implemented a breathing motion clip as a default loop cycle and then layered on the arm and body movements. However, the main focus was on animating the facial expressions, as they’re crucial for engaging with the audience. It took me about a week to animate a single episode, followed by another week to create and integrate the illustrations into the storyline.
The show’s production kicked off in 2023, and we’ve now wrapped up the first season comprising 25 episodes. The response from Thai audiences has been phenomenal, with one episode even surpassing 3 million views on TikTok! This project initially received a boost from the Thai government media fund. However, I have grander aspirations — I aim to dub it in English and introduce it to a global audience. With this journey just starting, I’m in the process of securing funds and seeking out potential sponsors to make this vision a reality.
If you’re keen on helping this science show become a global sensation, feel free to reach out to me to discuss potential opportunities. Let’s collaborate and share the magic of podcasts with audiences worldwide!
Follow Lucky Planet
YouTube: https://www.youtube.com/luckyplanet
X: https://x.com/LuckyPlanet_One
Email: wonderlugia@gmail.com
Learn More
Official product page:
2D Animation Software for Cartoon Maker | Cartoon Animator
FREE for 30 days & get 1,700+ ready-made assets:
2D Animation Software Download | Cartoon Animator
Related Posts
The original article was written by Lucky Planet and is also featured on Cartoon Brew.
ZBrush guru Mike Thompson and his iconic Cammy sculpt, made with Character Creator and ZBrush
3D Sculpt of Street Fighter Cammy: Power posed with ZBrush Pose Tools and Character Creator
Mike Thompson / Stylus League
Mike’s career in the creative industry is nothing short of extraordinary. With over two decades of experience, he has worked with AAA companies, leading high-profile projects and mastering both 2D and 3D realms. His clientele includes industry titans like Hasbro, Electronic Arts, Dimension Films, and Sideshow. Recently, Mike, a Clio award laureate, joined Microsoft Games as an Art Outsourcing Manager. His journey is a testament to his relentless pursuit of creative excellence.
Why I chose Character Creator and Pose Tools
Ever since I started collecting statues of my favorite comic book heroes, I’ve been captivated by their dynamic poses. I aim to infuse this dynamism into my sculptures, but it’s no easy task! Before discovering Reallusion’s Character Creator, I relied on Transpose Master in ZBrush for posing. It was functional, but far from ideal, and quite destructive. Once a pose was set, altering it was a challenge.
Then came Character Creator Pose Tools, a game-changer with its user-friendly interface and flexibility. It allows me to experiment with multiple pose iterations before finalizing. No matter how well-sculpted, textured, or detailed a character is, a weak pose can undermine the entire piece. When I decided to sculpt Cammy, I knew her pose had to be powerful. Thanks to Character Creator, I was confident I could achieve it.
Detailed Walkthrough
ZBrush Modeling
My process for preparing Cammy to go from ZBrush to CC4 is very similar to the one I use for ZBrush posing. The key is to ensure a low-poly mesh that gracefully supports intricate details at higher subdivision levels. Equally crucial is a topology with loops that accommodate joint deformation. Naturally, this is my initial step before assigning polygroups for effortless selection, aiding in isolating tricky parts for detailed sculpting.
Original Capcom Cammy Art – StreetFighter 5. Copyright Capcom
GoZ and AccuRig
Seamlessly moving a file between ZBrush and Character Creator requires some preparation. I begin by ensuring each element is named for easy identification in AccuRig (organization is key). With all subtools in view, I utilize the PoseTools plugin to scale down my model before exporting it to CC via GoZ.
ZBrush Modeling
I chose to exclude Cammy’s exaggerated ponytails, as posing them in ZBrush later would be simpler. By toggling off their visibility along with the base, I can send the remaining elements to CC4 for AccuRigging. It’s crucial to uncheck ‘All Meshes’ and check ‘Selected Meshes’; thus allowing me to choose only the components I wish to deform organically.
Posing in Character Creator
Once the AccuRigging process is complete and pose dots are fine-tuned, it’s time to bring Cammy to life! I had a few options: manual posing, using the motion library, or a blend of both. Character Creator boasts an impressive motion-captured library, perfect for selecting the ideal animation or static pose.
As a non-animator, this feature is a godsend! The Reallusion store also offers additional pose packs for purchase. For Cammy, I had a distinct pose in mind, so I opted for manual posing. The focus was on conveying weight distribution and kinetic energy, vital elements for a dynamic pose.
Fine-tuning in ZBrush
Having refined Cammy’s pose in CC4’s Edit Pose window and diligently saved iterations, I’m on the home stretch. I bypassed ‘Weight Painting’, leaving minor compression areas to address. No worries, though! A quick return to ZBrush lets me rectify any anatomical issues, then reintroduce the hair and base. With the pose finalized, re-sculpting problem areas is a breeze. I typically employ a trio of brushes – Move, Clay Buildup, and Dam Standard – to infuse volume and detail into my sculpt.
