首頁 » Page 33
Mastering 8 Key Animation Skills, A Minute at A Time
Lessons from Minute Guides
Cartoon Animator 5 is a powerful 2D animation software for creating engaging and dynamic animations. Whether you’re a seasoned animator or a beginner just starting out, mastering the essential tools offered by this software can significantly enhance your workflow and creativity.
  • Eight key functions that every animator should become proficient in to fully leverage the capabilities of Cartoon Animator 5.
  1. Motion Pilot – Animating without the timeline
  2. Face Puppet – Smooth facial expression
  3. 2D Motion Key Editor – Flexible animation
  4. Sprite Editor – Fine-tuning character designs
  5. Face Key Editor – Precise facial expressions
  6. Path properties – Leveraging animation paths
  7. Spring Editor – Organic animation
  8. In-application vector color adjustments
  • How to make your animations five times faster, smoother, and more lifelike, while easily animating complex facial expressions.
  • How to streamline character movements, switch sprites seamlessly, and control animation paths with precision. You’ll also learn how to create realistic follow-through effects effortlessly and adjust colors quickly and effectively.
Be well-equipped to create captivating animations that stand out. Let’s dive into each tool and uncover the specific benefits they bring to your animation projects, transforming your creative process and final results.
Motion Pilot lets you animate by pressing record and moving your mouse.
In this episode, you will learn how to generate unique and complex animations using a couple of clicks and swipes with Motion Pilot. This video covers how to initiate Motion Pilot, preview animation with different parameters, how Lazy Mouse can smooth your animation, add depth with Z controls, and change the moving directions.
The face puppet tool lets you animate facial expressions easily by moving your mouse, bringing life to your character.
In this episode, you will learn one of the quickest and most powerful ways to animate your character’s facial expressions in real-time using only mouse movements. Additionally, the video will show you how to choose from various animation profiles and templates, such as sad, angry, or happy, and how to disable specific facial elements, like the eyes, for more natural head movement. This tutorial will equip you with essential Face Puppet skills, enhancing your animation capabilities and enabling you to create detailed and vivid character expressions effortlessly.
The Motion Key Editor lets you freely pose 2D characters using bones in Cartoon Animator.
In this episode, you will learn how to structure intricate bone rigs, use pins to constrain certain bones, and optimize subdivision topology for smoother deformations. Additionally, you will learn how to change the direction of a character, lock leg positions to maintain a natural stance, and adjust overall character movements flexibly. Ultimately, the video will cover how to correct knee bending issues to ensure smooth and natural motions.
Sprites allow you to change from one drawing to another.
(Character made by Garry Pye for Space Coppers, directed by Ward Anderson)
In this episode, you’ll learn how to efficiently set up character components using PSD transfer in CTA Pipeline Edition. We’ll guide you through the process of selecting and replacing various body parts, including changing expressions, switching hand gestures, and animating by altering these elements. You’ll also learn how to use the face tab to modify facial features, such as choosing different eye expressions. Additionally, the video will demonstrate how to select body parts in the editor by simply clicking on them in the workspace.
The Face Key Editor allows precise facial animation. For automatic positioning, use the face puppet tool, but for precision, the Face Key Editor is best.
In this episode, you’ll learn ways to masterfully control the frame-by-frame expression animations of your characters. We’ll show you how to select and move individual eye components or coordinate multiple facial parts for synchronized movements. Using the Transform options, you’ll easily reposition facial elements or use the deform function to alter the shape of any element, allowing you to make your character smile or frown effortlessly.
6. Path Properties – Leveraging animation paths
Paths allow you to move characters on precise trajectories.
In this episode, you’ll learn how to infuse your animations with enhanced dynamism by defining object movement paths. Discover how to attach objects to a path, edit the path shape using bezier curves, give smooth or linear transitions, set start and end points, adjust movement speed, and ensure objects follow the path trajectory. Watch your character animated along the path, achieving smooth and precise movements.
Use spring effects to automate follow-through — one of the core animation principles — to make physics easy to animate in Cartoon Animator.
In this episode, you will learn how to adjust spring bones in characters and props, and enhance secondary animation with organic physics behaviors. Discover how to apply spring effects to selected bones and assign them to groups, or using presets for quick assignments. You’ll also see how to preview the effects in real-time, make necessary adjustments, and fine-tune settings like speed or gravity to perfect your animation.
With vector characters, you can easily change colors in Cartoon Animator without leaving the software.
In this episode, you will learn how to efficiently group vector elements and adjust colors in specific parts or across the entire character. Composer mode allows you to set up color groups, grouping by individual parts or entire color schemes. For instance, you can transform a blue skirt to red by utilizing the “Group by Color” feature, and change all the segment colors at once.
In Short:
Mastering these essential tools in Cartoon Animator 5 will significantly enhance your animation skills.  With smoother, more lifelike animations and increased efficiency, you’ll be able to create captivating projects that stand out.
Additional interface tips
After learning the key features above, you can continue with the step-by-step UI interface guide below to gain a clearer understanding of the operation steps.
1. Motion Pilot
1. Select your character and click the Motion Pilot icon to open it.
2. Practice your moves by pressing preview (space) to see it in action.
3. For smoother movement, click on “Settings” and increase “Lazy Mouse” to 15.
4. Adjust settings with the Z control to move in front of and behind objects like this seaweed.
5. You can also disable “Face Cursor” to make it move in one direction.
2. Face Puppet
1. Press Ctrl+U or find it in the toolbar.
2. Press “Record” and move your mouse to animate, using clicks to make your character blink.
3. Choose from different animation profiles and templates like sad, angry, or happy.
4. Click on face elements to disable them; for example, disabling eyes makes the head move without eye movement.
1. Press K or find its icon in the toolbar.
2. Click on “Flip Hip” to change the character’s direction.
3. The lock feature can keep the feet planted on the ground while the hips are moved about.
4. Disable it to move the entire character. And, if the knees bend incorrectly…
5. Select the shank and click “Reverse Joint” or press 5.
6. This applies to arms as well. Disable constraints to move bones freely and adjust bone settings by clicking “Bone Display” to hide bones, change their color, size, or opacity.
4. Sprite Editor
1. With your character selected, press S or find its icon in the toolbar to open the editor.
2. Select a body part, like the right hand, to switch between different sprites.
3. You can swap sprites for the body or click the face tab to change facial features.
4. For example, selecting the left eye, lets you choose different eye expressions.
5. Face Key Editor
1. Press Ctrl+K or find its icon in the toolbar.
2. Use the head rotation gizmo to turn the head, or drag the circle indicator to rotate it.
3. Select both eyes and click and drag to move them.
4. Select multiple face parts to move them together.
5. Click on templates to quickly change emotions like angry or sad. Select the expression style and face template.
6. Under the “Transform” tab, move face elements easily or use deform to change the shape of any element, making the character smile or frown quickly.
6. Path Properties
1. Click the “Create Path” icon in the toolbar, then click in the scene to add points.
2. Click and drag to add Bezier handles for a smooth curve.
3. Press ESC when done. Reposition points and adjust the path as needed.
4. After selecting another object, reselect the path and click “Path Properties” to start editing.
5. To animate a character along the path, select the character (1), click the Path Properties eyedropper tool (2), and then click the path (3).
6. To adjust the progression to move the character: Set progression to zero, advance the timeline, and set it to 100 to animate — now your character is moving along the path.
7. Spring Editor
1. To add springs, select the character, enter Composer mode.
2. Click on “Springs” in the toolbar, and choose the target bone for adding spring effects.
3. Select a bone and click “Assign to Group”.
4. Click “Preview” and move the character to see the springs in action. Continue adding springs to the group, previewing as you go.
5. Adjust settings or presets as needed; for example, reduce speed to 30.
6. When done, stop the preview, close the editor, and return to the stage.
1. First, select the character (1) and enter Composer mode (2).
2. Set up group colors by clicking the icon and choose to group by part or color sets.
3. For example, to change a dress from blue to red, click “Auto Color Group”.
4. Select “Group by Color”, click “Process”, and “Okay”.
5. Close the window; and in the toolbar, click on “Adjustments”.
6. Click on the blue skirt to make it blink. This indicates that the blue colors are selected.
7. Proceed to change the color.
8. Select red, and click “OK”.
9. Repeat the steps for all the blue elements, in order to turn them red. Recolor the entire dress  to complete this lesson.
Learn More
2D Animation Software for Cartoon Maker | Cartoon Animator
FREE for 30 days & get 1,700+ ready-made assets:
2D Animation Software Download | Cartoon Animator
Rigging Any 3D Model with Character Creator’s AccuRIG
When I got into 3D freelancing decades ago, rigging a character was a sought-after skill. Many of us could create props, even animated props, but that didn’t always translate into being a successful character developer who could handle the setup and rigging of the character’s internal skeleton. It wasn’t the creation of the mesh or the texturing, it was the skinning as we called it back then which today translates into rigging.
What is Rigging?
As I just stated, rigging was different in the early days. It meant, at least in my experience, attaching a control box to built-in animation controls or “rigs” as they were known. Control knobs and levers were made from non-rendering splines to create a control panel. These control rigs were set up on hands, digits, extremities, and anything that might need to be animated within the character. As computational power increased so did the complexities of rigging.