Create a turntable podium for Cammy
Upon finalizing the pose and detailing, I utilized ZBrush to ready my model for 3D printing. With a vision of a 1/6th scale statue, I employed Scale Master to aptly size all my subtools. Then, I strategically DynaMeshed the parts together. The final steps involved cutting and keying everything, followed by using the 3D Print Hub to convert the parts into .stl files, ready to be sent to Lychee Slicer. This meticulous process ensures a seamless transition from digital sculpting to physical manifestation.
Final thoughts
Integrating Character Creator into my workflow has been a game-changer. As a long-time ZBrush sculptor, I yearned for a tool that could help me swiftly generate poses for iterative and future sculpting. Character Creator not only fulfills this need but does so with an intuitive learning curve. I’m particularly fond of the pose libraries and body morphs that CC4 offers. This software has become an invaluable addition to my pipeline, and I eagerly anticipate the advancements in its future iterations.
Learn More
Related Posts
Filmmaker Richard Mans Reveals Workflow Secrets with iClone, Unreal Engine and Cargo!
This article is featured on 80 Level
Filmmaker Richard Mans and his latest vertical shorts on Fuzzy Realms channel
Richard Mans / Fuzzy Realms
Richard Mans is a New Zealand-based artist and filmmaker renowned for his fantastical short-form videos. His acclaimed 2011 animated short film “Abiogenesis” garnered widespread acclaim, winning awards and enjoying an extensive festival run globally. He also focused on animations and user experiences for prototype display technologies in the Automotive industry, where Mans continued to innovate.
Excited by the possibilities of high-quality real-time rendering, he is now dedicated to creating captivating short-form videos. “Fuzzyrealms” serves as his online portfolio, showcasing his latest works. Passionate about crafting brief glimpses into fantastical worlds, Mans finds inspiration in daily creativity. Follow him on Instagram, YouTube, Facebook, TikTok, or subscribe to his mailing list for updates.
Act out your dreams
My initial idea is very loose. No storyboards, I just dream and edit shots in my head. Once I settle on an idea I put on my motion tracking suit (I use a Perception Neuron 3 suit) and start acting out the characters in the scenes, this process helps me further refine my idea.
I record my Motion Capture directly in iClone using the Motion Live Plugin. I find that seeing my motion capture in realtime on a human character helps me troubleshoot issues with the motion capture performance that I may not see using a plain Motion Dummy.
Refine your performance with iClone
Two tools in iClone that I always use for editing my motion capture are the Smooth Filter and the Edit Motion Layer tool.
The Smooth Filter (found in the Curve Editor) eliminates any unwanted jittering noise that is usually in the raw Motion Capture Data. Sometimes I may not even notice the jittering until my final render when I’ll notice what looks like the character skipping frames. So I find It’s good practice to start with the Smooth Filter.
I use the “Edit Motion Layer” tool to fix more obvious issues like hands passing through the character’s leg, and correcting the character’s posture.
Give it soul
Once I’m happy with the edited motion capture, I blend various facial animation clips (from Reallusion’s “Digital Soul” pack) in the timeline. This way I can quickly create a natural-looking facial performance that matches my motion capture.
Simulate a crowd in iClone
Looking at reference videos (on YouTube) of busy streets in New York City reminds me that there’s often a flow of pedestrians walking down a street. For example, groups of people moving in one direction tend to stick to a certain side of the path. So I create two paths with characters flowing in opposite directions to achieve this effect. Then add a few more people to a third path in the distance to give the scene more depth.
Creating crowds of characters can be taxing on system resources, so preferably every character needs to end up in the final camera shots. So I restrict the paths to areas where I imagine the camera shots will go.
Send everything to Unreal Engine
Transferring everything to Unreal Engine is very straightforward using iClone’s “Unreal Live Link” plugin. First under the “Transfer File Settings” I deselect “Place Actors in Scene” and select “Bake all animations to sequencer” then transfer my two main Characters. Then I change the “Transfer File Settings” to “Exclude Morph Targets” and transfer all the other characters (the crowd). This way everything is optimized and organized nicely into Sequences in Unreal Engine.
Now that everything is transferred to Unreal Engine, I play with my cameras in Unreal Engine until I’m happy with my shots and the camera cuts in Sequencer.
Dress it up with Cargo
With the performances and cameras in place, I use Cargo (a plugin by KitBash3D) to dress up the shots.
Cargo gives me access to a huge library of assets that I can instantly import into Unreal Engine. I simply select the asset in the Cargo interface, click import and after a few seconds the asset loads in Unreal Engine with all the materials applied.
Finishing touches and thoughts
I add color grading and VFX elements (like the dust particles at the end of this short) using Adobe After Effects. Then sound effects and music using Adobe Audition. I love playing around with the sound and music, it’s where the short really comes to life.
Thanks for joining me through this process and I hope you’ve gained some valuable insights into creating short-form animations. With tools like iClone, Unreal Engine, and Cargo, the possibilities are endless. So, whether you’re an aspiring filmmaker or a seasoned pro, keep pushing the boundaries of creativity and never stop dreaming big! Please check out my @fuzzyrealms social media channels to see more of my work. Thanks!