After this came the process of skinning. This is where things could get interesting and more than a bit tedious. My software of choice back then was 3DS Max which worked with envelopes that encompassed every bone including finger and toe bones, which could get tedious. We had to set the control envelope tolerances to minimal to avoid collapse, folding over, or poke through on multi-layers like clothing. Those were just a few considerations.
You had to think ahead if you wanted a clean topology with tight control envelopes that wouldn’t distort the mesh in any fashion. Mesh collapse, usually on arms and legs at extreme poses, was a major headache in the low poly days. By extreme poses I mean folding the arms or crossing the legs when there were barely enough polys to pull it off.
Conventional Rigging/Skinning
Conventional rigging took many hours and was usually the bottleneck in any production pipeline whether it be a large studio or small indie project. Like texturing, rigging/skinning was a vital step and perhaps the most important step in the development of the character mesh. As I said earlier, in 3DS Max we had to size the control envelopes to each bone including knuckles in some cases. This meant a lot of control envelopes in a very small area. When they overlapped you resorted to the dreaded weighting, which was necessary in any decent character.
Rigging skeletal bones in 3DS Max. The Left is a Shaded view, the right is a wireframe working view. The Bones are moved forward in the left images so we can see them with the shaded view. Rigging one bone at a time with different “handles” for tweaking the size. Can be very time-consuming even with experience.
Today we paint weights which were available back in the early days but mainly it was manual weight tables with a lot of back-and-forth fine-tuning via numbers. This gave exact control but was one of the leading factors in the production bottleneck. An experienced skinner could push out the work, but it could take newbies, trainees, and interns a while to get on board. With experience, you knew a better range of weights to start with, which saved some time.
Creating the character mesh was fun, but took some time and texturing it took some time too, None were the time hog that rigging/skinning was. It was also a buzzkill. Nothing could kill the creative urge and slow down or almost stop your pace like being assigned to rig/skin a character. There were times I’d rather create an entire city than skin a character, especially a novel character with many arms and tentacles. Not all character meshes were bipedal. Creatures like aliens and monsters could be a real pain to wire up. It wasn’t unusual to have to add some meat to the character mesh in places so it would not collapse or bind. This wasn’t simple either as that change had to be re-topologized and re-textured.
The Weight table from 3DS Max. Tedious but direct vertex control. Not for beginners or the less adventurous.
Character development was a big part of the budget back then too. It was nothing to pay thousands of dollars over the development life of a character. Each revision had to go back down the line and then back up again, sometimes with multiple approvals along the way. It was nothing to wait several days to two weeks to get a small revision completed on a character.
It is no wonder it was incredibly expensive to produce a minute of animation back then as the character development cost was just a part of a much larger production budget.
AccuRIG and Characterization
Flash forward to today where the term skinning is not used anymore as rigging has replaced it as the terminology for skinning. If you use any of the old-school tools like Max, Maya, and the like then you can still create control rigs but why do so when Character Creator skips that step completely?
The same with skinning. It’s all handled, the clean topology, proper skinning tolerances, and all that goes with making a character ready for animation, by Character Creator with either the Characterization tool or AccuRIG.
Simply put, if you want to preserve an existing skeleton then you use Characterization by matching bone to bone until you have enough bones to activate a working, animatable character. If you want to add a skeleton to a character mesh that does not have one or you want to replace the existing skeleton, then you use AccuRIG.
Check out my article for more detailed information on AccuRIG versus Characterization to learn more about the process of each one.
A wide variety of character Meshes from several industry-leading sources rigged in Character Creator.
Using AccuRIG to Rig a Character Mesh
“Garfield” (https://skfb.ly/oHRtU) by gaddiellartey2010 is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
“Odie (1)” (https://skfb.ly/oGERJ) by mustafatylan68 is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
Anyone can Rig/Skin with Character Creator
Not only was rigging and skinning a sought-after skill, but it was also one that you had to use often or you could grow rusty. Freelancers tend to jump from task to task as called for by their contracts, so it wasn’t unusual to have to spend some unpaid time refreshing your skills when you got a character dev contract.
Character Creator and tools like AccuRIG have eliminated all of that. We get to focus on creating a great mesh with AAA texturing or use the sliders on a base mesh to shape a unique character. We can also send that base mesh over to ZBrush via a very robust GoZ function that makes transfers between the applications seamless. This feature alone gives us a method of sculpting that is used by studios and indies for top-shelf production.
With AccuRIG and Characterization, anyone with competent computer skills can create a “ready for animation” 3D character.
Using Characterization to Retarget an Existing Rig in a Character Mesh
“Cyberpunk character” (https://skfb.ly/6SDpO) by 4d_Bob is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
Masking Bones
A great feature, often overlooked, is the bone masking tool that allows us to mask out unnecessary bones from an unusual character mesh. We can rig meshes like partial characters or sculptured busts with the body, arms or legs masked out, so they don’t interfere or induce unwanted movement when applying motions.
“Wheeled Robot” (https://skfb.ly/ouCQD) by Andrei Milin is licensed under Creative Commons Attribution (http://creativecommons.org/licenses/by/4.0/).
In the image above I have masked out everything except the arms. When you select a bone and turn masking on it will mask all bones in that hierarchy. Masking a torso or pelvis bone will mask out the legs and feet or possibly all of the upper body depending on the bone chain direction. If you select a torso bone to mask and the arms are masked but you want to use them then select the arms again and turn off the mask for them.
I also used the Extract Mesh tool to extract the wheel/tire, radar, and a few other items and finally extracted the claws so I could spin them even though I didn’t use that in the demo.
Production Budgets Drop Dramatically
It’s still not cheap for a large, triple-A studio to create a minute of animation but budget considerations have changed dramatically for the small, indie producer or studio. It was not uncommon in the early days of 3D production to have $5K to $10K or more annual expenses just for licensing some needed applications.  That was in dollars that had a lot more purchasing power than today, so the tools weren’t cheap by any means. Piracy was a problem because of the expense. It was a barrier to a lot of smaller indie producers and animators.
Today we have pricing and competition that have reduced the annual cost of 3D software. It may still take a good budget to get started with a lot of tools, but maintaining those tools is no longer a $5K to $10K annual burden. There were times we were forced to spend the first few months of the year just paying for our software or maybe I should say waiting for that annual license to pay for itself, then we could make money.
Character Creator and iClone have empowered a lot of new animators by being able to learn and produce animation at a small fraction of the cost per minute. I’m not saying our time is not worth anything, but I am saying our time is key in lowering the budget for out-of-pocket expenses. Some iClone productions have little to no budget while producing quality work for any number of reasons from previsualization to trying to get noticed or a project financed.
Summary
It’s hard not to like the power and ease of use that Character Creator and tools like AccuRIG provide. I have become so spoiled at using Character Creator and its auto rigging tools that I can’t remember the last time I rigged a character in 3DS Max.
I hope I never have to again either.
MD McCallum - WarLord
MD McCallum – WarLord
Digital Artist MD “Mike” McCallum, aka WarLord, is a longtime iClone user. Having authored free tutorials for iClone in its early years and selected to write the iClone Beginners Guide from Packt Publishing in 2011, he was fortunate enough to meet and exchange tricks and tips with users from all over the world and loves to share this information with other users. He has authored hundreds of articles on iClone and digital art in general while reviewing some of the most popular software and hardware in the world. He has been published in many of the leading 3D online and print magazines while staying true to his biggest passion, 3D animation. For more information click here.
Selling your Art for 2D Animation – Clay Triche Interview
Selling your Art for 2D Animation with Cartoon Animator
Clay Triche – 2D Animator / Content Developer
Clay Triche
The Cartoon Animator 2D Marketplace is a rich source of potential for artists looking to profit from their 2D art work, as they are able to sell their content to a large audience of animators and have total control over their work.
Clay Triche is a new content developer for Cartoon Animator, and he made quite the impact when he joined the 2D community, not only as a developer but also as a leading animator.
Producing incredible characters for Cartoon Animator at record pace, Clay already has quite the catalogue of work which spans multiple themes and genres from crazy zombies, to famous faces. We sat down with Clay to discuss his speedy rise through the ranks of Cartoon Animators top developers and see what insights he could offer other artists.
“The reason I chose to use Cartoon Animator is because of how easy and fast it is to produce animation. For all of the other animation platforms that I used over the years, none of them has the flexibility and easy workflow like Cartoon Animator.”
Q: Hi Clay, welcome! Could you begin by telling us about your work using Cartoon Animator?
Hello there! I’m the kind of cartoonist that was raised in the 70’s and 80’s era and I grew up with Bugs Bunny, Scooby Doo, Woody Woodpecker, Popeye, along with all of those great cartoons, so the kind of work I’m doing is to bring back the feel of that era with my own creations.
Right now what I am working on with Cartoon Animator 5 are several projects, and one of them is my Mega Zombie Pack that I started on this past Halloween, but it’s been delayed for the Holidays and now that the Holidays are over I started working on it again, The idea of the pack was actually inspired by The Motion Comic Mini Event that was held back in September in the Cartoon Animator User Group page, so the entire Pack is actually designed for Motion Comics, but can be used in animations as well.