Related Posts
The original article was written by Richard Mans and also featured on 80 Level.
Beginners Guide to the BuildingGen Plugin
Generative building creation comes in many forms including extrusion-based, agent-based, and procedural. More complex generative applications like CityEngine can create an entire town or city but can be extremely complex to learn if you are unfamiliar with procedural generation.
iClone’s BuildingGen plugin is the opposite of complex with Reallusion’s typical “easy to use” approach as you only need to keep up with a few things. We can learn its basics with primitives as used in the tutorial below, or the supplied building pack and the new French Style pack.
There are a couple of things you must pay attention to, or you will get, what seems to be, very chaotic results when the plugin is simply doing what it was instructed to do.
One errant dropdown menu choice or checkbox in the plugin concerning Levels or Type can produce unexpected results.  Understanding why this happens can open the door to using your own or other building kits. As long as the kits provide separate walls, floors, and a few other necessary components that the plugin needs, BuildingGen can use them to create custom buildings.
While this plugin has a slight learning curve, it is not a complicated tool; all one has to do is wrap their head around exactly what they are telling the plugin to do.
If, for example, you add the short trim wall to the top level and forget to uncheck the default first level checkbox you get a combination of the regular wall and short trim wall on the first and top floors creating what looks like a jumbled-up mess but was in fact what you told the plugin to do by failing to uncheck the proper checkboxes.
Left: A properly created customer BuildingGen package. Right: Same package with only a couple of mistakes in checkboxes. This is covered in the tutorial.
Learning the Basics
I thought the easiest way to learn the plugin was to create a new BuildingGen package using the props that came with the plugin or the French-style pack. Using these, instead of a custom or third-party building kit would help me to understand what is happening and why it happened. This is because I would be working with props that I know are sized right and will work with the plugin. If you get unexpected results with these props, then you know you have an error.
While this did help me to learn the plugin, it was still a bit confusing with the actual windows, doors, and other props getting in the way of a clear view and now I needed to learn how to import props of differing sizes. I decided to create a building package (simple template) out of primitives that come with iClone.
One of the most important things I discovered was it does not matter how precise building pieces are in dimensions as you can alter the scale on any axis to make it a 2-, 3-,4- or whatever meter package. By this I mean does the floor take up 2 X 2 grid squares or 3X3, 4X4? We get to determine that by resizing the components to whatever size meets our needs for that particular building package or we can just go with the native sizing. All the plug-in needs to run without error is a floor and wall prop so this is where we will start in the tutorial. After this, we will add the other components.
The tutorial shows each step for the wall, floor, door, window, and Pillar. Some of you will pick it up quickly after watching the first floors and walls packaged and won’t need to watch the entire video but each component is covered for those that want to see it all come together. Once you’ve built your first successful package you apply the same principles to custom kits.
NOTE: I start with the floor.  Scale it first as in the video tutorial. It serves as the visual guide for the sizing of the remaining walls, doors, windows, and pillars. Most building kit components will not need to be rescaled, but they still can be if you need to. This makes the plugin very flexible in terms of importing our own custom-made props that might not be exact in dimensions.
NOTE: In Kai’s tutorial on external assets, he talks about having to center an object and reset its transform so it will be at the world center with a proper pivot. This is necessary because many building kits have assets spaced out across the workspace which sets their pivot points to the center of the entire project, not each prop within the kit. In my template example, we are building the props at the world center so there is no need to reset the transform as required in Kai’s tutorial.
Toon Castle
This was a fun project. It came from Sketchfab and not all the parts are used but it does have the necessary doors, windows, and pillars the plug-in needs for a basic building package. I made a floor 4 X 4 grid squares out of primitive and gave it a wood plank texture for the floor.
This tutorial demonstrates how to import the usable parts of the building kit, create a custom BuildingGen package from those parts, and then make a castle with buildings, towers, and walkways surrounded by castle walls within minutes.
Think Outside the Box
There are a lot of building kits out there, but you won’t be able to use all of the components in them like oddly shaped walls or roofs. However, you can use the regular walls, doors, windows, and pillars so look for those items in particular when searching for kits.  If there are windows and doors but no walls, then grab the texture(s) from the building and create your walls out of primitives using the textures from the kit.
The Toon House from Sketchfab is a good example of using parts from a kit and making your own for the parts that may be missing due to the way the model is created. In this case, there was no separate wall or floor. The walls were two different, irregular meshes versus a wall.
To remedy this, I created a wall and then used the eyedropper tool in materials to grab the texture from the irregular walls and transfer it to my newly made wall component. All I had to do was scale it which is easy using the window and other props as size guides. I repeated the same process for the floor prop. This method is detailed in the template tutorial.
The image below shows the various parts of the Toon House and the irregular walls. In front is the wall and floor I made to work with the other kit components to be able to make toon houses.