And one of the other projects that I’m working on is my Stone Age 10,000 B.C series for my Channel and as I create characters, props and scene, I add them to the marketplace to share with others so they to can create a Stone Age cartoon.
Q: Initially what drew you to working with Cartoon Animator as your 2D animation software of choice?
The reason I chose to use Cartoon Animator is because of how easy and fast it is  to produce animation. With all of the features that’s packed into Cartoon Animator is  actually everything you need to bring your ideas to life. For all of the other animation  platforms that I used over the years, none of them has the flexibility and easy workflow  like Cartoon Animator, so with that said Cartoon Animator will always be my platform of  choice!
“For all of the other animation  platforms that I used over the years, none of them has the flexibility and easy workflow  like Cartoon Animator, so with that said Cartoon Animator will always be my platform of  choice!”
The advantage I find Cartoon Animator gives me is that I can create animation and have them uploaded to my channel in one day, because I’m a fast creator. Plus I can earn money buy selling the content I make using Cartoon Animator by uploading them to the 2D Marketplace straight from the software, which helps me get recognized by other creators and build up my followers.
Q: Do you have a specific genre or theme that is your favourite to work with?
Hmmm… hard to tell what my favorite genre or theme is, but if I had to choose then I would say Military. I always loved to watch war movies, and TV shows like Hogan’s Heroes, and Gomer Pyle U.S.M.C, two of my all time favorites. So I always liked to do comic strips of my own  Military like I do with my series the Dog’s. I can think up of a bunch of funny stories of any military scenarios!
Q: You have created a number of characters in a very short time. How do you find the creation process for Cartoon Animator?
Cartoon Animator I find to be by far the most easiest and fastest animation platform on the market. I say this because with Cartoon animator I can actually enjoy making contents and animation without the frustrating features compared to other software choices which I have used but struggled with.
Now using Cartoon Animator I love what I do with a passion, and that’s animation, and I would recommend to anyone who wants to create their own cartoons without taking weeks, months, or even years to learn, to use Cartoon Animator!
Q: You say that Cartoon Animator makes 2D animation easy and fun. What tools, or features in particular do you like most?
My favorite feature in Cartoon Animator I would say is Spring Bones and Motion Pilot, because with spring bones you can now add more life and realism to your characters, I never had that in the other software before.
Seeing that I can make the hair on my characters bounce around, I even add them to my characters clothes, like a skirt, or an unbutton shirt to make them wave as the characters move. I find that to be really cool!
And Motion Pilot is another awesome feature I really love, because now I can just use the mouse to control the movement of my characters and props and it records it to the timeline, it really makes animating even a whole lot easier, and I love how you can add Flocks as well using this feature, these are wonderful addition of tools to Cartoon Animator and it makes me want to use Cartoon Animator even more!
Q: As a relatively new developer to the 2D Marketplace, and having already made a name for yourself as a leading developer, what advice do you have for for inspiring Cartoon Animator developers?
My advice to anyone who wants to create and sell contents, is create something unique, find out what users are looking for, and always add a good description to your content page.
Make sure to mention what you use to make it, what features it does and doesn’t have. This will help users decide whether or not they can use your content.
“The advantage I find Cartoon Animator gives me is that I can create animation and have them uploaded to my channel in one day, because I’m a fast creator. Plus I can earn money buy selling the content I make using Cartoon Animator.”
Q: So what are your future plans with Cartoon Animator? Do you have any current projects in the works?
Recently I have  been working on my Mega Zombie Pack for the Marketplace. I have also been working on my Stone Age series and Character packs for the Marketplace.
Some of my most recent releases include Pete the Dragon, a few Stone Age characters and a little Alien called Zee, which made me think outside of the box in order to make him unique. I have a bunch of projects planned, but I don’t want to give them all away because I like to surprise people with my creations. I like to see the wows, lol!
Let’s just say this….. I have plans to help the Marketplace grow!
Follow Clay Triche
Facebook:
https://www.facebook.com/profile.php?id=100090060426058
YouTube:
https://www.youtube.com/channel/UCp-ET1dJ9HD0cBxsBq_9FzQ
Related Posts
INCREDIBLE program for 3D Crowd Simulation
Welcome to Neriverso, where the captivating world of video games meets the expertise of Neri Neto, a seasoned technology journalist and skilled game programmer. Through Neriverso, Neri shares his profound insights and boundless passion for everything he adores, including video game development!
As a dedicated game programmer, Neri has lent his talents to numerous indie projects, crafting engaging mechanics and contributing to the development of captivating titles. Embrace the Neriverse and embark on a journey fueled by Neri Neto’s unwavering enthusiasm and commitment to his craft and community.
In his latest video, Neri talks about the powerful 3D crowd simulation feature in iClone, that enables animators, game developers, archviz creators and more to create realistic crowd scenes including how:
  • Creating crowds in 3D environments can be achieved using iClone Crowd 8 Simulation tool, a versatile software applicable in architecture, gaming, and virtual shows, offering robust crowd simulation capabilities.
  • Using software like iClone 8 can provide ready-to-use character libraries and animations, making it efficient for most projects, with the option to purchase additional characters and animations for more customization.
  • Using animation and real-time graphics, creator can seamlessly integrate characters into a scene, adjust animations, and create paths for character movement.
  • Using advanced character scanning technology to create realistic 3D characters for crowd simulation can enhance performance and visual quality in various projects.
Follow Neriverso:
Instagram:
https://www.instagram.com/neriverso/
TikTok:
https://www.tiktok.com/@neriverso
Create a Stylized Vampire with Free CC Character Base & ZBrush
This article is featured on 80 Level
 A Step-by-Step Guide Using Character Creator 4, ZBrush, Substance Painter and Maya
Gerard Martínez Sánchez – Character Modeling Artist
I’m Gerard Martínez, a 3D artist from Barcelona specializing in cartoon-style characters. I am also a 3D instructor and teacher. I have the privilege of combining two of my greatest passions: 3D art and teaching.
Currently, I teach at Libel Academy, one of the most recognized online 3D training academies in Latin America, with students from various parts of the world. I also teach 3D arts classes at various universities in Spain.
This year, I also had the opportunity to collaborate with XP-Pen Spain, which allowed me to bring art and technology to a wider audience and share my passion for both worlds.
“Character Creator 4 not only simplifies the technical process but also enhances the artistic aspect, allowing artists to focus on creativity and design. I appreciate how the free Character Base with its optimized topology and full rig, integrates seamlessly with tools like ZBrush and Substance Painter. “
Gerard Martínez Sánchez, Character Modeling Artist
INTRODUCTION
Welcome to the making of Ravenna, a stylized vampire created using tools like Character Creator 4, ZBrush, Substance Painter, and Maya. In this article, we will break down the entire process of creating this character, starting with one of the free bases from Character Creator 4.
Character Creator Bases
This base provides us with optimal topology and the flexibility needed to sculpt in ZBrush, taking advantage of Reallusion’s excellent morphs and rigging systems to achieve a fully animated character from the start.
We will continue the process by applying stylized and hand-painted textures in Substance Painter, using UDIM texturing capabilities to add more detail and precision.
Next, we will import the textured model back into Character Creator 4, where we will adjust the accessories and create poses to bring Ravenna to life.
Finally, we will create a small environment and render the character in Maya using the Arnold rendering engine, ensuring that every detail and texture stands out on the character.
Character Creator Open Pipeline
Prepare to discover how a simple idea transforms into a 3D character for animation.
DOWNLOAD your FREE CC Base:
https://www.reallusion.com/character-creator/free-3d-character-base.html
1. REFERENCES
For the creation of Ravenna, having a solid foundation of visual references to guide each stage of the process was crucial. From the beginning, my main goal was to give Ravenna a stylized and animated movie-like touch, as if she had come straight out of a lost castle in Transylvania. I wanted Ravenna to capture the essence of a classic vampire while also having a modern, stylized look that would make her stand out in any visual context.
Here’s how I approached the search and use of references for this project:
  1. Vampires in Art and Popular Culture: I started by looking for images of vampires in movies, TV series, and concept art. This helped me understand the different styles and common characteristics of vampires, such as pale skin, prominent fangs, and intense gazes.
  2. Illustrations and Cartoons: I also searched for illustrations and cartoons of vampires to capture a variety of stylized looks, from cartoonish to darker, gothic interpretations.
  3. Facial Structure and Expressions: To ensure Ravenna had believable anatomy, I researched photos of people with interesting facial features. I focused on images showing expressions that would help convey the character’s psychology.
  4. Gothic Clothing and Accessories: Clothing is crucial for Ravenna’s character. I looked for references of gothic clothing and accessories like corsets, capes, and jewelry to give her an authentic and fitting touch.
Once I had the images, I started building a visual board in PureRef. PureRef is a program that helps organize and visualize visual references efficiently.
Next, my partner, Ivet Macias, a 3D artist, helped me design a quick sketch of Ravenna’s look. This sketch was incredibly helpful in getting started with the modeling and having a clearer idea of the character.
Here are some of the reference images I used:
2. CHARACTER CREATOR
2.1 Begin with CC4 Base Model for Optimal Sculpting in ZBrush
First, I had to download the free bases. To download:
  1. Go to the Download page.
  2. Press the “Download Now” button.
  3. The file will automatically download to your computer.
  4. Unzip the contents to your preferred location and let’s explore what we can do!
The mesh of this model provides a universal topology, perfect for animation and sculpting. This base is ideal for Ravenna, as its cartoon and versatile style will allow us to modify and sculpt the stylized and distinctive details we want for the character.
To start, we need to load the base. In this case, I imported version 04_Toon Neutral_F. Start Character Creator by opening Reallusion HUB and then Character Creator 4.
In the File/Import/Import section, or using the shortcut Control+I.
We will import the model from the folder named //CC Character Base\FBX\04_Toon Neutral_F.
When clicking the import button, two pop-up windows will appear. The first will ask if it’s a character or an accessory. Select the Character option. The second window will allow us to choose the format for our character, with or without rigging. Select CC Avatar (Standard).
Once selected, the model will load into Character Creator 4, ready to be modified and adjusted according to our needs.
Once the model is loaded, we will place it in A-Pose or T-Pose to facilitate modifying the proportions.
Now, we will select the entire model and go to the Materials tab.
Select all the materials listed in the Material List.
Select the character materials in Character Creator
There, we will reduce the texture intensity to zero to focus only on the volumes.
Finally, we will adjust the Diffuse Color to a dark gray to better visualize our character.
Adjust the character Diffuse Color
Now our character is ready for base modification.
Go to the Morph tab and start working through the list, making large changes initially and then refining with more specific morphs to define the body and head shape.
Use the Character Creator Morph sliders to adjust your character
You can use the search bar to quickly find specific options; for example, type “scale” to access scale options for any body part.
In my case, I extensively used the Ultimate Morphs pack, available on the Reallusion Store. The variety of morphs and the nearly infinite combinations allowed me to personalize every detail of Ravenna, from the body structure to facial features, providing total flexibility.
Save time with the Ultimate Morphs pack for Character Creator
Additionally, you can enable the Morph option in the Menu Bar to unlock morphing in the Viewport. With this option enabled, simply click and drag parts of your character in the viewport to intuitively change the shapes.
Enable the Morph option in Character Creator
I thoroughly enjoyed this part because Character Creator offers immense versatility.
The ability to make numerous modifications allows for precise adjustments to every detail of the character. It felt like using a video game character editor due to its ease and intuitiveness, making the creative process a pleasure.
Now, I’ll share the before and after of the head and body starting from the 04_Toon Neutral_F base, using the CC4 sliders.
The visual comparison shows how morphs and adjustments can completely transform the character, highlighting significant changes in Ravenna’s facial and body structure.
2.2 Exporting from Character Creator to ZBrush Using GoZ
One of the moments I enjoy most in my creative process is sculpting in ZBrush. Character Creator 4 (CC4) has an excellent and very flexible connection with ZBrush, making it easy to export characters or props between programs.
Before exporting, it’s important to create a new document in ZBrush and clear the GoZ cache. To do this, go to Preferences > GoZ > Clear Cache. This ensures a clean and smooth transfer between the programs.
Clear the GoZ cache
Now it’s time to detail our character in ZBrush using its sculpting tools.
To send our character to ZBrush, follow these steps:
  1. Go to the Scene tab.
  2. Select all the character elements by holding down the Shift key.
  3. Click the GoZ button in the menu bar.
This will transfer your character to ZBrush for detailed sculpting and refinement.
Select the character features
In the GoZ settings panel, ensure the template is set to Create.
I prefer separating the eyelashes and tear ducts to have only the “skin” of the character as a sub-tool while I work, as it makes modifying the face, especially the eyes, much more comfortable.
To do this, in the settings panel, activate the eyelashes and tear ducts in the Split Body Parts section to divide them into their own subtools.
Select Current Pose in the Pose section.
3. ZBRUSH
3.1 Shape Refinement in ZBrush
When I had my character in ZBrush, I selected the “CC_Base_Body” sub-tool and began refining it. I used my favorite brushes to sculpt and adjust the body and face shapes.
First, I worked at subdivision level 1 to achieve the basic shape, using brushes like Move and DamStandard. These brushes allowed me to deform the mesh gradually, always aiming for smooth lines in the topology loops.
I spent a lot of time perfecting the face to ensure that when you see it, you can immediately say, “She’s a vampire!”
It’s crucial to ensure that facial features maintain proper proportions relative to the overall head and body shape. For example, achieving the correct position of the eyes, nose, and mouth helps capture the character’s essence accurately.
Next, the following step involves capturing secondary facial details such as the shape of the eyes, ears, mouth thickness, nose shape, eyebrows, and more.
Capturing secondary facial details
Once I have the head more defined, I paint the iris of the eyes to give it more vitality and expressiveness, providing greater inspiration for the sculpt. I apply the Toy Plastic material to the eyes.
Paint the iris of the eyes to give it more vitality
In the Geometry menu, we can find the ClayPolish tool. I use this option frequently to achieve a more defined and polished appearance, especially recommended for cartoon or stylized characters.
For this style, the most important aspect is perfecting the volumes and refining the shapes.
Referencing Dracula for my character
Then, I created an initial block of the hairstyle in ZBrush using a sphere to later place the hair strands and experiment with the shape and silhouette.
I used the most basic ZBrush brushes, such as Move, Smooth, Inflate, and Pinch, for this blockout. To add each hair strand, I utilized different brushes.
It is important to keep the geometry of each strand clean and organized.
Tips for Creating Hair
  1. Rotate the Model: Constantly rotate the model, don’t focus on a single angle, and look for irregular or uneven areas.
  2. Balance the Strands: Find a good balance in the number of strands you create. Too many can make the hair look messy, while too few can make it look simple or incomplete.
  3. Check Shapes and Silhouettes: When adding strands, review the shapes and silhouettes to ensure they match the concept.
  4. Add Variation: Working with symmetry is fine, but make sure to add some variation and asymmetry.
  5. Avoid Duplicates: Don’t duplicate strands side by side, as it often looks fake and unconvincing. This is a common mistake.
  6. Be Patient: Learning to create hair takes time.
3.3 Creating Stylized Cloth and Accessories
I follow a workflow that combines various tools and techniques to create clothing in ZBrush. Here’s how I do it:
Creating the Base with Extract:
  • I use the “Extract” tool in ZBrush. With the help of masks, I can define the areas of the base mesh that will become the clothing. This allows me to sculpt the basic shape of the garment.
  • After defining the shape, I perform a Z-Remesher to optimize the geometry.
Adding Thickness and Defining Seams with Panel Loops
In ZBrush, I add thickness and define seams using the Panel Loops function. First, I assign Polygroups where I want to mark the seams.
Below are the values I apply in Panel Loops. In the EdgeLoop sub-palette of the Geometry menu, I set the following adjustments:
  • Loops: 3
  • Polish: 0
  • Bevel: 50
  • Elevation: 0
Define seams using the ZBrush Panel Loops function
When pressing the Panel Loops button, ZBrush adds thickness to the interior of the mesh, creating a clean loop between the inner and outer panels. Each element gets its own polygroups, which is very useful for organizing the mesh.
Adding Support Loops
To avoid deformations when subdividing the mesh, I add support loops:
  1. Go to Geometry > Crease > Crease PG.
  2. This ensures that the edges of the mesh parts remain defined during subdivision.
Complex or More Polygonal Garments
For more elaborate garments like a corset, I prefer modeling them with polygons in Blender. This approach gives me greater control over the topology and design.
Afterward, I import the model into ZBrush to create its high-resolution version and apply detailed sculpting.
These steps allow me to create stylized clothing in ZBrush, combining sculpting and polygonal modeling techniques to achieve the best possible results.
Create stylized clothing in ZBrush
Before exporting all changes to Character Creator 4 (CC4), we need to unwrap the UVs for accessories, clothing, and hair to avoid any complications during texturing.
3.4 Importing Character, Hair, Clothes & Accessories into Character Creator
3.4.1 Importing Character
To minimize errors, we will export the character in parts. First, import the character without hair or clothing. Next, import the hair and match it with the skin. Finally, import the clothing and assign its weights.
Before transferring the character from ZBrush to CC4, ensure the character is selected in CC4. If not selected, it will not update.
Transferring the character from ZBrush to Character Creator 4
Then, we will hide the clothing and hair, and use GoZ, selecting the option to export only what is visible in the scene by pressing the “Visible” button.
This will automatically reduce your body subtool to SDiv 1 and send the mesh back to Character Creator.
The GoZ options in CC should be set to Update, and we will select Current Pose.
Once the model is in Character Creator, test the animations from the Content tab or Animation Player and use the morph system to make further adjustments. You can go back and forth between CC and ZBrush as many times as needed while perfecting your character.
3.4.2 Importing Hair
Next, we will send the hair and eyebrows to Character Creator. To do this, hide all the subtools by clicking on the eye icon and then press “Visible” to send them to Character Creator.