Left: Individual parts in the kit that can be used. Middle: The irregular walls. Right: The original Toon Building. Front: The wall & floor created from primitives.
French Style Atrium Building
As I wrote earlier my first try at learning the BuildingGen plugin used props from the French Style pack to create a conservatory/atrium-style building like a fine arts center.  I was looking for an elegant style with old-school vibes and large windows but not just plain windows. The AT windows in the pack made it work. I also had to correct the texture on the window glass when making the package so it would be transparent with some reflection mapping. This only had to be done on one window to change all of them.
In my testing example below, I used the custom BuildingGen package to create the major structures then built out the connecting walkway and used roof props for a different roof. I later learned I could have used the plugin to create the walkways as I did for the castle walls in the Toon Castle tutorial.
CAUTION: The video below has audio.
Below is the final package for the Atrium building for those that have the French Style pack and want to re-create the basic building package.
The secret to BuildingGen is… there is no secret.
Just pay close attention to the checkboxes and dropdown menu selections for each item. If you get an erratic result, go back to your packager and make sure the affected level doesn’t have conflicting or multiple props. The drop-down menu Type and Level Checkboxes can create a great custom-building package or a nightmare of conflicting parts with just a couple of errant checkboxes.
Quick Tip
You can make an interior hallway with BuildingGen using a two-sided wall or a wall turned 180 degrees to face the interior instead of the exterior.
I hope these tutorials can get you jumpstarted on creating custom BuildingGen packages along with Kai’s great tutorials over at Reallusion Courses.
A BuildingGen pack by Ranger J – Cartoon City – New York Style. Inspired by New York City architecture.
From the Product Page:
This product contains tons of props, and buildings with different structures can be quickly produced using the building gen plug-in. In addition, I have prebuilt the assembled buildings and even prepared the streets and scenes, so even people without a plug-in can enjoy the fun of this pack.
MD McCallum - WarLord
MD McCallum – WarLord
Digital Artist MD “Mike” McCallum, aka WarLord, is a longtime iClone user. Having authored free tutorials for iClone in its early years and selected to write the iClone Beginners Guide from Packt Publishing in 2011, he was fortunate enough to meet and exchange tricks and tips with users from all over the world and loves to share this information with other users. He has authored hundreds of articles on iClone and digital art in general while reviewing some of the most popular software and hardware in the world. He has been published in many of the leading 3D online and print magazines while staying true to his biggest passion, 3D animation. For more information click here.
Innovating the Future of 3D Animation Education at CMII
The Creative Media Industries Institute (CMII) has been at the forefront of integrating cutting-edge technology into its curriculum, ensuring that students are well-prepared for the dynamic world of media and entertainment.
Professors at Creative Media Industries Institute in Atlanta, Georgia , James Martin and Max Thomas, have been instrumental in this innovation, particularly in the fields of Advanced Visual Effects (VFX) and 3D Animation. Leading the way with projects focused on helping students develop their storytelling skills along with a valuable introduction to core technical requirements that will help them compete in the everchanging world of 3D animation and VFX.
CMII Professor James Martin, 3D Animation
Professor James Martin’s approach to teaching 3D Animation (CMIS 4160) is a testament to how modern tools can revolutionize education. Using Reallusion iClone software, Martin introduces students, many of whom are first-time animators, to animation through practical, real-world production scenarios. The course is structured around three comprehensive modules: Character Animation, Crowd-Simulation creation, and Motion Capture Animation cleanup.
“Reallusion iClone provides an accessible yet powerful toolset for students to immerse themselves in the world of animation. By simulating real-world production scenarios, students not only learn the technical skills but also understand the workflow and collaboration required in the industry.”
James Martin, CMII Professor 3D Animation
3D Animation CMIS 4160
25 Students – 16 Weeks – 3 Modules
Character Animation: In this module, students delve into the fundamentals of character animation. They learn to create and edit animations using the Timeline and Non-linear editing techniques in iClone. This hands-on approach helps students grasp essential concepts such as Transition Curves, Motion Blending, and Pipeline exporting. Through custom motion creation, they explore face, body, and hand animation, which are crucial skills for any aspiring animator.
Crowd-Simulation Creation: This module introduces students to the complexities of creating large-scale character animations to bring scenes to life. By working on crowd simulations, students learn to manage and animate multiple characters simultaneously, a skill highly valued in the industry.
Motion Capture Animation Cleanup: In the final module, students engage with motion capture data, learning how to clean up and refine this data for use in their projects. This involves applying motion editing and Motion Layer editing techniques to character rigs, combining keyframing and curve editing to achieve performance animation.
The Role of Discord in Learning
A significant innovation in Martin’s course is the integration of Discord as a teaching tool. This platform fosters a sense of community and accountability among students, allowing them to share their work, receive peer feedback, and grow collectively. Peer reviews on Discord are crucial as they enable students to critique, respond to feedback, and refine their projects in a collaborative environment.