In Character Creator, set these parts as Accessories and click Update. You may need to make some position adjustments.
To integrate each of these accessories as part of the character’s face, go to the Attributes panel, click on Create Hair, Eyebrows, Beard, and select the appropriate behavior for each. In this case, select Eyebrows and apply it to Brows.
Once configured, we can verify in the Facial Editor that each element behaves as expected.
If we want to adjust the weights, we go to “Facial Hair Vertex Assignment.” Here, we define the vertices that will influence each of these elements, allowing us to have complete control over how they deform when modifying the character’s expressions.
Now we will move on to the hair. For my hairstyle, the best template was Base/all.
Next, I tested the behavior of the hairstyle and had to adjust its weights in “Assign Conformable Regions.” This allowed me to precisely define how the hair deformed during the character’s animations and expressions.
3.4.3 Importing Clothes and Accessories
To import clothing into CC4, follow the same steps as with the hairstyle.
When importing clothing into CC4, import it as Cloth and accessories as Acc.
You may notice that the clothing doesn’t fit the character perfectly. Select all in the Scene tab, press W on your keyboard to activate the gizmo, and move the accessories over your character to position them correctly.
Select only the garment and press the Transfer Weights button. Choose the appropriate template and make any necessary adjustments to the weights. This will ensure that the clothing fits and moves correctly with the character.
Repeat this process for each clothing item.
Our character is now complete and ready for animations and final adjustments. This process ensures that every element of the character, from the hairstyle to the clothing, is perfectly integrated and functions smoothly during deformations.
4. ADOBE SUBSTANCE PAINTER
4.1 Export to Substance Painter Low and High Version
Before exporting to Substance Painter, I opened my character’s mouth to avoid errors during baking. To do this, follow these steps:
  1. Go to Motion Pose > Edit Facial.
  2. Then, go to Modify > Jaws.
  3. Edit the facial expression Jaws and set the value to 50.
With the character selected in Character Creator, I used the export option to Substance Painter to save an OBJ file in a folder with its respective textures. This low-resolution file will be used later for baking the details.
In ZBrush, with the subtools activated and at the highest subdivision level, I exported the high-resolution body as an FBX, making sure to activate the option to export only the visible elements.
4.2 Bake
Open Substance 3D Painter and select File > New. Then, press the Select button to import your OBJ file from Character Creator. It is very important to activate the Use UV Tile option before continuing.
Once we have our low-resolution character loaded, go to the Texture tab and scroll down until you find the Bake Mesh Maps button.
Deactivate all objects except Std_Skin_head. In the UV Tiles dropdown menu, uncheck the box for 1006, which corresponds to the eyelashes and does not need to be baked.
4.3 Texturing Skin
I began texturing Ravenna’s face using the “Skin Face” smart material as a base and made adjustments according to my preferences. The versatility of Smart Materials makes customization easy.
First, I adjusted the Base Skin layer to a paler tone for a vampiric look. Then, I duplicated the Skin Pores layer, modified the pore size using tiling, and strategically distributed them on specific areas of the face with layer masks.
Next, I created a new folder called Skin Shades and added several fill layers to introduce different skin tones. To break up the uniformity, I added a fill layer, applied a black mask, and used a procedural map with “Add Generator”. I chose “Tri-planar Advanced” and applied “BnW Spots 1” to alter the color mask, resulting in a more realistic and detailed skin texture.
4.4 Texturing Eyes
For the eyes, I created a texture in Photoshop and projected it in Substance Painter, setting the Roughness value to 0. This allowed the eyes to have a shiny and realistic appearance.
4.5 Texturing Cloth and Accessories
For the clothing and accessories, I used the Leather Stylized smart material, changing the base color and various layers.
For other accessories, I created stylized materials and added color layers for a more hand-painted finish.
Creating a Stylized Material
  1. Base Color Layer:
    ○ Start with a base color layer.
  2. Ambient Occlusion Layer:
    ○ Add an “Ambient Occlusion” layer with a black mask and inverted generator. Use a dark color in multiply blend mode.
  3. Edge Wear and Highlights:
    ○ Create an edge wear layer with a curvature generator, adjusting the color and settings.
  4. Color Gradient:
    ○ Add a gradient layer with a black mask and position generator. Set the blend mode to multiply.
  5. Baked Artificial Lighting:
    ○ Add a baked stylized lighting filter, adjusting the blend mode to soft light and the sun intensity.
    This process creates a solid and stylized base for materials, suitable for a more artistic and detailed finish.
For the hair texturing, I used color layers and details to achieve a stylized finish.
Now, I will share some renders made in Adobe Substance Painter with the finalized textures.
4.6 Export Textures to CC4 and Maya
Exporting for Maya with Arnold
Once I had all the textures for the character, I began the export process. I used the Arnold (Ai Standard) configuration in PNG format with a resolution of 4096.
Exporting for Character Creator 4
  1. Download the Preset File: [Character_Creator.spexp](C:\Users(User Name)\Documents\Adobe\Adobe Substance 3D Painter\assets\export-presets) and place it in the export-presets directory of Substance Painter.
  2. Configuration in Substance Painter:
    ○ In the Export Textures panel, select the materials and choose Character Creator as the output template.
    ○ The structure of the exported textures will match Character Creator’s texture folder.
  3. Export Settings:
    ○ Output Directory: Set the output directory where you want to save the textures. I recommend using the organized folder containing the exported textures, where the low-resolution OBJ file is located.
    ○ Texture Set Selection: Ensure only the necessary texture sets (UDIMs) are selected for export. Uncheck any texture sets that do not need to be updated (e.g., corneas, teeth, tongue).
    ○ Output Template: Choose the export template that matches Character Creator’s requirements. Use the Character Creator preset file if available.
4.7 Import Textures to CC4
Back in Character Creator, select the character and then choose the Update Textures from Painter option in the Substance Painter dropdown menu.
This will open a file explorer window.
Navigate to the folder that contains the organized folders with your textures. Press Select Folder and Character Creator will automatically update all the body part and clothing materials with your new textures.
With the textures applied, I recommend posing your character in Character Creator 4 to ensure that the textures maintain their quality and detail in different poses.
Here is a screenshot of how the character looks with the textures applied in CC4:
5. ZBRUSH POSE TOOLS (CC4)
5.1 Introduction
Now that we’ve imported and applied the textures, it’s time to pose Ravenna in Character Creator 4. This step allows us to adjust her facial expressions and body postures for different scenarios.
I must say, bringing my character to life was incredibly fun—I felt like a kid and spent many hours on it. Not because it was complex, but because it’s very easy to pose characters, whether adjusting the body or adding expressions. The possibilities are endless. The only limitations are your creativity, as you can position the character in any way you imagine.
This process allowed me to explore all the ways Ravenna could express and move, making every moment worthwhile.
5.2 Posing and Adjusting the Character
I started the posing process by trying different Motion Packs from the Reallusion Content Store. The ones that suited Ravenna best were “Evil Diva Moves” and “Egocentric Moves.”
These packs contain an extensive library of walk cycles, idle animations, and emotions, perfect for giving Ravenna the attitude I envisioned.
I applied the motion ‘Egocentric_Talk_F‘.”
Although the initial pose was quite good, I adjusted it to fit my specific needs.
With the character selected, I went to the Motion tab and clicked on Edit Pose. I used the mannequin in IK or FK mode to move and rotate the joints according to my needs.
Additionally, you can also navigate to the Poses and/or Gesture section in the Content tab to apply different body poses or hand positions to your character, achieving a more precise and personalized adjustment.
If you wish to modify an animation because some part of the character moves inward or is misplaced, you should go to Pose Offset. This tool will allow you to correct and adjust the movements, ensuring that the animation looks natural and meets your needs.
5.3 Adjusting Facial Expressions
For Ravenna’s facial expression, I aimed to achieve a flirtatious smile with a touch of mystery, intense and challenging gazes, and a confident, self-assured, somewhat arrogant attitude, but with a natural charm that attracts others.
Here are the steps I followed to edit the face:
  • Edit Facial Expression: In the Motion tab, I clicked on Edit Facial.
  • Muscle Tab: I clicked and dragged on different areas of the face to modify the expression.
  • Expressions Tab: I applied an expression from the dropdown list of options.
  • Modify Tab: I used the sliders to make precise changes to the character’s facial shapes.
I’m sharing the two poses I finally chose to render later. Each of these poses highlights Ravenna’s personality and character, showcasing her confident and mysterious attitude.
  • Pose 1: Ravenna stands with a defiant posture, showcasing her confidence.
  • Pose 2: Ravenna has a more introspective expression, with a touch of mystery and a penetrating gaze.
These poses will serve as the foundation for the final renders, where I’ll add an environment to further enhance the character presentation.
5.4 Transferring the Posed Character to ZBrush with Pose Tools
If you want to apply your pose as a layer, open the ZBrush Pose Tools plugin in ZBrush, click on the Record New Pose button, and then send the character elements from CC using GoZ. Once the changes are updated in ZBrush, click on Save New Record and give it a name. Repeat this process as many times as you like, building a library of poses as you progress.
Honestly, this plugin is amazing because it allows you to access all the poses with a simple click and it’s very organized.
5.5 Export to Maya
To export the character to Maya, follow these steps:
  1. Select the Character: Make sure the character is selected.
  2. Export: Go to File > Export > FBX > All (Character/Prop/Camera).
  1. Export Settings: In the popup window, set the Target Tool Preset to Maya.
This way, when we import the character into Maya, we can proceed with rigging and make any necessary adjustments.
 Alternatively, we can also export the character as an OBJ (as we did before for Substance Painter), but this way we will lose the rig.
6. MAYA
6.1 Import Character to Maya
In my case, since I already liked my poses, I imported it as an OBJ to make it less heavy.
The first thing I did was remodel a small environment I had; I wanted to recreate a small hall in a gothic castle and various props to decorate the scene like chandeliers, a rug, etc.
I attach a render from Substance Painter to showcase the texture outcome.
6.2 Lighting
To create Ravenna’s lighting, I opted for a combination of warm and cool tones. I aimed to give her an enigmatic and dramatic appearance by using cool overhead lights to highlight her mystery and a warm light from below to balance the scene.
Villains often have sinister lighting, while good characters benefit from warmer, softer lighting. Proper lighting not only defines the character’s atmosphere but also helps emphasize their role in the narrative and establish an emotional connection with the viewer.
To create Ravenna’s lighting, I incorporated a low-intensity HDRI as the primary light source to achieve subtle reflections. I used HDRI from HDRI Haven.
Next, I added an Area Light as the Key Light to illuminate the character from a specific angle, adjusting the intensity, color, and temperature to achieve the desired mood.
I placed a Fill Light on the opposite side of the Key Light to soften the shadows and balance the lighting.
I added two Rim Lights behind and above Ravenna to create a “glow” around her and simulate candle lighting.
Finally, I used Bounce Light to simulate light bouncing off surfaces and back into the scene, creating a more natural and immersive effect.
6.3 Shading
For Ravenna’s shader, I wanted to give it a style similar to that of cartoon animation films, without straying too far from my own style.
At this stage, I typically apply the maps in the aiStandardSurface material of Arnold.
  • Base Color: I apply the texture to the base color node and to the Subsurface Color.
  • Roughness: I connect the roughness map to control reflectivity.
  • Metalness: I apply the metalness map to define metallic properties.
  •  Normal Map: I connect the normal map to add details and depth to the character’s surface.
This approach allows me to maintain Ravenna’s essence while achieving the desired look.
6.4 Post-production
Once I had the Maya render, I immediately moved to Photoshop to add the final details, such as the window background and a bit of mist.
This entire stage was made possible thanks to the help of my great friend Eliant Elias. Thanks to him, I could achieve such an incredible window with those ominous clouds and moon.
With his collaboration, we added elements that enriched the atmosphere of the final render, bringing Ravenna’s scene to life and achieving an impressive visual finish. And now I share with you the result of the render with the effects applied:
The render of the lighting from Maya.
For the other pose, I made a variation in color for the lighting and background, and this is the result.
Elías also helped me here, ensuring that every detail of the background and tones perfectly complemented Ravenna’s pose and style.
7. CONCLUSIONS
This is the first time I’ve used this workflow to create characters in 3D, and I’m really impressed. I’ve always used Character Creator 4 to rig my characters and then pose them. But now that I’ve created a character from one of its bases, I’m fascinated by the speed and artistic result it provides, as it allows you to skip all the technical aspects like retopology, UV unwrapping, or rigging. The only technical thing I’ve done with this character is unwrap the UVs of the clothing, and that’s it!
Advantages I’ve Seen in Using Character Creator Bases:
  1. Speed: Character Creator bases allow for quick and efficient character creation, saving time on technical processes.
  2. Ease of Use: Intuitive tools and morphs make it easy to customize characters.
  3. Versatility: You can create anything from stylized to realistic characters, leveraging the robust rigging and animation systems.
  4. Integration: Character Creator seamlessly integrates with tools like ZBrush and Substance Painter, facilitating the workflow.
  5. Quality: The bases are designed with optimized topology and precise anatomical details, providing an excellent foundation for sculpting and texturing.
Acknowledgments:
I want to thank the entire team at Reallusion, especially Enoc Burgos, for giving me the opportunity to showcase my creative process and art.
Additionally, I want to thank my life partner, Ivet Macias, for helping me design Ravenna. Without her, it wouldn’t have turned out so incredible.
And lastly, to Eliant Elías for his magnificent touches in post-production. Without his help, the project wouldn’t have reached the level of quality it achieved.
Thank you all! I hope you enjoyed this making-of. Until next time!
Follow Gerard Martínez Sánchez:
Instagram:
https://www.instagram.com/gms.3dart/
Linkedin:
https://www.linkedin.com/in/gms3dart/
Website:
https://gms3dart.com/
The original article was written by Gerard Martínez and is also featured on 80 Level.
Our esteemed judges, Pablo Munoz Gomez and Martin Klekner, will share their insights preparing the 3D Character Contest. They’ll reveal what catches their eye, what makes a 3D character stand out, and what they value most in a submission.
How to stand out in the 2024 Reallusion 3D Character Contest
Not just any contest
3D characters are the cornerstone of creative productions, bringing life to movies, animated films, video games, and more. Reallusion is expanding this potential with synergistic solutions, and Character Creator together with iClone represents a significant leap in that direction. This powerful combination offers a seamless pipeline for digital content creation, transforming mere ideas into vivid, dynamic characters and animations.
Reallusion understands that seeing is believing. That’s why we are inviting everyone to experience these solutions firsthand by showcasing their talent and creativity in the 2024 Reallusion 3D Character Contest. It is where artists from around the globe are encouraged to submit their best works crafted with Character Creator and iClone. Winners will not only receive cash and sponsored prizes but also gain the prestigious opportunity to be featured on renowned 3D media platforms worldwide. Moreover, there’s a chance to become a sponsored partner or featured developer with Reallusion, allowing you to leverage a vast network and platform to monetize your skills.
To help you prepare for this contest, our esteemed judges, Pablo Munoz Gomez and Martin Klekner, will share their insights in this article. They’ll reveal what catches their eye, what makes a 3D character stand out, and what they value most in a submission. Near the end of the article, we’ll also highlight past contest winners who have secured exciting collaborations with us due to their standout entries.
Pablo Munoz Gomez on making a winning character
Pablo is an esteemed concept and character artist renowned for his work in both 3D and traditional media. As the founder of ZBrush Guides and 3D Concept Artist, he is steeped in visual development and sculpting. Pablo is also an instructor at The Extra Mile course and has curated numerous ZBrush training resources over the years. Plabo will be responsible for judging the 3D character qualities for the contest submissions. Here is a summary of his judging criteria:
Martin Klekner on making standout animations
Martin is a cinematic director and CG artist hailing from Prague, Czech Republic, bringing a wealth of expertise to the table. Specializing in Blender, Martin is a distinguished instructor at CGBoost.com. He also spearheads the ongoing project “Heroes of Bronze”, aiming to craft a narrative universe inspired by ancient Greece. Martin will be responsible for judging the 3D character animations for the contest submissions. Below is a summary of his tips:
Collaboration with past winners
The 2021 Lipsync Animation Contest held by Reallusion unearthed a remarkable group of talented 3D character artists and animators. Due to their exceptional skills and high-quality productions, many of them joined the Reallusion online stores as featured developers or have been invited to participate in marketing productions for Reallusion. These winners exemplify how the company fosters success by promoting the artists’ work and helping them achieve global recognition.
Loïc Bramoullé – Art Director & 2D/3D Concept Artist
Loïc Bramoullé is the 1st place winner of the Reallusion 2021 iClone Lip Sync Animation Contest. With his seasoned experience in games and films, Loïc completed Dream Harvest Games’ Nightmare Hunter short film with the use of the latest iClone 8 and Character Creator 4 features. In this video, Loïc navigates us through each key step and shares his tips on how to build a cinematic game trailer with Reallusion tools and Blender.
Erik Larson – Director of 3D, Animation & Video
Erik has won the Special Award from the Reallusion 2021 iClone Lip Sync Animation Contest. After the contest, he combined his knowledge of the Assassin’s Creed with 3D armory-building skills and launched his 3d props business. He also occasionally produces software and content reviews, helping Reallusion users to familiarize themselves with new tools and 3d content.
Libertas Review: Five Pro Tips for Character Creator 4
Do you want to follow in Loic and Erik’s footsteps and become our next featured artist? There’s still time to join this year’s contest!
Submissions close on September 1, 2024, PST. We look forward to your participation. May the best character and animation win!
Submit your entry before September 1st PST >>
PavMike CC GoZ Plus Tutorial Part 3 – Body, Clothing, and Accessories from ZBrush to Character Creator
In the previous article, we sent a single accessory from Character Creator to ZBrush using CC GoZ Plus. In this article, we’ll use CC GoZ Plus to bake a detailed base body polypaint with UDIMs back to Character Creator, along with an entire clothing costume, complete with accessory attachments!