The curriculum is delivered through a blend of online and lab-based instruction, supplemented with highly curated tutorials, assessments, and live training. Over 16 weeks, students benefit from lectures, demonstrations, and materials provided by Reallusion and curated by Professors James Martin and Max Thomas. The use of Discord extends the learning environment beyond the classroom, enabling students to remain engaged with their projects and peers.
3D Animation Student Showcase
Throughout the semester, students showcase their work on Discord, culminating in final projects that highlight their skills and creativity. These projects demonstrate the comprehensive knowledge and competencies they have acquired, setting the stage for successful careers in animation. Each semester the CMII invites students to showcase their work at a public event that allows students to present their semester projects and receive opportunities to to engage with local businesses, university administrators and fellow students.
Top 10 Student Animation Projects from each 3D Animation module:
Character Animation, Crowd Sim, Mocap Cleanup
Module 1: Character Animation: Alex Criss
Module 1: Character Animation: Ian Chasse
Module 2: Crowd Simulation: Alex Criss
Module 2: Crowd Simulation: J Wilson
Module 2: Crowd Simulation: Travis Le
Module 2: Crowd Simulation: J Clark
Module 3: Mocap Clean Up: Ian Chasse
Module 3: Mocap Clean Up: Alex Criss
Module 3: Mocap Clean Up: J Clark
Module 3: Mocap Clean Up: Emily Tran
Continuing Innovation at the CMII – Preparing Students for the Evolving Animation Pipeline
The innovative teaching methods and tools employed by Professors James Martin and Max Thomas at CMII exemplify the institute’s commitment to providing cutting-edge education. By integrating tools like Reallusion iClone and platforms like Discord, they prepare students not just to enter the world of animation but to excel in it. The skills and experiences gained in these courses equip students to contribute to the vibrant entertainment industry in Georgia and beyond.
At the Creative Media Industries Institute (CMII), the curriculum is designed to provide students with a comprehensive understanding of the animation pipeline, ensuring they are well-equipped to navigate the ever-evolving landscape of digital media and animation. The courses emphasize the importance of mastering a wide range of tools and technologies, connecting students to industry-standard software and practices.
The teaching pipeline at CMII is meticulously designed to mirror real-world production workflows. Students begin with foundational skills in modeling and animation, gradually progressing to more complex tasks such as rigging, motion capture cleanup, and integrating animations into interactive environments. This structured approach ensures that students not only learn the technical skills but also understand the workflow and collaborative nature of the industry.
Reallusion Toolset and Workflow Curriculum
Students at CMII are introduced to a robust pipeline of character and animation tools, essential for a career in animation and VFX. The curriculum covers:
  • Reallusion Character Creator and iClone for learning how to create and animate highly transferable characters for games, films, virtual production and AEC visualizations and simulations.
  • Unreal Engine: Students learn to integrate their animations into Unreal Engine, a leading platform for creating interactive experiences and real-time 3D content.
  • Nvidia Omniverse: The integration of Nvidia Omniverse allows students to collaborate and simulate complex scenes, leveraging real-time ray tracing and AI-enhanced workflows.
  • Unity: Unity’s versatile platform is used to teach students about creating interactive animations and game development.
  • Maya: An industry staple, Maya is employed for character rigging, animation, and VFX, providing students with a strong foundation in professional-grade software.
  • Generative AI workflows as an artist’s tool and how to incorporate AI into the creative process.
Lifelong Learning in a Rapidly Evolving Industry
The courses at CMII emphasize the necessity of lifelong learning. With technology and industry standards constantly evolving, students are encouraged to stay aware of the latest developments and continuously refine their skills inside the institute and beyond. The comprehensive training in various tools like Reallusion and Unreal ensures that graduates are adaptable and ready to tackle the challenges of the competitive animation and entertainment industry.
By equipping students with a diverse skill set and a deep understanding of the animation pipeline, CMII prepares them for a future in an industry that demands both versatility and specialization. The integration of tools like Unreal Engine, Nvidia Omniverse, Unity, ZBrush, Blender, and Maya ensures that students are not only proficient in current technologies but are also prepared to adapt to future advancements. This comprehensive education model fosters a culture of lifelong learning, essential for success in the rapidly evolving world of animation and VFX.
Reallusion is offering the following benefits for educators and students:
World’s Lightest Face Capture Device with iClone AccuFACE
It’s Time to Ditch the Bulky Helmets:
Rokoko Unveils World’s Lightest Face Mocap Device
Copenhagen, Denmark – May 22, 2024 – Rokoko, the leader in affordable motion capture technology, is thrilled to announce the launch of the Headcam. Designed to address the long-standing issues of cumbersome, bulky helmets and the impracticality of iPhones dangling over your face, the Headcam offers a non-intrusive, portable, and versatile solution for real-time face capture at an accessible pre-order price of just $495.
Goodbye Bulky Helmets
Everyone has seen footage of large, uncomfortable, and restrictive helmets used by motion capture actors. Rokoko’s Headcam eliminates these issues with its lightweight, ergonomic design, offering unrestricted freedom of movement without the neck-aches. Weighing just 240 grams, the Headcam features a high-resolution 60 fps camera, dimmable LED lights, and a built-in microphone, all housed within a perfectly balanced and adjustable head rig.
“We created the Headcam to solve the problem of the bulky and often comically impractical helmet that has dominated the facial motion capture industry.. As the demand for animation and 3D content continues to explode, we believe it’s crucial to offer tools that are not only effective for professionals but also accessible to creators at all levels.”
Jakob Balslev | Founder and CEO of Rokoko
Empowering creators in the age of 3D and animation
In line with Rokoko’s product ethos, the Headcam is designed to be workflow-agnostic, and can integrate with AccuFACE, Faceware, and VSeeFace for a multitude of use-cases. Furthermore, Rokoko’s new Face Capture app for Android also comes with its own mocap solver, which is included free for the first 12 months with pre-orders, and syncs the Headcam directly to their Studio software enabling real time full-body performance capture. This adaptability makes the Headcam an essential tool for a wide range of animation and 3D projects, from indie animators to professional studios.
Facial mocap with iClone’s AccuFACE
AccuFACE plugin for iClone is an AI facial tracker powered by NVIDIA RTX GPU, capable of capturing facial expressions from Rokoko Headcam and conventional video files to empower remote collaboration with performers around the world.”
Enoc Burgos | Director of Marketing at Reallusion
Balslev continues that “Camera-based solutions are often impractical, but essential for face capture since sensors can’t be placed on the face. There’s a clear lack of sensible solutions for smooth face filming. With the Headcam, we’ve addressed this need and are excited to see what our community will create with it.”
The Headcam can be pre-ordered today for $495, with worldwide shipping starting early August.
About Rokoko
Rokoko is a pioneering company in the field of motion capture technology, with offices in Copenhagen, Athens, and San Francisco, serving over 300,000 users in more than 125 countries. We are dedicated to empowering creators with tools that bring their digital characters to life in the most intuitive and efficient ways possible.
How to Make Good Use of Reallusion Stores & Content
One problem that faces any animator is content. Props, terrains, characters, and all those things that go with making an animated production. For a lot of animators, it seems there is never enough content anyway, whether it was purchased, freebies, or homemade.
It wasn’t that long ago that there wasn’t much content available for animators in any form. There has long been content for image renders, but in times past and even today, a lot of those assets are too poly-heavy to be used in animation. The computational overhead would bring a lot of computers to a crawl. A workable framerate would be almost impossible to achieve.
A lot of early iClone users learned to make content for their projects. Reallusion was a leaner company as most are in their early days, and the focus was on software development. They still managed to provide a lot of great content but as I stated earlier, there is never enough.
Flash forward to today where there is a staggering amount of content available for iClone. Reallusion, by itself, is releasing more content on a regular basis than I can keep up with as a writer.  Reallusion content has always been professionally made with best practices and has proved to be exemplary in visual quality and construction.
In addition to the Reallusion Content Store, there is the Marketplace that is open to third-party iClone content developers. These assets run the range from professional to budget-friendly. There is also a rating system for the content developers and their products by users who have purchased any of those products.
Then there is ActorCore, a website full of characters and motions that can give a boost to any project. Professionally produced content from animators… for animators is a core strength of Reallusion content and ActorCore is at the forefront.
In terms of general content available, you can storm a castle, fly into space, have a talk show, a hospital drama, a daytime drama, a daytime hospital drama… the possibilities are almost endless.
There is so much content available currently that it can be a bit confusing to new users as to which store to use and what their purpose is. The Software Store, Content Store, Marketplace, and ActorCore all serve different purposes so let’s take a look at what these stores provide.
The Software Store
This is where you purchase software applications like iClone, Character Creator and Cartoon Animator (2D).
Bundles & Specials:
  • iClone Unreal Live Link – a cinematic pipeline from iClone to Unreal Engine. Don’t panic over the listed price. The plugin was designed for large studios so there is a free Indie Live Link program that you can use if you qualify. Annual gross revenue from design work must be less than USD 100,000. You can get more info at the bottom of the live Link page. There is also a free 30-day trial.
  • Animation and Film – 3D Animation & Character Creation
  • Ultimate Digital Human – Realistic Character Creation
  • Draw to Animate – Works with PSD Tools and WACOM
The Content Store
The Content Store really must be seen to be believed. There are so many professionally produced assets from Reallusion and select developers that it is difficult to convey in words. Just to say it has characters, props, and other 2D/3D assets is a vast understatement.
It is a vault of 2D and 3D goodies that can improve a project and remove the burden of asset creation allowing you to focus on animating and telling a story.
There are themes, genres, and one-off custom creations that you can use in your next production from a children’s cartoon to a historical documentary. The Content Store contains a huge inventory and mixture of assets that meet just about any need.
Actorcore
ActorCore is another store loaded with content and bills itself as a “One-Stop platform for 3D motions, characters, and rigging due to its vast amount of assets available for immediate download”.