GoZ Base Body
I’m going to make Cooper from the Fallout TV show, so I’m going to start by loading up a neutral male base body from the “Content > Actor > Base” folder in Character Creator. For our initial setup, we’ll select our character in the “Scene” tab, then hit the “GoZ” button in the menu bar to send this mesh over to ZBrush. In the dialog box prompt, I’m going to uncheck “Enable GoZ Plus” — in this demo I’m not going to bake over the skin textures and pore detail, HOWEVER, if that would be useful as a starting point for the character you want to make, feel free to check this box on.
The last thing I’m going to do is check on “Eyelash” and “Tear Ducts” so they are separated out from the base body in ZBrush. This isn’t technically required… It is just how I like to work. Finally, select “Current Pose” and press the “GoZ” button; this will send over just the base topology meshes as a starting point for our character.
Now that we’re in ZBrush we can refine our character. To get more details, go to the “Tool > Geometry” menu and hit the “Divide” button. Continue to refine the sculpt and subdivide as needed, until you have your fully detailed sculpt complete.
For textures, turn on the paintbrush icon for your “CC_Base_Body” subtool to toggle colorize on, and start painting directly on the model (hit B, P, A on your keyboard to select the “Paint” brush, which is just the standard brush with RGB turned on, and Zadd turned off). If you’re wondering how I got such an accurate human skin polypaint, I’ll admit I just transferred the pore level details and color from scan data and modified it. However, feel free to paint from scratch using any ZBrush brush with RGB turned on.
If you want more information on a similar workflow, check out the Character Creator Pipeline Body article. There, we go through the process of:
  1. Starting with a neutral body in Character Creator dialing in our specific character look with morphs.
  2. GoZ that result into ZBrush.
  3. Subdivide and refine the sculptural details.
  4. Use the Substance 3D Painter bridge to texture the result.
  5. Then update everything in Character Creator.
Also, check out the Free Character Bases article, where we cover:
  1. How to download the free Character Creator base meshes that come in a variety of character body types, styles, and formats.
  2. How to import or open those files into your 3D modeling program of choice.
  3. How you can modify them into whatever crazy character you want — in this case, a Warhammer Ultramarine beefy boy!
CC GoZ Plus Base Body Bake
Let’s get our high-res sculpt and polypaint updates back to Character Creator. Go to the “ZPlugin > CC GoZ” menu, make sure the “Polypaint > Diffuse and Details > Normal” buttons are turned on, set your map size, and hit the “GoZ All” button. This will send over all the “CC_Base_Body” parts back to Character Creator.
GoZ Cooper Clothing and Accessories
Back in ZBrush, create any clothing and accessories you’d like to send over, appended as subtools to your base body ZTool. Just like the base body, any sculptural high-res detail for your clothing and accessory assets and polypaint applied to the object will be baked into a texture map for use in Character Creator.
Just remember, our base body was sent over with UVs from Character Creator; However, anything new you create will need to have UVs. If you’re in ZBrush, use the “ZPlugin > UV Master” and/or “UV Map > Create” (Unwrap). More information on creating a game-res mesh in ZBrush is in this video, and creating UVs in ZBrush can be found in this video.
Since we’ve already sent over and baked our body, we can hide all of the “CC_Base” subtools, and just have our suit and accessories visible. In the CC GoZ Plus ZPlugin menu, I’m going to choose the “4096” option to get a large texture size for the suit, but we’ll be able to reduce the texture size of the other objects in the next step. Press the Visible button in the CC GoZ Plugin to send your clothing and accessories over to Character Creator.
Back in Character Creator and inside the GoZ Options window, you can choose what texture size you want each asset to be, and you can also choose whether the object coming over will be a clothing, accessory, or prop. If your object will be affected by multiple joints during character movement (shirt, pants, boots, etc…), choose “Create Cloth”; for objects that can be bound to a single joint during movement (a hard surface item like the lapel pin), choose “Create Accessory”. Don’t worry if you pick the wrong option, you can convert an accessory to a clothing item and vice versa in Character Creator later. Dial in your settings and hit the “Update” button.
If you change your mind over what should be an accessory or clothing item, simply select the item and go to the “Attribute” tab. Choose “Convert to Accessory” to convert a previous clothing item to an accessory, or “Transfer Skin Weights” to convert an accessory to a clothing item that will inherit the body skin weights.
For any Accessory items you’ve created, there’s a few things we have to do. First, we’ll ensure that the accessory is in the right place — with the accessory object selected in your scene, hit the W key to enter move mode, and in the “Attribute” tab, scroll to the bottom to the “Pivot” section. I usually click the middle button to center the pivot on the object, but you can also use the “Edit Pivot” button at the bottom to fine-tune the pivot location. Then use the gizmo to reposition the asset.
We also need to make sure the accessory is bound to the correct joint; in the “Attach” section above the “Pivot” section, click the “Pick Parent” button, and click on your character to choose the correct bone for the object to be bound to (binding a helmet asset to “CC_Base_Head”, for example). If you can’t quite click the correct bone, use the 3 dots menu to select the exact bone you want.
Skin Weights
If we go to the “Motion” menu in the Animation Player and choose walk, we can see that some of our weights need to be slightly modified:
With the suit selected in the “Scene” tab, go to the “Attribute” tab and click the “Skin Weights” button. With “Paint” selected, right-click on the bone behind the problematic area, and choose the smooth brush. Paint the verts in this area to smooth the effect of the weights as the joints influence the mesh. In this case, the thigh weights need to be smoothed for both ThighTwist01 and 02. Click the “Skin Weights” button again to exit skin weights mode.
Materials – Metallic and Roughness
You might notice your metallic assets don’t look very metallic; With a metallic accessory selected, go to the “Material” tab, select the Metallic texture, and click the “Adjust Color” button. In the “Adjust Color” menu, you can pull the brightness to 100 in order to switch the texture from black (not metallic) to white (full metallic).
You can do the same thing for the suit roughness for example; If I select the suit, select the roughness texture, I can make the gray texture darker (shinier) or lighter (more matte). But what if I want to have the cloth areas more matte, and the rubber areas more shiny?
Instead of changing the brightness on the gray roughness texture, I’m going to select the Base Color texture, and click the “Launch” button. This will open the texture in an image editing program, and I can desaturate the image, create selections, change the levels, and/or fill/paint areas with different values to create rough or shiny areas of the suit.
Go to “File > Save As”, and save this roughness image somewhere on your computer (I saved it as SuitRoughness.png). Back in Character Creator, double-click the Roughness image in the “Material” tab, and select your newly created roughness map. Your suit will now have matte and shiny areas!
Hiding Body Parts
While wearing the boots and suit, we shouldn’t ever see the underlying human body polygons, so let’s hide them. With the suit selected in the “Scene” tab, go to the “Attribute” tab, and click on the “Hide Body Mesh” button. Use the mannequin to hide major sections of the body, and fine-tune with face selection. Do the same process for the boots. Now whenever the suit or boots are applied to a Character Creator mesh, it will always hide those underlying base body faces. Check out the previous CC GoZ article to see how to save clothing and accessories to your custom library to use on other characters.
Posing and Facial Expressions
Feel free to apply poses or animations to your character from the “Content Template” library. In this case, I’m going to apply the “Sporty_Pose01” pose to our character, and fine-tune it with the “Edit Pose” button in the “Motion Pose” tab:
We can change the facial expression as well: click the “Edit Facial” button in the “Motion Pose” tab:
Use the “Muscle”, “Expressions”, or “Modify” tabs to dial in an expression for your character.
Apply any other hair or accessories from your Character Creator library that you want to finish out your character.
Sending our Pose Back to ZBrush High-Res Source Assets
Let’s say we want to send this pose back to our ZBrush high-res so we can 3D print it. Select all of your character objects in your “Scene” tab, and hit the “GoZ” button in the menu bar:
In the GoZ Settings window, we’ll uncheck “Enable GoZ Plus” (we’re not baking any color or normal map info back to ZBrush, we’re just moving around SDiv 1 verts to match our posed assets). Check on “Relink Mesh Changes” in New Layer if you want your pose to be stored as a layer for all of the Asset subtools. We’ll also check on “Eyelash” and “Tear Ducts”, since we had previously separated those parts out of the base body earlier, and we want to match that.
Because our pose was saved out as a layer on all of our subtools, we can open the “ZPlugin > ZBrush Pose Tools” menu, hit “Refresh Pose List”, and a pose should be available in the selectable library. Select it and Rename it to something that makes sense. For more information about ZBrush Pose Tools functionality, check out this article.
Feel free to go back to Character Creator and create more poses / facial expressions. As long as you GoZ them over on a layer, you can keep adding them to your Pose Tools library for your character.
About The Author
Michael Pavlovich earned a Bachelor’s degree in Computer Animation from RSAD in 2005. Initially, he contributed to the development of environment and character art for popular video games such as Madden and NCAA Football. Later, he relocated to Austin to join Daybreak Games, where he worked on the creation of art assets for DC Universe Online.
Presently, Michael holds the position of Director of Character, Weapon, and Vehicle Art at Certain Affinity. His expertise lies in implementing iterative pipelines for Certain Affinity artists helping develop renowned video game franchises, including Halo, Call of Duty, and DOOM. To stay updated on his latest tutorial projects, you can visit Michael’s YouTube or ArtStation page.