Not only are there 3D motions and characters, but there is also the free character auto-rigger, accuRIG. This free download is a powerful character rigging tool that allows you to map out or create enough bones to get quality animation.
Features of ActorCore:
3D Motions:
  • ActorCore provides a vast library of high-quality 3D motion assets suitable for various applications, including games, films, interactive projects, architectural visualization (arch viz), training, simulations, and digital twins.
  • These motions are meticulously designed to meet different demands and themes, ensuring the best quality and accessibility.
  • Whether you’re animating characters for a business simulation, a training program, or a cinematic project, ActorCore has you covered.
3D Characters:
  • ActorCore’s 3D characters come in different styles, catering to diverse needs.
  • Photorealistic People: These characters are created from 3D scans, resulting in highly realistic human models.
  • Sci-Fi, Fantasy, Historical, and Toon Figures: These characters are crafted using Character Creator, offering versatility and creativity.
  • The characters are animation-ready, and you can easily import them into your preferred application with specific download formats for optimal rendering quality.
  • They feature color and material variations, allowing you to customize skin, hair, outfits, and accessories to create unique actor styles.
  • The character rigs are complete, ensuring realistic animation from head to toe. With consistent facial topology, you can edit expressions and control lip-sync.
3D Viewer:
  • ActorCore’s 3D Viewer offers complete customization for mobile viewing, web embedding, and content sharing.
  • With the preview window, you can easily assemble uploaded characters or try out motions in ActorCore, and enjoy the best viewing experience with a customized camera view, light setting and motion list.
Smooth Transitions and AAA Motion Production:
  • ActorCore employs a specially designed motion system for seamless transitions between primary and secondary stance modes.
  • Each motion pack undergoes a strict design process to deliver the best quality and meet project expectations.
Multi-Platform Support:
  • ActorCore’s massive 3D character animation library is compatible with all major 3D programs.
  • You can easily retarget motions to selected characters and find step-by-step guides and tutorials for each program.
ActorCore is compatible with Unreal Engine, Unity, Maya, MotionBuilder, Blender, 3ds Max, Cinema 4d, Nvidia Omniverse, and, of course, iClone, Character Creator and Cartoon Animator.
The Marketplace
A lot of what I wrote earlier about the Content Store is also true of the Marketplace with the content of the marketplace being produced by users and third-party content developers. In no way does this mean the quality of assets is inferior to the Content Store, they are just sourced from the public instead of in-house.
The Marketplace contains over 200,000 assets from budget-friendly to high-end assets and everything in between. The marketplace also operates as a community store that has a rating system for vendors and products so you can have an idea as to the quality of the product and read or leave feedback.
There are so many talented developers in the Marketplace that it can be hard to choose what to download. Some people draw inspiration from the characters they see in the Marketplace and create stories to match those characters.
One of the advantages of using the Reallusion Marketplace is the access to free trial content. You can select Trial Content from the Marketplace, download them via the Content Manager to try before purchasing. If you are satisfied with the trials, then you can directly add them to your cart for checkout.
You can think of the Marketplace as a huge world bazaar stuffed full of 2D and 3D assets of all sorts from all sorts of places and creators.
Reallusion Prime
Reallusion Prime is not a store but an annual subscription service that provides access to a library of digital assets, including characters, animations, props, and other 2D and 3D animation assets, which users can use in their animation projects.
  • Membership Cost: For an annual fee of $99, you gain access to a range of perks and discounts.
  • 15% Off Storewide: As a Prime member, you enjoy an extra 15% discount on all your purchases throughout the year. This discount applies to both software and content available in Reallusion’s online stores, including the online Software Store, Content Store, Marketplace, and ActorCore.
  • Bonus Points: When you shop in any of the Reallusion stores, you receive 500 Bonus Points each month. These points can be redeemed for future purchases.
  • Renewal Offer: When it’s time to renew your membership, you can do so for just $79/year.
  • Wide Selection of Assets:
    • 2D & 3D Animation Software: Access professional animation tools with perpetual licenses (no subscription required).
    • Branded Content Assets: Explore a wide variety of 2D and 3D assets.3D Motions, Actors & Auto-Rigging: A one-stop platform for all your 3D needs.
    • Community-Created Asset Creations: Discover content from the developer community.
  • Flexible Subscription: You can cancel your Prime membership anytime if needed.
Reallusion Prime provides substantial savings, exclusive offers, and a wealth of creative resources for animation and content creation. Subscribing to Prime can significantly enhance your budget and creative toolkit.
Not long ago Reallusion launched an authoritative structure Reallusion Workgroup for small studios or enterprises to no longer have to share private account credentials among teammates. The solution involves designating managers and administrators responsible for licensing and purchasing software and assets for the staff. They also require the capability to allocate and oversee licenses while maintaining control.