>> Check Michael’s Artstation
>> Check Michael’s Youtube Channel
Related Posts
  • PavMike CC GoZ Plus Tutorial Part 2 – Accessory from ZBrush to Character Creator
  • PavMike CC GoZ Plus Tutorial Part 3 – Body, Clothing, and Accessories from ZBrush to Character Creator
In the previous article, we sent a prop from Character Creator to ZBrush, modified it, and sent it back again with new baked color and normal details, using CC GoZ Plus. In this article, we’ll use CC GoZ Plus to send an accessory we made in ZBrush to Character Creator, complete with color and normal maps. We’ll also discuss techniques to fine-tune your roughness and metallic maps to complete the look of your new PBR asset, and finally add it to our custom library so we can use the asset on different characters.
Requirements
In order for this to work, there’s a few things our asset will need. First, you’ll need a low-res SDiv 1 for your asset. You can have as many subdivisions as you want past subdivision 1 that will hold all of your high-res sculptural and polypaint details, but your lowest subdivision level needs to be something reasonable to send over to Character Creator to attach to a character and animate. For example, SDiv 1 for the above mask is 46k polys — not exactly lightweight, but way better than the 3.17 million polygons that SDiv 4 has. For more information on how to make a quick game-res model and project your detail to it, you can watch this video here. Second, our asset needs UVs; UV Master and other UV techniques in ZBrush are covered in this video.
I’m also going to load up a character in Character Creator; This can be a character you previously made, one from the Reallusion content browser, or just a neutral base body — it doesn’t really matter, just something to put this mask onto when it gets to Character Creator.
CC GoZ Plugin
If your asset has subdivisions and UVs, you’re ready to send it over to Character Creator. Go to the ZPlugin menu and open the CC GoZ submenu. Because we have “Polypaint > Diffuse and Details > Normal” buttons on, it will bake out a Color Map texture and a Normal Map texture with our polypaint and sculpted high-res details, respectively. We’ll keep the map size at the default 2048, but feel free to choose 4096 for the most texture resolution (you can also change what size the incoming texture will be later in Character Creator). Since we’re only sending over one asset this time, we’ll press the “GoZ” button to send the SubD 1 mesh of the selected subtool to Character Creator to update our mesh, and send over the baked maps for our asset.
In the “GoZ Options” window back in Character Creator, choose the “Create Accessory” template along with “Update Mesh & Texture”. That will set the “Action” to “Create Accessory”, and check the “Mesh” and “Texture” checkboxes. If you’d like, you can change the action to create a clothing item or a prop, and you can uncheck mesh or texture if you want to skip a part of that import process. In our case, we’ll leave everything checked.
If you brought over an accessory, you’ll probably have to move it into place on the previously loaded character. First, set the pivot by scrolling down to the bottom of the “Attribute” tab, and clicking one of the “Quick Set” options. We’ll also choose a joint to attach to by using the “Pick Parent” button and clicking on your character, or using the 3 buttons menu to select the correct joint (in this example, it’s a face mask, so we’ll choose “CC_Base_Head”). Now just move the accessory into place on your character.
Materials and Textures
Our metal buttons aren’t looking very metallic — let’s create a custom Metallic map! Go to the “Material” tab with your asset selected, and you’ll see the Base Color and Bump (Normal) map from ZBrush is applied to this object. Select your Base Color map, and press the “Launch” button.
In your image editor, I’ll use the wand tool to select the gray section of the color map, which is what the metal parts are filled with. I’ll fill these areas with white, and the rest of the image with black — this will create a texture map where all the white parts that correspond to our metal button UVs will appear metallic, and all the black parts wont.
If we were to save this now and close the window, it would update our Color Map to this black and white image intended for our Metallic map. Instead, go to “File > Save As”, and save the black and white image as “HockeyMask_Metallic.png” (or whatever makes sense) somewhere on your computer.
Back in Character Creator, double-click the Metallic map image, and load in your custom Metallic map texture. You’ll see your metal buttons are now metallic! For the Roughness, if we just want to change how shiny or matte the image is overall, we can click on the “Adjust Color” button with the Roughness map selected, and change the “Brightness” slider to choose a Roughness value (darker is shinier, lighter is more matte):
Making the Roughness map darker (shinier appearance)
Or just like the Metallic map, you can Launch the Base Color map, desaturate it, and adjust the image to make certain areas lighter or darker (matte or shiny):
Saving a Clothing or Accessory Item
Let’s put this mask into our custom library so we can use it on other characters! Go to the “Scene” tab and make sure your asset is selected:
Next, choose the “Custom > Content” tab. Since this is a mask attached to the head joint, it makes sense to save this into the “Accessory > Head” directory. Navigate to that folder, and click the “Save” button. In the “Save Options” dialog box, give it a file name, and ensure the correct directory is chosen for the Asset Type (if not, you can manually navigate there through the down arrow menu). You now have a hockey mask saved in your “Custom” panel. Load up another character, then just double-click your new hockey mask and move it into place. It will animate along with the character’s head, with the object pivot where it should be, just like how it was set it up on your original character.
About The Author
Related Posts
  • PavMike CC GoZ Plus Tutorial Part 1 – Prop from Character Creator to ZBrush
In this article, we will discuss the CC GoZ Plus workflow that makes it easier for you to work with bodies, clothing, accessories, and props between Character Creator (CC) and ZBrush. Going from Character Creator to ZBrush, you can convert color and normal maps to polypaint and high-res details with just a click of a button. Similarly, you can transfer your polypaint and high-poly sculpt from ZBrush to Character Creator using the same button, creating color and normal maps for use in CC. Let’s begin!
CC GoZ Plus Installation
We can already natively GoZ assets from ZBrush to Character Creator and back again – but in order to send assets from ZBrush to Character Creator AND have it bake a base color and normal map, AND have it plug those textures into a material for us, we need the CC GoZ Plus plugin installed for ZBrush. In order to do that, we need to GoZ something from Character Creator to ZBrush — in this case, I’m going to grab the “Lion Head” asset from “Content > Props > PBR”:
With your object selected in the “Scene” tab, press the “GoZ” button in the menu bar:
When you see the “CC GoZ Plus” prompt, choose the correct version of ZBrush from the drop-down menu, and hit “OK”. This will install the plugin to the correct path (“C:\Program Files\Maxon ZBrush 2024\ZStartup\ZPlugs64”).
In the “GoZ Settings” dialog box, the “Template” setting should default to “Create”, and you can see we’ll be baking the color map to the ZBrush assets vertex color (polypaint), and the normal map in Character Creator will be baked to a “Detail Layer” in ZBrush! Let’s choose 5 in the dropdown menu for “Subdiv” — this will give us more than 6 million triangles, plenty of polygons to transfer our color map to our polypaint, as well as plenty of polygons to sculpt with! Hit the “GoZ” button at the bottom to send everything over to ZBrush.
As you can see, our subtool in ZBrush has 5 subdivisions, and the normal details are in a layer called “CC_Detail 1”. I want the details to be applied to my highest subdivision geometry, so I’m going to press the “Bake All” button in the layer palette.
Let’s change this into a dark steel eagle head! Choose a gray color in the color palette, then go to “Color > FillObject”
Use ZBrush sculpting brushes to change the lion into another animal — in this case, an eagle head. Feel free to polypaint on your asset as well to add color variation. Since this is a symmetrical object, I’ll hit X on my keyboard to turn on symmetry while I sculpt. Feel free to drop down to a lower subdivision in order to make broad changes, and step back up in subdivisions to dial in your details!
Lion sculpted into an eagle head
Polypaint color variation added
In the “ZPlugin > CC GoZ Plus” menu in ZBrush, press the GoZ button — with the default options, this will send the model back with the new low-res vertex positions, as well as bake your high-res sculpt detail to a normal map, and your polypaint to a base color map, with one button press!
Back in Character Creator, you’ll see that the GoZ Options have defaulted to the “Update Mesh & Texture” option, which will ensure that the “Mesh” and “Texture” boxes get checked, which means the mesh will update, and the new textures will be applied to our model after you click the Update button.
Textures and Materials
This particular asset has a displacement map applied; With your object selected, navigate to the material tab and select the displacement texture. Press the garbage can icon to delete it:
If your color map is too light or too dark, you can go back to ZBrush and adjust the polypaint, or you can click on the Base Color map, then click the “Adjust Color” button, and play with those sliders to get the exact look you want!
Right now the Metallic and Roughness textures are giving the asset a very grungy feel. If you want to modify those maps, you can double-click their map to load in your own custom texture, or press the “Launch” button to open the textures in an image editor. I’m going to go ahead and Launch the Metallic and Base Color textures!
I’ll fill the Metallic texture with white (I want the entire object to appear metallic in the shader), Ctrl+S to save, close the window, fill the Roughness map with a middle gray, save, close, and head back to Character Creator.
When we arrive back in Character Creator, you’ll see that your Metallic and Roughness maps have been updated. Feel free to use either the “Launch” or “Adjust Color” feature to tweak your asset’s appearance!
Original prop
Modified with CC GoZ Plus
About The Author
Related Posts