With the Prime for Team plan, contractors are able to deliver their work in a secure, private environment, ensuring confidentiality. This plan is specifically tailored for collaborations, to accommodate two versatile usage scenarios: outsourcing services and group projects. Whether you’re leading a seasoned production house, steering a startup studio handling client productions, or seeking collaboration with contributors for your creative ventures, Reallusion Workgroup is a helper to elevate your entire production process.
Summary
There is no way to properly convey the sheer amount of 2D and 3D content available in the Content Store, Marketplace, and ActorCore. All the stores are setup for easy purchase and download with assets being available through the Smart Content Manager for iClone and Character Creator or formats friendly to most of the industry-leading 3D software applications.
If you are undecided about purchasing a Reallusion product you can rest assured that a lack of content will not be a problem and for some can be a deciding factor when looking for animation tools.
FAQ
Where can I download Reallusion content assets?
You can download assets from the Reallusion Content Store and Marketplace, which offer characters, motions, props, and environments for tools like Character Creator, iClone, and Cartoon Animator.
Are Reallusion Marketplace assets safe to use?
Yes. Marketplace assets are reviewed by Reallusion and sold by verified developers, ensuring compatibility with Reallusion software and reliable downloads.
What is the difference between the Reallusion Content Store and Marketplace?
The Content Store features curated content packs created by Reallusion and certified developers, often sold as bundles and supported with official customer service. The Marketplace, on the other hand, is a community-driven platform where independent creators sell their own assets directly to users. Marketplace items are typically sold individually and may include trial downloads, while the Content Store focuses more on professionally packaged asset collections.
Can you try Reallusion Marketplace content before buying?
Yes. Many assets in the Marketplace offer a trial download feature, allowing users to test content before purchasing. This “try before you buy” approach helps creators evaluate whether an asset fits their project before committing to a purchase.
Can you sell your own assets on the Reallusion Marketplace?
Yes. Creators can become Marketplace developers and sell their own characters, motions, props, and other digital assets to the global Reallusion community.
2024 Reallusion 3D Character Contest: call for entries
Join the 2024 Reallusion 3D Character Contest
Groundbreaking character workflow for leading studios worldwide
From character design and modeling to animation, Reallusion is revolutionizing the 3D industry with innovative pipelines with ZBrush, Unreal Engine, Blender, Omniverse that automate character production without sacrificing creative flexibility. Reallusion’s extensive content ecosystem provides ready-made models and motions suitable for various mediums, including games, films, architectural visualization, digital doubling, and twinning. Character Creator stands out as the premier character creation platform, while iClone offers the most intuitive real-time animation editing. Combined with the rich asset library on ActorCore, character designers and artists can achieve impressive results at unprecedented speeds.
Calling for passionate and exceptional 3D artists
The 2024 Reallusion 3D Character Contest offers the 3D art community an excellent opportunity to experience industry-leading solutions and learn from seasoned professionals. It’s also a great platform to showcase your talent and skills to a global audience, gain valuable feedback, and see how you compare with your peers. Reallusion invites all enthusiastic 3D artists to participate, including concept artists, character artists, 3D scan artists, animators, digital modelers, and sculptors. Discover how easily iClone and Character Creator can enhance your existing artistic pipeline and how ActorCore provides the foundation to rig any character for real-time animation.
Explore fully-licensed Reallusion software for 3 months
Reallusion is excited to welcome new artists by offering free 3-month access to its software and plugin suites for qualified applicants with exceptional skills. To apply, simply submit your online portfolio (like ArtStation) for review. This one-time offer includes the chance to experience Character Creator, iClone, AccuFACE, Headshot, Face Tools, and Unreal Live Link.
Sponsored by the biggest names in the 3D industry with a $45,000 prize pool
This event is sponsored by top names in the animation industry, with $45,000 in cash and products up for grabs. Physical prizes include NVIDIA RTX-4070 laptop and full mocap solutions from Rokoko and Noitom. Software prizes include KitBash3D Cargo, Texturing.xyz, 3Dconnexion, Keen Tools and a Maxon One license that includes ZBrush.
Reallusion is also honored to have well-regarded judges such as ZBrush Guides founder and Blender expert Pablo Munos, and renowned Blender filmmaker Martin Klekner.
Contest categories for submission
The 2024 Reallusion 3D Character Contest features three main categories: “Best Character Design,” “Best Character Animation,” and “Best AccuRIG Character.” Each category offers unique cash and product prizes. The “Best Character Design” and “Best Character Animation” categories are further divided into “Realistic” and “Stylized” subcategories, mirroring their respective prize distribution models. In all, there are five contest categories:
  • Best Character Design (Realistic & Stylized)
  • Best Character Animation (Realistic & Stylized)
  • Best AccuRIG Character
Gain exposure, win prizes, and become a partner
Besides cash awards and special prizes, Reallusion will offer distinguished contestants featured on renowned 3D media sites. Selected artists may also be invited to join the digital content creation ecosystem and monetize their work, or be contracted for showcase projects. What are you waiting for? Join now and submit your entry before September 1 to win big!
